    R329代码里找不到BOOT0启动打印“HELLO! BOOT0 is starting!”
      yimu163com LV 4 最后由 编辑
      软硬件环境:
      peter@u14:~/share/r329-evb5$ lunch r329_evb5-tina
      TINA_BUILD_TOP=/home/peter/share/r329-evb5
      TINA_TARGET_ARCH=aarch64
      TARGET_PRODUCT=r329_evb5
      TARGET_PLATFORM=r329
      TARGET_BOARD=r329-evb5
      TARGET_PLAN=evb5
      TARGET_BUILD_VARIANT=tina
      TARGET_BUILD_TYPE=release
      TARGET_KERNEL_VERSION=4.9
      TARGET_UBOOT=u-boot-2018
      TARGET_CHIP=sun50iw11p1
      其中,~/share/r329-evb5是SDK顶层目录
      启动打印:
      [65]HELLO! BOOT0 is starting!
      [68]BOOT0 commit : 97444f5
      [70]set pll start
      [73]periph0 has been enabled
      代码里搜索第一行里的“starting!”:
      peter@u14:~/share/r329-evb5$  grep "starting!" --binary-files=without-match --exclude-dir=\.git --exclude-dir=\.repo --exclude=*tags -nwr ./
      peter@u14:~/share/r329-evb5$  grep "starting!" --exclude-dir=\.git --exclude-dir=\.repo --exclude=*tags -nwr ./
      Binary file ./device/config/chips/r329/bin/boot0_nand_sun50iw11p1.bin matches
      Binary file ./device/config/chips/r329/bin/sboot_sun50iw11p1.bin matches
      Binary file ./device/config/chips/r329/bin/boot0_spinor_sun50iw11p1.bin matches
      Binary file ./device/config/chips/r329/bin/boot0_sdcard_sun50iw11p1.bin matches
      大佬们,是代码文件里本身没有“HELLO! BOOT0 is starting!”,还是我搜索的问题?还是其他的原因?
      • Deleted by  Y yimu163com
      • Restored by  Y yimu163com
        awwwwa LV 8 最后由 编辑
        @yimu163com 在 R329代码里找不到BOOT0启动打印“HELLO! BOOT0 is starting!” 中说:
        在这几个bin里,BOOT0不开源
