    T113-i WIFI模块(cyfmac55572-sdio)移植求助!!!
      joehuang LV 2 最后由 编辑
      您好,
      我们最近在尝试将murate的LBEE5XV2EZ WiFi模块移植到T113-i系列开发板中,遇到了一点麻烦。
      Linux内核版本:5.4.61
      WIFI固件版本:cyfmac55572-sdio
      问题描述:在SDR50模式下,频率100Mhz,驱动能够挂载成功,ifconfig -a也有了wlan0节点,但是在执行ifconfig wlan0 up指令后,系统给出“SIOCSIFFLAGS: Input/output error”报错,偶尔能成功,但在后续通过iw dev wlan0 scan指令搜索WIFI,会有connected timeout的报错。后尝试逐步降频至10Mhz,问题依然存在。目前对硬件电压进行了排查,VBAT外部稳定供电3.3V,VDDIO外部稳定供电1.8V,CLK稳定输出。
      关键log信息如下:
      [ 41.845869] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac55572-sdio for chip BCM55560/2
      [ 41.858594] brcmfmac mmc2:0001:1: Direct firmware load for cypress/cyfmac55572-sdio.t.allwinner,t113_irxse failed with error -2
      [ 41.871630] brcmf_ops_sdio_probe enter
      [ 41.883436] brcmfmac: brcmf_fw_request_firmware: no board-specific nvram available (ret=-2), device will use cypress/cyfmac55572-sdio.txt
      [ 42.742833] brcmfmac: brcmf_sdio_hdparse: seq 0: max tx seq number error
      [ 42.750455] brcmfmac: brcmf_sdio_hdparse: seq 1: max tx seq number error
      [ 42.760151] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac55572-sdio for chip BCM55560/2
      [ 42.776699] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM55560/2 wl0: Nov 24 2023 01:48:44 version 18.53.284.17 (92de749) FWID 01-772c0c50
      [ 64.954376] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
      [ 66.409176] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 67.912072] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 69.415059] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 69.478936] brcmfmac: brcmf_sdio_dpc: sdio ctrlframe tx failed err=-110
      [ 69.486444] brcmfmac: brcmf_sdio_dpc: failed backplane access over SDIO, halting operation
      [ 74.370916] ieee80211 phy0: brcmf_dongle_scantime: Scan assoc time error (-19)
      [ 69.502614] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
      [ 69.818991] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
      [ 71.273878] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 72.776887] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 74.280046] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 74.343933] brcmfmac: brcmf_sdio_dpc: sdio ctrlframe tx failed err=-110
      [ 74.351398] brcmfmac: brcmf_sdio_dpc: failed backplane access over SDIO, halting operation
      [ 74.678864] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
      [ 76.133645] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 77.636564] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 79.139538] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
      [ 79.203422] brcmfmac: brcmf_sdio_dpc: sdio ctrlframe tx failed err=-110
      [ 79.210907] ieee80211 phy0: brcmf_netdev_open: failed to bring up cfg80211
      [ 79.210917] brcmfmac: brcmf_sdio_dpc: failed backplane access over SDIO, halting operation
      [ 79.544614] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
      具体log信息参考附件
      恳请您的帮助!
      T 1 条回复 最后回复 回复 引用 分享 0
      • T
        TouchUU LV 3 @joehuang 最后由 编辑
        @joehuang dts里面sdc1pin有没有设置1.8v
        	sdc1_pins_a: sdc1@0 {
        		vcc-pg-supply = <&reg_pio1_8>;
        		pins = "PG0", "PG1", "PG2",
        		       "PG3", "PG4", "PG5";
        		function = "sdc1";
        		drive-strength = <30>;
        		bias-pull-up;
        J 1 条回复 最后回复 回复 引用 分享 1
          joehuang LV 2 @TouchUU 最后由 编辑
          @touchuu 非常好意思,前段时间在调试其他模块,没有继续跟踪这个问题,sdc1 pins并没有单独配置1.8v,请问可以分享一下reg_pio1_8节点的内容吗?我会尝试一下这个改动。
          非常感谢!
