    T507现在的固件不适配我的底板,请大佬帮忙看看如何解决
    • X
      xexee LV 4 最后由 xiaowenge 编辑
      ?request gpio139 out
      [    3.483480] sunxi-ehci 5311000.ehci3-controller: ehci_irq: highspeed device connect
      [    3.493105] talowe_power request usb_5v
      [    3.497450] success request gpio131 out
      [    3.501839] talowe_power request hub_rst
      [    3.506275] success request gpio144 out
      [    3.511066] talowe_gpio prepare build 5 gpio
      [    3.515902] talowe_gpio request led
      [    3.519851] success request gpio145 flash
      [    3.524389] talowe_gpio request fan_en
      [    3.528630] success request gpio138 out gpio_data->talowe_gpio_num[gpio_cnt].action 1
      [    3.537467] talowe_gpio request gpiope12
      [    3.541902] success request gpio140 out gpio_data->talowe_gpio_num[gpio_cnt].action 1
      [    3.550741] talowe_gpio request gpiope19
      [    3.555180] success request gpio147 out gpio_data->talowe_gpio_num[gpio_cnt].action 1
      [    3.564018] talowe_gpio request gpiope22
      [    3.568454] success request gpio150 out gpio_data->talowe_gpio_num[gpio_cnt].action 1
      [    3.577545] input: gpio_event as /devices/platform/talowe_gpio/input/input2
      [    3.586165] usbcore: registered new interface driver snd-usb-audio
      [    3.597961] [sunxi_hdmi_codec_init] driver and deivce register finished.
      [    3.607467] codec supply vcc33_audio not found, using dummy regulator
      [    3.615061] lineout_vol:26, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:120, pa_ctl_level:1, gpio-spk:141
      [    3.633178] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
      [    3.643511] sndspdif sndspdif: ASoC: CPU DAI (null) not registered
      [    3.650661] sndspdif sndspdif: snd_soc_register_card failed: -517
      [    3.657674] sndspdif: probe of sndspdif failed with error -16
      [    3.665681] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
      [    3.674037] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
      [    3.686196] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
      [    3.695635] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
      [    3.705491] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
      [    3.714438] usb 3-1: new high-speed USB device number 2 using sunxi-ehci
      [    3.725077] u32 classifier
      [    3.728144]     Actions configured
      [    3.731993] Netfilter messages via NETLINK v0.30.
      [    3.737315] nfnl_acct: registering with nfnetlink.
      [    3.743119] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
      [    3.750253] ctnetlink v0.93: registering with nfnetlink.
      [    3.756822] xt_time: kernel timezone is -0000
      [    3.761855] ipip: IPv4 and MPLS over IPv4 tunneling driver
      [    3.768766] gre: GRE over IPv4 demultiplexor driver
      [    3.774269] ip_gre: GRE over IPv4 tunneling driver
      [    3.780859] IPv4 over IPsec tunneling driver
      [    3.786477] ip_tables: (C) 2000-2006 Netfilter Core Team
      [    3.792752] arp_tables: arp_tables: (C) 2002 David S. Miller
      [    3.799214] Initializing XFRM netlink socket
      [    3.804052] IPsec XFRM device driver
      [    3.808882] NET: Registered protocol family 10
      [    3.815836] mip6: Mobile IPv6
      [    3.819222] ip6_tables: (C) 2000-2006 Netfilter Core Team
      [    3.826493] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    3.834592] NET: Registered protocol family 17
      [    3.839639] NET: Registered protocol family 15
      [    3.844763] l2tp_core: L2TP core driver, V2.0
      [    3.849694] l2tp_ppp: PPPoL2TP kernel driver, V2.0
      [    3.855783] Registered cp15_barrier emulation handler
      [    3.858676] hub 3-1:1.0: USB hub found
      [    3.858805] hub 3-1:1.0: 7 ports detected
      [    3.870236] Registered setend emulation handler
      [    3.876441] registered taskstats version 1
      [    3.881804] HDMI 2.0 driver init start!
      [    3.886142] boot_hdmi=false
      [    3.889357] ERROR: can not get hdmi_cts_compatibility
      [    3.895793] Can not find the node of esm
      [    3.900223] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [    3.905815] Get hdmi_power0:bldo1
      [    3.911886] hdmi_cec_init
      [    3.915632] HDMI2.0 module init end
      [    4.157253] usb 3-1.7: new full-speed USB device number 3 using sunxi-ehci
      [    4.540594] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x4 cs:0x101 dvi_hdmi:2 range:0 scan:0 aspect_ratio:8
      [    5.580970] [DISP] disp_device_attached_and_enable,line:223:
      [    5.587191] attached ok, mgr0<-->dev0
      [    5.591522] [DISP] disp_device_attached_and_enable,line:236:
      [    5.597708] type:4,mode:10,fmt:rgb,bits:8bits,eotf:4,cs:257 dvi_hdmi:2, range:0 scan:0 ratio:8
      [    5.619428] sunxi_i2c_probe()2274 - [i2c2] twi_drv_used = 0
      [    5.625727] sunxi_i2c_probe()2278 - [i2c2] twi_pkt_interval = 0
      [    5.632999] twi_request_gpio()453 - [i2c2] init name: (null)
      [    5.640158] ============ hym8563_probe start !! =============
      [    5.670752] 2120-08-41(3) 00:00:01
      [    5.683915] 2011-01-01(6) 12:00:00
      [    5.697885] 2011-01-01(6) 12:00:00
      [    5.706634] 2011-01-01(6) 12:00:00
      [    5.710861] rtc_hym8563 2-0051: rtc core: registered rtc-hym8563 as rtc0
      [    5.718416] ============ hym8563_probe end !! =============
      [    5.729056] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
      [    5.739074] cpu cpu0: _opp_add: OPP not supported by regulators (600000000)
      [    5.747204] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
      [    5.757204] cpu cpu0: _opp_add: OPP not supported by regulators (792000000)
      [    5.766026] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
      [    5.776024] cpu cpu0: _opp_add: OPP not supported by regulators (1512000000)
      [    5.784016] cpu cpu1: opp_list_debug_create_link: Failed to create link
      [    5.791472] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
      [    5.799064] cpu cpu2: opp_list_debug_create_link: Failed to create link
      [    5.806519] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
      [    5.814110] cpu cpu3: opp_list_debug_create_link: Failed to create link
      [    5.821564] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
      [    5.832239] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.11 (r)
      [    5.840356] ======== dhd_wlan_init_plat_data ========
      [    5.846037] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=117, oob_irq_flags=0x4084
      [    5.854534] dhd_wlan_init_gpio: WL_REG_ON=-1
      [    5.859323] dhd_wifi_platform_load: Enter
      [    5.863885] Power-up adapter 'DHD generic adapter'
      [    5.869320] wifi_platform_set_power = 1
      [    5.873621] ======== PULL WL_REG_ON(-1) HIGH! ========
      [    5.880161] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [    5.889288] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [    6.213901] wifi_platform_bus_enumerate device present 1
      [    6.219869] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [    6.225627] ======== Card detection to detect SDIO card! ========
      [    6.232501] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    6.257182] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    6.284702] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    6.291500] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    6.297456] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    6.310672] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    6.323300] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    6.329996] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    6.336714] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    6.343410] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    6.349282] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    7.250503] hdmi_hpd_sys_config_release
      [    8.327168] failed to power up DHD generic adapter, 3 retry left
      [    8.350017] wifi_platform_set_power = 0
      [    8.354327] ======== PULL WL_REG_ON(-1) LOW! ========
      [    8.361059] wifi_platform_bus_enumerate device present 0
      [    8.367018] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [    8.372781] ======== Card detection to remove SDIO card! ========
      [    8.379633] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.380555] wifi_platform_set_power = 1
      [    8.380559] ======== PULL WL_REG_ON(-1) HIGH! ========
      [    8.381323] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [    8.382142] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [    8.430568] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.458038] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    8.464797] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    8.470754] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.483907] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.496480] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.503142] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.509800] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.516518] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.522464] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    8.697256] wifi_platform_bus_enumerate device present 1
      [    8.703213] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [    8.708974] ======== Card detection to detect SDIO card! ========
      [    8.715825] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.740568] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.767978] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    8.774789] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    8.780798] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.793998] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.806580] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.813297] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.820010] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.826727] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    8.832642] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   10.887171] failed to power up DHD generic adapter, 2 retry left
      [   10.909970] wifi_platform_set_power = 0
      [   10.914273] ======== PULL WL_REG_ON(-1) LOW! ========
      [   10.921022] wifi_platform_bus_enumerate device present 0
      [   10.926978] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   10.932737] ======== Card detection to remove SDIO card! ========
      [   10.939590] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   10.940553] wifi_platform_set_power = 1
      [   10.940555] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   10.941319] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   10.942137] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   10.990563] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.018040] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   11.024800] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   11.030806] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.043959] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.056538] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.063197] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.069852] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.076513] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.082367] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   11.257168] wifi_platform_bus_enumerate device present 1
      [   11.263129] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   11.268884] ======== Card detection to detect SDIO card! ========
      [   11.275730] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.300566] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.328031] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   11.334884] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   11.340896] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.354151] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.366767] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.373484] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.380199] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.386927] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   11.392833] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   13.447163] failed to power up DHD generic adapter, 1 retry left
      [   13.469956] wifi_platform_set_power = 0
      [   13.474260] ======== PULL WL_REG_ON(-1) LOW! ========
      [   13.480861] wifi_platform_bus_enumerate device present 0
      [   13.486832] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   13.492593] ======== Card detection to remove SDIO card! ========
      [   13.499455] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.509731] wifi_platform_set_power = 1
      [   13.509733] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   13.520470] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   13.529600] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   13.533839] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.551313] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   13.558075] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   13.564033] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.577246] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.589872] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.596568] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.603279] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.609977] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.615852] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   13.863899] wifi_platform_bus_enumerate device present 1
      [   13.869857] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   13.875615] ======== Card detection to detect SDIO card! ========
      [   13.882462] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.907231] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.934706] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   13.941518] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   13.947529] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.960724] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   13.973307] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.980020] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.986736] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.993443] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   13.999354] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   16.007231] failed to power up DHD generic adapter, 0 retry left
      [   16.030074] wifi_platform_set_power = 0
      [   16.034374] ======== PULL WL_REG_ON(-1) LOW! ========
      [   16.041036] wifi_platform_bus_enumerate device present 0
      [   16.046995] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   16.052758] ======== Card detection to remove SDIO card! ========
      [   16.059590] failed to power up DHD generic adapter, max retry reached**
      [   16.059605] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.077343] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.088234] unregister wifi platform drivers
      [   16.093025] wifi_platform_bus_enumerate device present 0
      [   16.098997] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   16.099797] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   16.105567] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   16.110736] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.118758] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.120654] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.131350] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.142072] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.147930] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.152990] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   16.175773] ======== Card detection to remove SDIO card! ========
      [   16.182609] ======== dhd_wlan_deinit_plat_data ========
      [   16.182624] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.198790] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.209600] dhd_module_init: Failed to load the driver, try cnt 3
      [   16.216463] ======== dhd_wlan_init_plat_data ========
      [   16.217246] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   16.222938] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   16.228093] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.236111] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.237974] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.238849] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.239724] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.240597] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.240672] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   16.290231] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=117, oob_irq_flags=0x4084
      [   16.298718] dhd_wlan_init_gpio: WL_REG_ON=-1
      [   16.303499] dhd_wifi_platform_load: Enter
      [   16.308018] Power-up adapter 'DHD generic adapter'
      [   16.313427] wifi_platform_set_power = 1
      [   16.317731] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   16.324245] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   16.333355] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   16.657192] wifi_platform_bus_enumerate device present 1
      [   16.663147] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   16.668913] ======== Card detection to detect SDIO card! ========
      [   16.675767] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.700507] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.728071] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   16.734879] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   16.740840] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.754052] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.766677] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.773373] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.780071] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.786778] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   16.792641] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   18.780497] failed to power up DHD generic adapter, 3 retry left
      [   18.803352] wifi_platform_set_power = 0
      [   18.807658] ======== PULL WL_REG_ON(-1) LOW! ========
      [   18.814499] wifi_platform_bus_enumerate device present 0
      [   18.820454] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   18.826220] ======== Card detection to remove SDIO card! ========
      [   18.833077] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.837212] wifi_platform_set_power = 1
      [   18.837215] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   18.853868] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   18.862965] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   18.871467] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.887977] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   18.894748] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   18.900720] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.913881] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.926467] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   18.933205] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   18.939901] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   18.946572] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   18.952443] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   19.220558] wifi_platform_bus_enumerate device present 1
      [   19.226511] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   19.232270] ======== Card detection to detect SDIO card! ========
      [   19.239141] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.263900] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.291369] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   19.298184] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   19.304191] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.317393] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.329972] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   19.336690] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   19.343407] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   19.350127] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   19.356039] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   21.340501] failed to power up DHD generic adapter, 2 retry left
      [   21.363340] wifi_platform_set_power = 0
      [   21.367646] ======== PULL WL_REG_ON(-1) LOW! ========
      [   21.374322] wifi_platform_bus_enumerate device present 0
      [   21.380281] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   21.386034] ======== Card detection to remove SDIO card! ========
      [   21.392887] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.393900] wifi_platform_set_power = 1
      [   21.393903] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   21.394666] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   21.395480] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   21.443893] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.471365] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   21.478176] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   21.484187] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.497384] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.509967] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.516677] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.523395] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.530107] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.536022] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   21.710500] wifi_platform_bus_enumerate device present 1
      [   21.716463] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   21.722218] ======== Card detection to detect SDIO card! ========
      [   21.729060] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.753894] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.781390] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   21.788203] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   21.794212] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.807463] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.820079] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.826827] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.833585] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.840333] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   21.846248] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   23.900501] failed to power up DHD generic adapter, 1 retry left
      [   23.923349] wifi_platform_set_power = 0
      [   23.927653] ======== PULL WL_REG_ON(-1) LOW! ========
      [   23.934310] wifi_platform_bus_enumerate device present 0
      [   23.940271] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   23.946030] ======== Card detection to remove SDIO card! ========
      [   23.952895] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   23.963191] wifi_platform_set_power = 1
      [   23.963194] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   23.973923] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   23.983016] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   23.987171] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   24.004646] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   24.011424] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   24.017398] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   24.030604] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   24.043225] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.049932] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.056593] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.063258] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.069129] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   24.317223] wifi_platform_bus_enumerate device present 1
      [   24.323184] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   24.328945] ======== Card detection to detect SDIO card! ========
      [   24.335805] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   24.360506] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   24.388064] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   24.394859] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   24.400826] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   24.414028] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   24.426651] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.433357] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.440053] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.446751] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   24.452621] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   26.460497] failed to power up DHD generic adapter, 0 retry left
      [   26.483293] wifi_platform_set_power = 0
      [   26.487596] ======== PULL WL_REG_ON(-1) LOW! ========
      [   26.494243] wifi_platform_bus_enumerate device present 0
      [   26.500199] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   26.505956] ======== Card detection to remove SDIO card! ========
      [   26.512794] failed to power up DHD generic adapter, max retry reached**
      [   26.512815] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.530600] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.541423] unregister wifi platform drivers
      [   26.546208] wifi_platform_bus_enumerate device present 0
      [   26.552181] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   26.552980] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   26.558753] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   26.563910] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.571387] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.581097] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.591841] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.597706] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.603586] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.603604] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   26.625537] ======== Card detection to remove SDIO card! ========
      [   26.632385] ======== dhd_wlan_deinit_plat_data ========
      [   26.632402] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.648590] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.659375] dhd_module_init: Failed to load the driver, try cnt 2
      [   26.666257] ======== dhd_wlan_init_plat_data ========
      [   26.671921] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   26.677893] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   26.677914] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.685945] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   26.697725] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.708486] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.714360] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.720251] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   26.720268] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   26.743278] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=117, oob_irq_flags=0x4084
      [   26.751773] dhd_wlan_init_gpio: WL_REG_ON=-1
      [   26.756558] dhd_wifi_platform_load: Enter
      [   26.761083] Power-up adapter 'DHD generic adapter'
      [   26.766512] wifi_platform_set_power = 1
      [   26.770815] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   26.777555] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   26.786668] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   27.110502] wifi_platform_bus_enumerate device present 1
      [   27.116470] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   27.122230] ======== Card detection to detect SDIO card! ========
      [   27.129086] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   27.153843] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   27.181395] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   27.188191] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   27.194149] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   27.207358] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   27.219980] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   27.226679] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   27.233390] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   27.240085] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   27.245945] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   29.233839] failed to power up DHD generic adapter, 3 retry left
      [   29.256637] wifi_platform_set_power = 0
      [   29.260942] ======== PULL WL_REG_ON(-1) LOW! ========
      [   29.267631] wifi_platform_bus_enumerate device present 0
      [   29.273590] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   29.279352] ======== Card detection to remove SDIO card! ========
      [   29.286204] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.287221] wifi_platform_set_power = 1
      [   29.287223] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   29.287986] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   29.288800] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   29.337223] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.364700] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   29.371512] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   29.377522] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.390724] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.403310] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.410020] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.416735] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.423447] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.429358] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   29.603890] wifi_platform_bus_enumerate device present 1
      [   29.609852] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   29.615609] ======== Card detection to detect SDIO card! ========
      [   29.622459] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.647225] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.674699] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   29.681509] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   29.687516] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.700711] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   29.713292] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.720007] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.726719] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.733442] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   29.739353] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   31.793828] failed to power up DHD generic adapter, 2 retry left
      [   31.816623] wifi_platform_set_power = 0
      [   31.820924] ======== PULL WL_REG_ON(-1) LOW! ========
      [   31.827567] wifi_platform_bus_enumerate device present 0
      [   31.833535] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   31.839302] ======== Card detection to remove SDIO card! ========
      [   31.846152] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   31.847213] wifi_platform_set_power = 1
      [   31.847215] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   31.866947] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   31.876047] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   31.880502] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   31.898062] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   31.904859] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   31.910815] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   31.924030] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   31.936653] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   31.943350] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   31.950022] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   31.956684] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   31.962542] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   32.210559] wifi_platform_bus_enumerate device present 1
      [   32.216516] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   32.222299] ======== Card detection to detect SDIO card! ========
      [   32.229145] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   32.253899] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   32.281362] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   32.288175] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   32.294184] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   32.307384] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   32.319960] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   32.326678] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   32.333388] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   32.340100] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   32.346007] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   34.353835] failed to power up DHD generic adapter, 1 retry left
      [   34.376627] wifi_platform_set_power = 0
      [   34.380930] ======== PULL WL_REG_ON(-1) LOW! ========
      [   34.387569] wifi_platform_bus_enumerate device present 0
      [   34.393540] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   34.399308] ======== Card detection to remove SDIO card! ========
      [   34.406162] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.407212] wifi_platform_set_power = 1
      [   34.407215] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   34.426949] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   34.436048] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   34.440502] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.458010] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   34.464815] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   34.470771] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.483980] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.496593] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.503296] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.509993] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.516670] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.522530] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   34.770555] wifi_platform_bus_enumerate device present 1
      [   34.776511] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   34.782265] ======== Card detection to detect SDIO card! ========
      [   34.789117] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.813891] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.841367] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   34.848179] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   34.854189] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.867394] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   34.879977] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.886692] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.893407] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.900122] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   34.906035] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   36.913837] failed to power up DHD generic adapter, 0 retry left
      [   36.936626] wifi_platform_set_power = 0
      [   36.940926] ======== PULL WL_REG_ON(-1) LOW! ========
      [   36.947586] wifi_platform_bus_enumerate device present 0
      [   36.953556] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   36.959320] ======== Card detection to remove SDIO card! ========
      [   36.966171] failed to power up DHD generic adapter, max retry reached**
      [   36.966193] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   36.983955] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   36.994789] unregister wifi platform drivers
      [   36.999588] wifi_platform_bus_enumerate device present 0
      [   37.005560] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   37.011321] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   37.017296] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   37.017333] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.025370] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.037158] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.047905] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.053800] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.059689] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.059707] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   37.082443] ======== Card detection to remove SDIO card! ========
      [   37.089279] ======== dhd_wlan_deinit_plat_data ========
      [   37.089294] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.105464] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.116249] dhd_module_init: Failed to load the driver, try cnt 1
      [   37.123112] ======== dhd_wlan_init_plat_data ========
      [   37.123926] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   37.129613] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   37.134739] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.137223] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.139088] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.139961] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.140837] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.141709] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.141781] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   37.195776] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=117, oob_irq_flags=0x4084
      [   37.204252] dhd_wlan_init_gpio: WL_REG_ON=-1
      [   37.209043] dhd_wifi_platform_load: Enter
      [   37.213557] Power-up adapter 'DHD generic adapter'
      [   37.218977] wifi_platform_set_power = 1
      [   37.223278] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   37.229801] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   37.238920] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   37.563914] wifi_platform_bus_enumerate device present 1
      [   37.569875] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   37.575630] ======== Card detection to detect SDIO card! ========
      [   37.582479] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.607226] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.634697] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   37.641509] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   37.647515] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.660716] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   37.673300] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.680015] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.686730] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.693440] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   37.699351] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   39.687172] failed to power up DHD generic adapter, 3 retry left
      [   39.709959] wifi_platform_set_power = 0
      [   39.714263] ======== PULL WL_REG_ON(-1) LOW! ========
      [   39.720888] wifi_platform_bus_enumerate device present 0
      [   39.726849] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   39.732610] ======== Card detection to remove SDIO card! ========
      [   39.739457] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   39.743879] wifi_platform_set_power = 1
      [   39.743881] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   39.744643] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   39.745461] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   39.790557] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   39.818029] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   39.824789] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   39.830743] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   39.843891] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   39.856467] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   39.863127] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   39.869787] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   39.876447] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   39.882307] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   40.093888] wifi_platform_bus_enumerate device present 1
      [   40.099858] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   40.105615] ======== Card detection to detect SDIO card! ========
      [   40.112466] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   40.137171] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   40.164723] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   40.171520] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   40.177483] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   40.190642] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   40.203262] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   40.209964] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   40.216668] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   40.223365] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   40.229226] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   42.247161] failed to power up DHD generic adapter, 2 retry left
      [   42.269943] wifi_platform_set_power = 0
      [   42.274247] ======== PULL WL_REG_ON(-1) LOW! ========
      [   42.280859] wifi_platform_bus_enumerate device present 0
      [   42.286820] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   42.292577] ======== Card detection to remove SDIO card! ========
      [   42.299428] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.300544] wifi_platform_set_power = 1
      [   42.300547] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   42.301309] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   42.302123] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   42.350557] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.378028] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   42.384843] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   42.390852] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.404051] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.416636] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.423351] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.430061] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.436778] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.442694] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   42.650504] wifi_platform_bus_enumerate device present 1
      [   42.656467] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   42.662245] ======== Card detection to detect SDIO card! ========
      [   42.669103] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.693828] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.721344] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   42.728140] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   42.734110] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.747308] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   42.759930] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.766639] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.773335] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.780028] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   42.785899] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   44.807168] failed to power up DHD generic adapter, 1 retry left
      [   44.829958] wifi_platform_set_power = 0
      [   44.834262] ======== PULL WL_REG_ON(-1) LOW! ========
      [   44.840900] wifi_platform_bus_enumerate device present 0
      [   44.846861] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   44.852622] ======== Card detection to remove SDIO card! ========
      [   44.859470] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   44.864387] wifi_platform_set_power = 1
      [   44.864390] ======== PULL WL_REG_ON(-1) HIGH! ========
      [   44.865151] sunxi-wlan soc@03000000:wlan: check wlan wlan_power voltage: 3300000
      [   44.865966] sunxi-wlan soc@03000000:wlan: check wlan io_regulator voltage: 1800000
      [   44.910501] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   44.938031] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   44.944845] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   44.950858] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   44.964064] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   44.976643] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   44.983363] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   44.990078] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   44.996791] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   45.002703] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   45.213885] wifi_platform_bus_enumerate device present 1
      [   45.219852] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   45.225609] ======== Card detection to detect SDIO card! ========
      [   45.232473] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   45.257172] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   45.284676] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   45.291479] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   45.297436] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   45.310650] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   45.323272] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   45.329968] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   45.336674] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   45.343347] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   45.349218] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   47.367163] failed to power up DHD generic adapter, 0 retry left
      [   47.390012] wifi_platform_set_power = 0
      [   47.394316] ======== PULL WL_REG_ON(-1) LOW! ========
      [   47.400998] wifi_platform_bus_enumerate device present 0
      [   47.406956] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   47.412715] ======== Card detection to remove SDIO card! ========
      [   47.419548] failed to power up DHD generic adapter, max retry reached**
      [   47.419565] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.437308] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.448130] unregister wifi platform drivers
      [   47.452922] wifi_platform_bus_enumerate device present 0
      [   47.458886] sunxi-wlan soc@03000000:wlan: bus_index: 1
      [   47.459686] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   47.465460] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   47.470621] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.478646] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.480510] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.491228] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.501950] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.507805] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.512863] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   47.535877] ======== Card detection to remove SDIO card! ========
      [   47.542709] ======== dhd_wlan_deinit_plat_data ========
      [   47.542723] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.558892] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.569675] dhd_module_init: Failed to load the driver, try cnt 0
      [   47.576555] Error creating socket.
      [   47.577315] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   47.581182] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [   47.586336] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.588759] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   47.590624] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.591495] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.592365] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.593235] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [   47.593305] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   47.648194] dhd_module_init: Failed to load driver max retry reached**
      [   47.655504] dhd_module_init: Exit err=-19
      [   47.660438] get id is fail, 84
      [   47.669463] 2011-01-01(6) 12:00:41
      [   47.673311] rtc_hym8563 2-0051: setting system clock to 2011-01-01 12:00:41 UTC (1293883241)
      [   47.683355] [sunxi_snddaudio_dev_probe] audio_format: 1, signal_inversion: 1, daudio_master: 4
      [   47.693098] snddaudio snddaudio3: codec: ac107.3-0036, codec_dai: ac107-pcm0.
      [   47.701692] ac107_read error1->[REG-0xa2]
      [   47.706430] ac107_write error->[REG-0xa2,val-0xfd]
      [   47.712086] ac107_read error1->[REG-0xa7]
      [   47.716823] ac107_write error->[REG-0xa7,val-0xfd]
      [   47.722392] snddaudio snddaudio3: ac107-pcm0 <-> sunxi-ahub-cpu-aif3 mapping ok
      [   47.732367] audio-vdd: disabling
      [   47.735992] audio-vdd1v8: disabling
      [   47.740261] axp858-dcdc4: disabling
      [   47.745489] axp858-aldo3: disabling
      [   47.750364] axp858-aldo5: disabling
      [   47.755241] axp858-bldo2: disabling
      [   47.760112] axp858-bldo3: disabling
      [   47.764993] axp858-bldo5: disabling
      [   47.769873] axp858-cldo3: disabling
      [   47.774768] ALSA device list:
      [   47.778099]   #0: audiocodec
      [   47.781348]   #1: sndahub
      [   47.784287]   #2: sndac107.3-0036
      [   47.790573] Freeing unused kernel memory: 4608K
      ^FffF?rt5: ttyS5 at MMIO 0x50???[    1.377474] brd: module loaded
      [    1.388645] loop: module ????????^F^F^F^F^F? bt_rst gpio=136  mul-sel=1  pull=-1  drv_level=-1  data=0
      [    1.422568] sunxi[   47.821245] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      -bt soc@03000000:bt: devm_pinctrl_get() failed!
      [    1.430[/init]: getty is ttyS0
      [/init]: RootDevice is "/dev/mmcblk0p4" , [   47.827691] sunxi-mmc sdc2: *****retry:start*****
      GPT_SUPPORT=1
      [/init]: Try to load EMMC ...
      e2fsck 1.42.12 (29-Aug-2014)
      [   47.844147] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   47.856850] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   47.862785] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   47.869027] sunxi-mmc sdc2: *****retry:start*****
      [   47.874327] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   47.880504] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   47.886435] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   47.892675] sunxi-mmc sdc2: *****retry:start*****
      [   47.897972] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   47.904131] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   47.910114] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   47.916358] sunxi-mmc sdc2: *****retry:start*****
      [   47.921650] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   47.927806] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   47.933738] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   47.939981] sunxi-mmc sdc2: *****retry:start*****
      [   47.945278] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   47.951434] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   47.957364] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   47.963606] sunxi-mmc sdc2: *****retry:start*****
      [   47.968902] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   47.975062] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   47.980996] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   47.987237] sunxi-mmc sdc2: *****retry:start*****
      [   47.992534] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   47.998686] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.004619] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.010861] sunxi-mmc sdc2: *****retry:start*****
      [   48.016154] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   48.022308] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.028294] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.034538] sunxi-mmc sdc2: *****retry:start*****
      [   48.039856] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   48.046016] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.052002] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.058245] sunxi-mmc sdc2: *****retry:start*****
      [   48.063537] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   48.069690] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.075670] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.081912] sunxi-mmc sdc2: *****retry:start*****
      [   48.087224] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   48.093378] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.099309] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.105551] sunxi-mmc sdc2: *****retry:start*****
      [   48.110846] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   48.117013] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.122996] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.129237] sunxi-mmc sdc2: *****retry:start*****
      [   48.134530] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   48.140686] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.146671] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.152916] sunxi-mmc sdc2: *****retry:start*****
      [   48.158206] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   48.164360] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.170289] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.176531] sunxi-mmc sdc2: *****retry:start*****
      [   48.181822] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   48.187979] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.193959] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.200201] sunxi-mmc sdc2: *****retry:start*****
      [   48.205496] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   48.211650] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.217583] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.223824] sunxi-mmc sdc2: *****retry:start*****
      [   48.229122] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   48.235279] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.241214] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.247456] sunxi-mmc sdc2: *****retry:start*****
      [   48.252748] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   48.258904] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.264881] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.271124] sunxi-mmc sdc2: *****retry:start*****
      [   48.276415] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   48.282567] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.288554] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.294798] sunxi-mmc sdc2: *****retry:start*****
      [   48.300085] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   48.306245] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.312172] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.318412] sunxi-mmc sdc2: *****retry:start*****
      [   48.323704] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   48.329864] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.335796] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.342038] sunxi-mmc sdc2: *****retry:start*****
      [   48.347331] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   48.353488] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.359419] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.365660] sunxi-mmc sdc2: *****retry:start*****
      [   48.370954] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   48.377110] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.383039] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.389280] sunxi-mmc sdc2: *****retry:start*****
      [   48.394575] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   48.400729] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.406709] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.412953] sunxi-mmc sdc2: *****retry:start*****
      [   48.418243] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   48.424403] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.430328] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.436566] sunxi-mmc sdc2: *****retry:start*****
      [   48.441846] sunxi-mmc sdc2: send  manual stop command failed
      [   48.448203] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   48.454363] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.460293] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.466538] sunxi-mmc sdc2: *****retry:start*****
      [   48.471829] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   48.477989] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.483918] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.490161] sunxi-mmc sdc2: *****retry:start*****
      [   48.495454] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   48.501616] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.507548] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.513791] sunxi-mmc sdc2: *****retry:start*****
      [   48.519096] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   48.525255] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.531185] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.537434] sunxi-mmc sdc2: *****retry:start*****
      [   48.542730] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   48.548884] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.554815] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.561056] sunxi-mmc sdc2: *****retry:start*****
      [   48.566347] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   48.572507] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.578432] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD SBE !!
      [   48.584679] sunxi-mmc sdc2: *****retry:start*****
      [   48.589958] sunxi-mmc sdc2: send  manual stop command failed
      [   48.596320] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   48.602473] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.608403] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   48.614646] sunxi-mmc sdc2: *****retry:start*****
      [   48.619937] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   48.625700] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   48.633016] sunxi-mmc sdc2: retry:give up
      [   48.637615] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   48.646126] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   48.658468] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   48.683825] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   48.710553] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   48.721336] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   48.734534] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   48.761740] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   48.773848] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   48.784967] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   48.796048] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   48.807103] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   48.813693] sunxi-mmc sdc2: *****retry:start*****
      [   48.818988] sunxi-mmc sdc2: send  manual stop command failed
      [   48.825349] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   48.831515] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.837359] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   48.843894] sunxi-mmc sdc2: *****retry:start*****
      [   48.849185] sunxi-mmc sdc2: send  manual stop command failed
      [   48.855542] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   48.861696] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.867546] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   48.874080] sunxi-mmc sdc2: *****retry:start*****
      [   48.879361] sunxi-mmc sdc2: send  manual stop command failed
      [   48.885730] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   48.891880] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.897726] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   48.904262] sunxi-mmc sdc2: *****retry:start*****
      [   48.909543] sunxi-mmc sdc2: send  manual stop command failed
      [   48.915905] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   48.922056] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.927906] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   48.934438] sunxi-mmc sdc2: *****retry:start*****
      [   48.939724] sunxi-mmc sdc2: send  manual stop command failed
      [   48.946084] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   48.952253] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.958103] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   48.964689] sunxi-mmc sdc2: *****retry:start*****
      [   48.969974] sunxi-mmc sdc2: send  manual stop command failed
      [   48.976336] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   48.982489] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   48.988337] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   48.994872] sunxi-mmc sdc2: *****retry:start*****
      [   49.000153] sunxi-mmc sdc2: send  manual stop command failed
      [   49.006516] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   49.012672] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.018521] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.025056] sunxi-mmc sdc2: *****retry:start*****
      [   49.030346] sunxi-mmc sdc2: send  manual stop command failed
      [   49.036712] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   49.042862] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.048712] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.055248] sunxi-mmc sdc2: *****retry:start*****
      [   49.060530] sunxi-mmc sdc2: send  manual stop command failed
      [   49.066900] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   49.073054] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.078899] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.085434] sunxi-mmc sdc2: *****retry:start*****
      [   49.090711] sunxi-mmc sdc2: send  manual stop command failed
      [   49.097073] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   49.103226] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.109073] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.115608] sunxi-mmc sdc2: *****retry:start*****
      [   49.120896] sunxi-mmc sdc2: send  manual stop command failed
      [   49.127254] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   49.133405] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.139248] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.145784] sunxi-mmc sdc2: *****retry:start*****
      [   49.151061] sunxi-mmc sdc2: send  manual stop command failed
      [   49.157419] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   49.163570] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.169419] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.175952] sunxi-mmc sdc2: *****retry:start*****
      [   49.181233] sunxi-mmc sdc2: send  manual stop command failed
      [   49.187588] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   49.193740] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.199586] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.206122] sunxi-mmc sdc2: *****retry:start*****
      [   49.211417] sunxi-mmc sdc2: send  manual stop command failed
      [   49.217775] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   49.223928] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.229775] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.236308] sunxi-mmc sdc2: *****retry:start*****
      [   49.241588] sunxi-mmc sdc2: send  manual stop command failed
      [   49.247957] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   49.254108] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.259953] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.266490] sunxi-mmc sdc2: *****retry:start*****
      [   49.271770] sunxi-mmc sdc2: send  manual stop command failed
      [   49.278128] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   49.284283] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.290129] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.296663] sunxi-mmc sdc2: *****retry:start*****
      [   49.301945] sunxi-mmc sdc2: send  manual stop command failed
      [   49.308307] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   49.314459] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.320306] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.326840] sunxi-mmc sdc2: *****retry:start*****
      [   49.332121] sunxi-mmc sdc2: send  manual stop command failed
      [   49.338483] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   49.344634] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.350485] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.357017] sunxi-mmc sdc2: *****retry:start*****
      [   49.362310] sunxi-mmc sdc2: send  manual stop command failed
      [   49.368672] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   49.374823] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.380666] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.387203] sunxi-mmc sdc2: *****retry:start*****
      [   49.392485] sunxi-mmc sdc2: send  manual stop command failed
      [   49.398859] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   49.405011] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.410857] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.417390] sunxi-mmc sdc2: *****retry:start*****
      [   49.422670] sunxi-mmc sdc2: send  manual stop command failed
      [   49.429026] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   49.435180] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.441025] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.447562] sunxi-mmc sdc2: *****retry:start*****
      [   49.452840] sunxi-mmc sdc2: send  manual stop command failed
      [   49.459204] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   49.465367] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.471215] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.477749] sunxi-mmc sdc2: *****retry:start*****
      [   49.483030] sunxi-mmc sdc2: send  manual stop command failed
      [   49.489385] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   49.495535] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.501382] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.507918] sunxi-mmc sdc2: *****retry:start*****
      [   49.513205] sunxi-mmc sdc2: send  manual stop command failed
      [   49.519568] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   49.525709] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.531557] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.538090] sunxi-mmc sdc2: *****retry:start*****
      [   49.543369] sunxi-mmc sdc2: send  manual stop command failed
      [   49.549730] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   49.555885] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.561732] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.568327] sunxi-mmc sdc2: *****retry:start*****
      [   49.573610] sunxi-mmc sdc2: send  manual stop command failed
      [   49.579973] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   49.586124] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.591971] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.598505] sunxi-mmc sdc2: *****retry:start*****
      [   49.603783] sunxi-mmc sdc2: send  manual stop command failed
      [   49.610136] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   49.616289] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.622136] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.628671] sunxi-mmc sdc2: *****retry:start*****
      [   49.633955] sunxi-mmc sdc2: send  manual stop command failed
      [   49.640314] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   49.646464] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.652312] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.658842] sunxi-mmc sdc2: *****retry:start*****
      [   49.664124] sunxi-mmc sdc2: send  manual stop command failed
      [   49.670499] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   49.676654] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.682487] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.689023] sunxi-mmc sdc2: *****retry:start*****
      [   49.694300] sunxi-mmc sdc2: send  manual stop command failed
      [   49.700670] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   49.706820] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.712669] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.719203] sunxi-mmc sdc2: *****retry:start*****
      [   49.724489] sunxi-mmc sdc2: send  manual stop command failed
      [   49.730844] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   49.737002] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.742848] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.749385] sunxi-mmc sdc2: *****retry:start*****
      [   49.754668] sunxi-mmc sdc2: send  manual stop command failed
      [   49.761027] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   49.767175] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.773025] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.779558] sunxi-mmc sdc2: *****retry:start*****
      [   49.784841] sunxi-mmc sdc2: send  manual stop command failed
      [   49.791200] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   49.796958] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   49.804280] sunxi-mmc sdc2: retry:give up
      [   49.808783] mmc0: switch to bus width 8 failed
      [   49.813859] sunxi-mmc sdc2: smc 0 p2 err, cmd 13, RE RCE !!
      [   49.820102] sunxi-mmc sdc2: *****retry:start*****
      [   49.825399] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   49.831558] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.837401] 1,end
      [   49.839562] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [   49.850642] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.857231] sunxi-mmc sdc2: *****retry:start*****
      [   49.862526] sunxi-mmc sdc2: send  manual stop command failed
      [   49.868886] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   49.875041] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.880890] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.887425] sunxi-mmc sdc2: *****retry:start*****
      [   49.892704] sunxi-mmc sdc2: send  manual stop command failed
      [   49.899066] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   49.905218] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.911062] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.917594] sunxi-mmc sdc2: *****retry:start*****
      [   49.922873] sunxi-mmc sdc2: send  manual stop command failed
      [   49.929236] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   49.935400] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.941247] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.947781] sunxi-mmc sdc2: *****retry:start*****
      [   49.953058] sunxi-mmc sdc2: send  manual stop command failed
      [   49.959417] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   49.965567] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   49.971411] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   49.977948] sunxi-mmc sdc2: *****retry:start*****
      [   49.983231] sunxi-mmc sdc2: send  manual stop command failed
      [   49.989592] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   49.995743] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.001591] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.008126] sunxi-mmc sdc2: *****retry:start*****
      [   50.013403] sunxi-mmc sdc2: send  manual stop command failed
      [   50.019771] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   50.025923] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.031768] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.038305] sunxi-mmc sdc2: *****retry:start*****
      [   50.043581] sunxi-mmc sdc2: send  manual stop command failed
      [   50.049943] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   50.056092] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.061937] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.068470] sunxi-mmc sdc2: *****retry:start*****
      [   50.073754] sunxi-mmc sdc2: send  manual stop command failed
      [   50.080114] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   50.086264] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.092109] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.098645] sunxi-mmc sdc2: *****retry:start*****
      [   50.103928] sunxi-mmc sdc2: send  manual stop command failed
      [   50.110291] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   50.116454] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.122303] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.128836] sunxi-mmc sdc2: *****retry:start*****
      [   50.134120] sunxi-mmc sdc2: send  manual stop command failed
      [   50.140492] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   50.146648] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.152494] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.159029] sunxi-mmc sdc2: *****retry:start*****
      [   50.164321] sunxi-mmc sdc2: send  manual stop command failed
      [   50.170681] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   50.176839] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.182683] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.189218] sunxi-mmc sdc2: *****retry:start*****
      [   50.194502] sunxi-mmc sdc2: send  manual stop command failed
      [   50.200860] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   50.207017] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.212865] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.219400] sunxi-mmc sdc2: *****retry:start*****
      [   50.224677] sunxi-mmc sdc2: send  manual stop command failed
      [   50.231043] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   50.237199] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.243046] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.249631] sunxi-mmc sdc2: *****retry:start*****
      [   50.254922] sunxi-mmc sdc2: send  manual stop command failed
      [   50.261287] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   50.267453] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.273302] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.279836] sunxi-mmc sdc2: *****retry:start*****
      [   50.285118] sunxi-mmc sdc2: send  manual stop command failed
      [   50.291481] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   50.297632] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.303481] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.310016] sunxi-mmc sdc2: *****retry:start*****
      [   50.315299] sunxi-mmc sdc2: send  manual stop command failed
      [   50.321660] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   50.327814] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.333658] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.340194] sunxi-mmc sdc2: *****retry:start*****
      [   50.345475] sunxi-mmc sdc2: send  manual stop command failed
      [   50.351840] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   50.357989] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.363834] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.370368] sunxi-mmc sdc2: *****retry:start*****
      [   50.375648] sunxi-mmc sdc2: send  manual stop command failed
      [   50.382012] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   50.388167] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.394009] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.400543] sunxi-mmc sdc2: *****retry:start*****
      [   50.405823] sunxi-mmc sdc2: send  manual stop command failed
      [   50.412187] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   50.418348] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.424196] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.430728] sunxi-mmc sdc2: *****retry:start*****
      [   50.436009] sunxi-mmc sdc2: send  manual stop command failed
      [   50.442368] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   50.448531] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.454376] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.460912] sunxi-mmc sdc2: *****retry:start*****
      [   50.466205] sunxi-mmc sdc2: send  manual stop command failed
      [   50.472568] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   50.478720] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.484566] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.491099] sunxi-mmc sdc2: *****retry:start*****
      [   50.496381] sunxi-mmc sdc2: send  manual stop command failed
      [   50.502736] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   50.508893] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.514738] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.521274] sunxi-mmc sdc2: *****retry:start*****
      [   50.526559] sunxi-mmc sdc2: send  manual stop command failed
      [   50.532916] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   50.539070] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.544916] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.551451] sunxi-mmc sdc2: *****retry:start*****
      [   50.556734] sunxi-mmc sdc2: send  manual stop command failed
      [   50.563090] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   50.569245] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.575091] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.581623] sunxi-mmc sdc2: *****retry:start*****
      [   50.586916] sunxi-mmc sdc2: send  manual stop command failed
      [   50.593274] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   50.599428] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.605277] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.611809] sunxi-mmc sdc2: *****retry:start*****
      [   50.617093] sunxi-mmc sdc2: send  manual stop command failed
      [   50.623447] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   50.629604] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.635449] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.641984] sunxi-mmc sdc2: *****retry:start*****
      [   50.647267] sunxi-mmc sdc2: send  manual stop command failed
      [   50.653624] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   50.659773] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.665618] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.672155] sunxi-mmc sdc2: *****retry:start*****
      [   50.677435] sunxi-mmc sdc2: send  manual stop command failed
      [   50.683817] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   50.689975] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.695824] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.702358] sunxi-mmc sdc2: *****retry:start*****
      [   50.707644] sunxi-mmc sdc2: send  manual stop command failed
      [   50.714003] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   50.720165] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.726015] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.732550] sunxi-mmc sdc2: *****retry:start*****
      [   50.737836] sunxi-mmc sdc2: send  manual stop command failed
      [   50.744193] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   50.750358] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.756205] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.762741] sunxi-mmc sdc2: *****retry:start*****
      [   50.768032] sunxi-mmc sdc2: send  manual stop command failed
      [   50.774393] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   50.780543] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.786388] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.792921] sunxi-mmc sdc2: *****retry:start*****
      [   50.798203] sunxi-mmc sdc2: send  manual stop command failed
      [   50.804562] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   50.810712] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.816555] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   50.823092] sunxi-mmc sdc2: *****retry:start*****
      [   50.828373] sunxi-mmc sdc2: send  manual stop command failed
      [   50.834735] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   50.840493] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   50.847815] sunxi-mmc sdc2: retry:give up
      [   50.852318] mmc0: switch to bus width 4 failed
      /dev/mmcblk0p4: clean, 4883/131072 files, 115719/524288 blocks[   50.866436] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   50.873728] sunxi-mmc sdc2: *****retry:start*****
      [   50.879238] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   50.885399] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.891346] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   50.897587] sunxi-mmc sdc2: *****retry:start*****
      [   50.902882] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   50.909037] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.914984] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   50.921226] sunxi-mmc sdc2: *****retry:start*****
      [   50.926541] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   50.932700] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.938647] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   50.944888] sunxi-mmc sdc2: *****retry:start*****
      [   50.950179] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   50.956333] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.962276] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   50.968518] sunxi-mmc sdc2: *****retry:start*****
      [   50.973833] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   50.979986] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   50.985933] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   50.992174] sunxi-mmc sdc2: *****retry:start*****
      [   50.997471] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   51.003619] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.009565] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.015806] sunxi-mmc sdc2: *****retry:start*****
      [   51.021104] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   51.027253] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.033230] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.039472] sunxi-mmc sdc2: *****retry:start*****
      [   51.044767] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   51.050921] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.056869] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.063113] sunxi-mmc sdc2: *****retry:start*****
      [   51.068404] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   51.074560] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.080508] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.086750] sunxi-mmc sdc2: *****retry:start*****
      [   51.092047] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   51.098211] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.104159] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.110400] sunxi-mmc sdc2: *****retry:start*****
      [   51.115695] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   51.121849] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.127850] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.134094] sunxi-mmc sdc2: *****retry:start*****
      [   51.139390] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   51.145541] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.151491] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.157731] sunxi-mmc sdc2: *****retry:start*****
      [   51.163023] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   51.169174] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.175124] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.181367] sunxi-mmc sdc2: *****retry:start*****
      [   51.186667] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   51.192821] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.198766] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.205008] sunxi-mmc sdc2: *****retry:start*****
      [   51.210304] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   51.216454] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.222455] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.228696] sunxi-mmc sdc2: *****retry:start*****
      [   51.233992] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   51.240147] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.246096] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.252338] sunxi-mmc sdc2: *****retry:start*****
      [   51.257630] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   51.263786] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.269733] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.275976] sunxi-mmc sdc2: *****retry:start*****
      [   51.281275] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   51.287432] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.293377] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.299618] sunxi-mmc sdc2: *****retry:start*****
      [   51.304923] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   51.311080] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.317028] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.323329] sunxi-mmc sdc2: *****retry:start*****
      [   51.328628] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   51.334795] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.340741] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.346982] sunxi-mmc sdc2: *****retry:start*****
      [   51.352278] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   51.358435] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.364382] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.370623] sunxi-mmc sdc2: *****retry:start*****
      [   51.375918] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   51.382072] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.388074] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.394313] sunxi-mmc sdc2: *****retry:start*****
      [   51.399606] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   51.405758] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.411706] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.417947] sunxi-mmc sdc2: *****retry:start*****
      [   51.423241] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   51.429400] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.435409] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.441710] sunxi-mmc sdc2: *****retry:start*****
      [   51.447005] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   51.453175] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.459123] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.465364] sunxi-mmc sdc2: *****retry:start*****
      [   51.470664] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   51.476818] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.482764] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.489006] sunxi-mmc sdc2: *****retry:start*****
      [   51.494301] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   51.500459] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.506409] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.512651] sunxi-mmc sdc2: *****retry:start*****
      [   51.517948] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   51.524104] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.530051] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.536295] sunxi-mmc sdc2: *****retry:start*****
      [   51.541597] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   51.547759] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.553708] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.559949] sunxi-mmc sdc2: *****retry:start*****
      [   51.565245] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   51.571400] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.577399] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.583639] sunxi-mmc sdc2: *****retry:start*****
      [   51.588941] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   51.595096] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.601096] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.607338] sunxi-mmc sdc2: *****retry:start*****
      [   51.612622] sunxi-mmc sdc2: send  manual stop command failed
      [   51.618979] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   51.625138] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.631120] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   51.637362] sunxi-mmc sdc2: *****retry:start*****
      [   51.642654] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   51.648418] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   51.655732] sunxi-mmc sdc2: retry:give up
      [   51.660295] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   51.668905] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   51.680556] random: crng init done
      [   51.681254] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   51.697157] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   51.727161] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   51.737944] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   51.751148] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   51.778589] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   51.790860] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   51.801981] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   51.813064] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   51.824122] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   51.830654] sunxi-mmc sdc2: *****retry:start*****
      [   51.835941] sunxi-mmc sdc2: send  manual stop command failed
      [   51.842300] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   51.848472] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.854318] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   51.860850] sunxi-mmc sdc2: *****retry:start*****
      [   51.866140] sunxi-mmc sdc2: send  manual stop command failed
      [   51.872503] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   51.878655] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.884508] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   51.891100] sunxi-mmc sdc2: *****retry:start*****
      [   51.896397] sunxi-mmc sdc2: send  manual stop command failed
      [   51.902762] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   51.908919] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.914767] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   51.921361] sunxi-mmc sdc2: *****retry:start*****
      [   51.926644] sunxi-mmc sdc2: send  manual stop command failed
      [   51.933002] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   51.939157] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.945005] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   51.951595] sunxi-mmc sdc2: *****retry:start*****
      [   51.956890] sunxi-mmc sdc2: send  manual stop command failed
      [   51.963262] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   51.969416] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   51.975262] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   51.981794] sunxi-mmc sdc2: *****retry:start*****
      [   51.987077] sunxi-mmc sdc2: send  manual stop command failed
      [   51.993436] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   51.999600] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.005448] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.011985] sunxi-mmc sdc2: *****retry:start*****
      [   52.017269] sunxi-mmc sdc2: send  manual stop command failed
      [   52.023625] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   52.029779] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.035626] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.042159] sunxi-mmc sdc2: *****retry:start*****
      [   52.047445] sunxi-mmc sdc2: send  manual stop command failed
      [   52.053825] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   52.059977] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.065823] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.072356] sunxi-mmc sdc2: *****retry:start*****
      [   52.077638] sunxi-mmc sdc2: send  manual stop command failed
      [   52.084001] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   52.090156] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.096001] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.102534] sunxi-mmc sdc2: *****retry:start*****
      [   52.107813] sunxi-mmc sdc2: send  manual stop command failed
      [   52.114172] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   52.120320] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.126169] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.132703] sunxi-mmc sdc2: *****retry:start*****
      [   52.137986] sunxi-mmc sdc2: send  manual stop command failed
      [   52.144344] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   52.150506] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.156352] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.162891] sunxi-mmc sdc2: *****retry:start*****
      [   52.168170] sunxi-mmc sdc2: send  manual stop command failed
      [   52.174529] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   52.180679] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.186524] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.193060] sunxi-mmc sdc2: *****retry:start*****
      [   52.198353] sunxi-mmc sdc2: send  manual stop command failed
      [   52.204714] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   52.210868] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.216712] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.223251] sunxi-mmc sdc2: *****retry:start*****
      [   52.228530] sunxi-mmc sdc2: send  manual stop command failed
      [   52.234891] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   52.241036] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.246884] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.253417] sunxi-mmc sdc2: *****retry:start*****
      [   52.258697] sunxi-mmc sdc2: send  manual stop command failed
      [   52.265058] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   52.271202] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.277047] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.283582] sunxi-mmc sdc2: *****retry:start*****
      [   52.288861] sunxi-mmc sdc2: send  manual stop command failed
      [   52.295224] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   52.301385] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.307233] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.313764] sunxi-mmc sdc2: *****retry:start*****
      [   52.319046] sunxi-mmc sdc2: send  manual stop command failed
      [   52.325407] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   52.331569] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.337414] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.343950] sunxi-mmc sdc2: *****retry:start*****
      [   52.349229] sunxi-mmc sdc2: send  manual stop command failed
      [   52.355591] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   52.361744] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.367592] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.374123] sunxi-mmc sdc2: *****retry:start*****
      [   52.379403] sunxi-mmc sdc2: send  manual stop command failed
      [   52.385758] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   52.391910] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.397758] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.404291] sunxi-mmc sdc2: *****retry:start*****
      [   52.409572] sunxi-mmc sdc2: send  manual stop command failed
      [   52.415944] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   52.422097] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.427945] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.434481] sunxi-mmc sdc2: *****retry:start*****
      [   52.439762] sunxi-mmc sdc2: send  manual stop command failed
      [   52.446117] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   52.452277] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.458124] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.464662] sunxi-mmc sdc2: *****retry:start*****
      [   52.469944] sunxi-mmc sdc2: send  manual stop command failed
      [   52.476303] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   52.482467] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.488314] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.494847] sunxi-mmc sdc2: *****retry:start*****
      [   52.500128] sunxi-mmc sdc2: send  manual stop command failed
      [   52.506485] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   52.512638] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.518485] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.525017] sunxi-mmc sdc2: *****retry:start*****
      [   52.530297] sunxi-mmc sdc2: send  manual stop command failed
      [   52.536655] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   52.542809] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.548654] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.555188] sunxi-mmc sdc2: *****retry:start*****
      [   52.560469] sunxi-mmc sdc2: send  manual stop command failed
      [   52.566836] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   52.572991] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.578835] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.585372] sunxi-mmc sdc2: *****retry:start*****
      [   52.590654] sunxi-mmc sdc2: send  manual stop command failed
      [   52.597012] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   52.603173] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.609019] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.615554] sunxi-mmc sdc2: *****retry:start*****
      [   52.620834] sunxi-mmc sdc2: send  manual stop command failed
      [   52.627191] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   52.633342] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.639187] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.645723] sunxi-mmc sdc2: *****retry:start*****
      [   52.651005] sunxi-mmc sdc2: send  manual stop command failed
      [   52.657368] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   52.663521] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.669369] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.675906] sunxi-mmc sdc2: *****retry:start*****
      [   52.681185] sunxi-mmc sdc2: send  manual stop command failed
      [   52.687544] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   52.693695] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.699543] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.706077] sunxi-mmc sdc2: *****retry:start*****
      [   52.711360] sunxi-mmc sdc2: send  manual stop command failed
      [   52.717726] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   52.723879] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.729725] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.736260] sunxi-mmc sdc2: *****retry:start*****
      [   52.741541] sunxi-mmc sdc2: send  manual stop command failed
      [   52.747912] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   52.754066] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.759909] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.766442] sunxi-mmc sdc2: *****retry:start*****
      [   52.771724] sunxi-mmc sdc2: send  manual stop command failed
      [   52.778086] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   52.784238] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.790086] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.796620] sunxi-mmc sdc2: *****retry:start*****
      [   52.801904] sunxi-mmc sdc2: send  manual stop command failed
      [   52.808264] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   52.814024] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   52.821343] sunxi-mmc sdc2: retry:give up
      [   52.825851] mmc0: switch to bus width 8 failed
      [   52.830938] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [   52.842013] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.848598] sunxi-mmc sdc2: *****retry:start*****
      [   52.853894] sunxi-mmc sdc2: send  manual stop command failed
      [   52.860251] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   52.866420] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.872266] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.878800] sunxi-mmc sdc2: *****retry:start*****
      [   52.884085] sunxi-mmc sdc2: send  manual stop command failed
      [   52.890443] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   52.896598] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.902448] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.908980] sunxi-mmc sdc2: *****retry:start*****
      [   52.914268] sunxi-mmc sdc2: send  manual stop command failed
      [   52.920622] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   52.926780] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.932626] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.939161] sunxi-mmc sdc2: *****retry:start*****
      [   52.944444] sunxi-mmc sdc2: send  manual stop command failed
      [   52.950812] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   52.956969] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.962816] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.969347] sunxi-mmc sdc2: *****retry:start*****
      [   52.974632] sunxi-mmc sdc2: send  manual stop command failed
      [   52.980993] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   52.987173] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   52.993016] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   52.999554] sunxi-mmc sdc2: *****retry:start*****
      [   53.004836] sunxi-mmc sdc2: send  manual stop command failed
      [   53.011200] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   53.017350] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.023195] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.029730] sunxi-mmc sdc2: *****retry:start*****
      [   53.035010] sunxi-mmc sdc2: send  manual stop command failed
      [   53.041369] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   53.047521] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.053370] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.059903] sunxi-mmc sdc2: *****retry:start*****
      [   53.065183] sunxi-mmc sdc2: send  manual stop command failed
      [   53.071544] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   53.077698] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.083545] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.090079] sunxi-mmc sdc2: *****retry:start*****
      [   53.095362] sunxi-mmc sdc2: send  manual stop command failed
      [   53.101724] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   53.107875] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.113725] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.120262] sunxi-mmc sdc2: *****retry:start*****
      [   53.125546] sunxi-mmc sdc2: send  manual stop command failed
      [   53.131922] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   53.138075] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.143920] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.150452] sunxi-mmc sdc2: *****retry:start*****
      [   53.155734] sunxi-mmc sdc2: send  manual stop command failed
      [   53.162096] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   53.168264] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.174109] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.180643] sunxi-mmc sdc2: *****retry:start*****
      [   53.185921] sunxi-mmc sdc2: send  manual stop command failed
      [   53.192284] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   53.198436] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.204284] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.210818] sunxi-mmc sdc2: *****retry:start*****
      [   53.216096] sunxi-mmc sdc2: send  manual stop command failed
      [   53.222456] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   53.228609] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.234456] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.240992] sunxi-mmc sdc2: *****retry:start*****
      [   53.246270] sunxi-mmc sdc2: send  manual stop command failed
      [   53.252635] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   53.258791] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.264636] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.271171] sunxi-mmc sdc2: *****retry:start*****
      [   53.276452] sunxi-mmc sdc2: send  manual stop command failed
      [   53.282820] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   53.288973] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.294821] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.301354] sunxi-mmc sdc2: *****retry:start*****
      [   53.306632] sunxi-mmc sdc2: send  manual stop command failed
      [   53.312993] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   53.319158] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.325006] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.331540] sunxi-mmc sdc2: *****retry:start*****
      [   53.336821] sunxi-mmc sdc2: send  manual stop command failed
      [   53.343177] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   53.349329] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.355175] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.361711] sunxi-mmc sdc2: *****retry:start*****
      [   53.366990] sunxi-mmc sdc2: send  manual stop command failed
      [   53.373346] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   53.379497] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.385343] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.391876] sunxi-mmc sdc2: *****retry:start*****
      [   53.397159] sunxi-mmc sdc2: send  manual stop command failed
      [   53.403526] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   53.409682] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.415527] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.422064] sunxi-mmc sdc2: *****retry:start*****
      [   53.427347] sunxi-mmc sdc2: send  manual stop command failed
      [   53.433719] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   53.439870] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.445716] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.452250] sunxi-mmc sdc2: *****retry:start*****
      [   53.457533] sunxi-mmc sdc2: send  manual stop command failed
      [   53.463890] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   53.470047] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.475892] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.482427] sunxi-mmc sdc2: *****retry:start*****
      [   53.487713] sunxi-mmc sdc2: send  manual stop command failed
      [   53.494077] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   53.500232] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.506076] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.512610] sunxi-mmc sdc2: *****retry:start*****
      [   53.517893] sunxi-mmc sdc2: send  manual stop command failed
      [   53.524252] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   53.530406] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.536254] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.542791] sunxi-mmc sdc2: *****retry:start*****
      [   53.548082] sunxi-mmc sdc2: send  manual stop command failed
      [   53.554445] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   53.560595] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.566443] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.572976] sunxi-mmc sdc2: *****retry:start*****
      [   53.578260] sunxi-mmc sdc2: send  manual stop command failed
      [   53.584635] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   53.590787] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.596633] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.603167] sunxi-mmc sdc2: *****retry:start*****
      [   53.608449] sunxi-mmc sdc2: send  manual stop command failed
      [   53.614815] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   53.620965] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.626813] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.633344] sunxi-mmc sdc2: *****retry:start*****
      [   53.638622] sunxi-mmc sdc2: send  manual stop command failed
      [   53.644980] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   53.651132] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.656977] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.663512] sunxi-mmc sdc2: *****retry:start*****
      [   53.668792] sunxi-mmc sdc2: send  manual stop command failed
      [   53.675154] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   53.681319] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.687167] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.693701] sunxi-mmc sdc2: *****retry:start*****
      [   53.698979] sunxi-mmc sdc2: send  manual stop command failed
      [   53.705338] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   53.711492] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.717339] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.723875] sunxi-mmc sdc2: *****retry:start*****
      [   53.729165] sunxi-mmc sdc2: send  manual stop command failed
      [   53.735526] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   53.741679] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.747525] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.754057] sunxi-mmc sdc2: *****retry:start*****
      [   53.759341] sunxi-mmc sdc2: send  manual stop command failed
      [   53.765708] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   53.771862] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.777709] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.784246] sunxi-mmc sdc2: *****retry:start*****
      [   53.789525] sunxi-mmc sdc2: send  manual stop command failed
      [   53.795881] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   53.802032] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.807877] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   53.814408] sunxi-mmc sdc2: *****retry:start*****
      [   53.819692] sunxi-mmc sdc2: send  manual stop command failed
      [   53.826048] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   53.831804] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   53.839123] sunxi-mmc sdc2: retry:give up
      [   53.843628] mmc0: switch to bus width 4 failed
      [   53.854401] EXT4-fs (mmcblk0p4): barriers disabled
      [   53.859918] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   53.866220] sunxi-mmc sdc2: *****retry:start*****
      [   53.871531] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   53.877683] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.883630] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   53.889871] sunxi-mmc sdc2: *****retry:start*****
      [   53.895167] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   53.901330] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.907333] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   53.913575] sunxi-mmc sdc2: *****retry:start*****
      [   53.918876] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   53.925031] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.931018] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   53.937260] sunxi-mmc sdc2: *****retry:start*****
      [   53.942557] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   53.948708] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.954657] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   53.960898] sunxi-mmc sdc2: *****retry:start*****
      [   53.966191] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   53.972346] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   53.978294] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   53.984536] sunxi-mmc sdc2: *****retry:start*****
      [   53.989830] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   53.995986] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.001986] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.008229] sunxi-mmc sdc2: *****retry:start*****
      [   54.013521] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   54.019682] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.025682] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.031926] sunxi-mmc sdc2: *****retry:start*****
      [   54.037221] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   54.043372] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.049321] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.055563] sunxi-mmc sdc2: *****retry:start*****
      [   54.060855] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   54.067022] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.072969] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.079210] sunxi-mmc sdc2: *****retry:start*****
      [   54.084509] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   54.087158]
      [   54.087158] insmod_device_driver
      [   54.087158]
      [   54.097591] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.103537] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.109836] sunxi-mmc sdc2: *****retry:start*****
      [   54.115139] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   54.121292] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.127240] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.133538] sunxi-mmc sdc2: *****retry:start*****
      [   54.138835] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   54.144991] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.150938] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.157233] sunxi-mmc sdc2: *****retry:start*****
      [   54.162530] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   54.168691] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.174637] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.180928] sunxi-mmc sdc2: *****retry:start*****
      [   54.186222] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   54.192384] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.198330] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.204625] sunxi-mmc sdc2: *****retry:start*****
      [   54.209920] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   54.216091] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.222037] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.228340] sunxi-mmc sdc2: *****retry:start*****
      [   54.233637] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   54.239802] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.245750] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.251993] sunxi-mmc sdc2: *****retry:start*****
      [   54.257303] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   54.263455] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.269432] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.275679] sunxi-mmc sdc2: *****retry:start*****
      [   54.280972] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   54.287152] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.293099] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.299344] sunxi-mmc sdc2: *****retry:start*****
      [   54.304647] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   54.310808] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.316807] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.323049] sunxi-mmc sdc2: *****retry:start*****
      [   54.328344] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   54.334507] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.340504] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.346748] sunxi-mmc sdc2: *****retry:start*****
      [   54.352041] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   54.358199] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.364197] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.370443] sunxi-mmc sdc2: *****retry:start*****
      [   54.375735] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   54.381888] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.387833] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.394080] sunxi-mmc sdc2: *****retry:start*****
      [   54.399369] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   54.405523] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.411471] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.417774] sunxi-mmc sdc2: *****retry:start*****
      [   54.423079] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   54.429230] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.435174] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.441419] sunxi-mmc sdc2: *****retry:start*****
      [   54.446712] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   54.452867] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.458812] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.465055] sunxi-mmc sdc2: *****retry:start*****
      [   54.470347] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   54.476507] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.482455] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.488753] sunxi-mmc sdc2: *****retry:start*****
      [   54.494052] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   54.500214] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.506159] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.512459] sunxi-mmc sdc2: *****retry:start*****
      [   54.517756] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   54.523914] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.529861] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.536105] sunxi-mmc sdc2: *****retry:start*****
      [   54.541401] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   54.547560] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.553503] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.559749] sunxi-mmc sdc2: *****retry:start*****
      [   54.565044] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   54.571206] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.577149] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.583393] sunxi-mmc sdc2: *****retry:start*****
      [   54.588672] sunxi-mmc sdc2: send  manual stop command failed
      [   54.595034] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   54.601188] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.607138] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.613381] sunxi-mmc sdc2: *****retry:start*****
      [   54.618665] sunxi-mmc sdc2: send  manual stop command failed
      [   54.625027] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   54.631180] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.637128] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   54.643371] sunxi-mmc sdc2: *****retry:start*****
      [   54.648663] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   54.654426] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   54.661739] sunxi-mmc sdc2: retry:give up
      [   54.666323] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   54.674934] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   54.687266] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   54.713933] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   54.740554] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   54.751335] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   54.764540] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   54.791864] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   54.803988] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   54.815093] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   54.826169] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   54.837218] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   54.843748] sunxi-mmc sdc2: *****retry:start*****
      [   54.849027] sunxi-mmc sdc2: send  manual stop command failed
      [   54.855394] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   54.861546] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.867392] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   54.873982] sunxi-mmc sdc2: *****retry:start*****
      [   54.879266] sunxi-mmc sdc2: send  manual stop command failed
      [   54.885639] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   54.891790] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.897639] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   54.904173] sunxi-mmc sdc2: *****retry:start*****
      [   54.909454] sunxi-mmc sdc2: send  manual stop command failed
      [   54.915816] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   54.921968] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.927814] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   54.934349] sunxi-mmc sdc2: *****retry:start*****
      [   54.939629] sunxi-mmc sdc2: send  manual stop command failed
      [   54.945994] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   54.952148] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.957994] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   54.964529] sunxi-mmc sdc2: *****retry:start*****
      [   54.969820] sunxi-mmc sdc2: send  manual stop command failed
      [   54.976184] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   54.982337] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   54.988184] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   54.994717] sunxi-mmc sdc2: *****retry:start*****
      [   54.999997] sunxi-mmc sdc2: send  manual stop command failed
      [   55.006356] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   55.012510] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.018356] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.024893] sunxi-mmc sdc2: *****retry:start*****
      [   55.030180] sunxi-mmc sdc2: send  manual stop command failed
      [   55.036537] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   55.042691] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.048538] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.055070] sunxi-mmc sdc2: *****retry:start*****
      [   55.060352] sunxi-mmc sdc2: send  manual stop command failed
      [   55.066716] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   55.072870] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.078713] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.085246] sunxi-mmc sdc2: *****retry:start*****
      [   55.090526] sunxi-mmc sdc2: send  manual stop command failed
      [   55.096889] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   55.103047] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.108894] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.115428] sunxi-mmc sdc2: *****retry:start*****
      [   55.120716] sunxi-mmc sdc2: send  manual stop command failed
      [   55.127071] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   55.133238] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.139083] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.145618] sunxi-mmc sdc2: *****retry:start*****
      [   55.150900] sunxi-mmc sdc2: send  manual stop command failed
      [   55.157262] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   55.163412] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.169261] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.175796] sunxi-mmc sdc2: *****retry:start*****
      [   55.181077] sunxi-mmc sdc2: send  manual stop command failed
      [   55.187437] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   55.193591] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.199437] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.205972] sunxi-mmc sdc2: *****retry:start*****
      [   55.211251] sunxi-mmc sdc2: send  manual stop command failed
      [   55.217619] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   55.223770] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.229616] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.236149] sunxi-mmc sdc2: *****retry:start*****
      [   55.241433] sunxi-mmc sdc2: send  manual stop command failed
      [   55.247798] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   55.253950] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.259794] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.266331] sunxi-mmc sdc2: *****retry:start*****
      [   55.271611] sunxi-mmc sdc2: send  manual stop command failed
      [   55.277972] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   55.284136] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.289986] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.296517] sunxi-mmc sdc2: *****retry:start*****
      [   55.301797] sunxi-mmc sdc2: send  manual stop command failed
      [   55.308157] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   55.314310] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.320157] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.326691] sunxi-mmc sdc2: *****retry:start*****
      [   55.331974] sunxi-mmc sdc2: send  manual stop command failed
      [   55.338334] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   55.344485] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.350328] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.356860] sunxi-mmc sdc2: *****retry:start*****
      [   55.362145] sunxi-mmc sdc2: send  manual stop command failed
      [   55.368518] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   55.374673] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.380521] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.387056] sunxi-mmc sdc2: *****retry:start*****
      [   55.392336] sunxi-mmc sdc2: send  manual stop command failed
      [   55.398698] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   55.404847] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.410694] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.417228] sunxi-mmc sdc2: *****retry:start*****
      [   55.422506] sunxi-mmc sdc2: send  manual stop command failed
      [   55.428862] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   55.435018] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.440862] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.447398] sunxi-mmc sdc2: *****retry:start*****
      [   55.452677] sunxi-mmc sdc2: send  manual stop command failed
      [   55.459039] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   55.465199] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.471047] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.477582] sunxi-mmc sdc2: *****retry:start*****
      [   55.482860] sunxi-mmc sdc2: send  manual stop command failed
      [   55.489221] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   55.495371] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.501217] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.507754] sunxi-mmc sdc2: *****retry:start*****
      [   55.513038] sunxi-mmc sdc2: send  manual stop command failed
      [   55.519406] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   55.525557] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.531403] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.537939] sunxi-mmc sdc2: *****retry:start*****
      [   55.543216] sunxi-mmc sdc2: send  manual stop command failed
      [   55.549568] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   55.555722] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.561570] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.568104] sunxi-mmc sdc2: *****retry:start*****
      [   55.573385] sunxi-mmc sdc2: send  manual stop command failed
      [   55.579741] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   55.585900] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.591748] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.598283] sunxi-mmc sdc2: *****retry:start*****
      [   55.603562] sunxi-mmc sdc2: send  manual stop command failed
      [   55.609919] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   55.616087] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.621935] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.628471] sunxi-mmc sdc2: *****retry:start*****
      [   55.633756] sunxi-mmc sdc2: send  manual stop command failed
      [   55.640114] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   55.646268] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.652116] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.658649] sunxi-mmc sdc2: *****retry:start*****
      [   55.663931] sunxi-mmc sdc2: send  manual stop command failed
      [   55.670291] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   55.676445] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.682293] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.688825] sunxi-mmc sdc2: *****retry:start*****
      [   55.694106] sunxi-mmc sdc2: send  manual stop command failed
      [   55.700486] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   55.706637] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.712484] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.719018] sunxi-mmc sdc2: *****retry:start*****
      [   55.724302] sunxi-mmc sdc2: send  manual stop command failed
      [   55.730664] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   55.736831] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.742675] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.749212] sunxi-mmc sdc2: *****retry:start*****
      [   55.754494] sunxi-mmc sdc2: send  manual stop command failed
      [   55.760855] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   55.767015] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.772861] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.779396] sunxi-mmc sdc2: *****retry:start*****
      [   55.784681] sunxi-mmc sdc2: send  manual stop command failed
      [   55.791043] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   55.797198] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.803042] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.809578] sunxi-mmc sdc2: *****retry:start*****
      [   55.814870] sunxi-mmc sdc2: send  manual stop command failed
      [   55.821232] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   55.826989] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   55.834306] sunxi-mmc sdc2: retry:give up
      [   55.838811] mmc0: switch to bus width 8 failed
      [   55.843944] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [   55.855018] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.861610] sunxi-mmc sdc2: *****retry:start*****
      [   55.866895] sunxi-mmc sdc2: send  manual stop command failed
      [   55.873269] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   55.879427] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.885273] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.891808] sunxi-mmc sdc2: *****retry:start*****
      [   55.897088] sunxi-mmc sdc2: send  manual stop command failed
      [   55.903462] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   55.909613] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.915458] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.921995] sunxi-mmc sdc2: *****retry:start*****
      [   55.927275] sunxi-mmc sdc2: send  manual stop command failed
      [   55.933643] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   55.939792] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.945641] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.952174] sunxi-mmc sdc2: *****retry:start*****
      [   55.957452] sunxi-mmc sdc2: send  manual stop command failed
      [   55.963824] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   55.969980] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   55.975826] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   55.982361] sunxi-mmc sdc2: *****retry:start*****
      [   55.987640] sunxi-mmc sdc2: send  manual stop command failed
      [   55.994003] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   56.000156] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.006004] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.012539] sunxi-mmc sdc2: *****retry:start*****
      [   56.017817] sunxi-mmc sdc2: send  manual stop command failed
      [   56.024175] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   56.030331] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.036178] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.042712] sunxi-mmc sdc2: *****retry:start*****
      [   56.047999] sunxi-mmc sdc2: send  manual stop command failed
      [   56.054363] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   56.060512] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.066358] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.072893] sunxi-mmc sdc2: *****retry:start*****
      [   56.078175] sunxi-mmc sdc2: send  manual stop command failed
      [   56.084538] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   56.090690] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.096534] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.103067] sunxi-mmc sdc2: *****retry:start*****
      [   56.108347] sunxi-mmc sdc2: send  manual stop command failed
      [   56.114712] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   56.120863] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.126710] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.133245] sunxi-mmc sdc2: *****retry:start*****
      [   56.138528] sunxi-mmc sdc2: send  manual stop command failed
      [   56.144892] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   56.151050] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.156895] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.163427] sunxi-mmc sdc2: *****retry:start*****
      [   56.168707] sunxi-mmc sdc2: send  manual stop command failed
      [   56.175072] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   56.181223] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.187071] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.193607] sunxi-mmc sdc2: *****retry:start*****
      [   56.198887] sunxi-mmc sdc2: send  manual stop command failed
      [   56.205247] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   56.211400] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.217247] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.223782] sunxi-mmc sdc2: *****retry:start*****
      [   56.229062] sunxi-mmc sdc2: send  manual stop command failed
      [   56.235420] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   56.241572] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.247417] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.253951] sunxi-mmc sdc2: *****retry:start*****
      [   56.259239] sunxi-mmc sdc2: send  manual stop command failed
      [   56.265599] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   56.271747] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.277593] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.284132] sunxi-mmc sdc2: *****retry:start*****
      [   56.289411] sunxi-mmc sdc2: send  manual stop command failed
      [   56.295771] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   56.301924] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.307772] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.314304] sunxi-mmc sdc2: *****retry:start*****
      [   56.319584] sunxi-mmc sdc2: send  manual stop command failed
      [   56.325944] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   56.332097] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.337941] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.344476] sunxi-mmc sdc2: *****retry:start*****
      [   56.349755] sunxi-mmc sdc2: send  manual stop command failed
      [   56.356117] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   56.362268] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.368112] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.374648] sunxi-mmc sdc2: *****retry:start*****
      [   56.379940] sunxi-mmc sdc2: send  manual stop command failed
      [   56.386301] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   56.392457] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.398303] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.404838] sunxi-mmc sdc2: *****retry:start*****
      [   56.410124] sunxi-mmc sdc2: send  manual stop command failed
      [   56.416483] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   56.422633] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.428479] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.435012] sunxi-mmc sdc2: *****retry:start*****
      [   56.440294] sunxi-mmc sdc2: send  manual stop command failed
      [   56.446649] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   56.452802] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.458646] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.465181] sunxi-mmc sdc2: *****retry:start*****
      [   56.470460] sunxi-mmc sdc2: send  manual stop command failed
      [   56.476815] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   56.482964] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.488811] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.495343] sunxi-mmc sdc2: *****retry:start*****
      [   56.500635] sunxi-mmc sdc2: send  manual stop command failed
      [   56.506998] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   56.513154] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.519000] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.525534] sunxi-mmc sdc2: *****retry:start*****
      [   56.530816] sunxi-mmc sdc2: send  manual stop command failed
      [   56.537174] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   56.543326] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.549175] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.555708] sunxi-mmc sdc2: *****retry:start*****
      [   56.560989] sunxi-mmc sdc2: send  manual stop command failed
      [   56.567350] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   56.573504] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.579349] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.585882] sunxi-mmc sdc2: *****retry:start*****
      [   56.591165] sunxi-mmc sdc2: send  manual stop command failed
      [   56.597529] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   56.603671] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.609517] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.616049] sunxi-mmc sdc2: *****retry:start*****
      [   56.621330] sunxi-mmc sdc2: send  manual stop command failed
      [   56.627691] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   56.633847] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.639694] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.646227] sunxi-mmc sdc2: *****retry:start*****
      [   56.651510] sunxi-mmc sdc2: send  manual stop command failed
      [   56.657876] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   56.664025] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.669872] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.676406] sunxi-mmc sdc2: *****retry:start*****
      [   56.681690] sunxi-mmc sdc2: send  manual stop command failed
      [   56.688051] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   56.694205] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.700050] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.706584] sunxi-mmc sdc2: *****retry:start*****
      [   56.711870] sunxi-mmc sdc2: send  manual stop command failed
      [   56.718234] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   56.724384] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.730229] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.736759] sunxi-mmc sdc2: *****retry:start*****
      [   56.742042] sunxi-mmc sdc2: send  manual stop command failed
      [   56.748403] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   56.754559] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.760404] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.766939] sunxi-mmc sdc2: *****retry:start*****
      [   56.772218] sunxi-mmc sdc2: send  manual stop command failed
      [   56.778582] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   56.784734] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.790580] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.797115] sunxi-mmc sdc2: *****retry:start*****
      [   56.802396] sunxi-mmc sdc2: send  manual stop command failed
      [   56.808758] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   56.814915] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.820758] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   56.827294] sunxi-mmc sdc2: *****retry:start*****
      [   56.832575] sunxi-mmc sdc2: send  manual stop command failed
      [   56.838938] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   56.844697] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   56.852027] sunxi-mmc sdc2: retry:give up
      [   56.856529] mmc0: switch to bus width 4 failed
      [   56.863341] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,barrier=0,data=ordered
      [   56.878507] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   56.884768] sunxi-mmc sdc2: *****retry:start*****
      [   56.890116] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   56.896293] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.902239] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   56.908480] sunxi-mmc sdc2: *****retry:start*****
      [   56.913774] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   56.919936] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.925882] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   56.932122] sunxi-mmc sdc2: *****retry:start*****
      [   56.937429] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   56.943589] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.949589] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   56.955833] sunxi-mmc sdc2: *****retry:start*****
      [   56.961125] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   56.967286] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.973282] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   56.979525] sunxi-mmc sdc2: *****retry:start*****
      [   56.984819] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   56.990978] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   56.996922] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.003167] sunxi-mmc sdc2: *****retry:start*****
      [   57.008464] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   57.014630] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.020575] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.026818] sunxi-mmc sdc2: *****retry:start*****
      [   57.032109] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   57.038268] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.044265] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.050568] sunxi-mmc sdc2: *****retry:start*****
      [   57.055867] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   57.062020] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.067968] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.074209] sunxi-mmc sdc2: *****retry:start*****
      [   57.079502] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   57.085663] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.091660] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.097906] sunxi-mmc sdc2: *****retry:start*****
      [   57.103196] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   57.109356] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.115355] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.121598] sunxi-mmc sdc2: *****retry:start*****
      [   57.126888] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   57.133041] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.139038] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.145280] sunxi-mmc sdc2: *****retry:start*****
      [   57.150570] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   57.156725] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.162671] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.168914] sunxi-mmc sdc2: *****retry:start*****
      [   57.174206] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   57.180360] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.186305] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.192547] sunxi-mmc sdc2: *****retry:start*****
      [   57.197839] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   57.203996] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.209995] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.216238] sunxi-mmc sdc2: *****retry:start*****
      [   57.221539] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   57.227698] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.233644] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.239891] sunxi-mmc sdc2: *****retry:start*****
      [   57.245183] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   57.251339] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.257283] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.263526] sunxi-mmc sdc2: *****retry:start*****
      [   57.268815] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   57.274970] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.280916] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.287161] sunxi-mmc sdc2: *****retry:start*****
      [   57.292453] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   57.298623] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.304571] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.310816] sunxi-mmc sdc2: *****retry:start*****
      [   57.316109] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   57.322268] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.328215] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.334459] sunxi-mmc sdc2: *****retry:start*****
      [   57.339763] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   57.345919] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.351864] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.358107] sunxi-mmc sdc2: *****retry:start*****
      [   57.363398] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   57.369564] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.375507] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.381754] sunxi-mmc sdc2: *****retry:start*****
      [   57.387049] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   57.393208] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.399154] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.405394] sunxi-mmc sdc2: *****retry:start*****
      [   57.410686] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   57.416847] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.422843] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.429087] sunxi-mmc sdc2: *****retry:start*****
      [   57.434380] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   57.440538] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.446539] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.452781] sunxi-mmc sdc2: *****retry:start*****
      [   57.458076] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   57.464231] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.470180] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.476425] sunxi-mmc sdc2: *****retry:start*****
      [   57.481717] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   57.487874] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.493821] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.500062] sunxi-mmc sdc2: *****retry:start*****
      [   57.505364] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   57.511524] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.517522] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.523766] sunxi-mmc sdc2: *****retry:start*****
      [   57.529061] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   57.535216] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.541162] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.547405] sunxi-mmc sdc2: *****retry:start*****
      [   57.552697] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   57.558850] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.564795] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.571038] sunxi-mmc sdc2: *****retry:start*****
      [   57.576327] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   57.582483] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.588431] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.594674] sunxi-mmc sdc2: *****retry:start*****
      [   57.599965] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   57.606124] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.612122] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.618367] sunxi-mmc sdc2: *****retry:start*****
      [   57.623649] sunxi-mmc sdc2: send  manual stop command failed
      [   57.630006] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   57.636160] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.642158] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   57.648398] sunxi-mmc sdc2: *****retry:start*****
      [   57.653690] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   57.659448] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   57.666763] sunxi-mmc sdc2: retry:give up
      [   57.671324] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   57.679847] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   57.692191] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   57.717158] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   57.743825] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   57.754605] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   57.767804] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   57.795077] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   57.807188] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   57.818296] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   57.829374] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   57.840431] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   57.847022] sunxi-mmc sdc2: *****retry:start*****
      [   57.852312] sunxi-mmc sdc2: send  manual stop command failed
      [   57.858671] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   57.864836] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.870681] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   57.877216] sunxi-mmc sdc2: *****retry:start*****
      [   57.882499] sunxi-mmc sdc2: send  manual stop command failed
      [   57.888863] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   57.895013] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.900861] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   57.907394] sunxi-mmc sdc2: *****retry:start*****
      [   57.912673] sunxi-mmc sdc2: send  manual stop command failed
      [   57.919034] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   57.925187] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.931034] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   57.937570] sunxi-mmc sdc2: *****retry:start*****
      [   57.942851] sunxi-mmc sdc2: send  manual stop command failed
      [   57.949220] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   57.955373] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.961220] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   57.967753] sunxi-mmc sdc2: *****retry:start*****
      [   57.973040] sunxi-mmc sdc2: send  manual stop command failed
      [   57.979397] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   57.985548] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   57.991396] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   57.997932] sunxi-mmc sdc2: *****retry:start*****
      [   58.003214] sunxi-mmc sdc2: send  manual stop command failed
      [   58.009570] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   58.015723] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.021568] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.028104] sunxi-mmc sdc2: *****retry:start*****
      [   58.033385] sunxi-mmc sdc2: send  manual stop command failed
      [   58.039748] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   58.045901] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.051747] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.058284] sunxi-mmc sdc2: *****retry:start*****
      [   58.063571] sunxi-mmc sdc2: send  manual stop command failed
      [   58.069937] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   58.076090] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.081933] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.088473] sunxi-mmc sdc2: *****retry:start*****
      [   58.093755] sunxi-mmc sdc2: send  manual stop command failed
      [   58.100121] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   58.106275] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.112121] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.118655] sunxi-mmc sdc2: *****retry:start*****
      [   58.123938] sunxi-mmc sdc2: send  manual stop command failed
      [   58.130297] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   58.136447] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.142293] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.148825] sunxi-mmc sdc2: *****retry:start*****
      [   58.154106] sunxi-mmc sdc2: send  manual stop command failed
      [   58.160462] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   58.166626] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.172473] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.179009] sunxi-mmc sdc2: *****retry:start*****
      [   58.184288] sunxi-mmc sdc2: send  manual stop command failed
      [   58.190653] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   58.196801] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.202648] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.209183] sunxi-mmc sdc2: *****retry:start*****
      [   58.214466] sunxi-mmc sdc2: send  manual stop command failed
      [   58.220828] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   58.226981] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.232825] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.239364] sunxi-mmc sdc2: *****retry:start*****
      [   58.244645] sunxi-mmc sdc2: send  manual stop command failed
      [   58.251007] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   58.257160] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.263007] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.269541] sunxi-mmc sdc2: *****retry:start*****
      [   58.274828] sunxi-mmc sdc2: send  manual stop command failed
      [   58.281202] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   58.287352] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.293202] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.299737] sunxi-mmc sdc2: *****retry:start*****
      [   58.305019] sunxi-mmc sdc2: send  manual stop command failed
      [   58.311384] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   58.317535] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.323383] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.329914] sunxi-mmc sdc2: *****retry:start*****
      [   58.335198] sunxi-mmc sdc2: send  manual stop command failed
      [   58.341558] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   58.347712] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.353558] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.360094] sunxi-mmc sdc2: *****retry:start*****
      [   58.365377] sunxi-mmc sdc2: send  manual stop command failed
      [   58.371740] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   58.377892] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.383738] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.390267] sunxi-mmc sdc2: *****retry:start*****
      [   58.395556] sunxi-mmc sdc2: send  manual stop command failed
      [   58.401915] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   58.408067] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.413910] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.420446] sunxi-mmc sdc2: *****retry:start*****
      [   58.425725] sunxi-mmc sdc2: send  manual stop command failed
      [   58.432089] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   58.438233] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.444080] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.450613] sunxi-mmc sdc2: *****retry:start*****
      [   58.455894] sunxi-mmc sdc2: send  manual stop command failed
      [   58.462256] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   58.468418] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.474265] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.480797] sunxi-mmc sdc2: *****retry:start*****
      [   58.486078] sunxi-mmc sdc2: send  manual stop command failed
      [   58.492446] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   58.498612] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.504461] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.510997] sunxi-mmc sdc2: *****retry:start*****
      [   58.516277] sunxi-mmc sdc2: send  manual stop command failed
      [   58.522631] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   58.528786] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.534631] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.541165] sunxi-mmc sdc2: *****retry:start*****
      [   58.546445] sunxi-mmc sdc2: send  manual stop command failed
      [   58.552808] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   58.558960] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.564809] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.571342] sunxi-mmc sdc2: *****retry:start*****
      [   58.576623] sunxi-mmc sdc2: send  manual stop command failed
      [   58.582978] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   58.589130] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.594975] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.601508] sunxi-mmc sdc2: *****retry:start*****
      [   58.606787] sunxi-mmc sdc2: send  manual stop command failed
      [   58.613146] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   58.619302] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.625148] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.631685] sunxi-mmc sdc2: *****retry:start*****
      [   58.636970] sunxi-mmc sdc2: send  manual stop command failed
      [   58.643330] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   58.649485] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.655331] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.661866] sunxi-mmc sdc2: *****retry:start*****
      [   58.667154] sunxi-mmc sdc2: send  manual stop command failed
      [   58.673511] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   58.679658] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.685505] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.692037] sunxi-mmc sdc2: *****retry:start*****
      [   58.697322] sunxi-mmc sdc2: send  manual stop command failed
      [   58.703675] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   58.709827] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.715672] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.722206] sunxi-mmc sdc2: *****retry:start*****
      [   58.727484] sunxi-mmc sdc2: send  manual stop command failed
      [   58.733855] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   58.740008] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.745851] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.752389] sunxi-mmc sdc2: *****retry:start*****
      [   58.757675] sunxi-mmc sdc2: send  manual stop command failed
      [   58.764034] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   58.770197] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.776045] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.782584] sunxi-mmc sdc2: *****retry:start*****
      [   58.787862] sunxi-mmc sdc2: send  manual stop command failed
      [   58.794224] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   58.800376] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.806224] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.812758] sunxi-mmc sdc2: *****retry:start*****
      [   58.818040] sunxi-mmc sdc2: send  manual stop command failed
      [   58.824400] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   58.830157] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   58.837478] sunxi-mmc sdc2: retry:give up
      [   58.841982] mmc0: switch to bus width 8 failed
      [   58.847096] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [   58.858159] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.864740] sunxi-mmc sdc2: *****retry:start*****
      [   58.870036] sunxi-mmc sdc2: send  manual stop command failed
      [   58.876400] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   58.882554] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.888403] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.894992] sunxi-mmc sdc2: *****retry:start*****
      [   58.900273] sunxi-mmc sdc2: send  manual stop command failed
      [   58.906636] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   58.912789] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.918636] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.925168] sunxi-mmc sdc2: *****retry:start*****
      [   58.930458] sunxi-mmc sdc2: send  manual stop command failed
      [   58.936822] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   58.942976] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.948820] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.955356] sunxi-mmc sdc2: *****retry:start*****
      [   58.960636] sunxi-mmc sdc2: send  manual stop command failed
      [   58.967013] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   58.973166] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   58.979015] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   58.985549] sunxi-mmc sdc2: *****retry:start*****
      [   58.990829] sunxi-mmc sdc2: send  manual stop command failed
      [   58.997185] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   59.003336] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.009183] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.015721] sunxi-mmc sdc2: *****retry:start*****
      [   59.021006] sunxi-mmc sdc2: send  manual stop command failed
      [   59.027372] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   59.033525] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.039372] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.045905] sunxi-mmc sdc2: *****retry:start*****
      [   59.051186] sunxi-mmc sdc2: send  manual stop command failed
      [   59.057544] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   59.063695] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.069542] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.076079] sunxi-mmc sdc2: *****retry:start*****
      [   59.081364] sunxi-mmc sdc2: send  manual stop command failed
      [   59.087726] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   59.093874] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.099720] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.106256] sunxi-mmc sdc2: *****retry:start*****
      [   59.111549] sunxi-mmc sdc2: send  manual stop command failed
      [   59.117906] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   59.124057] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.129902] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.136439] sunxi-mmc sdc2: *****retry:start*****
      [   59.141719] sunxi-mmc sdc2: send  manual stop command failed
      [   59.148094] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   59.154246] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.160091] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.166622] sunxi-mmc sdc2: *****retry:start*****
      [   59.171905] sunxi-mmc sdc2: send  manual stop command failed
      [   59.178265] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   59.184431] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.190279] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.196814] sunxi-mmc sdc2: *****retry:start*****
      [   59.202096] sunxi-mmc sdc2: send  manual stop command failed
      [   59.208462] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   59.214610] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.220456] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.226990] sunxi-mmc sdc2: *****retry:start*****
      [   59.232272] sunxi-mmc sdc2: send  manual stop command failed
      [   59.238632] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   59.244776] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.250621] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.257157] sunxi-mmc sdc2: *****retry:start*****
      [   59.262435] sunxi-mmc sdc2: send  manual stop command failed
      [   59.268807] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   59.274957] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.280804] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.287337] sunxi-mmc sdc2: *****retry:start*****
      [   59.292619] sunxi-mmc sdc2: send  manual stop command failed
      [   59.298981] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   59.305134] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.310978] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.317514] sunxi-mmc sdc2: *****retry:start*****
      [   59.322795] sunxi-mmc sdc2: send  manual stop command failed
      [   59.329155] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   59.335308] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.341155] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.347736] sunxi-mmc sdc2: *****retry:start*****
      [   59.353017] sunxi-mmc sdc2: send  manual stop command failed
      [   59.359379] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   59.365544] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.371389] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.377925] sunxi-mmc sdc2: *****retry:start*****
      [   59.383203] sunxi-mmc sdc2: send  manual stop command failed
      [   59.389561] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   59.395713] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.401560] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.408096] sunxi-mmc sdc2: *****retry:start*****
      [   59.413375] sunxi-mmc sdc2: send  manual stop command failed
      [   59.419730] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   59.425883] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.431726] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.438262] sunxi-mmc sdc2: *****retry:start*****
      [   59.443541] sunxi-mmc sdc2: send  manual stop command failed
      [   59.449899] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   59.456050] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.461894] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.468426] sunxi-mmc sdc2: *****retry:start*****
      [   59.473705] sunxi-mmc sdc2: send  manual stop command failed
      [   59.480063] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   59.486226] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.492073] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.498605] sunxi-mmc sdc2: *****retry:start*****
      [   59.503889] sunxi-mmc sdc2: send  manual stop command failed
      [   59.510248] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   59.516399] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.522247] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.528780] sunxi-mmc sdc2: *****retry:start*****
      [   59.534065] sunxi-mmc sdc2: send  manual stop command failed
      [   59.540424] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   59.546578] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.552424] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.558960] sunxi-mmc sdc2: *****retry:start*****
      [   59.564237] sunxi-mmc sdc2: send  manual stop command failed
      [   59.570594] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   59.576747] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.582595] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.589131] sunxi-mmc sdc2: *****retry:start*****
      [   59.594410] sunxi-mmc sdc2: send  manual stop command failed
      [   59.600767] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   59.606918] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.612766] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.619299] sunxi-mmc sdc2: *****retry:start*****
      [   59.624579] sunxi-mmc sdc2: send  manual stop command failed
      [   59.630941] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   59.637093] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.642941] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.649472] sunxi-mmc sdc2: *****retry:start*****
      [   59.654755] sunxi-mmc sdc2: send  manual stop command failed
      [   59.661111] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   59.667262] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.673107] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.679643] sunxi-mmc sdc2: *****retry:start*****
      [   59.684921] sunxi-mmc sdc2: send  manual stop command failed
      [   59.691281] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   59.697433] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.703282] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.709818] sunxi-mmc sdc2: *****retry:start*****
      [   59.715100] sunxi-mmc sdc2: send  manual stop command failed
      [   59.721461] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   59.727613] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.733457] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.739992] sunxi-mmc sdc2: *****retry:start*****
      [   59.745271] sunxi-mmc sdc2: send  manual stop command failed
      [   59.751647] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   59.757799] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.763646] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.770182] sunxi-mmc sdc2: *****retry:start*****
      [   59.775463] sunxi-mmc sdc2: send  manual stop command failed
      [   59.781827] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   59.787980] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.793826] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.800360] sunxi-mmc sdc2: *****retry:start*****
      [   59.805636] sunxi-mmc sdc2: send  manual stop command failed
      [   59.812000] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   59.818149] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.823996] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   59.830533] sunxi-mmc sdc2: *****retry:start*****
      [   59.835813] sunxi-mmc sdc2: send  manual stop command failed
      [   59.842166] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   59.847934] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   59.855255] sunxi-mmc sdc2: retry:give up
      [   59.859761] mmc0: switch to bus width 4 failed
      [   59.891705] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   59.898025] sunxi-mmc sdc2: *****retry:start*****
      [   59.903347] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   59.909522] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.915469] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   59.921714] sunxi-mmc sdc2: *****retry:start*****
      [   59.927015] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   59.933193] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.939191] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   59.945433] sunxi-mmc sdc2: *****retry:start*****
      [   59.950729] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   59.956887] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.962885] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   59.969130] sunxi-mmc sdc2: *****retry:start*****
      [   59.974423] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   59.980587] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   59.986516] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD SBE !!
      [   59.992762] sunxi-mmc sdc2: *****retry:start*****
      [   59.998042] sunxi-mmc sdc2: send  manual stop command failed
      [   60.004403] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   60.010557] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.016503] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.022748] sunxi-mmc sdc2: *****retry:start*****
      [   60.028042] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   60.034202] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.040148] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.046392] sunxi-mmc sdc2: *****retry:start*****
      [   60.051689] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   60.057844] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.063791] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.070035] sunxi-mmc sdc2: *****retry:start*****
      [   60.075326] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   60.081482] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.087427] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.093669] sunxi-mmc sdc2: *****retry:start*****
      [   60.098966] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   60.105121] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.111067] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.117308] sunxi-mmc sdc2: *****retry:start*****
      [   60.122599] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   60.128757] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.134702] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.140944] sunxi-mmc sdc2: *****retry:start*****
      [   60.146233] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   60.152392] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.158337] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.164576] sunxi-mmc sdc2: *****retry:start*****
      [   60.169869] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   60.176029] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.182029] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.188327] sunxi-mmc sdc2: *****retry:start*****
      [   60.193628] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   60.199783] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.205785] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.212028] sunxi-mmc sdc2: *****retry:start*****
      [   60.217335] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   60.223495] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.229445] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.235685] sunxi-mmc sdc2: *****retry:start*****
      [   60.240984] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   60.247137] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.253081] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.259324] sunxi-mmc sdc2: *****retry:start*****
      [   60.264617] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   60.270778] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.276722] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.282964] sunxi-mmc sdc2: *****retry:start*****
      [   60.288261] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   60.294415] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.300363] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.306605] sunxi-mmc sdc2: *****retry:start*****
      [   60.311901] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   60.318061] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.324059] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.330300] sunxi-mmc sdc2: *****retry:start*****
      [   60.335593] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   60.341747] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.347694] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.353936] sunxi-mmc sdc2: *****retry:start*****
      [   60.359228] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   60.365380] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.371381] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.377624] sunxi-mmc sdc2: *****retry:start*****
      [   60.382916] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   60.389069] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.395015] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.401258] sunxi-mmc sdc2: *****retry:start*****
      [   60.406564] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   60.412723] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.418671] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.424915] sunxi-mmc sdc2: *****retry:start*****
      [   60.430209] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   60.436369] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.442315] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.448559] sunxi-mmc sdc2: *****retry:start*****
      [   60.453866] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   60.460020] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.465944] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD SBE !!
      [   60.472241] sunxi-mmc sdc2: *****retry:start*****
      [   60.477524] sunxi-mmc sdc2: send  manual stop command failed
      [   60.483902] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   60.490062] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.496008] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.502253] sunxi-mmc sdc2: *****retry:start*****
      [   60.507547] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   60.513701] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.519646] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.525893] sunxi-mmc sdc2: *****retry:start*****
      [   60.531187] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   60.537347] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.543289] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.549533] sunxi-mmc sdc2: *****retry:start*****
      [   60.554831] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   60.560988] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.566934] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.573177] sunxi-mmc sdc2: *****retry:start*****
      [   60.578471] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   60.584632] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.590578] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.596819] sunxi-mmc sdc2: *****retry:start*****
      [   60.602112] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   60.608274] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.614265] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.620509] sunxi-mmc sdc2: *****retry:start*****
      [   60.625793] sunxi-mmc sdc2: send  manual stop command failed
      [   60.632149] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   60.638301] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.644306] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.650609] sunxi-mmc sdc2: *****retry:start*****
      [   60.655893] sunxi-mmc sdc2: send  manual stop command failed
      [   60.662257] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   60.668414] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.674358] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   60.680603] sunxi-mmc sdc2: *****retry:start*****
      [   60.685896] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   60.691661] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   60.698987] sunxi-mmc sdc2: retry:give up
      [   60.703533] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   60.712098] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   60.724436] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   60.750491] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   60.780494] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   60.791273] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   60.804483] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   60.831688] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   60.843804] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   60.854931] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   60.866019] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   60.877067] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   60.883658] sunxi-mmc sdc2: *****retry:start*****
      [   60.888941] sunxi-mmc sdc2: send  manual stop command failed
      [   60.895304] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   60.901469] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.907316] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   60.913902] sunxi-mmc sdc2: *****retry:start*****
      [   60.919186] sunxi-mmc sdc2: send  manual stop command failed
      [   60.925546] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   60.931710] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.937556] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   60.944148] sunxi-mmc sdc2: *****retry:start*****
      [   60.949439] sunxi-mmc sdc2: send  manual stop command failed
      [   60.955800] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   60.961951] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.967798] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   60.974388] sunxi-mmc sdc2: *****retry:start*****
      [   60.979679] sunxi-mmc sdc2: send  manual stop command failed
      [   60.986055] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   60.992208] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   60.998053] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.004646] sunxi-mmc sdc2: *****retry:start*****
      [   61.009932] sunxi-mmc sdc2: send  manual stop command failed
      [   61.016296] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   61.022447] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.028292] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.034824] sunxi-mmc sdc2: *****retry:start*****
      [   61.040105] sunxi-mmc sdc2: send  manual stop command failed
      [   61.046466] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   61.052619] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.058464] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.065000] sunxi-mmc sdc2: *****retry:start*****
      [   61.070281] sunxi-mmc sdc2: send  manual stop command failed
      [   61.076644] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   61.082795] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.088643] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.095176] sunxi-mmc sdc2: *****retry:start*****
      [   61.100457] sunxi-mmc sdc2: send  manual stop command failed
      [   61.106811] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   61.112961] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.118808] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.125344] sunxi-mmc sdc2: *****retry:start*****
      [   61.130623] sunxi-mmc sdc2: send  manual stop command failed
      [   61.136989] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   61.143142] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.148986] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.155521] sunxi-mmc sdc2: *****retry:start*****
      [   61.160803] sunxi-mmc sdc2: send  manual stop command failed
      [   61.167171] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   61.173319] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.179165] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.185700] sunxi-mmc sdc2: *****retry:start*****
      [   61.190979] sunxi-mmc sdc2: send  manual stop command failed
      [   61.197347] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   61.203497] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.209345] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.215877] sunxi-mmc sdc2: *****retry:start*****
      [   61.221153] sunxi-mmc sdc2: send  manual stop command failed
      [   61.227514] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   61.233666] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.239511] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.246099] sunxi-mmc sdc2: *****retry:start*****
      [   61.251385] sunxi-mmc sdc2: send  manual stop command failed
      [   61.257749] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   61.263902] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.269748] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.276283] sunxi-mmc sdc2: *****retry:start*****
      [   61.281564] sunxi-mmc sdc2: send  manual stop command failed
      [   61.287925] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   61.294076] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.299923] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.306458] sunxi-mmc sdc2: *****retry:start*****
      [   61.311739] sunxi-mmc sdc2: send  manual stop command failed
      [   61.318102] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   61.324243] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.330095] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.336631] sunxi-mmc sdc2: *****retry:start*****
      [   61.341914] sunxi-mmc sdc2: send  manual stop command failed
      [   61.348284] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   61.354435] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.360278] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.366811] sunxi-mmc sdc2: *****retry:start*****
      [   61.372090] sunxi-mmc sdc2: send  manual stop command failed
      [   61.378453] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   61.384614] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.390461] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.396996] sunxi-mmc sdc2: *****retry:start*****
      [   61.402286] sunxi-mmc sdc2: send  manual stop command failed
      [   61.408648] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   61.414812] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.420657] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.427192] sunxi-mmc sdc2: *****retry:start*****
      [   61.432472] sunxi-mmc sdc2: send  manual stop command failed
      [   61.438835] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   61.444979] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.450828] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.457361] sunxi-mmc sdc2: *****retry:start*****
      [   61.462644] sunxi-mmc sdc2: send  manual stop command failed
      [   61.469001] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   61.475153] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.480998] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.487535] sunxi-mmc sdc2: *****retry:start*****
      [   61.492813] sunxi-mmc sdc2: send  manual stop command failed
      [   61.499186] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   61.505343] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.511190] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.517722] sunxi-mmc sdc2: *****retry:start*****
      [   61.523002] sunxi-mmc sdc2: send  manual stop command failed
      [   61.529361] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   61.535516] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.541360] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.547946] sunxi-mmc sdc2: *****retry:start*****
      [   61.553228] sunxi-mmc sdc2: send  manual stop command failed
      [   61.559593] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   61.565745] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.571594] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.578128] sunxi-mmc sdc2: *****retry:start*****
      [   61.583406] sunxi-mmc sdc2: send  manual stop command failed
      [   61.589766] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   61.595919] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.601765] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.608300] sunxi-mmc sdc2: *****retry:start*****
      [   61.613579] sunxi-mmc sdc2: send  manual stop command failed
      [   61.619937] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   61.626092] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.631940] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.638475] sunxi-mmc sdc2: *****retry:start*****
      [   61.643753] sunxi-mmc sdc2: send  manual stop command failed
      [   61.650126] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   61.656279] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.662123] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.668658] sunxi-mmc sdc2: *****retry:start*****
      [   61.673937] sunxi-mmc sdc2: send  manual stop command failed
      [   61.680294] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   61.686441] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.692289] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.698823] sunxi-mmc sdc2: *****retry:start*****
      [   61.704105] sunxi-mmc sdc2: send  manual stop command failed
      [   61.710464] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   61.716617] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.722461] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.728995] sunxi-mmc sdc2: *****retry:start*****
      [   61.734274] sunxi-mmc sdc2: send  manual stop command failed
      [   61.740636] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   61.746789] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.752633] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.759168] sunxi-mmc sdc2: *****retry:start*****
      [   61.764455] sunxi-mmc sdc2: send  manual stop command failed
      [   61.770815] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   61.776968] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.782817] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.789350] sunxi-mmc sdc2: *****retry:start*****
      [   61.794630] sunxi-mmc sdc2: send  manual stop command failed
      [   61.800998] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   61.807154] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.813000] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.819536] sunxi-mmc sdc2: *****retry:start*****
      [   61.824818] sunxi-mmc sdc2: send  manual stop command failed
      [   61.831177] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   61.837329] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.843173] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.849709] sunxi-mmc sdc2: *****retry:start*****
      [   61.854988] sunxi-mmc sdc2: send  manual stop command failed
      [   61.861353] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   61.867123] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   61.874445] sunxi-mmc sdc2: retry:give up
      [   61.878948] mmc0: switch to bus width 8 failed
      [   61.884035] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [   61.895157] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.901693] sunxi-mmc sdc2: *****retry:start*****
      [   61.906975] sunxi-mmc sdc2: send  manual stop command failed
      [   61.913347] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   61.919511] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.925358] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.931890] sunxi-mmc sdc2: *****retry:start*****
      [   61.937174] sunxi-mmc sdc2: send  manual stop command failed
      [   61.943530] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   61.949691] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.955539] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.962074] sunxi-mmc sdc2: *****retry:start*****
      [   61.967352] sunxi-mmc sdc2: send  manual stop command failed
      [   61.973709] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   61.979859] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   61.985704] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   61.992240] sunxi-mmc sdc2: *****retry:start*****
      [   61.997521] sunxi-mmc sdc2: send  manual stop command failed
      [   62.003882] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   62.010032] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.015876] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.022411] sunxi-mmc sdc2: *****retry:start*****
      [   62.027691] sunxi-mmc sdc2: send  manual stop command failed
      [   62.034061] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   62.040211] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.046058] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.052591] sunxi-mmc sdc2: *****retry:start*****
      [   62.057870] sunxi-mmc sdc2: send  manual stop command failed
      [   62.064234] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   62.070398] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.076240] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.082777] sunxi-mmc sdc2: *****retry:start*****
      [   62.088061] sunxi-mmc sdc2: send  manual stop command failed
      [   62.094423] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   62.100587] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.106434] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.112969] sunxi-mmc sdc2: *****retry:start*****
      [   62.118250] sunxi-mmc sdc2: send  manual stop command failed
      [   62.124608] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   62.130763] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.136606] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.143198] sunxi-mmc sdc2: *****retry:start*****
      [   62.148480] sunxi-mmc sdc2: send  manual stop command failed
      [   62.154844] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   62.161000] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.166848] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.173380] sunxi-mmc sdc2: *****retry:start*****
      [   62.178663] sunxi-mmc sdc2: send  manual stop command failed
      [   62.185032] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   62.191187] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.197034] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.203570] sunxi-mmc sdc2: *****retry:start*****
      [   62.208850] sunxi-mmc sdc2: send  manual stop command failed
      [   62.215226] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   62.221381] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.227226] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.233761] sunxi-mmc sdc2: *****retry:start*****
      [   62.239041] sunxi-mmc sdc2: send  manual stop command failed
      [   62.245399] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   62.251559] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.257405] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.263940] sunxi-mmc sdc2: *****retry:start*****
      [   62.269219] sunxi-mmc sdc2: send  manual stop command failed
      [   62.275580] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   62.281731] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.287577] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.294113] sunxi-mmc sdc2: *****retry:start*****
      [   62.299394] sunxi-mmc sdc2: send  manual stop command failed
      [   62.305753] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   62.311905] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.317749] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.324287] sunxi-mmc sdc2: *****retry:start*****
      [   62.329565] sunxi-mmc sdc2: send  manual stop command failed
      [   62.335923] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   62.342075] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.347924] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.354455] sunxi-mmc sdc2: *****retry:start*****
      [   62.359733] sunxi-mmc sdc2: send  manual stop command failed
      [   62.366106] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   62.372262] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.378110] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.384649] sunxi-mmc sdc2: *****retry:start*****
      [   62.389927] sunxi-mmc sdc2: send  manual stop command failed
      [   62.396291] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   62.402454] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.408302] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.414837] sunxi-mmc sdc2: *****retry:start*****
      [   62.420120] sunxi-mmc sdc2: send  manual stop command failed
      [   62.426477] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   62.432631] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.438478] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.445015] sunxi-mmc sdc2: *****retry:start*****
      [   62.450294] sunxi-mmc sdc2: send  manual stop command failed
      [   62.456654] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   62.462806] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.468653] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.475187] sunxi-mmc sdc2: *****retry:start*****
      [   62.480466] sunxi-mmc sdc2: send  manual stop command failed
      [   62.486835] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   62.492989] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.498837] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.505369] sunxi-mmc sdc2: *****retry:start*****
      [   62.510650] sunxi-mmc sdc2: send  manual stop command failed
      [   62.517006] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   62.523158] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.529004] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.535537] sunxi-mmc sdc2: *****retry:start*****
      [   62.540821] sunxi-mmc sdc2: send  manual stop command failed
      [   62.547180] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   62.553331] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.559178] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.565712] sunxi-mmc sdc2: *****retry:start*****
      [   62.570991] sunxi-mmc sdc2: send  manual stop command failed
      [   62.577355] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   62.583505] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.589351] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.595881] sunxi-mmc sdc2: *****retry:start*****
      [   62.601161] sunxi-mmc sdc2: send  manual stop command failed
      [   62.607522] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   62.613674] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.619518] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.626050] sunxi-mmc sdc2: *****retry:start*****
      [   62.631329] sunxi-mmc sdc2: send  manual stop command failed
      [   62.637693] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   62.643847] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.649692] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.656226] sunxi-mmc sdc2: *****retry:start*****
      [   62.661509] sunxi-mmc sdc2: send  manual stop command failed
      [   62.667870] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   62.674025] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.679868] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.686402] sunxi-mmc sdc2: *****retry:start*****
      [   62.691683] sunxi-mmc sdc2: send  manual stop command failed
      [   62.698045] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   62.704198] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.710044] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.716579] sunxi-mmc sdc2: *****retry:start*****
      [   62.721861] sunxi-mmc sdc2: send  manual stop command failed
      [   62.728221] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   62.734385] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.740230] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.746766] sunxi-mmc sdc2: *****retry:start*****
      [   62.752044] sunxi-mmc sdc2: send  manual stop command failed
      [   62.758406] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   62.764551] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.770400] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.776935] sunxi-mmc sdc2: *****retry:start*****
      [   62.782218] sunxi-mmc sdc2: send  manual stop command failed
      [   62.788578] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   62.794734] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.800579] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.807112] sunxi-mmc sdc2: *****retry:start*****
      [   62.812390] sunxi-mmc sdc2: send  manual stop command failed
      [   62.818764] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   62.824915] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.830766] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.837302] sunxi-mmc sdc2: *****retry:start*****
      [   62.842584] sunxi-mmc sdc2: send  manual stop command failed
      [   62.848942] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   62.855096] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   62.860939] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   62.867473] sunxi-mmc sdc2: *****retry:start*****
      [   62.872754] sunxi-mmc sdc2: send  manual stop command failed
      [   62.879110] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   62.884866] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   62.892189] sunxi-mmc sdc2: retry:give up
      [   62.896693] mmc0: switch to bus width 4 failed
      [   63.023302] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.029568] sunxi-mmc sdc2: *****retry:start*****
      [   63.034904] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   63.041080] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.047026] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.053267] sunxi-mmc sdc2: *****retry:start*****
      [   63.058564] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   63.064724] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.070671] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.076919] sunxi-mmc sdc2: *****retry:start*****
      [   63.082217] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   63.088366] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.094314] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.100559] sunxi-mmc sdc2: *****retry:start*****
      [   63.105865] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   63.112022] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.117972] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.124220] sunxi-mmc sdc2: *****retry:start*****
      [   63.129517] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   63.135667] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.141615] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.147860] sunxi-mmc sdc2: *****retry:start*****
      [   63.153156] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   63.159312] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.165259] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.171504] sunxi-mmc sdc2: *****retry:start*****
      [   63.176800] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   63.182952] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.188895] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.195137] sunxi-mmc sdc2: *****retry:start*****
      [   63.200431] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   63.206588] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.212532] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.218775] sunxi-mmc sdc2: *****retry:start*****
      [   63.224074] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   63.230227] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.236175] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.242417] sunxi-mmc sdc2: *****retry:start*****
      [   63.247711] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   63.253877] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.259823] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.266067] sunxi-mmc sdc2: *****retry:start*****
      [   63.271365] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   63.277514] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.283463] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.289699] sunxi-mmc sdc2: *****retry:start*****
      [   63.294993] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   63.301149] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.307096] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.313336] sunxi-mmc sdc2: *****retry:start*****
      [   63.318631] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   63.324783] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.330783] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.337026] sunxi-mmc sdc2: *****retry:start*****
      [   63.342320] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   63.348475] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.354422] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.360723] sunxi-mmc sdc2: *****retry:start*****
      [   63.366033] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   63.372191] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.378139] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.384382] sunxi-mmc sdc2: *****retry:start*****
      [   63.389674] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   63.395825] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.401825] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.408064] sunxi-mmc sdc2: *****retry:start*****
      [   63.413356] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   63.419508] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.425452] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.431694] sunxi-mmc sdc2: *****retry:start*****
      [   63.436991] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   63.443148] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.449095] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.455336] sunxi-mmc sdc2: *****retry:start*****
      [   63.460629] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   63.466787] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.472736] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.478975] sunxi-mmc sdc2: *****retry:start*****
      [   63.484269] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   63.490425] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.496371] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.502615] sunxi-mmc sdc2: *****retry:start*****
      [   63.507927] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   63.514083] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.520082] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.526325] sunxi-mmc sdc2: *****retry:start*****
      [   63.531620] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   63.537775] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.543719] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.550015] sunxi-mmc sdc2: *****retry:start*****
      [   63.555311] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   63.561470] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.567417] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.573660] sunxi-mmc sdc2: *****retry:start*****
      [   63.578955] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   63.585111] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.591060] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.597299] sunxi-mmc sdc2: *****retry:start*****
      [   63.602593] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   63.608752] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.614697] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.620936] sunxi-mmc sdc2: *****retry:start*****
      [   63.626230] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   63.632388] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.638338] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.644581] sunxi-mmc sdc2: *****retry:start*****
      [   63.649879] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   63.656036] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.661982] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.668223] sunxi-mmc sdc2: *****retry:start*****
      [   63.673515] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   63.679674] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.685620] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.691916] sunxi-mmc sdc2: *****retry:start*****
      [   63.697213] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   63.703369] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.709314] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.715557] sunxi-mmc sdc2: *****retry:start*****
      [   63.720863] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   63.727017] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.732966] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.739263] sunxi-mmc sdc2: *****retry:start*****
      [   63.744548] sunxi-mmc sdc2: send  manual stop command failed
      [   63.750911] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   63.757064] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.763012] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.769309] sunxi-mmc sdc2: *****retry:start*****
      [   63.774592] sunxi-mmc sdc2: send  manual stop command failed
      [   63.780953] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   63.787105] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   63.793052] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   63.799351] sunxi-mmc sdc2: *****retry:start*****
      [   63.804647] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   63.810405] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   63.817730] sunxi-mmc sdc2: retry:give up
      [   63.822272] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   63.830841] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   63.843181] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   63.867157] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   63.893822] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   63.904608] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   63.917760] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   63.945022] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   63.957130] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   63.968251] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   63.979389] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   63.990445] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   63.996970] sunxi-mmc sdc2: *****retry:start*****
      [   64.002252] sunxi-mmc sdc2: send  manual stop command failed
      [   64.008615] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   64.014769] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.020612] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.027149] sunxi-mmc sdc2: *****retry:start*****
      [   64.032440] sunxi-mmc sdc2: send  manual stop command failed
      [   64.038801] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   64.044951] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.050800] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.057331] sunxi-mmc sdc2: *****retry:start*****
      [   64.062611] sunxi-mmc sdc2: send  manual stop command failed
      [   64.068979] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   64.075133] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.080978] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.087515] sunxi-mmc sdc2: *****retry:start*****
      [   64.092795] sunxi-mmc sdc2: send  manual stop command failed
      [   64.099162] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   64.105316] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.111161] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.117696] sunxi-mmc sdc2: *****retry:start*****
      [   64.122977] sunxi-mmc sdc2: send  manual stop command failed
      [   64.129334] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   64.135486] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.141334] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.147871] sunxi-mmc sdc2: *****retry:start*****
      [   64.153152] sunxi-mmc sdc2: send  manual stop command failed
      [   64.159508] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   64.165669] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.171517] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.178051] sunxi-mmc sdc2: *****retry:start*****
      [   64.183332] sunxi-mmc sdc2: send  manual stop command failed
      [   64.189689] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   64.195841] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.201689] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.208225] sunxi-mmc sdc2: *****retry:start*****
      [   64.213511] sunxi-mmc sdc2: send  manual stop command failed
      [   64.219878] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   64.226026] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.231872] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.238405] sunxi-mmc sdc2: *****retry:start*****
      [   64.243686] sunxi-mmc sdc2: send  manual stop command failed
      [   64.250045] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   64.256198] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.262043] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.268578] sunxi-mmc sdc2: *****retry:start*****
      [   64.273861] sunxi-mmc sdc2: send  manual stop command failed
      [   64.280222] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   64.286381] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.292229] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.298762] sunxi-mmc sdc2: *****retry:start*****
      [   64.304046] sunxi-mmc sdc2: send  manual stop command failed
      [   64.310402] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   64.316556] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.322403] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.328939] sunxi-mmc sdc2: *****retry:start*****
      [   64.334223] sunxi-mmc sdc2: send  manual stop command failed
      [   64.340587] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   64.346737] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.352582] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.359117] sunxi-mmc sdc2: *****retry:start*****
      [   64.364401] sunxi-mmc sdc2: send  manual stop command failed
      [   64.370768] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   64.376919] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.382764] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.389355] sunxi-mmc sdc2: *****retry:start*****
      [   64.394645] sunxi-mmc sdc2: send  manual stop command failed
      [   64.401009] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   64.407158] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.413004] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.419540] sunxi-mmc sdc2: *****retry:start*****
      [   64.424823] sunxi-mmc sdc2: send  manual stop command failed
      [   64.431183] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   64.437337] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.443183] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.449717] sunxi-mmc sdc2: *****retry:start*****
      [   64.455000] sunxi-mmc sdc2: send  manual stop command failed
      [   64.461363] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   64.467526] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.473375] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.479907] sunxi-mmc sdc2: *****retry:start*****
      [   64.485187] sunxi-mmc sdc2: send  manual stop command failed
      [   64.491550] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   64.497704] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.503549] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.510084] sunxi-mmc sdc2: *****retry:start*****
      [   64.515366] sunxi-mmc sdc2: send  manual stop command failed
      [   64.521727] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   64.527877] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.533724] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.540259] sunxi-mmc sdc2: *****retry:start*****
      [   64.545541] sunxi-mmc sdc2: send  manual stop command failed
      [   64.551907] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   64.558061] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.563908] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.570441] sunxi-mmc sdc2: *****retry:start*****
      [   64.575720] sunxi-mmc sdc2: send  manual stop command failed
      [   64.582085] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   64.588236] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.594083] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.600616] sunxi-mmc sdc2: *****retry:start*****
      [   64.605895] sunxi-mmc sdc2: send  manual stop command failed
      [   64.612254] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   64.618409] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.624255] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.630789] sunxi-mmc sdc2: *****retry:start*****
      [   64.636068] sunxi-mmc sdc2: send  manual stop command failed
      [   64.642431] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   64.648586] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.654432] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.660968] sunxi-mmc sdc2: *****retry:start*****
      [   64.666248] sunxi-mmc sdc2: send  manual stop command failed
      [   64.672612] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   64.678766] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.684612] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.691145] sunxi-mmc sdc2: *****retry:start*****
      [   64.696425] sunxi-mmc sdc2: send  manual stop command failed
      [   64.702795] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   64.708946] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.714793] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.721327] sunxi-mmc sdc2: *****retry:start*****
      [   64.726607] sunxi-mmc sdc2: send  manual stop command failed
      [   64.732975] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   64.739129] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.744976] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.751511] sunxi-mmc sdc2: *****retry:start*****
      [   64.756791] sunxi-mmc sdc2: send  manual stop command failed
      [   64.763149] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   64.769309] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.775157] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.781690] sunxi-mmc sdc2: *****retry:start*****
      [   64.786970] sunxi-mmc sdc2: send  manual stop command failed
      [   64.793330] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   64.799482] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.805328] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.811863] sunxi-mmc sdc2: *****retry:start*****
      [   64.817153] sunxi-mmc sdc2: send  manual stop command failed
      [   64.823513] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   64.829665] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.835513] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.842046] sunxi-mmc sdc2: *****retry:start*****
      [   64.847330] sunxi-mmc sdc2: send  manual stop command failed
      [   64.853695] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   64.859848] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.865693] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.872227] sunxi-mmc sdc2: *****retry:start*****
      [   64.877507] sunxi-mmc sdc2: send  manual stop command failed
      [   64.883880] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   64.890033] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.895879] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.902413] sunxi-mmc sdc2: *****retry:start*****
      [   64.907696] sunxi-mmc sdc2: send  manual stop command failed
      [   64.914058] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   64.920209] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.926056] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.932593] sunxi-mmc sdc2: *****retry:start*****
      [   64.937874] sunxi-mmc sdc2: send  manual stop command failed
      [   64.944239] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   64.950390] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   64.956238] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   64.962772] sunxi-mmc sdc2: *****retry:start*****
      [   64.968052] sunxi-mmc sdc2: send  manual stop command failed
      [   64.974414] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   64.980170] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   64.987499] sunxi-mmc sdc2: retry:give up
      [   64.992005] mmc0: switch to bus width 8 failed
      [   64.997162] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [   65.008224] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.014758] sunxi-mmc sdc2: *****retry:start*****
      [   65.020038] sunxi-mmc sdc2: send  manual stop command failed
      [   65.026398] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   65.032554] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.038396] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.044933] sunxi-mmc sdc2: *****retry:start*****
      [   65.050217] sunxi-mmc sdc2: send  manual stop command failed
      [   65.056577] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   65.062730] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.068578] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.075112] sunxi-mmc sdc2: *****retry:start*****
      [   65.080391] sunxi-mmc sdc2: send  manual stop command failed
      [   65.086758] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   65.092913] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.098762] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.105296] sunxi-mmc sdc2: *****retry:start*****
      [   65.110576] sunxi-mmc sdc2: send  manual stop command failed
      [   65.116937] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   65.123087] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.128935] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.135467] sunxi-mmc sdc2: *****retry:start*****
      [   65.140748] sunxi-mmc sdc2: send  manual stop command failed
      [   65.147108] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   65.153272] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.159118] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.165656] sunxi-mmc sdc2: *****retry:start*****
      [   65.170935] sunxi-mmc sdc2: send  manual stop command failed
      [   65.177295] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   65.183446] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.189295] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.195829] sunxi-mmc sdc2: *****retry:start*****
      [   65.201110] sunxi-mmc sdc2: send  manual stop command failed
      [   65.207472] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   65.213623] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.219469] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.226004] sunxi-mmc sdc2: *****retry:start*****
      [   65.231285] sunxi-mmc sdc2: send  manual stop command failed
      [   65.237649] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   65.243802] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.249650] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.256183] sunxi-mmc sdc2: *****retry:start*****
      [   65.261473] sunxi-mmc sdc2: send  manual stop command failed
      [   65.267833] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   65.273986] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.279833] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.286367] sunxi-mmc sdc2: *****retry:start*****
      [   65.291650] sunxi-mmc sdc2: send  manual stop command failed
      [   65.298012] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   65.304169] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.310015] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.316548] sunxi-mmc sdc2: *****retry:start*****
      [   65.321829] sunxi-mmc sdc2: send  manual stop command failed
      [   65.328192] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   65.334359] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.340203] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.346737] sunxi-mmc sdc2: *****retry:start*****
      [   65.352018] sunxi-mmc sdc2: send  manual stop command failed
      [   65.358380] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   65.364532] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.370377] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.376907] sunxi-mmc sdc2: *****retry:start*****
      [   65.382188] sunxi-mmc sdc2: send  manual stop command failed
      [   65.388546] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   65.394700] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.400546] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.407081] sunxi-mmc sdc2: *****retry:start*****
      [   65.412360] sunxi-mmc sdc2: send  manual stop command failed
      [   65.418729] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   65.424882] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.430727] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.437259] sunxi-mmc sdc2: *****retry:start*****
      [   65.442540] sunxi-mmc sdc2: send  manual stop command failed
      [   65.448911] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   65.455061] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.460907] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.467440] sunxi-mmc sdc2: *****retry:start*****
      [   65.472720] sunxi-mmc sdc2: send  manual stop command failed
      [   65.479082] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   65.485221] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.491068] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.497600] sunxi-mmc sdc2: *****retry:start*****
      [   65.502883] sunxi-mmc sdc2: send  manual stop command failed
      [   65.509243] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   65.515399] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.521246] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.527784] sunxi-mmc sdc2: *****retry:start*****
      [   65.533062] sunxi-mmc sdc2: send  manual stop command failed
      [   65.539425] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   65.545578] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.551426] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.557958] sunxi-mmc sdc2: *****retry:start*****
      [   65.563239] sunxi-mmc sdc2: send  manual stop command failed
      [   65.569599] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   65.575754] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.581601] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.588138] sunxi-mmc sdc2: *****retry:start*****
      [   65.593418] sunxi-mmc sdc2: send  manual stop command failed
      [   65.599774] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   65.605925] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.611770] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.618301] sunxi-mmc sdc2: *****retry:start*****
      [   65.623582] sunxi-mmc sdc2: send  manual stop command failed
      [   65.629940] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   65.636092] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.641939] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.648476] sunxi-mmc sdc2: *****retry:start*****
      [   65.653755] sunxi-mmc sdc2: send  manual stop command failed
      [   65.660121] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   65.666273] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.672119] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.678653] sunxi-mmc sdc2: *****retry:start*****
      [   65.683935] sunxi-mmc sdc2: send  manual stop command failed
      [   65.690293] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   65.696451] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.702295] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.708829] sunxi-mmc sdc2: *****retry:start*****
      [   65.714110] sunxi-mmc sdc2: send  manual stop command failed
      [   65.720492] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   65.726642] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.732491] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.739023] sunxi-mmc sdc2: *****retry:start*****
      [   65.744306] sunxi-mmc sdc2: send  manual stop command failed
      [   65.750680] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   65.756832] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.762677] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.769216] sunxi-mmc sdc2: *****retry:start*****
      [   65.774496] sunxi-mmc sdc2: send  manual stop command failed
      [   65.780858] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   65.787022] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.792870] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.799404] sunxi-mmc sdc2: *****retry:start*****
      [   65.804686] sunxi-mmc sdc2: send  manual stop command failed
      [   65.811047] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   65.817215] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.823060] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.829598] sunxi-mmc sdc2: *****retry:start*****
      [   65.834880] sunxi-mmc sdc2: send  manual stop command failed
      [   65.841243] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   65.847393] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.853241] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.859774] sunxi-mmc sdc2: *****retry:start*****
      [   65.865067] sunxi-mmc sdc2: send  manual stop command failed
      [   65.871427] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   65.877582] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.883428] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.889963] sunxi-mmc sdc2: *****retry:start*****
      [   65.895243] sunxi-mmc sdc2: send  manual stop command failed
      [   65.901614] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   65.907764] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.913614] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.920145] sunxi-mmc sdc2: *****retry:start*****
      [   65.925426] sunxi-mmc sdc2: send  manual stop command failed
      [   65.931794] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   65.937946] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.943791] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.950325] sunxi-mmc sdc2: *****retry:start*****
      [   65.955607] sunxi-mmc sdc2: send  manual stop command failed
      [   65.961964] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   65.968129] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   65.973977] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   65.980512] sunxi-mmc sdc2: *****retry:start*****
      [   65.985790] sunxi-mmc sdc2: send  manual stop command failed
      [   65.992145] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   65.997903] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   66.005217] sunxi-mmc sdc2: retry:give up
      [   66.009718] mmc0: switch to bus width 4 failed
      [   66.021521] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.027780] sunxi-mmc sdc2: *****retry:start*****
      [   66.033102] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   66.039275] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.045222] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.051464] sunxi-mmc sdc2: *****retry:start*****
      [   66.056755] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   66.062916] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.068861] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.075105] sunxi-mmc sdc2: *****retry:start*****
      [   66.080402] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   66.086556] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.092501] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.098744] sunxi-mmc sdc2: *****retry:start*****
      [   66.104035] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   66.110191] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.116139] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.122444] sunxi-mmc sdc2: *****retry:start*****
      [   66.127744] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   66.133923] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.139869] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.146115] sunxi-mmc sdc2: *****retry:start*****
      [   66.151414] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   66.157570] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.163519] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.169762] sunxi-mmc sdc2: *****retry:start*****
      [   66.175055] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   66.181212] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.187208] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.193454] sunxi-mmc sdc2: *****retry:start*****
      [   66.198749] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   66.204910] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.210857] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.217102] sunxi-mmc sdc2: *****retry:start*****
      [   66.222392] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   66.228548] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.234495] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.240739] sunxi-mmc sdc2: *****retry:start*****
      [   66.246032] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   66.252200] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.258144] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.264389] sunxi-mmc sdc2: *****retry:start*****
      [   66.269681] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   66.275836] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.281781] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.288027] sunxi-mmc sdc2: *****retry:start*****
      [   66.293325] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   66.299479] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.305428] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.311672] sunxi-mmc sdc2: *****retry:start*****
      [   66.316964] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   66.323122] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.329067] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.335310] sunxi-mmc sdc2: *****retry:start*****
      [   66.340605] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   66.346760] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.352706] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.358949] sunxi-mmc sdc2: *****retry:start*****
      [   66.364247] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   66.370400] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.376346] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.382595] sunxi-mmc sdc2: *****retry:start*****
      [   66.387896] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   66.394055] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.400003] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.406248] sunxi-mmc sdc2: *****retry:start*****
      [   66.411545] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   66.417706] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.423704] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.429946] sunxi-mmc sdc2: *****retry:start*****
      [   66.435238] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   66.441392] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.447391] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.453633] sunxi-mmc sdc2: *****retry:start*****
      [   66.458926] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   66.465080] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.471026] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.477268] sunxi-mmc sdc2: *****retry:start*****
      [   66.482560] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   66.488715] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.494659] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.500901] sunxi-mmc sdc2: *****retry:start*****
      [   66.506202] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   66.512358] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.518304] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.524549] sunxi-mmc sdc2: *****retry:start*****
      [   66.529844] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   66.536001] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.541948] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.548191] sunxi-mmc sdc2: *****retry:start*****
      [   66.553483] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   66.559639] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.565585] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.571828] sunxi-mmc sdc2: *****retry:start*****
      [   66.577120] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   66.583275] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.589222] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.595520] sunxi-mmc sdc2: *****retry:start*****
      [   66.600820] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   66.606979] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.612925] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.619169] sunxi-mmc sdc2: *****retry:start*****
      [   66.624469] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   66.630623] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.636570] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.642867] sunxi-mmc sdc2: *****retry:start*****
      [   66.648173] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   66.654324] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.660270] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.666514] sunxi-mmc sdc2: *****retry:start*****
      [   66.671804] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   66.677961] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.683904] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.690146] sunxi-mmc sdc2: *****retry:start*****
      [   66.695438] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   66.701595] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.707590] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.713829] sunxi-mmc sdc2: *****retry:start*****
      [   66.719121] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   66.725276] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.731221] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.737463] sunxi-mmc sdc2: *****retry:start*****
      [   66.742742] sunxi-mmc sdc2: send  manual stop command failed
      [   66.749104] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   66.755255] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.761203] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.767446] sunxi-mmc sdc2: *****retry:start*****
      [   66.772725] sunxi-mmc sdc2: send  manual stop command failed
      [   66.779085] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   66.785251] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   66.791194] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   66.797438] sunxi-mmc sdc2: *****retry:start*****
      [   66.802730] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   66.808494] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   66.815807] sunxi-mmc sdc2: retry:give up
      [   66.820402] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   66.828974] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   66.841323] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   66.867156] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   66.893822] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   66.904600] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   66.917750] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   66.945019] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   66.957187] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   66.968296] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   66.979384] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   66.990434] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   66.997029] sunxi-mmc sdc2: *****retry:start*****
      [   67.002310] sunxi-mmc sdc2: send  manual stop command failed
      [   67.008675] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   67.014838] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.020686] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.027276] sunxi-mmc sdc2: *****retry:start*****
      [   67.032558] sunxi-mmc sdc2: send  manual stop command failed
      [   67.038921] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   67.045070] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.050914] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.057518] sunxi-mmc sdc2: *****retry:start*****
      [   67.062802] sunxi-mmc sdc2: send  manual stop command failed
      [   67.069162] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   67.075313] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.081161] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.087697] sunxi-mmc sdc2: *****retry:start*****
      [   67.092977] sunxi-mmc sdc2: send  manual stop command failed
      [   67.099349] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   67.105502] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.111346] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.117880] sunxi-mmc sdc2: *****retry:start*****
      [   67.123164] sunxi-mmc sdc2: send  manual stop command failed
      [   67.129529] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   67.135681] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.141531] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.148063] sunxi-mmc sdc2: *****retry:start*****
      [   67.153345] sunxi-mmc sdc2: send  manual stop command failed
      [   67.159702] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   67.165868] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.171713] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.178250] sunxi-mmc sdc2: *****retry:start*****
      [   67.183530] sunxi-mmc sdc2: send  manual stop command failed
      [   67.189887] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   67.196037] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.201886] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.208421] sunxi-mmc sdc2: *****retry:start*****
      [   67.213711] sunxi-mmc sdc2: send  manual stop command failed
      [   67.220067] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   67.226219] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.232065] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.238601] sunxi-mmc sdc2: *****retry:start*****
      [   67.243880] sunxi-mmc sdc2: send  manual stop command failed
      [   67.250249] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   67.256403] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.262250] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.268786] sunxi-mmc sdc2: *****retry:start*****
      [   67.274069] sunxi-mmc sdc2: send  manual stop command failed
      [   67.280423] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   67.286574] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.292417] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.298954] sunxi-mmc sdc2: *****retry:start*****
      [   67.304241] sunxi-mmc sdc2: send  manual stop command failed
      [   67.310603] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   67.316756] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.322602] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.329137] sunxi-mmc sdc2: *****retry:start*****
      [   67.334418] sunxi-mmc sdc2: send  manual stop command failed
      [   67.340780] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   67.346932] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.352777] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.359312] sunxi-mmc sdc2: *****retry:start*****
      [   67.364594] sunxi-mmc sdc2: send  manual stop command failed
      [   67.370957] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   67.377100] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.382945] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.389478] sunxi-mmc sdc2: *****retry:start*****
      [   67.394766] sunxi-mmc sdc2: send  manual stop command failed
      [   67.401133] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   67.407286] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.413131] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.419667] sunxi-mmc sdc2: *****retry:start*****
      [   67.424946] sunxi-mmc sdc2: send  manual stop command failed
      [   67.431307] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   67.437459] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.443306] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.449841] sunxi-mmc sdc2: *****retry:start*****
      [   67.455127] sunxi-mmc sdc2: send  manual stop command failed
      [   67.461487] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   67.467640] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.473486] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.480021] sunxi-mmc sdc2: *****retry:start*****
      [   67.485299] sunxi-mmc sdc2: send  manual stop command failed
      [   67.491661] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   67.497822] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.503668] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.510205] sunxi-mmc sdc2: *****retry:start*****
      [   67.515487] sunxi-mmc sdc2: send  manual stop command failed
      [   67.521849] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   67.528000] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.533846] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.540379] sunxi-mmc sdc2: *****retry:start*****
      [   67.545658] sunxi-mmc sdc2: send  manual stop command failed
      [   67.552021] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   67.558175] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.564021] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.570553] sunxi-mmc sdc2: *****retry:start*****
      [   67.575834] sunxi-mmc sdc2: send  manual stop command failed
      [   67.582204] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   67.588356] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.594202] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.600735] sunxi-mmc sdc2: *****retry:start*****
      [   67.606015] sunxi-mmc sdc2: send  manual stop command failed
      [   67.612372] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   67.618523] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.624368] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.630903] sunxi-mmc sdc2: *****retry:start*****
      [   67.636184] sunxi-mmc sdc2: send  manual stop command failed
      [   67.642543] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   67.648698] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.654546] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.661080] sunxi-mmc sdc2: *****retry:start*****
      [   67.666372] sunxi-mmc sdc2: send  manual stop command failed
      [   67.672728] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   67.678878] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.684726] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.691262] sunxi-mmc sdc2: *****retry:start*****
      [   67.696546] sunxi-mmc sdc2: send  manual stop command failed
      [   67.702909] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   67.709061] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.714907] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.721441] sunxi-mmc sdc2: *****retry:start*****
      [   67.726723] sunxi-mmc sdc2: send  manual stop command failed
      [   67.733095] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   67.739245] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.745091] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.751624] sunxi-mmc sdc2: *****retry:start*****
      [   67.756906] sunxi-mmc sdc2: send  manual stop command failed
      [   67.763268] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   67.769437] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.775285] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.781818] sunxi-mmc sdc2: *****retry:start*****
      [   67.787098] sunxi-mmc sdc2: send  manual stop command failed
      [   67.793460] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   67.799612] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.805459] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.811993] sunxi-mmc sdc2: *****retry:start*****
      [   67.817275] sunxi-mmc sdc2: send  manual stop command failed
      [   67.823635] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   67.829789] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.835635] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.842172] sunxi-mmc sdc2: *****retry:start*****
      [   67.847451] sunxi-mmc sdc2: send  manual stop command failed
      [   67.853830] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   67.859981] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.865830] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.872364] sunxi-mmc sdc2: *****retry:start*****
      [   67.877645] sunxi-mmc sdc2: send  manual stop command failed
      [   67.884014] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   67.890166] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.896011] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.902544] sunxi-mmc sdc2: *****retry:start*****
      [   67.907828] sunxi-mmc sdc2: send  manual stop command failed
      [   67.914188] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   67.920342] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.926188] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.932723] sunxi-mmc sdc2: *****retry:start*****
      [   67.938003] sunxi-mmc sdc2: send  manual stop command failed
      [   67.944364] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   67.950528] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   67.956374] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   67.962909] sunxi-mmc sdc2: *****retry:start*****
      [   67.968189] sunxi-mmc sdc2: send  manual stop command failed
      [   67.974551] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   67.980305] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   67.987634] sunxi-mmc sdc2: retry:give up
      [   67.992140] mmc0: switch to bus width 8 failed
      [   67.997223] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [   68.008286] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.014819] sunxi-mmc sdc2: *****retry:start*****
      [   68.020101] sunxi-mmc sdc2: send  manual stop command failed
      [   68.026464] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   68.032619] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.038465] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.044998] sunxi-mmc sdc2: *****retry:start*****
      [   68.050276] sunxi-mmc sdc2: send  manual stop command failed
      [   68.056641] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   68.062796] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.068640] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.075231] sunxi-mmc sdc2: *****retry:start*****
      [   68.080516] sunxi-mmc sdc2: send  manual stop command failed
      [   68.086892] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   68.093046] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.098893] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.105481] sunxi-mmc sdc2: *****retry:start*****
      [   68.110777] sunxi-mmc sdc2: send  manual stop command failed
      [   68.117161] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   68.123319] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.129163] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.135700] sunxi-mmc sdc2: *****retry:start*****
      [   68.140980] sunxi-mmc sdc2: send  manual stop command failed
      [   68.147342] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   68.153505] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.159352] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.165888] sunxi-mmc sdc2: *****retry:start*****
      [   68.171166] sunxi-mmc sdc2: send  manual stop command failed
      [   68.177524] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   68.183679] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.189525] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.196058] sunxi-mmc sdc2: *****retry:start*****
      [   68.201340] sunxi-mmc sdc2: send  manual stop command failed
      [   68.207702] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   68.213852] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.219702] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.226236] sunxi-mmc sdc2: *****retry:start*****
      [   68.231517] sunxi-mmc sdc2: send  manual stop command failed
      [   68.237882] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   68.244034] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.249878] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.256414] sunxi-mmc sdc2: *****retry:start*****
      [   68.261700] sunxi-mmc sdc2: send  manual stop command failed
      [   68.268063] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   68.274217] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.280065] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.286596] sunxi-mmc sdc2: *****retry:start*****
      [   68.291879] sunxi-mmc sdc2: send  manual stop command failed
      [   68.298246] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   68.304400] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.310242] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.316779] sunxi-mmc sdc2: *****retry:start*****
      [   68.322057] sunxi-mmc sdc2: send  manual stop command failed
      [   68.328418] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   68.334568] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.340412] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.346945] sunxi-mmc sdc2: *****retry:start*****
      [   68.352226] sunxi-mmc sdc2: send  manual stop command failed
      [   68.358588] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   68.364752] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.370595] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.377128] sunxi-mmc sdc2: *****retry:start*****
      [   68.382408] sunxi-mmc sdc2: send  manual stop command failed
      [   68.388770] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   68.394924] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.400774] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.407309] sunxi-mmc sdc2: *****retry:start*****
      [   68.412587] sunxi-mmc sdc2: send  manual stop command failed
      [   68.418950] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   68.425102] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.430945] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.437483] sunxi-mmc sdc2: *****retry:start*****
      [   68.442761] sunxi-mmc sdc2: send  manual stop command failed
      [   68.449122] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   68.455274] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.461121] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.467655] sunxi-mmc sdc2: *****retry:start*****
      [   68.472938] sunxi-mmc sdc2: send  manual stop command failed
      [   68.479298] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   68.485464] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.491309] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.497842] sunxi-mmc sdc2: *****retry:start*****
      [   68.503124] sunxi-mmc sdc2: send  manual stop command failed
      [   68.509486] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   68.515635] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.521483] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.528019] sunxi-mmc sdc2: *****retry:start*****
      [   68.533299] sunxi-mmc sdc2: send  manual stop command failed
      [   68.539656] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   68.545813] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.551656] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.558193] sunxi-mmc sdc2: *****retry:start*****
      [   68.563475] sunxi-mmc sdc2: send  manual stop command failed
      [   68.569839] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   68.575990] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.581835] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.588368] sunxi-mmc sdc2: *****retry:start*****
      [   68.593649] sunxi-mmc sdc2: send  manual stop command failed
      [   68.600020] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   68.606172] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.612019] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.618557] sunxi-mmc sdc2: *****retry:start*****
      [   68.623836] sunxi-mmc sdc2: send  manual stop command failed
      [   68.630198] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   68.636347] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.642192] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.648725] sunxi-mmc sdc2: *****retry:start*****
      [   68.654007] sunxi-mmc sdc2: send  manual stop command failed
      [   68.660360] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   68.666509] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.672354] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.678889] sunxi-mmc sdc2: *****retry:start*****
      [   68.684172] sunxi-mmc sdc2: send  manual stop command failed
      [   68.690537] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   68.696688] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.702533] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.709065] sunxi-mmc sdc2: *****retry:start*****
      [   68.714346] sunxi-mmc sdc2: send  manual stop command failed
      [   68.720718] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   68.726868] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.732712] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.739248] sunxi-mmc sdc2: *****retry:start*****
      [   68.744531] sunxi-mmc sdc2: send  manual stop command failed
      [   68.750894] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   68.757039] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.762883] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.769415] sunxi-mmc sdc2: *****retry:start*****
      [   68.774694] sunxi-mmc sdc2: send  manual stop command failed
      [   68.781052] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   68.787205] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.793051] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.799587] sunxi-mmc sdc2: *****retry:start*****
      [   68.804868] sunxi-mmc sdc2: send  manual stop command failed
      [   68.811230] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   68.817385] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.823232] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.829768] sunxi-mmc sdc2: *****retry:start*****
      [   68.835059] sunxi-mmc sdc2: send  manual stop command failed
      [   68.841422] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   68.847575] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.853422] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.859959] sunxi-mmc sdc2: *****retry:start*****
      [   68.865241] sunxi-mmc sdc2: send  manual stop command failed
      [   68.871601] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   68.877750] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.883598] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.890132] sunxi-mmc sdc2: *****retry:start*****
      [   68.895412] sunxi-mmc sdc2: send  manual stop command failed
      [   68.901788] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   68.907942] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.913789] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.920323] sunxi-mmc sdc2: *****retry:start*****
      [   68.925605] sunxi-mmc sdc2: send  manual stop command failed
      [   68.931982] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   68.938136] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.943980] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.950517] sunxi-mmc sdc2: *****retry:start*****
      [   68.955811] sunxi-mmc sdc2: send  manual stop command failed
      [   68.962169] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   68.968320] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   68.974166] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   68.980700] sunxi-mmc sdc2: *****retry:start*****
      [   68.985979] sunxi-mmc sdc2: send  manual stop command failed
      [   68.992340] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   68.998112] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   69.005433] sunxi-mmc sdc2: retry:give up
      [   69.009933] mmc0: switch to bus width 4 failed
      [   69.147967] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.154232] sunxi-mmc sdc2: *****retry:start*****
      [   69.159557] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   69.165730] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.171680] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.177920] sunxi-mmc sdc2: *****retry:start*****
      [   69.183234] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   69.189393] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.195341] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.201583] sunxi-mmc sdc2: *****retry:start*****
      [   69.206883] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   69.213036] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.218985] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.225282] sunxi-mmc sdc2: *****retry:start*****
      [   69.230577] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   69.236749] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.242693] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.248935] sunxi-mmc sdc2: *****retry:start*****
      [   69.254231] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   69.260386] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.266327] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.272572] sunxi-mmc sdc2: *****retry:start*****
      [   69.277865] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   69.284021] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.289967] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.296210] sunxi-mmc sdc2: *****retry:start*****
      [   69.301509] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   69.307666] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.313607] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.319849] sunxi-mmc sdc2: *****retry:start*****
      [   69.325144] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   69.331311] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.337262] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.343503] sunxi-mmc sdc2: *****retry:start*****
      [   69.348803] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   69.354956] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.360901] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.367148] sunxi-mmc sdc2: *****retry:start*****
      [   69.372444] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001494
      [   69.378599] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.384547] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.390792] sunxi-mmc sdc2: *****retry:start*****
      [   69.396091] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001696
      [   69.402242] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.408186] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.414430] sunxi-mmc sdc2: *****retry:start*****
      [   69.419726] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001898
      [   69.425883] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.431832] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.438073] sunxi-mmc sdc2: *****retry:start*****
      [   69.443368] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001a9a
      [   69.449528] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.455473] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.461716] sunxi-mmc sdc2: *****retry:start*****
      [   69.467021] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001c9c
      [   69.473175] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.479174] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.485419] sunxi-mmc sdc2: *****retry:start*****
      [   69.490714] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001e9e
      [   69.496870] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.502868] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.509110] sunxi-mmc sdc2: *****retry:start*****
      [   69.514405] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000020a0
      [   69.520562] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.526563] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.532805] sunxi-mmc sdc2: *****retry:start*****
      [   69.538098] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000022a2
      [   69.544251] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.550270] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.556509] sunxi-mmc sdc2: *****retry:start*****
      [   69.561802] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000024a4
      [   69.567956] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.573956] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.580200] sunxi-mmc sdc2: *****retry:start*****
      [   69.585497] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000026a6
      [   69.591652] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.597599] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.603840] sunxi-mmc sdc2: *****retry:start*****
      [   69.609133] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000028a8
      [   69.615286] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.621286] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.627583] sunxi-mmc sdc2: *****retry:start*****
      [   69.632892] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002aaa
      [   69.639050] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.645050] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.651351] sunxi-mmc sdc2: *****retry:start*****
      [   69.656652] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002cac
      [   69.662806] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.668753] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.675052] sunxi-mmc sdc2: *****retry:start*****
      [   69.680349] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00002eae
      [   69.686508] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.692505] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.698746] sunxi-mmc sdc2: *****retry:start*****
      [   69.704048] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000030b0
      [   69.710203] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.716203] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.722440] sunxi-mmc sdc2: *****retry:start*****
      [   69.727733] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000032b2
      [   69.733892] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.739891] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.746133] sunxi-mmc sdc2: *****retry:start*****
      [   69.751423] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000034b4
      [   69.757578] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.763525] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.769768] sunxi-mmc sdc2: *****retry:start*****
      [   69.775063] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000036b6
      [   69.781217] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.787161] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.793400] sunxi-mmc sdc2: *****retry:start*****
      [   69.798698] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x000038b8
      [   69.804854] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.810855] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.817098] sunxi-mmc sdc2: *****retry:start*****
      [   69.822398] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003aba
      [   69.828554] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.834504] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.840746] sunxi-mmc sdc2: *****retry:start*****
      [   69.846045] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003cbc
      [   69.852197] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.858146] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.864385] sunxi-mmc sdc2: *****retry:start*****
      [   69.869667] sunxi-mmc sdc2: send  manual stop command failed
      [   69.876028] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00003ebe
      [   69.882182] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.888179] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.894422] sunxi-mmc sdc2: *****retry:start*****
      [   69.899703] sunxi-mmc sdc2: send  manual stop command failed
      [   69.906066] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000080
      [   69.912218] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   69.918166] sunxi-mmc sdc2: smc 0 p2 err, cmd 18, RD DCE !!
      [   69.924406] sunxi-mmc sdc2: *****retry:start*****
      [   69.929699] sunxi-mmc sdc2: sunxi v4p5x retry give up!
      [   69.935460] sunxi-mmc sdc2: retry:set phase failed or over retry times
      [   69.942779] sunxi-mmc sdc2: retry:give up
      [   69.947343] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
      [   69.955859] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   69.968194] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   69.993820] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   70.020489] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   70.031275] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   70.044472] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   70.071684] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   70.083793] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   70.094904] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [   70.105997] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [   70.117053] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.123643] sunxi-mmc sdc2: *****retry:start*****
      [   70.128938] sunxi-mmc sdc2: send  manual stop command failed
      [   70.135297] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000282
      [   70.141453] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.147297] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.153833] sunxi-mmc sdc2: *****retry:start*****
      [   70.159118] sunxi-mmc sdc2: send  manual stop command failed
      [   70.165489] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000484
      [   70.171648] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.177496] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.184031] sunxi-mmc sdc2: *****retry:start*****
      [   70.189312] sunxi-mmc sdc2: send  manual stop command failed
      [   70.195675] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000686
      [   70.201828] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.207675] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.214211] sunxi-mmc sdc2: *****retry:start*****
      [   70.219493] sunxi-mmc sdc2: send  manual stop command failed
      [   70.225857] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000888
      [   70.232020] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.237867] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.244401] sunxi-mmc sdc2: *****retry:start*****
      [   70.249684] sunxi-mmc sdc2: send  manual stop command failed
      [   70.256045] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000a8a
      [   70.262198] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.268043] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.274577] sunxi-mmc sdc2: *****retry:start*****
      [   70.279856] sunxi-mmc sdc2: send  manual stop command failed
      [   70.286226] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000c8c
      [   70.292380] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.298227] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.304761] sunxi-mmc sdc2: *****retry:start*****
      [   70.310041] sunxi-mmc sdc2: send  manual stop command failed
      [   70.316409] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00000e8e
      [   70.322565] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.328412] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.334948] sunxi-mmc sdc2: *****retry:start*****
      [   70.340227] sunxi-mmc sdc2: send  manual stop command failed
      [   70.346583] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001090
      [   70.352748] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.358595] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.365129] sunxi-mmc sdc2: *****retry:start*****
      [   70.370413] sunxi-mmc sdc2: send  manual stop command failed
      [   70.376773] sunxi-mmc sdc2: RETRY: REG_SAMP_DL: 0x00001292
      [   70.382937] sunxi-mmc sdc2: *****retry:re-send cmd*****
      [   70.388786] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RD DCE EBE !!
      [   70.395322] sunxi-mmc sdc2: *****retry:start*****
      [   70.400607] sunxi-mmc sdc2: send  manual stop command failed
