    T113的usb0问题
      KoGu LV 5 最后由 编辑
      启动设备后插入u盘没有任何反应和打印信息,需要我用下面的命令重启驱动才有反应这是为什么呢?
      # echo 0 > /sys/devices/platform/soc@3000000/4101000.ehci0-controller/ehci_enable
      # echo 1 > /sys/devices/platform/soc@3000000/4101000.ehci0-controller/ehci_enable
      配置如下
      reg_usb0_vbus: usb0-vbus {
      		regulator-name = "usb0-vbus";
      		gpio = <&pio PG 6 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x1>;
      	enable-active-high;
      &ehci0 {
      	drvvbus-supply = <&reg_usb0_vbus>;
      &ohci0 {
        KoGu LV 5 最后由 编辑
        我发现是有个开机脚本给切换了...
        #!/bin/sh
        # Start the adbd....
        # config adb serialnumber for adb devices
        adb_serialnumber=/etc/.adb_sn
        disable_udc="/etc/.disable_udc"
        udc_config=/sys/kernel/config/usb_gadget/g1/UDC
        otg_role_file="/sys/devices/platform/soc/usbc0/otg_role"
        usb_device_file="/sys/devices/platform/soc/usbc0/usb_device"
        hardware_type=`cat /proc/cmdline | tr ' ' '\n' | grep 'hardware' | awk -F "=" '{print $2}'`
        function enable_udc(){
        	while [ 1 ];do
        		udc=`ls /sys/class/udc 2>/dev/null`
        		isudc=`cat $udc_config 2>/dev/null`
        		if [ "x$isudc" = "x" ] && [ -f $udc_config ]; then
        			echo $udc > $udc_config
        		fi
        		sleep 1
        		if [ -f $disable_udc ];then
        			rm $disable_udc
        			break
        		fi
        	done
        function start_adb(){
        	serialnumber=$1
        	if [ "x$serialnumber" = "x" ];then
        		serialnumber="0402101560"
        	fi
        	printf "Starting adb: "
        	# for adbd compatibilities
        	mkdir -p /system/
        	mkdir -p /system/bin
        	if [ ! -f /system/bin/sh ];then
        		ln -s /bin/sh /system/bin/sh
        	fi
        	# config ptmx
        	mkdir -p /dev/pts
        	mount -t devpts none /dev/pts
        	# config adb function
        	mount -t configfs none /sys/kernel/config > /dev/null 2>&1
        	mkdir -p /sys/kernel/config/usb_gadget/g1
        	echo "0x18d1" > /sys/kernel/config/usb_gadget/g1/idVendor
        	echo "0x0002" > /sys/kernel/config/usb_gadget/g1/idProduct
        	mkdir -p /sys/kernel/config/usb_gadget/g1/strings/0x409
        	echo "$serialnumber" > /sys/kernel/config/usb_gadget/g1/strings/0x409/serialnumber
        	echo "Google.Inc" > /sys/kernel/config/usb_gadget/g1/strings/0x409/manufacturer
        	echo "Configfs ffs gadget" > /sys/kernel/config/usb_gadget/g1/strings/0x409/product
        	mkdir -p /sys/kernel/config/usb_gadget/g1/functions/ffs.adb
        	mkdir -p /sys/kernel/config/usb_gadget/g1/configs/c.1
        	mkdir -p /sys/kernel/config/usb_gadget/g1/configs/c.1/strings/0x409
        	echo 0xc0 > /sys/kernel/config/usb_gadget/g1/configs/c.1/bmAttributes
        	echo 500 > /sys/kernel/config/usb_gadget/g1/configs/c.1/MaxPower
        	ln -s /sys/kernel/config/usb_gadget/g1/functions/ffs.adb/ /sys/kernel/config/usb_gadget/g1/configs/c.1/ffs.adb > /dev/null 2>&1
        	mkdir -p /dev/usb-ffs
        	mkdir -p /dev/usb-ffs/adb
        	if [ "x`ls -A /dev/usb-ffs/adb`" = "x" ];then
        		mount -o uid=2000,gid=2000 -t functionfs adb /dev/usb-ffs/adb/
        	fi
        	# start adbd daemon
        	adbd &
        	[ $? -eq 0 ] && echo "OK" || "FAIL"
        	# enable_udc &
        case "$1" in
        	start|"")
        		if [ "x$hardware_type" = "xsun8iw11p1" ];then
        			otg_role_file="/sys/devices/platform/soc@1c00000/soc@1c00000:usbc0@0/otg_role"
        		elif [ "x$hardware_type" = "xsun8iw20p1" ];then
        			otg_role_file="/sys/devices/platform/soc@3000000/soc@3000000:usbc0@0/otg_role"
        		fi
        		[ -f "$otg_role_file" ] && otg_role=`cat "$otg_role_file"`
        		echo "usb0 current mode: $otg_role"
        		if [ -f "$otg_role_file" ] && [ "x$otg_role" != "xusb_device" ];then
        			# force switch usb0 to device mode
        			echo "Starting switch usb0 to device mode."
        				usb_device_file="/sys/devices/platform/soc@1c00000/soc@1c00000:usbc0@0/usb_device"
        				usb_device_file="/sys/devices/platform/soc@3000000/soc@3000000:usbc0@0/usb_device"
        			fi
        			[ -f "$usb_device_file" ] && cat $usb_device_file
        		fi
        		[ -f $adb_serialnumber ] && serialnumber=`cat $adb_serialnumber`
        			serialnumber=`cat /proc/cmdline | tr ' ' '\n' | grep 'snum' | awk -F "=" '{print $2}'`
        		fi
        		start_adb $serialnumber
        	stop)
        		printf "Stopping adbd "
        		# touch $disable_udc
        		# sleep 2
        		killall adbd &
        	restart|reload)
        		"$0" stop
        		"$0" start
        		exit 1
        esac
