    全志适配TP9930时csi&isp setup link failed
      shuaige LV 6 最后由 编辑
      在调试时出现CSI与ISP未能链接的情况,有没有人遇到过,帮忙看一下
      应用程序测试
      csi_test_usrptr 16 0 1280 720 /usr 4 10 25
      csi_test_usrptr 17 0 1280 720 /usr 4 10 25
      CSI 和 ISP 之间的链接时遇到问题
      定位代码:bsp/drivers/vin/vin-video/vin_video.c
      添加打印,确认isp和csi 都非空
      media_entity_find_link函数的实现
      kernel/linux-5.15/drivers/media/mc/mc-entity.c
      设备树:
      在T527平台中,parser(csi)个数为4 个(parser0/1/2/3),其中 parser3可配置为并口输入。所以作为 BT656/BT1120 输入的时候,csi_sel 只能选择 3,不能选择其他选项
      csi3:csi@5823000 {
      pinctrl-0 = <&ncsi_bt1120_pins_a>;
      pinctrl-1 = <&ncsi_bt1120_pins_b>;
          sensor1:sensor@5812010 {
                  device_type = "sensor1";
                  sensor1_mname = "tp9930";
                  sensor1_twi_cci_id = <3>;//twi3, 连接的TWI 组号
                  sensor1_twi_addr = <0x8a>;//TWI地址
                  sensor1_mclk_id = <3>; //连接的MCLK组号
                  sensor1_pos = "front";
                  sensor1_isp_used = <0>;
                  sensor1_fmt = <0>;
                  sensor1_stby_mode = <0>;
                  sensor1_vflip = <0>;
                  sensor1_hflip = <0>;
                  sensor1_iovdd-supply = <>;
                  sensor1_iovdd_vol = <>;
                  sensor1_avdd-supply = <>;
                  sensor1_avdd_vol = <>;
                  sensor1_dvdd-supply = <>;
                  sensor1_dvdd_vol = <>;
                  sensor1_power_en = <>;
                  sensor1_reset = <&pio PK 10 GPIO_ACTIVE_LOW>;
                  sensor1_reset = <>;
                  sensor1_pwdn = <>;
          vinc40:vinc@5834000 {
                  vinc16_csi_sel = <3>; //代表选择的csi 接口
                  vinc16_mipi_sel = <0xff>;
                  vinc16_isp_sel = <5>;
                  vinc16_isp_tx_ch = <0>;
                  vinc16_tdm_rx_sel = <0>;
                  vinc16_rear_sensor_sel = <1>;
                  vinc16_front_sensor_sel = <1>;
                  vinc16_sensor_list = <0>;
                  device_id = <16>;
          vinc50:vinc@5835000 {
                  vinc17_csi_sel = <3>;
                  vinc17_mipi_sel = <0xff>;
                  vinc17_isp_sel = <5>;
                  vinc17_isp_tx_ch = <1>;
                  vinc17_tdm_rx_sel = <0>;
                  vinc17_rear_sensor_sel = <1>;
                  vinc17_front_sensor_sel = <1>;
                  vinc17_sensor_list = <0>;
                  device_id = <17>;
        shuaige LV 6 最后由 编辑
        已解决,csi驱动未成功注册驱动的原因
          summer_x LV 3 最后由 编辑
          你好,我也遇到了相同错误,请问你最后是怎么注册上的?
