    T113S3使用spinand启动进不了kernel问题
    4013
      leokemp LV 3 最后由 编辑
      使用evb1板卡的配置,跟随下方链接配置为spi nand启动后,发现进不了kernel
      https://bbs.aw-ol.com/topic/1701/tina-linux-存储介质切换-emmc-spi-nand-spi-nor-sd-card-sd-nand?_=1699127558925
      使用的flash是1Gbit的XT26G04CWSIGA,看到id.c中有这个芯片的支持。
      完整日志如下:
      HELLO! BOOT0 is starting!
      [09:59:25.488] [140]BOOT0 commit : 1417090655
      [09:59:25.498] [143]set pll start
      [09:59:25.498] [149]periph0 has been enabled
      [09:59:25.498] [152]set pll end
      [09:59:25.508] [154][pmu]: bus read error
      [09:59:25.508] [157]board init ok
      [09:59:25.508] [159]enable_jtag
      [09:59:25.508] [160]ZQ value = 0x30
      [09:59:25.519] [162]get_pmu_exist() = -1
      [09:59:25.519] [165]DRAM BOOT DRIVE INFO: V0.33
      [09:59:25.519] [168]DRAM CLK = 792 MHz
      [09:59:25.519] [170]DRAM Type = 3 (2:DDR2,3:DDR3)
      [09:59:25.529] [174]DRAMC read ODT  off.
      [09:59:25.529] [176]DRAM ODT value: 0x42.
      [09:59:25.529] [179]ddr_efuse_type: 0xa
      [09:59:25.529] [182]DRAM SIZE =128 M
      [09:59:25.539] [184]dram_tpr4:0x0
      [09:59:25.539] [186]PLL_DDR_CTRL_REG:0xf8004100
      [09:59:25.539] [189]DRAM_CLK_REG:0xc0000000
      [09:59:25.539] [192][TIMING DEBUG] MR2= 0x18
      [09:59:25.549] [200]DRAM simple test OK.
      [09:59:25.549] [202]rtc standby flag is 0x0, super standby flag is 0x0
      [09:59:25.559] [208]dram size =128
      [09:59:25.559] [211]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [09:59:25.569] [216]block from 8 to 32
      [09:59:25.569] [300]Check is correct.
      [09:59:25.648] [302]dma 0x2ac4c int is not used yet
      [09:59:25.658] [305]dma 0x2ac4c int is free, you do not need to free it again
      [09:59:25.658] [311]Entry_name        = u-boot
      [09:59:25.668] [318]Entry_name        = optee
      [09:59:25.668] [322]Entry_name        = dtb
      [09:59:25.678] [325]Jump to second Boot.
      [09:59:25.678] M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
      [09:59:25.718]
      [09:59:25.718]
      [09:59:25.718] U-Boot 2018.07-gd9e6718-dirty (Aug 20 2024 - 01:08:36 +0000) Allwinner Technology
      [09:59:25.728]
      [09:59:25.728] [00.377]CPU:   Allwinner Family
      [09:59:25.728] [00.380]Model: sun8iw20
      [09:59:25.738] [00.382]DRAM:  128 MiB
      [09:59:25.738] [00.386]Relocation Offset is: 04ec4000
      [09:59:25.738] [00.413]secure enable bit: 0
      [09:59:25.768] E/TC:0   fdt_getprop_u32:343 prop trace_level not found
      [09:59:25.778] [00.426]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [09:59:25.788] [00.432]gic: sec monitor mode
      [09:59:25.788] sunxi flash map init
      [09:59:25.788] SPI ALL:   ready
      [09:59:25.788] [00.439]flash init start
      [09:59:25.798] [00.442]workmode = 0,storage type = 0
      [09:59:25.798] [00.448]sunxi-spinand-phy: spinand sample_mode:2 sample_delay:8
      [09:59:25.808]
      [09:59:25.808] device nand0 <nand>, # parts = 4
      [09:59:25.818]  #: name		size		offset		mask_flags
      [09:59:25.818]  0: boot0               0x00200000	0x00000000	1
      [09:59:25.818]  1: uboot               0x00600000	0x00200000	1
      [09:59:25.818]  2: secure_storage      0x00200000	0x00800000	1
      [09:59:25.828]  3: sys                 0x1f600000	0x00a00000	0
      [09:59:25.828]
      [09:59:25.828] active partition: nand0,0 - (boot0) 0x00200000 @ 0x00000000
      [09:59:25.838]
      [09:59:25.838] defaults:
      [09:59:25.838] mtdids  : nand0=nand
      [09:59:25.838] mtdparts: mtdparts=nand:2048k@0(boot0)ro,6144k@2097152(uboot)ro,2048k@8388608(secure_storage)ro,-(sys)
      [09:59:25.848] [00.894]ubi0: attaching mtd4
      [09:59:26.249] [01.443]ubi0: scanning is finished
      [09:59:26.798] [01.450]ubi0: attached mtd4 (name "sys", size 502 MiB)
      [09:59:26.809] [01.455]ubi0: PEB size: 524288 bytes (512 KiB), LEB size: 516096 bytes
      [09:59:26.819] [01.461]ubi0: min./max. I/O unit sizes: 8192/8192, sub-page size 4096
      [09:59:26.819] [01.467]ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
      [09:59:26.829] [01.474]ubi0: good PEBs: 999, bad PEBs: 5, corrupted PEBs: 0
      [09:59:26.829] [01.479]ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
      [09:59:26.839] [01.486]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [09:59:26.849] [01.493]ubi0: available PEBs: 0, total reserved PEBs: 999, PEBs reserved for bad PEB handling: 35
      [09:59:26.849] [01.502]sunxi flash init ok
      [09:59:26.859] [01.505]line:703 init_clocks
      [09:59:26.859] [01.508]drv_disp_init
      [09:59:26.859] [01.512]handle_num : 6
      [09:59:26.869] request pwm success, pwm7:pwm7:0x2000c00.
      [09:59:26.879] [01.523]drv_disp_init finish
      [09:59:26.879] [01.568]Loading Environment from SUNXI_FLASH... Can't find env-redund partition
      [09:59:26.949] *** Warning - no device, using default environment
      [09:59:26.949]
      [09:59:26.949] Failed (-19)
      [09:59:26.959] [01.603]boot_gui_init:start
      [09:59:26.959] [01.606]set disp.dev2_output_type fail. using defval=0
      [09:59:26.959] [01.612]set disp.fb0_rot_used fail. using defval=0
      [09:59:26.969] [01.617]set disp.fb0_rot_degree fail. using defval=0
      [09:59:26.969] [01.622]boot_gui_init:finish
      [09:59:26.979] partno erro : can't find partition bootloader
      [09:59:26.989] partno erro : can't find partition boot-resource
      [09:59:27.009] [01.660]Get bootloader and boot-resource partition number fail!
      [09:59:27.018] [01.668]Item0 (Map) magic is bad
      [09:59:27.028] [01.671]usb burn from boot
      [09:59:27.028] delay time 0
      [09:59:27.028] weak:otg_phy_config
      [09:59:27.028] [01.682]usb prepare ok
      [09:59:27.038] [01.793]LCD open finish
      [09:59:27.148] [01.869]usb sof ok
      [09:59:27.218] [01.871]usb probe ok
      [09:59:27.228] [01.873]usb setup ok
      [09:59:27.228] set address 0x3e
      [09:59:27.258] set address 0x3e ok
      [09:59:27.258] set address 0x3f
      [09:59:27.449] set address 0x3f ok
      [09:59:27.449] try to update
      [09:59:27.488] [02.278]do_burn_from_boot usb : have no handshake
      [09:59:27.639] cann't get the boot_base from the env
      [09:59:27.639] [02.300]update bootcmd
      [09:59:27.649] [02.334]change working_fdt 0x45e83e70 to 0x45e63e70
      [09:59:27.689] [02.353]update dts
      [09:59:27.709] Hit any key to stop autoboot:  2
       1  0
      [09:59:29.718] ## Error: "distro_bootcmd" not defined
      env.cfg如下
      #kernel command arguments
      earlyprintk=sunxi-uart,0x02500000
      initcall_debug=0
      console=ttyS0,115200
      nand_root=/dev/ubiblock0_5
      mmc_root=/dev/mmcblk0p5
      mtd_name=sys
      rootfstype=squashfs
      root_partition=rootfs
      boot_partition=boot
      init=/init
      loglevel=8
      cma=4M
      mac=
      wifi_mac=
      bt_mac=
      specialstr=
      #keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
      dsp0_partition=dsp0
      #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
      setargs_nand=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      #nand command syntax: sunxi_flash read address partition_name read_bytes
      #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
      #boot_dsp0=sunxi_flash read 43000000 ${dsp0_partition};bootr 43000000 0 0
      #boot_normal=sunxi_flash read 43000000 ${boot_partition};bootm 43000000
      boot_recovery=sunxi_flash read 43000000 recovery;bootm 43000000
      boot_fastboot=fastboot
      #uboot system env config
      bootdelay=2
      #default nand boot
      #bootcmd=run setargs_nand boot_dsp0 boot_normal
      bootcmd=run setargs_nand boot_normal
      sys_config.fex中storage_type = 5
      看日志似乎和分区表sys_partition.fex有点关系?
      麻烦各位大佬帮忙看看,提供点思路。
      L 1 条回复 最后回复 回复 引用 分享 1
        leokemp LV 3 @leokemp 最后由 编辑
        看日志说的是找不发到env-redund分区
        [17:26:53.990] *** Warning - no device, using default environment
        但是我的sys_partition.fex已经了加了这个分区来着
        [code]
        ;    mbr的大小, 以Kbyte为单位
        [mbr]
        size = 252
        ;  partition 定义范例:
        ; 注:1、name唯一, 不允许同名
        ;     2、name最大12个字符
        ;     4、align to logical block size(504 sectors), leb size = 2*(1 nand phy block size - 1 phy page size)
        [partition_start]
        [partition]
            name         = boot-resource
            size         = 504
            user_type    = 0x8000
        [partition]
            name         = env
            size         = 504
            downloadfile = "env.fex"
            user_type    = 0x8000
        [partition]
            name         = env-redund
            size         = 504
            user_type    = 0x8000
        [partition]
            name         = boot
            size         = 20160
            downloadfile = "boot.fex"
            user_type    = 0x8000
        [partition]
            name         = rootfs
            size         = 61440
            downloadfile = "rootfs.fex"
            user_type    = 0x8000
        [partition]
            name         = private
            size         = 10080
            user_type    = 0x8000
        [partition]
            name         = recovery
            size         = 23184
            ;downloadfile = "recovery.fex"
            user_type    = 0x8000
        [/code]
          leokemp LV 3 最后由 编辑
          对比下能够正常启动的固件,和不能正常启动的日志,差异如下,目前还没找到问题的解决办法来着。
          正常
          [17:24:57.908] [01.880]Loading Environment from SUNXI_FLASH... OK
          异常
          [11:12:03.078] [01.569]Loading Environment from SUNXI_FLASH... Can't find env-redund partition
          [11:12:03.158] *** Warning - no device, using default environment
          正常
          [17:24:57.698] partno erro : can't find partition bootloader
          异常
          [11:12:03.178] partno erro : can't find partition bootloader
          [11:12:03.199] partno erro : can't find partition boot-resource
          [11:12:03.219] [01.662]Get bootloader and boot-resource partition number fail!
          正常
          [17:24:59.469] List file under ULI/factory
          [17:24:59.469] ** Unrecognized filesystem type **
          异常
          [11:12:03.838] cann't get the boot_base from the env
            zoipuus LV 5 最后由 编辑
            看一下openWRT配置,在根目录执行make menuconfig,搜索redund看看
             Symbol: SUNXI_MAKE_REDUNDANT_ENV [=y]        │
              │ Type  : bool        │
              │ Defined at target/linux/generic/image/Config.in:223        │
              │   Prompt: sunxi make redundant env data        │
              │   Location:        │
              │ (1) -> Target Images        │
              │ Symbol: SUNXI_REDUNDANT_ENV_SIZE [=0x20000]        │
              │ Type  : string        │
              │ Defined at target/linux/generic/image/Config.in:229        │
              │   Prompt: redundant env data size        │
              │   Depends on: SUNXI_MAKE_REDUNDANT_ENV [=y]        │
              │   Location:        │
              │     -> Target Images        │
              │ (2)   -> sunxi make redundant env data (SUNXI_MAKE_REDUNDANT_ENV [=y])
