    使用T113S3 tina linux驱动ST7701S RGB长条屏幕,显示lvgl demo分两半问题
      leokemp LV 3 最后由 编辑
      问题卡了两周,各位路过的大佬帮忙看看呗!感激不尽
      使用T113S3 tina linux驱动ST7701S RGB屏幕,打开lvgl demo,显示分了两半的问题:
      通过指令保存的图片是正常的:
      echo 0 > /sys/class/disp/disp/attr/disp
      echo /data/1.bmp > /sys/class/disp/disp/attr/capture_dump
      厂家给的参数:
      HS:10 HBP:30 HFP: 50
      VS:2 VBP:15 VFP:17
      400*960
      DTS部分配置如下:
      &disp {
      	disp_rotation_used		 = <1>;
      	degree0					 = <0>;
      	fb0_width                = <400>;
      	fb0_height               = <960>;  /*read from lcd*/
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      &lcd0 {
          lcd_used            = <1>;
          lcd_driver_name     = "st7701s_rgb";
          lcd_if              = <0>;  //0:rgb 1:CPU/I80 2:保留 3:lvds 4:dsi
          lcd_hv_if           = <0>;  //0:并行rgb
          lcd_width           = <46>; //物理宽度 mm
          lcd_height          = <110>;  //物理高度 mm
          lcd_x               = <400>; //宽度
          lcd_y               = <960>; //高度
          lcd_dclk_freq       = <29>;  //屏幕时钟 MHz
          lcd_hbp             = <40>;  //hbp+hspw,从时序图可以看到hspw包含在hbp中,所以只需要填写hbp的值
          lcd_ht              = <490>;  //lcd_x+hs+hbp+hspw
          lcd_hspw            = <10>;  //hspw
          lcd_vbp             = <17>;  //vbp+vspw
          lcd_vt              = <994>;  //lcd_y+vs+vbp+vspw
          lcd_vspw            = <2>;   //vspw
          lcd_backlight       = <50>; //背光默认亮度
          lcd_pwm_used        = <1>;  //使用背光
          lcd_pwm_ch          = <7>;  //使用pwm通道7
          lcd_pwm_freq        = <10000>; //PWM 频率,单位 Hz
          lcd_pwm_pol         = <0>;  //背光 PWM 的极性
          lcd_pwm_max_limit   = <255>;
          lcd_bright_curve_en = <0>;
          lcd_dsi_if          = <0>;
          lcd_dsi_lane        = <4>;
          lcd_lvds_if         = <0>;
          lcd_lvds_colordepth = <0>;
          lcd_lvds_mode       = <0>;
          lcd_frm             = <1>;
          lcd_hv_clk_phase    = <0>;
          lcd_hv_sync_polarity= <0>;
          lcd_gamma_en        = <0>;
          lcd_cmap_en         = <0>;
          lcd_fsync_en        = <0>;
          lcd_fsync_act_time  = <1000>;
          lcd_fsync_dis_time  = <1000>;
          lcd_fsync_pol       = <0>;
          deu_mode            = <0>;
          lcdgamma4iep        = <22>;
          smart_color         = <90>;
          pinctrl-0 = <&rgb18_pins_a>;
          pinctrl-1 = <&rgb18_pins_b>;
          lcd_gpio_0 = <&pio PE 9 GPIO_ACTIVE_HIGH>; //RST
          lcd_gpio_1 = <&pio PE 8 GPIO_ACTIVE_HIGH>; //CS
          lcd_gpio_2 = <&pio PE 7 GPIO_ACTIVE_HIGH>; //SDA
          lcd_gpio_3 = <&pio PE 6 GPIO_ACTIVE_HIGH>; //SCK
      驱动部分参考sdk的st7701改的,spi+rgb驱动
      #include "st7701s_rgb.h"
      #include "default_panel.h"
      //s32 sunxi_lcd_gpio_set_value(u32 screen_id, u32 io_index, u32 value)
      #define st7701s_spi_scl_1   sunxi_lcd_gpio_set_value(0, 3, 1)
      #define st7701s_spi_scl_0   sunxi_lcd_gpio_set_value(0, 3, 0)
      #define st7701s_spi_sdi_1   sunxi_lcd_gpio_set_value(0, 2, 1)
      #define st7701s_spi_sdi_0   sunxi_lcd_gpio_set_value(0, 2, 0)
      #define st7701s_spi_cs_1    sunxi_lcd_gpio_set_value(0, 1, 1)
      #define st7701s_spi_cs_0    sunxi_lcd_gpio_set_value(0, 1, 0)
      #define st7701s_spi_reset_1 sunxi_lcd_gpio_set_value(0, 0, 1)
      #define st7701s_spi_reset_0 sunxi_lcd_gpio_set_value(0, 0, 0)
      static void LCD_cfg_panel_info(panel_extend_para *info)
          u32 i = 0, j = 0;
          u32 items;
          u8 lcd_gamma_tbl[][2] = {
              /* {input value, corrected value} */
              {0, 0},
              {15, 15},
              {30, 30},
              {45, 45},
              {60, 60},
              {75, 75},
              {90, 90},
              {105, 105},
              {120, 120},
              {135, 135},
              {150, 150},
              {165, 165},
              {180, 180},
              {195, 195},
              {210, 210},
              {225, 225},
              {240, 240},
              {255, 255},
          u32 lcd_cmap_tbl[2][3][4] = {
              for (j = 0; j < num; j++) {
                  u32 value = 0;
                  value =
                      lcd_gamma_tbl[i][1] +
                      ((lcd_gamma_tbl[i + 1][1] -
                        lcd_gamma_tbl[i][1]) * j) / num;
                      (value << 16) + (value << 8) + value;
          info->lcd_gamma_tbl[255] =
              (lcd_gamma_tbl[items - 1][1] << 16) +
              (lcd_gamma_tbl[items - 1][1] << 8) + lcd_gamma_tbl[items - 1][1];
          printk("=====================LCD_open_flow\n");
          /* open lcd power, and delay 50ms */
          LCD_OPEN_FUNC(sel, LCD_power_on, 20);
          /* open lcd power, than delay 200ms */
          LCD_OPEN_FUNC(sel, LCD_panel_init, 20);
          /* open lcd controller, and delay 100ms */
          LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 100);
          /* open lcd backlight, and delay 0ms */
          /* close lcd backlight, and delay 0ms */
          LCD_CLOSE_FUNC(sel, LCD_bl_close, 0);
          /* close lcd controller, and delay 0ms */
          LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
          LCD_CLOSE_FUNC(sel, LCD_panel_exit, 200);
          /* close lcd power, and delay 500ms */
          LCD_CLOSE_FUNC(sel, LCD_power_off, 500);
          printk("=====================LCD_power_on\n");
          /* config lcd_power pin to open lcd power0 */
          sunxi_lcd_power_enable(sel, 0);
          sunxi_lcd_pin_cfg(sel, 1);
          sunxi_lcd_pin_cfg(sel, 0);
          /* config lcd_power pin to close lcd power0 */
          sunxi_lcd_power_disable(sel, 0);
          printk("=====================LCD_bl_open\n");
          sunxi_lcd_pwm_enable(sel);
          sunxi_lcd_backlight_enable(sel);
          /* config lcd_bl_en pin to close lcd backlight */
          sunxi_lcd_pwm_disable(sel);
      //three line 9bit mode
      static void LCD_WRITE_DATA(u32 value)
          u32 i;
          st7701s_spi_cs_0;
          st7701s_spi_sdi_1;
          st7701s_spi_scl_0;
          sunxi_lcd_delay_us(10);
          st7701s_spi_scl_1;
          for (i = 0; i < 8; i++) {
              if (value & 0x80)
                  st7701s_spi_sdi_1;
                  st7701s_spi_sdi_0;
              value <<= 1;
              st7701s_spi_scl_0;
              st7701s_spi_scl_1;
          st7701s_spi_cs_1;
      static void LCD_WRITE_COMMAND(u32 value)
          u32 i;
          st7701s_spi_cs_0;
          st7701s_spi_sdi_0;
          st7701s_spi_scl_0;
          st7701s_spi_scl_1;
              if (value & 0x80)
                  st7701s_spi_sdi_1;
                  st7701s_spi_sdi_0;
              st7701s_spi_scl_0;
              st7701s_spi_scl_1;
              value <<= 1;
          st7701s_spi_cs_1;
          printk("=====================LCD_panel_init\n");
          //ST7701S+AUO4.58
          LCD_WRITE_COMMAND (0xFF);
          LCD_WRITE_DATA (0x77);
          LCD_WRITE_DATA (0x01);
          LCD_WRITE_DATA (0x00);
          LCD_WRITE_DATA (0x13);
          LCD_WRITE_COMMAND (0xEF);
          LCD_WRITE_DATA (0x08);
          LCD_WRITE_DATA (0x10);
          LCD_WRITE_COMMAND (0xC0);
          LCD_WRITE_COMMAND (0xC1);
          LCD_WRITE_DATA (0x09);
          LCD_WRITE_COMMAND (0xC2);//inv
          LCD_WRITE_DATA (0x02);
          LCD_WRITE_COMMAND (0xC3); //????
          LCD_WRITE_DATA (0x02); //82 HVmode    02 DEmode
          LCD_WRITE_COMMAND (0xCC);
          LCD_WRITE_COMMAND (0xB0);
          LCD_WRITE_DATA (0x40);
          LCD_WRITE_DATA (0x14);
          LCD_WRITE_DATA (0x59);
          LCD_WRITE_DATA (0x12);
          LCD_WRITE_DATA (0x03);
          LCD_WRITE_DATA (0x05);
          LCD_WRITE_DATA (0x1E);
          LCD_WRITE_DATA (0x68);
          LCD_WRITE_DATA (0x33);
          LCD_WRITE_DATA (0x15);
          LCD_WRITE_COMMAND (0xB1);
          LCD_WRITE_DATA (0x53);
          LCD_WRITE_DATA (0x11);
          LCD_WRITE_DATA (0x07);
          LCD_WRITE_DATA (0x1A);
          LCD_WRITE_DATA (0x04);
          LCD_WRITE_DATA (0x64);
          LCD_WRITE_DATA (0x29);
          LCD_WRITE_DATA (0x6D);  //6D
          LCD_WRITE_COMMAND (0xB1);   //vcom
          LCD_WRITE_DATA (0x1D);
          LCD_WRITE_COMMAND (0xB2);
          LCD_WRITE_DATA (0x87);
          LCD_WRITE_COMMAND (0xB3);
          LCD_WRITE_DATA (0x80);
          LCD_WRITE_COMMAND (0xB5);
          LCD_WRITE_DATA (0x49);
          LCD_WRITE_COMMAND (0xB7);
          LCD_WRITE_DATA (0x85);
          LCD_WRITE_COMMAND (0xB8);
          LCD_WRITE_DATA (0x20);
          LCD_WRITE_DATA (0x78);
          LCD_WRITE_COMMAND (0xD0);
          LCD_WRITE_DATA (0x88);
          LCD_WRITE_COMMAND (0xE0);
          LCD_WRITE_COMMAND (0xE1);
          LCD_WRITE_DATA (0x8C);
          LCD_WRITE_COMMAND (0xE2);
          LCD_WRITE_DATA (0xC9);
          LCD_WRITE_DATA (0x3C);
          LCD_WRITE_DATA (0xCA);
          LCD_WRITE_COMMAND (0xE3);
          LCD_WRITE_COMMAND (0xE4);
          LCD_WRITE_DATA (0x44);
          LCD_WRITE_COMMAND (0xE5);
          LCD_WRITE_DATA (0xCD);
          LCD_WRITE_DATA (0x82);
          LCD_WRITE_DATA (0xCF);
          LCD_WRITE_DATA (0xCB);
          LCD_WRITE_COMMAND (0xE6);
          LCD_WRITE_COMMAND (0xE7);
          LCD_WRITE_COMMAND (0xE8);
          LCD_WRITE_DATA (0x06);
          LCD_WRITE_DATA (0xCE);
          LCD_WRITE_DATA (0xD0);
          LCD_WRITE_DATA (0xCC);
          LCD_WRITE_COMMAND (0xEB);
          LCD_WRITE_DATA (0xE4);
          LCD_WRITE_COMMAND (0xEC);
          LCD_WRITE_COMMAND (0xED);
          LCD_WRITE_DATA (0xFF);
          LCD_WRITE_DATA (0xF0);
          LCD_WRITE_DATA (0x65);
          LCD_WRITE_DATA (0x4F);
          LCD_WRITE_DATA (0xFC);
          LCD_WRITE_DATA (0xC2);
          LCD_WRITE_DATA (0x2F);
          LCD_WRITE_DATA (0xF2);
          LCD_WRITE_DATA (0x2C);
          LCD_WRITE_DATA (0xF4);
          LCD_WRITE_DATA (0x56);
          LCD_WRITE_DATA (0x70);
          LCD_WRITE_DATA (0x0F);
          LCD_WRITE_DATA (0x0D);
          LCD_WRITE_DATA (0x3F);
          LCD_WRITE_DATA (0x1F);
          LCD_WRITE_COMMAND (0x11);
          sunxi_lcd_delay_ms(120);
          LCD_WRITE_COMMAND (0x35);
          LCD_WRITE_COMMAND (0x3A);
          LCD_WRITE_DATA (0x66);
          //LCD_WRITE_COMMAND (0x11);
          //sunxi_lcd_delay_ms(120);
          LCD_WRITE_COMMAND (0x29);
          return;
          return;
      /* sel: 0:lcd0; 1:lcd1 */
      static s32 LCD_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
      __lcd_panel_t st7701s_rgb_panel = {
          /* panel driver name, must mach the lcd_drv_name in sys_config.fex */
          .name = "st7701s_rgb",
          .func = {
               .cfg_panel_info = LCD_cfg_panel_info,
               .lcd_user_defined_func = LCD_user_defined_func,
