    全志F133A SPI FLASH启动卡死
    H/F/TV Series
      haodada LV 2 最后由 编辑
      求大神帮忙看看,用SPI FLASH启动失败
      [55]HELLO! BOOT0 is starting!
      [58]BOOT0 commit : adaf1174cc
      [60]set pll start
      [62]periph0 has been enabled
      [65]set pll end
      [67][pmu]: bus read error
      [69]board init ok
      [71]ZQ value = 0x2e
      [73]get_pmu_exist() = -1
      [75]DRAM BOOT DRIVE INFO: V0.33
      [78]DRAM CLK = 528 MHz
      [80]DRAM Type = 2 (2:DDR2,3:DDR3)
      [83]DRAMC read ODT off.
      [85]DRAM ODT off.
      [87]ddr_efuse_type: 0xb
      [90]DRAM SIZE =64 M
      [92]dram_tpr4:0x0
      [93]PLL_DDR_CTRL_REG:0xf8002b00
      [96]DRAM_CLK_REG:0xc0000000
      [99][TIMING DEBUG] MR2= 0x0
      [103]DRAM simple test OK.
      [106]dram size =64
      [108]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [113]block from 8 to 32
      [173]Check is correct.
      [175]dma 0x306c8 int is not used yet
      [178]dma 0x306c8 int is free, you do not need to free it again
      [184]Entry_name = opensbi
      [187]Entry_name = u-boot
      [191]Entry_name = dtb
      [193]Jump to second Boot.
      OpenSBI auto-t113-linux-V0.8-1-g771d82e
      / __ \ / | _ _ |
      __ ___ _ __ | (
      | | | | '_ \ / _ \ '_ \ ___ | _ < | |
      | || | |) | __/ | | |) | |) || |
      _
      /| ./ _|| ||/|____/|
      |_|
      Platform Name : T-HEAD Xuantie Platform
      Platform Max HARTs : 1
      Current Hart : 0
      Firmware Base : 0x41fc0400
      Firmware Size : 75 KB
      Runtime SBI Version : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP0 : 0x0000000041fc0000-0x0000000041fdffff (A)
      PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
      PMP2 : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
      PMP3 : 0x0000000000020000-0x0000000000027fff (A,▒
      U-Boot 2018.05-g2a1965a (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
      [00.279]DRAM: 64 MiB
      [00.281]Relocation Offset is: 01ed9000
      [00.285]secure enable bit: 0
      [00.288]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [00.294]flash init start
      [00.296]workmode = 0,storage type = 0
      [00.303]sunxi-spinand-phy: spinand sample_mode:2 sample_delay:1
      #: name size offset mask_flags
      0: boot0 0x00100000 0x00000000 1
      1: uboot 0x00300000 0x00100000 1
      2: secure_storage 0x00100000 0x00400000 1
      3: sys 0x07b00000 0x00500000 0
      defaults:
      mtdids : nand0=nand
      [00.418]ubi0: attaching mtd4
      [00.514]ubi0: scanning is finished
      [00.520]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.525]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.531]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.537]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.544]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [00.549]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.556]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.563]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [00.572]sunxi flash init ok
      [00.575]line:703 init_clocks
      [00.578]drv_disp_init
      [00.596]unable to map hdmi registers
      [00.599]drv_disp_init finish
      [00.696]Loading Environment from SUNXI_FLASH... OK
      [00.717]boot_gui_init:start
      [00.720]set disp.dev2_output_type fail. using defval=0
      [00.728]boot_gui_init:finish
      [00.748]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 3 ms (12.2 MiB/s)
      [00.759]out of usb burn from boot: not need burn key
      [00.764]Item0 (Map) magic is bad
      List file under ULI/factory
      [00.783]update bootcmd
      [00.795]change working_fdt 0x42a98da0 to 0x42a78da0
      [00.823]update dts
      noncached_alloc(): addr = 0x42b27080
      noncached_alloc(): addr = 0x42b1da00
      noncached_alloc(): addr = 0x42b1da40
      noncached_alloc(): addr = 0x42b1e280
      geth_sys_init:639: get node 'gmac0' error
      geth_sys_init fail!
      [00.843]Board Net Initialization Failed
      [00.846]No ethernet found.
      Hit any key to stop autoboot: 1 FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
      [00.918]LCD open finish 0
      [02.186]no vendor_boot partition is found
      Android's image name: f133-mq_r
      Detect comp none
      [02.202]
      Starting kernel ...
      [ 0.000000] Linux version 5.4.61 (test@test-virtual-machine) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #10 PREEMPT Mon Sep 2 08:13:54 UTC 2024
      [ 0.000000] Zone ranges:
      [ 0.000000] DMA32 [mem 0x0000000040000000-0x0000000043ffffff]
      [ 0.000000] Normal empty
      [ 0.000000] Movable zone start for each node
      [ 0.000000] Early memory node ranges
      [ 0.000000] node 0: [mem 0x0000000040000000-0x0000000043ffffff]
      [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
      [ 0.000000] On node 0 totalpages: 16384
      [ 0.000000] DMA32 zone: 224 pages used for memmap
      [ 0.000000] DMA32 zone: 0 pages reserved
      [ 0.000000] DMA32 zone: 16384 pages, LIFO batch:3
      [ 0.000000] elf_hwcap is 0x20112d
      [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
      [ 0.000000] pcpu-alloc: [0] 0
      [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16160
      [ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g2a1965a(07/10/2022-02:50:57) mbr_offset=155648
      [ 0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [ 0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [ 0.000000] Sorting __ex_table...
      [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [ 0.000000] Memory: 55896K/65536K available (4125K kernel code, 402K rwdata, 1700K rodata, 136K init, 229K bss, 9640K reserved, 0K cma-reserved)
      [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
      [ 0.000000] Tasks RCU enabled.
      [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
      [ 0.000000] plic: mapped 200 interrupts with 1 handlers for 2 contexts.
      [ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
      [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      [ 0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [ 0.000026] riscv_timer_clockevent depends on broadcast, but no broadcast function available
      [ 0.000361] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [ 0.000941] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [ 0.000963] pid_max: default: 32768 minimum: 301
      [ 0.001123] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [ 0.001139] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [ 0.002822] ASID allocator initialised with 65536 entries
      [ 0.002998] rcu: Hierarchical SRCU implementation.
      [ 0.003675] devtmpfs: initialized
      [ 0.021576] random: get_random_u32 called from bucket_table_alloc.isra.27+0x102/0x124 with crng_init=0
      [ 0.022441] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [ 0.022472] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
      [ 0.022615] pinctrl core: initialized pinctrl subsystem
      [ 0.023997] NET: Registered protocol family 16
      [ 0.024773] DMA: preallocated 256 KiB pool for atomic allocations
      [ 0.025445] cpuidle: using governor menu
      [ 0.067347] rtc_ccu: sunxi ccu init OK
      [ 0.076118] clock: sunxi ccu init OK
      [ 0.077794] clock: sunxi ccu init OK
      [ 0.106609] iommu: Default domain type: Translated
      [ 0.106804] sunxi iommu: irq = 4
      [ 0.108020] SCSI subsystem initialized
      [ 0.108274] usbcore: registered new interface driver usbfs
      [ 0.108365] usbcore: registered new interface driver hub
      [ 0.108474] usbcore: registered new device driver usb
      [ 0.109476] Advanced Linux Sound Architecture Driver Initialized.
      [ 0.110747] pwm module init!
      [ 0.112382] g2d 5410000.g2d: Adding to iommu group 0
      [ 0.112894] G2D: rcq version initialized.major:252
      [ 0.113922] clocksource: Switched to clocksource riscv_clocksource
      [ 0.127917] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [ 0.131248] NET: Registered protocol family 2
      [ 0.132132] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      [ 0.132172] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      [ 0.132190] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      [ 0.132205] TCP: Hash tables configured (established 512 bind 512)
      [ 0.132344] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [ 0.132387] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [ 0.132611] NET: Registered protocol family 1
      [ 0.133804] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [ 0.134524] spi spi0: spi0 supply spi not found, using dummy regulator
      [ 0.134803] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
      [ 0.134868] sunxi_spi_resource_get()2163 - sample_mode:2 sample_delay:1
      [ 0.134946] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
      [ 0.135778] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
      [ 0.137934] workingset: timestamp_bits=62 max_order=14 bucket_order=0
      [ 0.146263] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [ 0.146508] ntfs: driver 2.1.32 [Flags: R/W].
      [ 0.146826] fuse: init (API version 7.31)
      [ 0.168695] io scheduler mq-deadline registered
      [ 0.168710] io scheduler kyber registered
      [ 0.169619] [DISP]disp_module_init
      [ 0.170242] disp 5000000.disp: Adding to iommu group 0
      [ 0.170828] [DISP] parser_disp_init_para,line:1430:
      [ 0.170834] of_property_read fb0_width fail
      [ 0.170854] [DISP] disp_init,line:2386:
      [ 0.170858] smooth display screen:0 type:1 mode:4
      [ 0.212010] display_fb_request,fb_id:0
      [ 0.220325] Freeing logo buffer memory: 1500K
      [ 0.220863] disp_al_manager_apply ouput_type:1
      [ 0.221307] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [ 0.222108] [DISP]disp_module_init finish
      [ 0.223021] sunxi_sid_init()551 - insmod ok
      [ 0.223619] pwm-regulator: supplied by regulator-dummy
      [ 0.225457] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [ 0.225941] uart uart0: uart0 supply uart not found, using dummy regulator
      [ 0.226331] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
      [ 0.226361] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [ 0.928466] printk: console [ttyS0] enabled
      [ 0.934398] misc dump reg init
      [ 0.938867] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [ 0.950137] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [ 0.957452] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [ 0.964780] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [ 0.972199] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [ 0.978739] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [ 0.985690] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [ 0.993417] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [ 1.001302] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [ 1.009504] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [ 1.017212] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [ 1.024040] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [ 1.031551] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      [ 1.039818] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [ 1.047641] [ADDR_MGT] addr_mgt_probe: success.
      [ 1.053684] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
      [ 1.061015] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      [ 1.068873] sunxi-spinand-phy: not detect any munufacture from id table
      [ 1.076361] sunxi-spinand-phy: get spi-nand Model from fdt fail
      [ 1.082962] sunxi-spinand-phy: get phy info from fdt fail
      [ 1.089047] sunxi-spinand-phy: not detect munufacture from fdt
      [ 1.095715] sunxi-spinand-phy: detect munufacture from id table: Winbond
      [ 1.103189] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [ 1.110238] sunxi-spinand-phy: ========== arch info ==========
      [ 1.116769] sunxi-spinand-phy: Model: W25N01GVZEIG
      [ 1.123482] sunxi-spinand-phy: Munufacture: Winbond
      [ 1.129717] sunxi-spinand-phy: DieCntPerChip: 1
      [ 1.135367] sunxi-spinand-phy: BlkCntPerDie: 1024
      [ 1.141300] sunxi-spinand-phy: PageCntPerBlk: 64
      [ 1.147049] sunxi-spinand-phy: SectCntPerPage: 4
      [ 1.152678] sunxi-spinand-phy: OobSizePerPage: 64
      [ 1.158451] sunxi-spinand-phy: BadBlockFlag: 0x0
      [ 1.164301] sunxi-spinand-phy: OperationOpt: 0x7
      [ 1.170120] sunxi-spinand-phy: MaxEraseTimes: 65000
      [ 1.176177] sunxi-spinand-phy: EccFlag: 0x0
      [ 1.181998] sunxi-spinand-phy: EccType: 2
      [ 1.187652] sunxi-spinand-phy: EccProtectedType: 3
      [ 1.193296] sunxi-spinand-phy: ========================================
      [ 1.200695] sunxi-spinand-phy:
      [ 1.204212] sunxi-spinand-phy: ========== physical info ==========
      [ 1.211115] sunxi-spinand-phy: TotalSize: 128 M
      [ 1.216479] sunxi-spinand-phy: SectorSize: 512 B
      [ 1.221815] sunxi-spinand-phy: PageSize: 2 K
      [ 1.227010] sunxi-spinand-phy: BlockSize: 128 K
      [ 1.232345] sunxi-spinand-phy: OOBSize: 64 B
      [ 1.237610] sunxi-spinand-phy: ========================================
      [ 1.245034] sunxi-spinand-phy:
      [ 1.248531] sunxi-spinand-phy: ========== logical info ==========
      [ 1.255345] sunxi-spinand-phy: TotalSize: 128 M
      [ 1.260698] sunxi-spinand-phy: SectorSize: 512 B
      [ 1.266063] sunxi-spinand-phy: PageSize: 4 K
      [ 1.271207] sunxi-spinand-phy: BlockSize: 256 K
      [ 1.276593] sunxi-spinand-phy: OOBSize: 128 B
      [ 1.281930] sunxi-spinand-phy: ========================================
      [ 1.289336] sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
      [ 1.296382] sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
      [ 1.303467] sunxi-spinand-phy: block lock register: 0x00
      [ 1.309583] sunxi-spinand-phy: feature register: 0x19
      [ 1.315256] sunxi-spinand-phy: sunxi physic nand init end
      [ 1.321980] Creating 4 MTD partitions on "sunxi_mtd_nand":
      [ 1.328256] 0x000000000000-0x000000100000 : "boot0"
      [ 1.344810] 0x000000100000-0x000000500000 : "uboot"
      [ 1.353103] random: fast init done
      [ 1.364822] 0x000000500000-0x000000600000 : "secure_storage"
      [ 1.384742] 0x000000600000-0x000008000000 : "sys"
      [ 1.564955] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [ 1.572238] sunxi-ehci: EHCI SUNXI driver
      [ 1.577270] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [ 1.584246] sunxi-ohci: OHCI SUNXI driver
      [ 1.589949] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [ 1.600978] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [ 1.611736] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [ 1.623004] sunxi-rtc 7090000.rtc: registered as rtc0
      [ 1.628775] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [ 1.639384] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:46 UTC (46)
      [ 1.648436] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [ 1.654431] i2c /dev entries driver
      [ 1.658362] sunxi cedar version 1.1
      [ 1.662568] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [ 1.668874] VE: install start!!!
      [ 1.668874]
      [ 1.674435] VE: cedar-ve the get irq is 6
      [ 1.674435]
      [ 1.680811] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [ 1.680811]
      [ 1.692400] VE: install end!!!
      [ 1.692400]
      [ 1.697517] VE: sunxi_cedar_probe
      [ 1.702206] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [ 1.713744] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [ 1.723766] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
      [ 1.730038] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [ 1.736382] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [ 1.742787] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [ 1.749258] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [ 1.755793] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [ 1.762315] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [ 1.768850] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [ 1.775869] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [ 1.781248] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [ 1.787938] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.799134] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [ 1.819298] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.843829] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [ 1.849555] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.861897] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [ 1.872044] sunxi-mmc 4021000.sdmmc: ctl-spec-caps 8
      [ 1.878348] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [ 1.884747] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [ 1.891192] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.902810] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [ 1.909252] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [ 1.915932] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [ 1.922482] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [ 1.929098] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [ 1.935710] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [ 1.944478] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.956876] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.968200] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [ 1.977528] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.989154] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 2.013520] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [ 2.021387] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [ 2.028752] ashmem: initialized
      [ 2.032297] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [ 2.039199] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 2.050860] exFAT: Version 1.3.0
      [ 2.057646] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 2.069301] mmc0: host does not support reading read-only switch, assuming write-enable
      [ 2.080397] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [ 2.080397]
      [ 2.097772] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [ 2.108737] mmc0: Problem switching card into high-speed mode!
      [ 2.115535] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 2.127293] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [ 2.134412] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [ 2.142589] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [ 2.149597] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
      [ 2.161349] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [ 2.168983] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [ 2.175783] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [ 2.187571] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [ 2.197477] mmc0: new SDHC card at address 0001
      [ 2.203062] [SNDCODEC][sunxi_card_init][583]:card init finished
      [ 2.210798] mmcblk0: mmc0:0001 SD 7.50 GiB
      [ 2.218141] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [ 2.232421] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [ 2.244021] mmcblk0: p1
      [ 2.248579] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [ 2.258170] NET: Registered protocol family 10
      [ 2.264097] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [ 2.271996] Segment Routing with IPv6
      [ 2.276471] NET: Registered protocol family 17
      [ 2.304672] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [ 2.319500] sunxi-i2c sunxi-i2c2: probe success
      [ 2.326884] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [ 2.340902] get ehci0-controller wakeup-source is fail.
      [ 2.346890] sunxi ehci0-controller don't init wakeup source
      [ 2.353145] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000661b28, 0x:ffffffd0040fa000, irq_no:2e
      [ 2.366690] [sunxi-ehci0]: Not init ehci0
      [ 2.371697] get ohci0-controller wakeup-source is fail.
      [ 2.377695] sunxi ohci0-controller don't init wakeup source
      [ 2.384007] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000661ef0
      [ 2.394415] [sunxi-ohci0]: Not init ohci0
      [ 2.399425] get ehci1-controller wakeup-source is fail.
      [ 2.405409] sunxi ehci1-controller don't init wakeup source
      [ 2.411628] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0006622b8, 0x:ffffffd004835000, irq_no:31
      [ 2.425526] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [ 2.439157] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [ 2.446435] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [ 2.456356] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
      [ 2.493980] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [ 2.502858] hub 1-0:1.0: USB hub found
      [ 2.507179] hub 1-0:1.0: 1 port detected
      [ 2.512677] get ohci1-controller wakeup-source is fail.
      [ 2.518754] sunxi ohci1-controller don't init wakeup source
      [ 2.525056] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000662680
      [ 2.535838] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [ 2.548272] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [ 2.555610] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [ 2.565438] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
      [ 2.639065] hub 2-0:1.0: USB hub found
      [ 2.643311] hub 2-0:1.0: 1 port detected
      [ 2.650768] get usb_detect_mode is fail, -22
      [ 2.655654] get det_vbus is fail, -84
      [ 2.659736] get id is fail, -84
      [ 2.665787] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [ 2.675522] clk: Not disabling unused clocks
      [ 2.680291] ALSA device list:
      [ 2.683644] #0: audiocodec
      [ 2.686948] cfg80211: failed to load regulatory.db
      [ 2.692355] alloc_fd: slot 0 not NULL!
      [ 2.697069] VFS: Cannot open root device "mmcblk0p5" or unknown-block(179,5): error -6
      [ 2.706033] Please append a correct "root=" boot option; here are the available partitions:
      [ 2.715422] 1f00 1024 mtdblock0
      [ 2.715426] (driver?)
      [ 2.722738] 1f01 4096 mtdblock1
      [ 2.722740] (driver?)
      [ 2.730098] 1f02 1024 mtdblock2
      [ 2.730101] (driver?)
      [ 2.737460] 1f03 124928 mtdblock3
      [ 2.737463] (driver?)
      [ 2.744776] b300 7864320 mmcblk0
      [ 2.744781] driver: mmcblk
      [ 2.752374] b301 7864288 mmcblk0p1 008b7d5c-01
      [ 2.752376]
      [ 2.760145] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
      [ 2.769563] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #10
      [ 2.776060] Call Trace:
      [ 2.778800] [<ffffffe000023d56>] walk_stackframe+0x0/0x70
      [ 2.784823] [<ffffffe000027d2c>] panic+0xdc/0x266
      [ 2.790070] [<ffffffe000000d9c>] mount_block_root+0x1fe/0x266
      [ 2.796479] [<ffffffe000000fc2>] prepare_namespace+0x136/0x144
      [ 2.802985] [<ffffffe000424ab6>] rest_init+0xbc/0xc0
      [ 2.808517] [<ffffffe000424ac4>] kernel_init+0xa/0xe8
      [ 2.814144] [<ffffffe000424ab6>] rest_init+0xbc/0xc0
      [ 2.819678] [<ffffffe000022d5c>] ret_from_syscall+0xa/0xe
      [ 2.825705] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5) ]---
