    V853S mipi LCD显示驱动调试,colorbar显示异常
      steven73 LV 4 最后由 编辑
      V853S调试mipi显示驱动时,colorbar输出如下图,顺序有点乱;有大佬知道这是哪块的问题么(驱动,dts),看论坛里大家说是驱动初始化配置的问题,不知大佬能否提供调试思路。
      1、echo 2 > /sys/class/disp/disp/attr/colorbar
      2、echo 1 > /sys/class/disp/disp/attr/colorbar
      3、echo 7 > /sys/class/disp/disp/attr/colorbar
        awwwwa LV 8 最后由 awwwwa 编辑
        dclk过高,屏幕分屏了?
        这里提供一个py脚本计算分频系数,这里对应的是HV屏,DSI也可以参考
        def find_closest_clock(target_clock, clock_list):
            clock_list = sorted(clock_list)
            low, high = 0, len(clock_list) - 1
            closest = clock_list[low]
            while low <= high:
                mid = (low + high) // 2
                if clock_list[mid] < target_clock:
                    low = mid + 1
                elif clock_list[mid] > target_clock:
                    high = mid - 1
                else:
                    return clock_list[mid]
                if abs(clock_list[mid] - target_clock) < abs(closest - target_clock):
                    closest = clock_list[mid]
            return closest
        def calculate_divisor(clock_need, clock_list, min_divisor=6):
            is_perfect = True
            for i in clock_list:
                for j in range(0, 255):
                    if (clock_need * j) == i:
                        closest_clock = i
                        divisor = j
                        return closest_clock, divisor, is_perfect
            is_perfect = False
            closest_clock = find_closest_clock(clock_need, clock_list)
            if closest_clock == 0:
                return None, None, None
            divisor = closest_clock // clock_need
            if divisor < min_divisor:
                min_diff = float('inf')
                best_clock = None
                for clock in clock_list:
                    if clock >= clock_need * min_divisor:
                        current_divisor = clock // clock_need
                        if current_divisor < min_divisor:
                            continue
                        diff = abs(clock - clock_need * current_divisor)
                        if diff < min_diff:
                            min_diff = diff
                            best_clock = clock
                if best_clock is not None:
                    return best_clock, best_clock // clock_need, is_perfect
        clock_list = [
            408, 420, 432, 444, 456, 468, 480, 492, 504, 516, 528, 540, 552, 564,
            576, 588, 600, 612, 624, 636, 648, 660, 672, 684, 696, 708, 720, 732,
            744, 756, 768, 780, 792, 804, 816, 828, 840, 852, 864, 876, 888, 900,
            912, 924, 936, 948, 960, 972, 984, 996, 1008, 1020, 1032, 1044, 1056,
            1068, 1080, 1092, 1104, 1116, 1128, 1140, 1152, 1164, 1176, 1188, 1200,
            1212, 1224, 1236, 1248, 1260, 1272, 1284, 1296, 1308, 1320, 1332, 1344,
            1356, 1368, 1380, 1392, 1404, 1416, 1428, 1440, 1452, 1464, 1476, 1488,
            1500, 1512, 1524, 1536, 1548, 1560, 1572, 1584, 1596, 1608, 1620, 1632,
            1644, 1656, 1668, 1680, 1692
        clock_need = int(input("请输入需要的时钟(MHz): "))
        closest_clock, divisor, is_perfect = calculate_divisor(clock_need, clock_list)
        if is_perfect:
            print(f"父时钟: {closest_clock}MHz, 分频系数: {divisor}, 分频后的频率: {closest_clock / divisor}MHz")
        else:
            print(f"无法找到完美,最近的父时钟: {closest_clock}, 分频系数: {divisor}, 分频后的频率: {closest_clock / divisor}MHz")
        print("请修改分频系数表 clk_tbl 中 HV 分频系数为: {LCD_IF_HV, " + hex(divisor) + ", 1, 1, 0}")
          sy84436446 LV 1 最后由 编辑
          大佬,我的屏和你一样,你是怎么解决的?
