    编译时总有一些包安装不上,会被Hold
      dnvwf LV 3 最后由 编辑
      [ -d /home/wh/tina-v85x/out/v851se-ylai/compile_dir/target/rootfs/tmp ] || mkdir -p /home/wh/tina-v85x/out/v851se-ylai/compile_dir/target/rootfs/tmp
      Installing adb (0.0.1-1) to root...
      Installing libc (-1) to root...
      Installing libgcc (-1) to root...
      Installing aic8800-firmware (1) to root...
      Installing alsa-lib (1.1.4.1-1) to root...
      Installing libpthread (-1) to root...
      Installing librt (-1) to root...
      Installing blkid (2.25.2-4) to root...
      Installing libblkid (2.25.2-4) to root...
      Installing libuuid (2.25.2-4) to root...
      Installing busybox-init-base-files (167-1726625522) to root...
      Installing busybox (1.27.2-3) to root...
      Installing e2fsprogs (1.46.4-1) to root...
      Installing libext2fs (1.46.4-1) to root...
      Installing eudev (3.2.9-1) to root...
      Conffile /home/wh/tina-v85x/out/v851se-ylai/compile_dir/target/rootfs/etc/udev/udev.conf-opkg.backup using maintainer's setting.
      Installing eyesee-mpp-external (1.0-1) to root...
      Installing glog (0.3.5-2) to root...
      Installing libstdcpp (-1) to root...
      Installing libunwind (1.2.1-2) to root...
      Installing eyesee-mpp-framework (1.0-1) to root...
      Installing eyesee-mpp-middleware (1.0-1) to root...
      Installing eyesee-mpp-system (1.0-1) to root...
      Installing zlib (1.2.8-1) to root...
      Installing libexpat (2.1.0-3) to root...
      Installing libawion (1-1) to root...
      Package eyesee-mpp-middleware (1.0-1) installed in root is up to date.
      Installing eyesee-mpp-private-rtsp (1.0-1) to root...
      Package eyesee-mpp-system (1.0-1) installed in root is up to date.
      Installing gdbserver (10.1-1) to root...
      Package glog (0.3.5-2) installed in root is up to date.
      Installing hostapd-common (2020-06-08-32) to root...
      Installing iperf (2.0.10-1) to root...
      Installing uclibcxx (0.2.4-3) to root...
      Installing iw (4.3-1) to root...
      Installing libnl-tiny (0.1-5) to root...
      Installing kernel (4.9.191-1-cf3d21f8d62ea16162f8889f83c0654b) to root...
      Installing liballwinner-base (1-1) to root...
      Package libawion (1-1) installed in root is up to date.
      Package libblkid (2.25.2-4) installed in root is up to date.
      Package libc (-1) installed in root is up to date.
      Installing libconfig (1.4.9-1) to root...
      Package libexpat (2.1.0-3) installed in root is up to date.
      Package libext2fs (1.46.4-1) installed in root is up to date.
      Package libgcc (-1) installed in root is up to date.
      Installing libjpeg (9a-1) to root...
      Installing liblua (5.1.5-1) to root...
      Package libnl-tiny (0.1-5) installed in root is up to date.
      Installing libopenssl (1.1.0i-1) to root...
      Installing libpng (1.2.56-1) to root...
      Package libpthread (-1) installed in root is up to date.
      Package librt (-1) installed in root is up to date.
      Installing libsqlite3 (3120200-1) to root...
      Package libstdcpp (-1) installed in root is up to date.
      Installing libubox (2016-02-26-5326ce1046425154ab715387949728cfb09f4083) to root...
      Installing libubus (2016-01-26-619f3a160de4f417226b69039538882787b3811c) to root...
      Package libunwind (1.2.1-2) installed in root is up to date.
      Package libuuid (2.25.2-4) installed in root is up to date.
      Installing mtd-utils-mkfs.jffs2 (1.5.2-3) to root...
      Installing mtd-utils (1.5.2-3) to root...
      Package mtd-utils (1.5.2-3) installed in root is up to date.
      Installing ota-burnboot (0.1-0.1) to root...
      Installing ramparser (1.6-1.6) to root...
      Installing swupdate (2019.11-5) to root...
      Installing uboot-envtools (2018.03-2) to root...
      Installing tslib (1.15-2) to root...
      Package uboot-envtools (2018.03-2) installed in root is up to date.
      Package uclibcxx (0.2.4-3) installed in root is up to date.
      Installing viplite-driver (vip-1.8.0-1) to root...
      Installing wifimanager-v2.0-demo (0.1-1) to root...
      Installing wifimanager-v2.0 (0.1-1) to root...
      Installing wifimanager-v2.0-lib (0.1-1) to root...
      Installing wirelesscommon (1.0.0-1) to root...
      Package wifimanager-v2.0-lib (0.1-1) installed in root is up to date.
      Package wifimanager-v2.0 (0.1-1) installed in root is up to date.
      Package wirelesscommon (1.0.0-1) installed in root is up to date.
      Installing wpa-cli (2020-06-08-32) to root...
      Installing wpad-basic-openssl (2020-06-08-32) to root...
      Installing xr819s-rftest (1.0.0-1) to root...
      Package zlib (1.2.8-1) installed in root is up to date.
      Installing kmod-cfg80211 (4.9.191-1) to root...
      Installing kmod-input-core (4.9.191-1) to root...
      Installing kmod-input-evdev (4.9.191-1) to root...
      Installing kmod-mmc (4.9.191-1) to root...
      Installing kmod-net-aic8800 (4.9.191-1) to root...
      Installing kmod-sunxi-rf-wlan (4.9.191-1) to root...
      Package kmod-sunxi-rf-wlan (4.9.191-1) installed in root is up to date.
      Installing kmod-vin-v4l2 (4.9.191-1) to root...
      Configuring libgcc.
      Configuring libc.
      Configuring uclibcxx.
      Configuring libpthread.
      Configuring iperf.
      Configuring libjpeg.
      Configuring libnl-tiny.
      Configuring iw.
      Configuring wifimanager-v2.0.
      Configuring libstdcpp.
      Configuring zlib.
      Configuring wirelesscommon.
      Configuring libopenssl.
      Configuring wifimanager-v2.0-lib.
      Configuring librt.
      Configuring alsa-lib.
      Configuring busybox.
      Configuring kernel.
      Configuring kmod-vin-v4l2.
      Configuring xr819s-rftest.
      Configuring libunwind.
      Configuring glog.
      Configuring libconfig.
      Configuring uboot-envtools.
      Configuring mtd-utils.
      Configuring ota-burnboot.
      Configuring swupdate.
      Configuring adb.
      Configuring kmod-input-core.
      Configuring liballwinner-base.
      Configuring eyesee-mpp-external.
      Configuring eyesee-mpp-system.
      Configuring libawion.
      Configuring libuuid.
      Configuring libblkid.
      Configuring libexpat.
      Configuring eyesee-mpp-middleware.
      Configuring eyesee-mpp-framework.
      Configuring kmod-mmc.
      Configuring liblua.
      Configuring gdbserver.
      Configuring ramparser.
      Configuring libpng.
      Configuring mtd-utils-mkfs.jffs2.
      Configuring kmod-input-evdev.
      Configuring busybox-init-base-files.
      Configuring libubox.
      Configuring eudev.
      Configuring kmod-sunxi-rf-wlan.
      Configuring libext2fs.
      Configuring e2fsprogs.
      Configuring wifimanager-v2.0-demo.
      Configuring hostapd-common.
      Configuring libubus.
      Configuring wpad-basic-openssl.
      Configuring wpa-cli.
      Configuring viplite-driver.
      Configuring aic8800-firmware.
      Configuring kmod-cfg80211.
      Configuring kmod-net-aic8800.
      Configuring libsqlite3.
      Configuring eyesee-mpp-private-rtsp.
      Configuring tslib.
      Configuring blkid.
      Setting flags for package kernel to hold.
      Setting flags for package kmod-input-core to hold.
      Setting flags for package kmod-input-evdev to hold.
      Setting flags for package kmod-cfg80211 to hold.
      Setting flags for package kmod-vin-v4l2 to hold.
      Setting flags for package kmod-sunxi-rf-wlan to hold.
      Setting flags for package kmod-mmc to hold.
      Setting flags for package kmod-net-aic8800 to hold.
      Setting flags for package libc to hold.
      Setting flags for package libgcc to hold.
      Setting flags for package libstdcpp to hold.
      Setting flags for package libpthread to hold.
      Setting flags for package librt to hold.
      Setting flags for package uboot-envtools to nonshared.
      make[3]: Entering directory '/home/wh/tina-v85x'
      make[3]: Nothing to be done for 'package/preconfig'.
      make[3]: Leaving directory '/home/wh/tina-v85x'
      ./etc/init.d/rcS: line 37: /proc/sys/kernel/printk: Permission denied
      hostname: you must be root to change the host name
      ./etc/init.d/rcS: line 45: ifconfig: command not found
      /etc/init.d/rcS does not have a START or STOP value
      sed -i "s/Installed-Time: ./Installed-Time: 1726625522/" /home/wh/tina-v85x/out/v851se-ylai/compile_dir/target/rootfs/usr/lib/opkg/status
      rm -f /home/wh/tina-v85x/out/v851se-ylai/compile_dir/target/rootfs/usr/lib/opkg/info/
      .postinst*
      rm -f /home/wh/tina-v85x/out/v851se-ylai/compile_dir/target/rootfs/usr/lib/opkg/info/.prerm
      rm -rf /home/wh/tina-v85x/out/v851se-ylai/compile_dir/target/rootfs/usr/lib/opkg
