    求助:R528 Tina Linux 尝试添加Secure boot,uboot卡住不动
    • T
      tel18326674223 LV 2 最后由 编辑
      之前是正常启动的,尝试运行
      ./scripts/createkeys
      make -j
      pack -s
      一路成功,然后刷进板子,boot0之后 uboot直接卡住,没刷rotpk
      log:
      [79]HELLO! SBOOT is starting!
      [81]sboot commit : df175133
      [84]set pll start
      [90]periph0 has been enabled
      [93]set pll end
      [94][pmu]: bus read error
      [97]board init ok
      [99]ZQ value = 0x2f
      [101]get_pmu_exist() = -1
      [103]DRAM BOOT DRIVE INFO: V0.33
      [106]DRAM CLK = 792 MHz
      [108]DRAM Type = 3 (2:DDR2,3:DDR3)
      [111]DRAMC read ODT  off.
      [114]DRAM ODT value: 0x42.
      [117]ddr_efuse_type: 0xf
      [120]DRAM SIZE =128 M
      [122]dram_tpr4:0x2000
      [124]PLL_DDR_CTRL_REG:0xf8004100
      [127]DRAM_CLK_REG:0xc0000000
      [129][TIMING DEBUG] MR2= 0x18
      [134]DRAM simple test OK.
      [136]rtc standby flag is 0x0, super standby flag is 0x0
      [141]dram size =128
      [143][mmc]: mmc driver ver 2021-05-21 14:47
      [153][mmc]: Wrong media type 0x0
      [156][mmc]: ***Try SD card 0***
      [159][mmc]: mmc 0 cmd 8 timeout, err 100
      [163][mmc]: mmc 0 cmd 8 err 100
      [166][mmc]: mmc 0 send if cond failed
      [170][mmc]: mmc 0 cmd 55 timeout, err 100
      [174][mmc]: mmc 0 cmd 55 err 100
      [177][mmc]: mmc 0 send app cmd failed
      [180][mmc]: ***Try MMC card 0***
      [205][mmc]: RMCA OK!
      [207][mmc]: sdc0 spd mode error, 2
      [210][mmc]: mmc 0 bias 0
      [215][mmc]: MMC 5.1
      [216][mmc]: HSSDR52/SDR25 4 bit
      [219][mmc]: 50000000 Hz
      [222][mmc]: 7296 MB
      [223][mmc]: ***SD/MMC 0 init OK!!!***
      [320]read toc1 from emmc 32800 sector
      [324]OLD version: 0.0
      [326]NEW version: 0.0
      [330]don't have rotpk, skip check
      [380]load rotpk hash
      [475]load boot-key hash
      [477]load boot hash
      [525]load dsp-key hash
      [527]load dsp hash
      [584]monitor entry=0x0
      [586]uboot entry=0x43000000
      [589]optee entry=0x41b00000
      [591]opensbi entry=0x0
      [593]no need rotpk flag
      [596]run out of boot0
      M/TC: OP-TEE version: c8daf536-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Wed 26 Apr 2023 08:19:22 AM UTC arm
      U-Boot 2018.05-00014-g8cc97dd (Oct 08 2024 - 11:12:43 +0000) Allwinner Technology
      [00.653]CPU:   Allwinner Family
      [00.656]Model: sun8iw20
      [00.658]DRAM:
      然后就卡住不动了,怎么搞都没反应。
      重启之后还是一样。
      可以按键刷安全固件,但是刷过之后还是一样的问题。
