    V853 启动报错 FDT_ERR_NOTFOUND
      zhuangjinfu LV 5 最后由 编辑
      [170]HELLO! BOOT0 is starting!
      [173]BOOT0 commit : 7cbc2fc77e
      [177]PMU: AXP21
      [180]set pll start
      [182]periph0 has been enabled
      [185]set pll end
      [186]board init ok
      [188]DRAM use external ZQ!!
      [191]chip id check OK
      [194]DRAM_VCC set to 1500 mv
      [196]DRAM BOOT DRIVE INFO: V0.19
      [200]DRAM CLK = 936 MHz
      [202]DRAM Type = 3 (2:DDR2,3:DDR3)
      [205]DRAMC ZQ value: 0x7b7bfb
      [208]DRAM ODT value: 0x42.
      [212]DRAM SIZE =512 M
      [214]dram_tpr4:0x0
      [221]DRAM simple test OK.
      [223]rtc standby flag is 0x0, super standby flag is 0x0
      [229]dram size =512
      [231]audio:avcc calibration
      [234]card no is 2
      [236]sdcard 2 line count 8
      [238][mmc]: mmc driver ver 2022-10-25 19:07
      [248][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [253][mmc]: Try MMC card 2
      [267][mmc]: RMCA OK!
      [269][mmc]: bias 100
      [271][mmc]: mmc 2 bias 100
      [274][mmc]: MMC 5.1
      [276][mmc]: HSSDR52/SDR25 8 bit
      [279][mmc]: 50000000 Hz
      [281][mmc]: 29820 MB
      [283][mmc]: SD/MMC 2 init OK!!!
      [338]Loading boot-pkg Succeed(index=0).
      [341]Entry_name = optee
      [344]Entry_name = u-boot
      [351]Entry_name = dtb
      [355]tunning data addr:0x430003e8
      [358]Jump to second Boot.
      M/TC: OP-TEE version: 2c52b317-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #3 Fri Aug 12 11:46:59 UTC 2022 arm
      E/TC:0 fdt_getprop_u32:343 prop trace_level not found
      [00.595][mmc]: mmc driver ver uboot2018:2023-02-10 14:15:00
      [00.600][mmc]: get sdc_type fail and use default host:tm4.
      [00.607][mmc]: get clk_mmc_name string failed
      [00.611][mmc]: get pll0 string failed
      [00.614][mmc]: get pll1 string failed
      [00.618][mmc]: get pll2 string failed
      [00.621][mmc]: SUNXI SDMMC Controller Version:0x50400
      [00.646][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
      [00.680]set disp.dev2_output_type fail. using defval=0
      [00.689]set disp.fb0_rot_used fail. using defval=0
      [00.694]set disp.fb0_rot_degree fail. using defval=0
      [00.716]Item0 (Map) magic is bad
      [00.719]the secure storage item0 copy0 magic is bad
      [00.736]Item0 (Map) magic is bad
      [00.739]the secure storage item0 copy1 magic is bad
      [00.744]Item0 (Map) magic is bad
      [00.747]out of usb burn from boot: not need burn key
      [00.755][mmc]: delete mmc-hs400-1_8v from dtb
      [00.759][mmc]: delete mmc-hs200-1_8v from dtb
      [00.763][mmc]: get max-frequency ok 50000000 Hz
      [00.774][mmc]: get sunxi-mmc2 string failed
      [00.781]The storage not support sample function
      [00.788]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      V853 EMMC 报错
