    T113 I2S 音频输出至 Lontium 芯片 / T113 I2S Audio Output to Lontium chip
    8
    6237
      dazb3 LV 5 最后由 编辑
      嗨。我正在尝试配置我的 T113,以将 I2S 音频输出到 Lontium LT9611UXC MIPI 到 HDMI 芯片。我已将我的 DTS 配置为输出 I2S。但是查看 dmesg 我发现我的 DOUT 引脚未正确初始化:
      [    1.881261] sun8iw20-pinctrl pio: unsupported function i2s2 on pin PB4
      有什么帮助或想法吗?最后是我的 dts:
      Hi. I'm trying to configure my T113 to output I2S audio to a Lontium LT9611UXC MIPI to HDMI chip. I've configured my DTS to output I2S. However looking at dmesg I see that my DOUT pin isn't properly initialised:
      Any help or ideas? Below is my dts:
      /dts-v1/;
      /*/memreserve/ 0x41900000 0x00100000;*/
      /* DSP used 1MB */
      /* /memreserve/ 0x42000000 0x00100000; */
      #include "sun8iw20p1.dtsi"
      	model = "sun8iw20";
      	reg_vdd_cpu: vdd-cpu {
      		compatible = "pwm-regulator";
      		pwms = <&pwm 3 5000 0>;
      		regulator-name = "vdd_cpu";
      		regulator-settling-time-us = <4000>;
      		regulator-always-on;
      		regulator-boot-on;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		enable-active-high;
      	reg_vdd_3v3: vdd_3v3 {
      		regulator-name = "vdd-3v3";
      		enable-active-high;
      	can0: can@0x0 {
      		#address-cells = <1>;
      		#size-cells = <0>;
      		compatible = "allwinner,sun8i-can";
      		device_type = "can0";
      		id = <0>;
      		status = "disabled";
      	can1: can@0x1 {
      		#size-cells = <0>;
      		device_type = "can1";
      		id = <1>;
      	gpio-keys {
      		compatible = "gpio-keys";
      		vol-down-key {
      			gpios = <&pio PE 1 GPIO_ACTIVE_LOW>;
      			linux,code = <114>;
      			label = "user key";
      			debounce-interval = <10>;
      			wakeup-source = <0x1>;
      	gpio-leds {
      		compatible = "gpio-leds";
      		led-blue {
      			label = "led-blue";
      			gpios = <&pio PE 2 GPIO_ACTIVE_HIGH>;
      			linux,default-trigger = "heartbeat";
      			defaults-state = "on";
      &cpu0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		allwinner,pull = <1>;
      		function = "sdc0";
      		drive-strength = <30>;
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      		function = "gpio_in";
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		drive-strength = <10>;
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      			function = "sdc1";
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	wlan_pins_a:wlan@0 {
      		pins = "PG11";
      		function = "clk_fanout1";
      	function = "uart0";
      	bias-pull-up;
      		function = "uart1";
      		bias-pull-up;
      		pins = "PC0", "PC1";
      		function = "uart2";
      		bias-pull-up;
      	uart3_pins_a: uart3_pins@0 {  /* For t113_evb */
      		pins = "PG8", "PG9";
      		function = "uart3";
      		bias-pull-up;
      	uart4_pins_a: uart4_pins@0 {
      		pins = "PE4", "PE5";
      		function = "uart4";
      		bias-pull-up;
      	uart4_pins_b: uart4_pins@1 {
      	uart5_pins_a: uart5_pins@0 {
      		pins = "PE6", "PE7";
      		function = "uart5";
      		bias-pull-up;
      	uart5_pins_b: uart5_pins@1 {
      	twi1_pins_a: twi1@0 {
      		pins = "PE14", "PE15";
      		function = "twi1";
      	twi1_pins_b: twi1@1 {
      	twi2_pins_a: twi2@0 {
      		pins = "PE12", "PE13";
      		function = "twi2";
      	twi2_pins_b: twi2@1 {
      	twi3_pins_a: twi3@0 {
      		pins = "PB6", "PB7";
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      	s_cir0_pins_a: s_cir0@0 {
      		pins = "PB1";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir0@1 {
      		pins = "PB1";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      	dmic_pins_a: dmic@0 {
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		pins = "PB7", "PB5", "PB6", "PB4";
      		function = "i2s2";
      		bias-disable;
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2_sleep@0 {
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PG18";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PG18";
      		bias-disable;
      	gmac0_pins_a: gmac@0 {
      		allwinner,pins = "PG0", "PG1", "PG2", "PG3", "PG4",
      				 "PG5", "PG12", "PG13", "PG14", "PG15";
      		allwinner,function = "gmac0";
      		allwinner,muxsel = <4>;
      		allwinner,drive = <1>;
      		allwinner,pull = <0>;
      	gmac0_pins_b: gmac@1 {
      		allwinner,function = "gpio_in";
      		allwinner,muxsel = <0>;
      	spi0_pins_a: spi0@0 {
      		pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
      		function = "spi0";
      	spi0_pins_b: spi0@1 {
      		pins = "PC3";
      		function = "spi0";
      		bias-pull-up;   /* only CS should be pulled up */
      	spi0_pins_c: spi0@2 {
      	spi1_pins_a: spi1@0 {
      		pins = "PB11", "PB10", "PB9","PB8", "PB0"; /*clk mosi miso hold wp*/
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		pins = "PB12";
      		function = "spi1";
      		bias-pull-up;   // only CS should be pulled up
      	spi1_pins_c: spi1@2 {
      		allwinner,pins = "PB0", "PB8", "PB9", "PB10","PB11", "PB12";
      	pwm2_pin_a: pwm2@0 {
      		pins = "PE8";
      		function = "pwm2";
      		bias-pull-up;
      	pwm2_pin_b: pwm2@1 {
      		pins = "PE8";
      	pwm3_pin_a: pwm3@0 {
      		pins = "PB0";
      		function = "pwm3";
      		bias-pull-up;
      	pwm3_pin_b: pwm3@1 {
      		pins = "PB0";
      	pwm5_pin_a: pwm5@0 {
      		pins = "PE13";
      		function = "pwm5";
      		bias-pull-up;
      	pwm5_pin_b: pwm5@1 {
      		pins = "PE13";
      	dsi4lane_pins_a: dsi4lane@0 {
      		allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,function = "dsi4lane";
      	dsi4lane_pins_b: dsi4lane@1 {
      		allwinner,function = "dsi4lane_suspend";
      		allwinner,muxsel = <7>;
      &uart0 {
      &uart1 {
      &uart2 {
      &uart3 {
      &uart4 {
      	pinctrl-0 = <&uart4_pins_a>;
      	pinctrl-1 = <&uart4_pins_b>;
      &uart5 {
      	pinctrl-0 = <&uart5_pins_a>;
      	pinctrl-1 = <&uart5_pins_b>;
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	no-sdio;
      	no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-power-save-mode;
      	sunxi-dis-signal-vol-sw;
      	mmc-bootpart-noacc;
      	max-frequency = <150000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &sdc0 {
      	bus-width = <4>;
      	cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_DOWN)>;
      	/*non-removable;*/
      	broken-cd;
      	/*cd-inverted*/
      	/*data3-detect;*/
      	/*cd-used-24M;*/
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	/*sunxi-dis-signal-vol-sw;*/
      	ctl-spec-caps = <0x8>;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	/*sunxi-power-save-mode;*/
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      &rtc {
      &twi0 {
      &twi1 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi1_pins_a>;
      	pinctrl-1 = <&twi1_pins_b>;
      	// twi_drv_used = <1>;
      	// dmas = <&dma 45>, <&dma 45>;
      	// dma-names = "tx", "rx";
      	rtc@32 {
      		compatible = "epson,rx8025t";
      		reg = <0x32>;
      	edt-ft5x06@38 {
      		compatible = "edt,edt-ft5406", "edt,edt-ft5x06";
      		reg = <0x38>;
      		interrupt-parent = <&pio>;
      		interrupts = <PE 10 IRQ_TYPE_EDGE_FALLING>; //IRQ_TYPE_LEVEL_LOW
      		// reset-gpios = <&pio PD 23 1 0xffffffff 0xffffffff 1>;
      		// gpio-controller;
      		touchscreen-size-x=<1024>;
              	touchscreen-size-y=<600>;
      	ctp {
      		device_type = "ctp";
      		ctp_twi_id = <0x1>;
      		ctp_twi_addr = <0x38>;
      		ctp_screen_max_x = <0x400>;
      		ctp_screen_max_y = <0x258>;
      		ctp_revert_x_flag = <0x0>;
      		ctp_revert_y_flag = <0x1>;
      		ctp_exchange_x_y_flag = <0x1>;
      		ctp_int_port = <&pio PE 10 GPIO_ACTIVE_HIGH>;
      		// ctp_wakeup = <&pio PB 7 GPIO_ACTIVE_HIGH>;
      		ctp-supply = <&reg_vdd_3v3>;
      		ctp_power_ldo_vol = <3300>;
      &twi2 {
      &spi0 {
      &spi1 {
      &ledc {
      &s_cir0 {
      	pinctrl-names = "default";
      	pinctrl-0 = <&s_cir0_pins_a>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      &gmac0 {
      	pinctrl-0 = <&gmac0_pins_a>;
      	pinctrl-1 = <&gmac0_pins_b>;
      	phy-mode = "rmii";
      	use_ephy25m = <0>;//1
      	tx-delay = <7>;//7
      	rx-delay = <31>;//31
      	phy-rst = <&pio PG 6 GPIO_ACTIVE_HIGH>;
      &soc {
      	platform@45000004 {
      		reg = <0x0 0x45000004 0x0 0x0>;
      		eraseflag   = <1>;
      		next_work   = <3>;
      		debug_mode  = <8>;
      	target@45000008 {
      		reg = <0x0 0x45000008 0x0 0x0>;
      		boot_clock = <1008>;	/*CPU boot frequency, Unit: MHz*/
      		storage_type = <0xffffffff>; /*boot medium, 0-nand, 1-card0, 2-card2, -1(defualt)auto scan*/
      		burn_key = <0>;		/*1:support burn key; 0:not support burn key*/
      		dragonboard_test = <0>;	/*1:support card boot dragonboard; 0:not support card boot dragonboard*/
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_a>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc2_pins_a>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      	btlpm: btlpm@0 {
      	car_reverse:car-reverse {
      &vind0 {
      	csi_top = <378000000>;
      	csi_isp = <327000000>;
      	status = "disabled"; /* enable twi and ver1 spi-nand max freq 30M */
      ;tv configuration
      ;interface          (interface type,1<->cvbs,2<->YPBPR,4<->SVIDEO)
      ;dac_type           (0<->composite,1<->luma,2<->chroma,3<->reserved,4<->y/green,
      ;                    5<->u/pb/blue,6<->v/pr/red)
      ;dac_src            (dac no,support dac_src0~dac_src3,dac num max is 4)
      ;NOTE:              tv0,tv1 can not use the same dac_src.
      &tv0 {
      	interface       = <1>;
      	dac_type0       = <0>;
      	dac_src0        = <0>;
      	status =  "okay";
      tvd configuration
                             mode,mean enable)
      &tvd {
      	tvd_sw          = <1>;
      	tvd_interface   = <0>;
      	tvd_format      = <0>;
      	tvd_system      = <1>;
      	tvd_row         = <1>;
      	tvd_column      = <1>;
      	tvd_channel0_en = <1>;
      	tvd_channel1_en = <0>;
      	tvd_channel2_en = <0>;
      	tvd_channel3_en = <0>;
      	/*tvd_power0      = "dc1sw"*/
      	/*tvd_power1      = "eldo3"*/
      &tvd0 {
      &hdmi {
      /* Audio Driver modules */
      &codec {
      	mic1gain 		= <0x1F>;
      	mic2gain 		= <0x1F>;
      	mic3gain 		= <0x1F>;
      	adcdrc_cfg		= <0x0>;
      	adchpf_cfg		= <0x1>;
      	dacdrc_cfg		= <0x0>;
      	dachpf_cfg		= <0x0>;
      	/* Volume about */
      	digital_vol 	= <0x00>;
      	lineout_vol 	= <0x1a>;
      	headphonegain	= <0x03>;
      	/* Pa enabled about */
      	pa_level 		= <0x01>;
      	pa_pwr_level 	= <0x01>;
      	pa_msleep_time 	= <0x78>;
      	/* gpio-spk	= <&pio PE 11 GPIO_ACTIVE_LOW>; */
      	/* CMA config about */
      	playback_cma	= <128>;
      	capture_cma	= <256>;
      	/* regulator about */
      &sndcodec {
      	hp_detect_case	= <0x00>;
      	jack_enable		= <0x01>;
      &dummy_cpudai {
      	status			= "okay";
      &dmic {
      &dmic_codec {
      &sounddmic {
       * tdm_config		0 --> pcm
       *			1 --> i2s
       * mclk_div		0 --> not output
       *			1 --> HDMI audio type
      &daudio0 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tdm_config 	= <0x01>;
      	sign_extend 	= <0x00>;
      	msb_lsb_first 	= <0x00>;
      	pcm_lrck_period = <0x80>;
      	slot_width_select = <0x20>;
      	pinctrl_used	= <0x0>;
      &sounddaudio0 {
      		/* sound-dai = <&ac108>; */
      &daudio1 {
      &sounddaudio1 {
      &daudio2 {
      	mclk_div = <0x00>;
      	frametype = <0x00>;
      	tx_data_mode = <0x00>;
      	rx_data_mode = <0x00>;
      	pcm_lrck_period = <0x20>;
      	asrc_function_en = <0x00>;
      	pinctrl-0       = <&daudio2_pins_a>;
      	pinctrl-1       = <&daudio2_pins_b>;
      	daudio_type = <0x1>;
      &hdmiaudio {
      &sounddaudio2 {
      	simple-audio-card,name = "sndhdmi";
      		sound-dai = <&hdmiaudio>;
      &spdif {
      &soundspdif {
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x01>;
      	usb_detect_type = <0x1>;
      	usb_regulator_io = "nocare";
      	usb_wakeup_suspend = <0>;
      &ehci0 {
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
      &ehci1 {
      &ohci1 {
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      &disp {
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_driver_name     = "he0801a068";
      	lcd_backlight       = <50>;
      	lcd_if              = <4>;
      	lcd_x               = <1920>;    // Horizontal Active
      	lcd_y               = <1080>;    // Vertical Active
      	lcd_width           = <150>;
      	lcd_height          = <94>;
      	lcd_dclk_freq       = <149>;     // Dot clock in MHz
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_pol         = <1>;
      	lcd_pwm_max_limit   = <255>;
      	lcd_hbp             = <148>;     // Horizontal Back Porch
      	lcd_ht              = <2200>;    // Horizontal Total
      	lcd_hspw            = <44>;      // Horizontal Sync Pulse Width
      	lcd_vbp             = <36>;      // Vertical Back Porch
      	lcd_vt              = <1125>;    // Vertical Total
      	lcd_vspw            = <5>;       // Vertical Sync Pulse Width
      	lcd_dsi_lane        = <4>;
      	lcd_dsi_if          = <0>;
      	lcd_dsi_format      = <0>;
      	lcd_dsi_te          = <0>;
      	lcd_frm             = <0>;
      	lcd_io_phase        = <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	lcd_gpio_0 = <&pio PG 13 GPIO_ACTIVE_HIGH>;
      &pwm2 {
      	pinctrl-0 = <&pwm2_pin_a>;
      	pinctrl-1 = <&pwm2_pin_b>;
      &pwm3 {
      	pinctrl-0 = <&pwm3_pin_a>;
      	pinctrl-1 = <&pwm3_pin_b>;
      &pwm5 {
      	pinctrl-0 = <&pwm5_pin_a>;
      	pinctrl-1 = <&pwm5_pin_b>;
      &pwm7 {
      &gpadc {
      	channel_num = <1>;
      	channel_select = <0x1>;
      	channel_data_select = <0>;
      	channel_compare_select = <0x1>;
      	channel_cld_select = <0x1>;
      	channel_chd_select = <0>;
      	key_cnt = <5>;
      	key0_vol = <210>;
      	key0_val = <115>;
      	key1_vol = <410>;
      	key1_val = <114>;
      	key2_vol = <590>;
      	key2_val = <119>;
      	key3_vol = <750>;
      	key3_val = <373>;
      	key4_vol = <880>;
      	key4_val = <28>;
      &tpadc {
      	key_cnt = <4>;
      	key1 = <210 115>;
      	key2 = <410 114>;
      	key3 = <590 119>;
      	key4 = <750 373>;
      W 2 条回复 最后回复 回复 引用 分享 0
        whycanservice2 LV 8 @dazb3 最后由 whycanservice2 编辑
        @dazb3 在 T113 I2S 音频输出至 Lontium 芯片 / T113 I2S Audio Output to Lontium chip 中说:
        > &daudio2 {
        > 	mclk_div = <0x00>;
        > 	frametype = <0x00>;
        > 	pinctrl-0       = <&daudio2_pins_a  &daudio2_pins_b>;
        > 	pinctrl-1       = <&daudio2_pins_c>;
        > 	status = "okay";
          @dazb3
          修改如下:
          		pins = "PB7", "PB5", "PB6";
          		function = "i2s2";
          		bias-disable;
          	daudio2_pins_b: daudio2@1 {
          		/* I2S_PIN: DOUT0 */
          		pins = "PB4";
          		function = "i2s2_dout";
          		bias-disable;
          	daudio2_pins_c: daudio2@2 {
          		/* I2S_PIN: DIN0 */
          		pins = “PB7", "PB5", "PB6", "PB4";
          		bias-disable;
          D 1 条回复 最后回复 回复 引用 分享 2
            dazb3 LV 5 @whycanservice2 最后由 dazb3 编辑
            @whycanservice2 感谢您的回复。这似乎已经修复了错误。我不再收到错误,我可以使用“cat /sys/kernel/debug/pinctrl/pio/pinmux-pins”来查看引脚是否已分配给 I2S。
            但是我仍然无法通过 I2S 播放音频。我正在使用 tplayerdemo 播放带音频的视频。我会继续调查,但有什么想法吗?
            此外,是否有资源或文档可以让我稍后自己查找此信息?我查看了 Tina SDK 手册,但似乎找不到此信息。
            非常感谢您的帮助!
            W Z 2 条回复 最后回复 回复 引用 分享 2
              whycanservice2 LV 8 @dazb3 最后由 编辑
              @dazb3 需要切换声卡才可以使用i2s播放。给你一份文件吧。D1_Linux_AUDIOCODEC_开发指南.pdf
                huafv LV 2 最后由 编辑
                666大佬yyds
                  zoengjay LV 5 @dazb3 最后由 编辑
                  @dazb3 there's a i2s doc on 100ask.net https://forums.100ask.net/uploads/short-url/3Da0tOrvGPKeV7Be36UVkzivSE6.pdf
                  to test i2s, why not try aplay or tinyplay?
                  D 1 条回复 最后回复 回复 引用 分享 1
                    dazb3 LV 5 @zoenggit 最后由 编辑
                    @whycanservice2 @zoenggit
                    谢谢你们的帮助。附件中的文档和链接非常有用。
                    我用示波器检查了引脚,可以看到 I2S 正在输出。在咨询了 Lontium 后,我终于能够将正确的 I2S 格式输入芯片中。
                    作为参考,该芯片是 Lontium LT9611UXC。
                    以下是我的完整 dts:
                    /dts-v1/;
                    /* DSP used 1MB */
                    	model = "sun8iw20";
                    		regulator-boot-on;
                    		enable-active-high;
                    		enable-active-high;
                    	can0: can@0x0 {
                    		#size-cells = <0>;
                    		id = <0>;
                    	can1: can@0x1 {
                    		#size-cells = <0>;
                    		id = <1>;
                    	gpio-keys {
                    		vol-down-key {
                    			linux,code = <114>;
                    			label = "user key";
                    &cpu0 {
                    &pio {
                    		function = "sdc0";
                    		bias-pull-up;
                    		function = "sdc0";
                    		bias-pull-up;
                    		function = "uart0";
                    		bias-pull-up;
                    			"PF5";
                    		function = "jtag";
                    		bias-pull-up;
                    		function = "sdc1";
                    		bias-pull-up;
                    			function = "sdc1";
                    		function = "sdc2";
                    		bias-pull-up;
                    		pins = "PG11";
                    	function = "uart0";
                    	bias-pull-up;
                    		function = "uart1";
                    		bias-pull-up;
                    		function = "uart2";
                    		bias-pull-up;
                    		function = "uart3";
                    		bias-pull-up;
                    		function = "uart4";
                    		bias-pull-up;
                    		function = "uart5";
                    		bias-pull-up;
                    		function = "twi1";
                    		function = "twi2";
                    		function = "twi3";
                    		pins = "PB1";
                    		function = "ir";
                    		bias-pull-up;
                    		pins = "PB1";
                    	ir1_pins_a: ir1@0 {
                    		pins = "PB0";
                    		function = "ir";
                    		bias-pull-up;
                    	ir1_pins_b: ir1@1 {
                    		pins = "PB0";
                    		function = "dmic";
                    		bias-disable;
                    		bias-disable;
                    		function = "i2s2";
                    		bias-disable;
                    		pins = "PB7", "PB6", "PB5", "PB4";
                    		bias-disable;
                    		function = "i2s2";
                    		bias-disable;
                    		pins = "PB4";
                    		bias-disable;
                    		/* I2S_PIN: DIN0 */
                    		bias-disable;
                    		pins = "PG18";
                    		function = "spdif";
                    		bias-disable;
                    		pins = "PG18";
                    		bias-disable;
                    		function = "spi0";
                    		pins = "PC3";
                    		function = "spi0";
                    		function = "spi1";
                    		pins = "PB12";
                    		function = "spi1";
                    		pins = "PE8";
                    		function = "pwm2";
                    		bias-pull-up;
                    		pins = "PE8";
                    		pins = "PB0";
                    		function = "pwm3";
                    		bias-pull-up;
                    		pins = "PB0";
                    &uart0 {
                    &uart1 {
                    &uart2 {
                    &uart3 {
                    &uart4 {
                    &uart5 {
                    &sdc2 {
                    	non-removable;
                    	bus-width = <4>;
                    	mmc-ddr-1_8v;
                    	mmc-hs200-1_8v;
                    	no-sdio;
                    	no-sd;
                    	cap-mmc-highspeed;
                    	mmc-bootpart-noacc;
                    &sdc0 {
                    	bus-width = <4>;
                    	/*non-removable;*/
                    	broken-cd;
                    	/*cd-inverted*/
                    	/*data3-detect;*/
                    	/*cd-used-24M;*/
                    	cap-sd-highspeed;
                    	/*sd-uhs-sdr50;*/
                    	/*sd-uhs-ddr50;*/
                    	/*sd-uhs-sdr104;*/
                    	no-sdio;
                    	no-mmc;
                    &sdc1 {
                    	bus-width = <4>;
                    	no-mmc;
                    	no-sd;
                    	cap-sd-highspeed;
                    	/*sd-uhs-sdr12*/
                    	/*sd-uhs-sdr25;*/
                    	/*sd-uhs-sdr50;*/
                    	/*sd-uhs-ddr50;*/
                    	/*sd-uhs-sdr104;*/
                    	cap-sdio-irq;
                    	ignore-pm-notify;
                    &rtc {
                    &twi0 {
                    &twi1 {
                    	rtc@32 {
                    		reg = <0x32>;
                    	edt-ft5x06@38 {
                    		reg = <0x38>;
                    		// gpio-controller;
                    	ctp {
                    		ctp_twi_id = <0x1>;
                    &twi2 {
                    &spi0 {
                    &spi1 {
                    &ledc {
                    &s_cir0 {
                    &ir1 {
                    &gmac0 {
                    	phy-mode = "rmii";
                    	tx-delay = <7>;//7
                    &soc {
                    	platform@45000004 {
                    		eraseflag   = <1>;
                    		next_work   = <3>;
                    		debug_mode  = <8>;
                    	target@45000008 {
                    	card0_boot_para@2 {
                    		card_ctrl = <0x0>;
                    		card_line = <0x4>;
                    	card2_boot_para@3 {
                    		card_ctrl = <0x2>;
                    		card_line = <0x4>;
                    		sdc_io_1v8 = <0x1>;
                    	rfkill: rfkill@0 {
                    	btlpm: btlpm@0 {
                    &vind0 {
                    ;tv configuration
                    &tv0 {
                    	interface       = <1>;
                    	dac_type0       = <0>;
                    	dac_src0        = <0>;
                    	status =  "okay";
                    tvd configuration
                                           mode,mean enable)
                    &tvd {
                    	tvd_sw          = <1>;
                    	tvd_format      = <0>;
                    	tvd_system      = <1>;
                    	tvd_row         = <1>;
                    	tvd_column      = <1>;
                    &tvd0 {
                    &hdmi {
                    &codec {
                    	mic1gain 		= <0x1F>;
                    	mic2gain 		= <0x1F>;
                    	mic3gain 		= <0x1F>;
                    	adcdrc_cfg		= <0x0>;
                    	adchpf_cfg		= <0x1>;
                    	dacdrc_cfg		= <0x0>;
                    	dachpf_cfg		= <0x0>;
                    	/* Volume about */
                    	pa_level 		= <0x01>;
                    &sndcodec {
                    &dummy_cpudai {
                    	status			= "okay";
                    &dmic {
                    &dmic_codec {
                    &sounddmic {
                     *			1 --> i2s
                    &daudio0 {
                    	mclk_div 	= <0x01>;
                    	frametype 	= <0x00>;
                    &sounddaudio0 {
                    &daudio1 {
                    &sounddaudio1 {
                     *			1 --> i2s
                    &daudio2 {
                    	mclk_div 	= <0x80>;
                    	frametype 	= <0x01>;
                    	pinctrl_used	= <0x1>;
                    &hdmiaudio {
                    &sounddaudio2 {
                    &spdif {
                    &soundspdif {
                    &usbc0 {
                    &ehci0 {
                    &ohci0 {
                    &usbc1 {
                    &ehci1 {
                    &ohci1 {
                                       in display.
                    &disp {
                    	/*VCC-LCD*/
                    	/*VCC-DSI*/
                    	/*VCC-PD*/
                    ;lcd0 configuration
                    &lcd0 {
                    	lcd_used            = <1>;
                    	lcd_if              = <4>;
                    	lcd_width           = <150>;
                    	lcd_height          = <94>;
                    	lcd_pwm_used        = <1>;
                    	lcd_pwm_ch          = <7>;
                    	lcd_pwm_pol         = <1>;
                    	lcd_dsi_lane        = <4>;
                    	lcd_dsi_if          = <0>;
                    	lcd_dsi_te          = <0>;
                    	lcd_frm             = <0>;
                    	lcd_io_phase        = <0>;
                    	lcd_gamma_en        = <0>;
                    	lcd_cmap_en         = <0>;
                    	deu_mode            = <0>;
                    	smart_color         = <90>;
                    &pwm2 {
                    &pwm3 {
                    &pwm5 {
                    &pwm7 {
                    &gpadc {
                    	channel_num = <1>;
                    	key_cnt = <5>;
                    	key0_vol = <210>;
                    	key0_val = <115>;
                    	key1_vol = <410>;
                    	key1_val = <114>;
                    	key2_vol = <590>;
                    	key2_val = <119>;
                    	key3_vol = <750>;
                    	key3_val = <373>;
                    	key4_vol = <880>;
                    	key4_val = <28>;
                    &tpadc {
                    	key_cnt = <4>;
                    	key1 = <210 115>;
                    	key2 = <410 114>;
                    	key3 = <590 119>;
                    	key4 = <750 373>;
                    再次感谢!
