    t113-s3 tplayerdemo 播放视频爆红错误
      lyg116 LV 6 最后由 编辑
      tplayerdemo 播放视频爆红求助下,已排除音频问题?
      root@TinaLinux:/# tplayerdemo /mnt/UDISK/1.mp4
      WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 6
      [1970-01-01 08:16:52] INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
      [1970-01-01 08:16:52] INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
      [1970-01-01 08:16:52] INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
      [1970-01-01 08:16:52] INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
      [1970-01-01 08:16:52] INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
      [1970-01-01 08:16:52] INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
      ERROR  : awplayer <DlOpenPlugin:105>: dlopen 'libawwmv3.so' fail: libawwmv3.so: cannot open shared object file: No such file or directory
      [1970-01-01 08:16:52] INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
      * This program implements a simple player, you can type commands to control the player.
      * To show what commands supported, type 'help'.
      dd: error writing '/dev/fb0': No space left on device
      16001+0 records in
      16000+0 records out
      [ 1009.870266] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
      argc = 2
      argv[0] = tplayerdemo
      argv[1] = /mnt/UDISK/1.mp4
      may be is one file:cut down suffix is:.mp4
      find the matched type:.mp4
      create player:0
      tag   : tina3.5
      branch: tina-dev
      Change-Id: I5f6c8a88d7b387a312b77a0d5f8ab07ee7a
      xplayer:process message XPLAYER_COMMAND_SET_AUDIOSINK.[ 1009.998032] VE: enable hw clock
      xplayer:process message XPLAYER_COMMAND_SET_SURFACE.
      xplayer:process message XPLAYER_COMMAND_SET_SUBCTRL.
      xplayer:process me[ 1010.002873] enable_cedar_hw_clk,552
      ssage XPLAYER_COMMAND_SET_DI.
      create player[0]:0x1bf96d8
      screen width:800,screen height:1280
      1:playVideo:0
      before TPlayerSet[ 1010.017990] VE: VE real_freq=576000000
      [ 1010.017990]
      DataSource,155680:/mnt/UDISK/1.mp4
      xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
      xplayer:process message XPLAYER_COMMAND_PREPARE.
      warning: unknown callback from Tinaplayer.
      [1970-01-01 08:16:52] INFO   : cedarc <log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
      [1970-01-01 08:16:52] ERROR  : cedarc <DebugCheckConfig:302>: now cedarc log level:5
      setDataSource end
      *****tplayer:video width = 800,height = 480
      TPLAYER_NOTIFY_PREPARED,has prepared.
      TPlayerPrepare end
      xplayer:process message XPLAYER_COMMAND_START.
      (Allwinner Audio Middle Layer),line(971) : Create Decoder!!=====
      (Allwinner Audio Middle Layer),line(603) : AudioDec_Installaudiolib ok
      (Allwinner Audio Middle Layer),line(606) : audio decoder init start ...
      (AllwinnerAlibs),line(50) :
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : audiocodec-v1.2
      branch: new
      commit: 3ba65962c01cbf1280ddda19d9b6ef8ce85
      date  : Tue Jan 8 16:25:27 2019 +0800
      (AllwinnerAlibs),line(700) : ----Loading so success!
      (AllwinnerAlibs),line(902) : *************pAudioStreamInfo start******************
      (AllwinnerAlibs),line(903) : eCodecFormat         :id(4), name(aac low-complexy)
      (AllwinnerAlibs),line(904) : eSubCodecFormat      :0
      (AllwinnerAlibs),line(905) : nChannelNum          :2
      (AllwinnerAlibs),line(906) : nBitsPerSample       :16
      (AllwinnerAlibs),line(907) : nSampleRate          :48000
      (AllwinnerAlibs),line(908) : nAvgBitrate          :2276
      (AllwinnerAlibs),line(909) : nMaxBitRate          :2276
      (AllwinnerAlibs),line(910) : nFileSize            :0
      (AllwinnerAlibs),line(911) : eAudioBitstreamSource:0
      (AllwinnerAlibs),line(912) : eDataEncodeType      :0
      (AllwinnerAlibs),line(913) : nCodecSpecificDataLen:5
      (AllwinnerAlibs),line(914) : pCodecSpecificData   :0xb4f650b8
      (AllwinnerAlibs),line(915) : nFlags               :0
      (AllwinnerAlibs),line(916) : nBlockAlign          :0
      (AllwinnerAlibs),line(917) : *************pAudioStreamInfo end  ******************
      (AAC Decoder),line(36) : init successs...
      (Allwinner Audio Middle Layer),line(614) : AUDIO DECODE INIT OK...0
      started.
      ****player(0x1bfa9c0): first audio pts = 0*****
      ERROR  : awplayer <__LayerQueueBuffer:934>: *** picNode is full when queue buffer
      *****tplayer:video decoded width = 800,height = 480
      *****tplayerdemo:video decoded width = 800,height = 480real set to display rect:w = 800,h = 480
      *****tplayer:video width = 1600,height = 960
      ****player(0x1bfa9c0): first video pts = 83333*****
      ****player(0x1bfa9c0): first audio pts = 39999*****
      [1970-01-01 08:16:53] ERROR  : fbm.c <FbmReturnPicture:1043>: invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=1, bAlreadyDisplayed=0.
      [1970-01-01 08:16:53] ERROR  : fbm.c <FbmReturnPicture:1044>: **picture[0xb5001790],id[8]
      [1970-01-01 08:16:53] WARNING: cedarc <ReturnPicture:1700>: FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
      ^CGot signal 2, exiting ...
      xplayer:process message XPLAYER_COMMAND_RESET.
      (AAC Decoder),line(44) : exit successs...
      (AllwinnerAlibs),line(750) : ----dlclose so success!
      (Allwinner Audio Middle Layer),line(920) : destroy_ResampleInfo!!
      (Allwinner Audio Resample),line(68) : Destroy_ResampleInfo...
      [ 1013.481410] VE: disable hw clock
      [ 1013.485116] disable_cedar_hw_clk,592
      TPlayerDestroy(0) successfully
      destroy tplayer
      tplaydemo exit
        lyg116 LV 6 最后由 编辑
        ![替代文字](错误.jpg 图片地址)
