    Tina偶尔上电启动出错,log显示坏块,是什么原因
    • N
      nice0513 LV 4 最后由 编辑
      Launching microcom serial connection on /dev/ttyS2.
      Press Ctrl+X to exit.
      [158]HELLO! BOOT0 is starting!
      [160]BOOT0 commit : 88480af-dirty
      [164]set pll start
      [166]fix vccio detect value:0xc0
      [173]periph0 has been enabled
      [176]set pll end
      [178][pmu]: bus read error
      [180]board init ok
      [182]ZQ value = 0x31
      [184]get_pmu_exist() = -1
      [187]DRAM BOOT DRIVE INFO: V0.33
      [190]DRAM CLK = 936 MHz
      [192]DRAM Type = 3 (2:DDR2,3:DDR3)
      [195]DRAMC read ODT  off.
      [198]DRAM ODT value: 0x42.
      [200]ddr_efuse_type: 0xa
      [204]DRAM SIZE =128 M
      [206]dram_tpr4:0x0
      [207]PLL_DDR_CTRL_REG:0xf8004d00
      [210]DRAM_CLK_REG:0xc0000000
      [213][TIMING DEBUG] MR2= 0x20
      [221]DRAM simple test OK.
      [223]rtc standby flag is 0x0, super standby flag is 0x0
      [228]dram size =128
      [231]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [236]block from 8 to 32
      [239]oob_buf[0] = 0
      [241]spi nand block 8 is bad
      [244]oob_buf[0] = 0
      [246]spi nand block 9 is bad
      [249]oob_buf[0] = 0
      [250]spi nand block 10 is bad
      [254]oob_buf[0] = 0
      [255]spi nand block 11 is bad
      [258]oob_buf[0] = 0
      [260]spi nand block 12 is bad
      [263]oob_buf[0] = 0
      [265]spi nand block 13 is bad
      [268]oob_buf[0] = 0
      [270]spi nand block 14 is bad
      [273]oob_buf[0] = 0
      [275]spi nand block 15 is bad
      [278]oob_buf[0] = 0
      [280]spi nand block 16 is bad
      [283]oob_buf[0] = 0
      [285]spi nand block 17 is bad
      [288]oob_buf[0] = 0
      [289]spi nand block 18 is bad
      [292]oob_buf[0] = 0
      [294]spi nand block 19 is bad
      [297]oob_buf[0] = 0
      [299]spi nand block 20 is bad
      [302]oob_buf[0] = 0
      [304]spi nand block 21 is bad
      [307]oob_buf[0] = 0
      [309]spi nand block 22 is bad
      [312]oob_buf[0] = 0
      [314]spi nand block 23 is bad
      [317]oob_buf[0] = 0
      [319]spi nand block 24 is bad
      [322]oob_buf[0] = 0
      [323]spi nand block 25 is bad
      [326]oob_buf[0] = 0
      [328]spi nand block 26 is bad
      [331]oob_buf[0] = 0
      [333]spi nand block 27 is bad
      [336]oob_buf[0] = 0
      [338]spi nand block 28 is bad
      [341]oob_buf[0] = 0
      [343]spi nand block 29 is bad
      [346]oob_buf[0] = 0
      [347]spi nand block 30 is bad
      [350]oob_buf[0] = 0
      [352]spi nand block 31 is bad
      [355]oob_buf[0] = 0
      [357]spi nand block 32 is bad
      [360]Can't find a good Boot1 copy in spi nand.
      [364]dma 0x29c0c int is not used yet
      [367]dma 0x29c0c int is free, you do not need to free it again
