    编译851S时:INFO: build_openwrt_rootfs failed
      zy_linux LV 2 最后由 编辑
      纯小白初学者,求助大佬!在构建环境之后执行make编译遇到了INFO: build_openwrt_rootfs failed,尝试了各种办法依然无法解决,希望各位大佬能够能够给予帮助!
      zy-851s@zy-851s-use:~/linux/v851s/tina-v853-open$ make -j1 V=c
      ===There is tina environment.===
       Note: make is the shell functon in envsetup.sh.
      == action: openwrt_build, action_args: -j1 V=c ==
      ========ACTION List: build_linuxdev -j1 V=c;========
      options :
      INFO: build linuxdev ...
      INFO: chip: sun8iw21p1
      INFO: platform: linux
      INFO: kernel: linux-4.9
      INFO: board: lizard
      INFO: output: /home/zy-851s/linux/v851s/tina-v853-open/out/v851s/lizard/openwrt
      INFO: don't build dtbo ...
      INFO: build arisc
      INFO: build_bootloader: brandy_path= /home/zy-851s/linux/v851s/tina-v853-open/brandy/brandy-2.0
      INFO: skip build brandy.
      INFO: build kernel ...
      INFO: Prepare toolchain ...
      Building kernel
      /home/zy-851s/linux/v851s/tina-v853-open/kernel/linux-4.9/output/lib/modules/4.9.191
        CHK     include/config/kernel.release
        CHK     include/generated/uapi/linux/version.h
        CHK     include/generated/utsrelease.h
        CHK     scripts/mod/devicetable-offsets.h
        CHK     include/generated/timeconst.h
        CHK     include/generated/bounds.h
        CHK     include/generated/asm-offsets.h
        CALL    scripts/checksyscalls.sh
        CHK     include/generated/compile.h
        DTC     arch/arm/boot/dts/board.dtb
        Kernel: arch/arm/boot/Image is ready
        Building modules, stage 2.
        MODPOST 16 modules
        Kernel: arch/arm/boot/zImage is ready
        Kernel: arch/arm/boot/uImage is ready
      'arch/arm/boot/Image' -> 'output/bImage'
      'arch/arm/boot/uImage' -> 'output/uImage'
      'arch/arm/boot/zImage' -> 'output/zImage'
      Copy rootfs.cpio.gz for arm
      Building modules
      [GPU]: No GPU type is configured in /home/zy-851s/linux/v851s/tina-v853-open/kernel/linux-4.9/.config.
      INFO: build dts ...
      removed '/home/zy-851s/linux/v851s/tina-v853-open/out/v851s/lizard/openwrt/.board.dtb.d.dtc.tmp'
      removed '/home/zy-851s/linux/v851s/tina-v853-open/out/v851s/lizard/openwrt/.board.dtb.dts.tmp'
      '/home/zy-851s/linux/v851s/tina-v853-open/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.d.dtc.tmp' -> '/home/zy-851s/linux/v851s/tina-v853-open/out/v851s/lizard/openwrt/.board.dtb.d.dtc.tmp'
      '/home/zy-851s/linux/v851s/tina-v853-open/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.dts.tmp' -> '/home/zy-851s/linux/v851s/tina-v853-open/out/v851s/lizard/openwrt/.board.dtb.dts.tmp'
      INFO: build rootfs ...
      ==mkcmd.sh: build_openwrt_rootfs -j1 V=c==
      make: Entering directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt'
      make[1]: Entering directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt'
      CreateSoftLink  /home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt/tmp link to  /home/zy-851s/linux/v851s/tina-v853-open/out/v851s/lizard/openwrt/tmp
      CreateSoftLink  /home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt/staging_dir link to  /home/zy-851s/linux/v851s/tina-v853-open/out/v851s/lizard/openwrt/staging_dir
      make[2]: Entering directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt'
      make[2]: Leaving directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt'
      Check Vendor Package...
      CreateSoftLink  /home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt/package/subpackage link to  /home/zy-851s/linux/v851s/tina-v853-open/openwrt/package
      end
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/decodertest/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/encoderStressTest/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/encodertest/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-good', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland-protocols', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'opencv', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1badvideo', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-base/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/jpegdecodedemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/kernel/linux/Makefile' has a dependency on 'kmod-sunxi-rf-wlan', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/lvgl-8/lv_monitor/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/moduledemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/minigui/multimedia-test/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'weston', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'qt5-multimediawidgets', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a build dependency on 'libstdcpp', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/minigui/smart-music-player/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/tmetadataretrieverdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/tplayerdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/trecorderdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/minigui/washing-machine/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/xplayerdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/testtools/testapk/__trecordertest/Makefile' has a dependency on 'libcedarx', which does not exist
      make[2]: Entering directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt/scripts/config'
      make[2]: 'conf' is up to date.
      make[2]: Leaving directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt/scripts/config'
      copy from /home/zy-851s/linux/v851s/tina-v853-open/openwrt/target/v851s/v851s-lizard/defconfig
      scripts/config/conf: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.27' not found (required by scripts/config/conf)
      /home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt/include/toplevel.mk:98: recipe for target '.config' failed
      make[1]: *** [.config] Error 1
      make[1]: Leaving directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt'
      /home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'world' failed
      make: *** [world] Error 2
      make: Leaving directory '/home/zy-851s/linux/v851s/tina-v853-open/openwrt/openwrt'
