    V851SE 想用TF卡启动 求指点
    • F
      fdag43262g32 LV 4 最后由 编辑
      [188]HELLO! BOOT0 is starting!
      [191]BOOT0 commit : 4b419f21ba
      [287][pmu]: bus read error
      [289]set pll start
      [291]periph0 has been enabled
      [294]set pll end
      [296]board init ok
      [298]DRAM use internal ZQ!!
      [300]ZQ value = 0x2d
      [303]chip id check OK
      [305]POWER SETTING ERROR!
      [307]trefi:7.8ms
      [310][AUTO DEBUG] single rank and full DQ!
      [314]trefi:7.8ms
      [316][AUTO DEBUG] rank 0 row = 13
      [319][AUTO DEBUG] rank 0 bank = 4
      [323][AUTO DEBUG] rank 0 page size = 2 KB
      [327]DRAM BOOT DRIVE INFO: V0.16
      [330]DRAM CLK = 528 MHz
      [332]DRAM Type = 2 (2:DDR2,3:DDR3)
      [335]DRAMC read ODT off.
      [338]DRAM ODT off.
      [340]DRAM SIZE =64 M
      [342]dram_tpr4:0x0
      [349]DRAM simple test OK.
      [351]rtc standby flag is 0x0, super standby flag is 0x0
      [356]dram size =64
      [359]audio:avcc calibration
      [361]card no is 0
      [363]sdcard 0 line count 4
      [366][mmc]: mmc driver ver 2021-12-27 10:07
      [375][mmc]: Wrong media type 0x0
      [378][mmc]: Try SD card 0
      [400][mmc]: DS26/SDR12 4 bit
      [403][mmc]: 25000000 Hz
      [405][mmc]: 942 MB
      [407][mmc]: SD/MMC 0 init OK!!!
      [536]Loading boot-pkg Succeed(index=0).
      [540]Entry_name = optee
      [543]Entry_name = u-boot
      [551]Entry_name = dtb
      [554]mmc not para
      [556]Jump to second Boot.
      E/TC:0 0 platform_standby_fdt_parse:133 no pmu node
      E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      U-Boot 2018.05 (Nov 08 2024 - 00:03:36 +0800) Allwinner Technology
      [00.633]CPU: Allwinner Family
      [00.636]Model: sun8iw21
      I2C: [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
      ready
      [00.696]DRAM: 64 MiB
      [00.700]Relocation Offset is: 00ed0000
      [00.732]secure enable bit: 0
      E/TC:0 tee_read_fdt:433 fine node /firmware/optee failed with FDT_ERR_NOTFOUND
      [00.747]smc_tee_inform_fdt failed with: ffff0000
      [I2C-ERROR]:twi_stop() 339 STOP can't sendout!
      [00.757]pmu_axp2101_probe pmic_bus_read fail
      [00.765]bmu_axp2101_probe pmic_bus_read fail
      [00.769]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=300Mhz
      [00.775]gic: sec monitor mode
      sunxi flash map init
      [00.780]flash init start
      [00.782]workmode = 0,storage type = 1
      [00.786][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.791][mmc]: get sdc_type fail and use default host:tm1.
      [00.798][mmc]: can't find node "mmc0",will add new node
      [00.802][mmc]: fdt err returned <no error>
      [00.806][mmc]: Using default timing para
      [00.810][mmc]: SUNXI SDMMC Controller Version:0x50400
      [00.841][mmc]: card_caps:0x30000002
      [00.844][mmc]: host_caps:0x3000003f
      [00.848]sunxi flash init ok
      [00.851]line:724 init_clocks
      [00.854]drv_disp_init
      [00.863]drv_disp_init finish
      [00.877]Loading Environment from SUNXI_FLASH... backup env check CRC fail
      Now update backup env
      Saving Environment to SUNXI_FLASH... Writing to env...
      OK
      OK
      [00.975]boot_gui_init:start
      [00.983]Get Reserve0 partition number fail!
      [00.990]boot_gui_init:finish
      [01.003]Get bootloader and boot-resource partition number fail!
      [01.026]Item0 (Map) magic is bad
      [01.029]the secure storage item0 copy0 magic is bad
      [01.051]Item0 (Map) magic is bad
      [01.054]the secure storage item0 copy1 magic is bad
      [01.058]Item0 (Map) magic is bad
      [01.061]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [01.072]update part info
      [01.076]update bootcmd
      [01.080]libfdt fdt_check_header(): FDT_ERR_BADMAGIC
      [01.092]The storage not support sample function
      [01.097]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.103]update dts
      input addr exceed dram scope
      [02.402]no vendor_boot partition is found
      Android's image name: v851se-perf1
      [02.434]Starting kernel ...
      [02.436][mmc]: MMC Device 2 not found
      [02.440][mmc]: mmc 2 not find, so not exit
