    请教A133 G2D调用出现G2D irq pending flag timeout,G2D BITBLT Failed!
    2884
      wupaul2001 LV 5 最后由 编辑
      如题,我把G2D的调试打开,看输入输出参数都没问题,但没有接收到完成中断,请教是什么问题。下面是我的调试LOG
      [ 754.288879] [G2D-g2d_bsp_bitblt] line:1970: BITBLT_flag: 0x0
      [ 754.288886] [G2D-g2d_bsp_bitblt] line:1972: Input info:---------------------------------
      [ 754.288890] [G2D-g2d_bsp_bitblt] line:1973: Src_fd: 6
      [ 754.288895] [G2D-g2d_bsp_bitblt] line:1974: Format: 0x29
      [ 754.288899] [G2D-g2d_bsp_bitblt] line:1975: BITBLT_alpha_mode: 0x0
      [ 754.288904] [G2D-g2d_bsp_bitblt] line:1976: BITBLT_alpha_val: 0x0
      [ 754.288908] [G2D-g2d_bsp_bitblt] line:1977: inClipRectX: 0
      [ 754.288912] [G2D-g2d_bsp_bitblt] line:1978: inClipRectY: 0
      [ 754.288917] [G2D-g2d_bsp_bitblt] line:1979: inClipRectW: 1920
      [ 754.288921] [G2D-g2d_bsp_bitblt] line:1980: inClipRectH: 1080
      [ 754.288925] [G2D-g2d_bsp_bitblt] line:1982: Output info:--------------------------------
      [ 754.288930] [G2D-g2d_bsp_bitblt] line:1983: Dst_fd: 23
      [ 754.288934] [G2D-g2d_bsp_bitblt] line:1984: Format: 0x3
      [ 754.288938] [G2D-g2d_bsp_bitblt] line:1985: outClipRectX: 0
      [ 754.288943] [G2D-g2d_bsp_bitblt] line:1986: outClipRectY: 0
      [ 754.288947] [G2D-g2d_bsp_bitblt] line:1987: outClipRectW: 1920
      [ 754.288951] [G2D-g2d_bsp_bitblt] line:1988: outClipRectH: 1080
      [ 754.288958] [G2D-g2d_vlayer_set] line:627: VInPITCH: 1920, 1920, 0
      [ 754.288964] [G2D-g2d_vlayer_set] line:629: VInAddrB: 0xf7400000, 0xf75fa400, 0xf76f7600
      [ 754.288969] [G2D-g2d_vlayer_set] line:646: VInAddrA: 0xf7400000, 0xf75fa400, 0xf76f7600
      [ 754.288983] [G2D-g2d_bldin_set] line:1359: BLD_CH_ISIZE W: 0x780
      [ 754.288987] [G2D-g2d_bldin_set] line:1360: BLD_CH_ISIZE H: 0x438
      [ 754.288991] [G2D-g2d_bldin_set] line:1367: BLD_CH_ISIZE X: 0x0
      [ 754.288996] [G2D-g2d_bldin_set] line:1368: BLD_CH_ISIZE Y: 0x0
      [ 754.289002] [G2D-g2d_wb_set] line:717: BLD_CH_OSIZE W: 0x780
      [ 754.289006] [G2D-g2d_wb_set] line:718: BLD_CH_OSIZE H: 0x438
      [ 754.289012] [G2D-g2d_wb_set] line:765: OutputPitch: 7680, 0, 0
      [ 754.289017] [G2D-g2d_wb_set] line:782: WbAddr: 0xf6800000, 0xf69fa400, 0xf6bf4800
      [ 754.289022] [G2D-g2d_bsp_bitblt] line:2297: INIT_MODULE: 0x80000000
      [ 754.390950] G2D irq pending flag timeout
      [ 754.390956] G2D BITBLT Failed!
      W 1 条回复 最后回复 回复 引用 分享 0
        wupaul2001 LV 5 @wupaul2001 最后由 编辑
        改为了使用物理地址,也还是一样
        [ 4408.395590] [G2D-g2d_bsp_bitblt] line:1970: BITBLT_flag: 0x0
        [ 4408.395597] [G2D-g2d_bsp_bitblt] line:1972: Input info:---------------------------------
        [ 4408.395601] [G2D-g2d_bsp_bitblt] line:1973: Src_fd: 0
        [ 4408.395605] [G2D-g2d_bsp_bitblt] line:1974: Format: 0x29
        [ 4408.395609] [G2D-g2d_bsp_bitblt] line:1975: BITBLT_alpha_mode: 0x0
        [ 4408.395614] [G2D-g2d_bsp_bitblt] line:1976: BITBLT_alpha_val: 0x0
        [ 4408.395618] [G2D-g2d_bsp_bitblt] line:1977: inClipRectX: 0
        [ 4408.395623] [G2D-g2d_bsp_bitblt] line:1978: inClipRectY: 0
        [ 4408.395627] [G2D-g2d_bsp_bitblt] line:1979: inClipRectW: 1920
        [ 4408.395631] [G2D-g2d_bsp_bitblt] line:1980: inClipRectH: 1080
        [ 4408.395636] [G2D-g2d_bsp_bitblt] line:1982: Output info:--------------------------------
        [ 4408.395640] [G2D-g2d_bsp_bitblt] line:1983: Dst_fd: 0
        [ 4408.395644] [G2D-g2d_bsp_bitblt] line:1984: Format: 0x3
        [ 4408.395649] [G2D-g2d_bsp_bitblt] line:1985: outClipRectX: 0
        [ 4408.395653] [G2D-g2d_bsp_bitblt] line:1986: outClipRectY: 0
        [ 4408.395657] [G2D-g2d_bsp_bitblt] line:1987: outClipRectW: 1920
        [ 4408.395662] [G2D-g2d_bsp_bitblt] line:1988: outClipRectH: 1080
        [ 4408.395669] [G2D-g2d_vlayer_set] line:627: VInPITCH: 1920, 1920, 0
        [ 4408.395674] [G2D-g2d_vlayer_set] line:629: VInAddrB: 0xff400000, 0xff5fa400, 0x0
        [ 4408.395679] [G2D-g2d_vlayer_set] line:646: VInAddrA: 0xff400000, 0xff5fa400, 0x0
        [ 4408.395693] [G2D-g2d_bldin_set] line:1359: BLD_CH_ISIZE W: 0x780
        [ 4408.395697] [G2D-g2d_bldin_set] line:1360: BLD_CH_ISIZE H: 0x438
        [ 4408.395702] [G2D-g2d_bldin_set] line:1367: BLD_CH_ISIZE X: 0x0
        [ 4408.395706] [G2D-g2d_bldin_set] line:1368: BLD_CH_ISIZE Y: 0x0
        [ 4408.395712] [G2D-g2d_wb_set] line:717: BLD_CH_OSIZE W: 0x780
        [ 4408.395717] [G2D-g2d_wb_set] line:718: BLD_CH_OSIZE H: 0x438
        [ 4408.395722] [G2D-g2d_wb_set] line:765: OutputPitch: 7680, 0, 0
        [ 4408.395727] [G2D-g2d_wb_set] line:782: WbAddr: 0xf9000000, 0x0, 0x0
        [ 4408.395732] [G2D-g2d_bsp_bitblt] line:2297: INIT_MODULE: 0x80000000
        [ 4408.496871] G2D irq pending flag timeout
        [ 4408.496876] G2D BITBLT Failed!
        下面是我调用的代码
        int g2d::NV21ToRGB(ion_mem* in, ion_mem* out)
        int ret = 0;
        g2d_blt_h blit;
        memset(&blit, 0, sizeof(blit));
        if(g2d_fd < 0)
            printf("G2D not open! \n");
            return -1;
        blit.flag_h = G2D_BLT_NONE_H;       						//纯转换
        blit.src_image_h.format = G2D_FORMAT_YUV420UVC_U1V1U0V0;	//NV21
        blit.src_image_h.width = IMAGEWIDTH;
        blit.src_image_h.height = IMAGEHEIGHT;
        blit.src_image_h.align[0] = 0;
        blit.src_image_h.align[1] = 0;
        blit.src_image_h.clip_rect.x = 0;
        blit.src_image_h.clip_rect.y = 0;
        blit.src_image_h.clip_rect.w = IMAGEWIDTH;
        blit.src_image_h.clip_rect.h = IMAGEHEIGHT;
        blit.src_image_h.gamut = G2D_BT601;
        blit.src_image_h.bpremul = 0;
        blit.src_image_h.mode = G2D_PIXEL_ALPHA;
        blit.src_image_h.use_phy_addr = 1;
        blit.src_image_h.laddr[0] = in->phy;
        blit.src_image_h.laddr[1] = in->phy + IMAGEWIDTH * IMAGEHEIGHT;
        blit.dst_image_h.format = G2D_FORMAT_BGRA8888;
        blit.dst_image_h.width = IMAGEWIDTH;
        blit.dst_image_h.height = IMAGEHEIGHT;
        blit.dst_image_h.align[0] = 0;
        blit.dst_image_h.clip_rect.x = 0;
        blit.dst_image_h.clip_rect.y = 0;
        blit.dst_image_h.clip_rect.w = IMAGEWIDTH;
        blit.dst_image_h.clip_rect.h = IMAGEHEIGHT;
        blit.dst_image_h.gamut = G2D_BT601;
        blit.dst_image_h.bpremul = 0;
        blit.dst_image_h.mode = G2D_PIXEL_ALPHA;
        blit.dst_image_h.use_phy_addr = 1;
        blit.dst_image_h.laddr[0] = out->phy;
        if(ioctl(g2d_fd, G2D_CMD_BITBLT_H, (unsigned long)&blit) < 0)
            printf("G2D convert failed! \n");
            return -1;
          终于找到问题了,A133的G2D被精准刀法砍掉,G2D只有旋转功能,WriteBack功能也被砍掉,导致不能做RGB转YUV![9448fcc0-d8a4-4cc6-9623-79b305845553-FSLUSEV8BB~XYA$680`ERU.png
          • B
            benlypan LV 2 最后由 编辑
            哥们,你拯救了我😭 ,调了两个小时了,旋转可以,缩放不行,然后搜到了你的贴子,再翻了手册,大坑。
