    V851SE挂载aic8800报错:wlan0: Unsupported driver 'nl80211'
      syk1324 LV 3 最后由 编辑
      不知道大家有没有同样的情况。
      1970-01-01 00:00:25:624: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: hostapd not exist
      root@TinaLinux:/# Trying to connect to SWUpdate...
      1970-01-01 00:00:25:682: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:25:682: WMG_DEBUG [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1429]:  wpa_supplicant is not running, need to start it
      swu_param: ####
      swu_software: ####
      swu_mode: ####
      udhcpc: sending discover
      udhcpc: sendto: Network is down
      udhcpc: read error: Network is down, reopening socket
      1970-01-01 00:00:26:710: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:27:732: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:28:754: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:29:776: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:30:798: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:30:799: WMG_ERROR [src/os/linux/linux_wpa.c:start_supplicant:357]:  failed to start wpa_supplicant times 1
      1970-01-01 00:00:30:802: WMG_ERROR [src/os/linux/linux_wpa.c:start_supplicant:357]:  failed to start wpa_supplicant times 2
      1970-01-01 00:00:30:802: WMG_ERROR [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1432]:  start wpa_supplicant failed
      1970-01-01 00:00:30:802: WMG_ERROR [src/wmg_sta.c:sta_mode_enable:416]:  failed to connect to wpa_supplicant
      1970-01-01 00:00:30:802: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:297]:  wifi sta mode enable faile
      1970-01-01 00:00:30:802: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:320]:  switch after current_mode_bitmap:0x0
      1970-01-01 00:00:30:802: WMG_ERROR [src/wmg_common.c:wifimg_switch_mode:327]:  switch mode faile
      1970-01-01 00:00:30:802: WMG_ERROR [src/wifimg.c:__wifi_on:34]:  failed to switch wifi mode
      1970-01-01 00:00:30:802: WMG_ERROR [wifi_daemon.c:cmd_handle_o:58]:  wifi on sta mode failed
      udhcpc: no lease, forking to background
      C J 2 条回复 最后回复 回复 引用 分享 0
        Haitun_CZR LV 3 @syk1324 最后由 编辑
        @syk1324
        SDK根目录下执行make menuconfig
        然后把PACKAGE_kmod-cfg80211选上即可。
        原因是wpa_supplicant和内核的通信是通过netlink,是用户态协议,然后你没在openwrt的配置中选中,所以会无法使用。选上后即可。
          jiangfeilong LV 2 @syk1324 最后由 编辑
          @syk1324 你在哪里下载的sdk呢
