    F1C200S dd: writing '/dev/fb0': No space left on device 始终是这个错 无语了
      dongjing120426 LV 2 最后由 编辑
      始终是这个错 无语了
      root@TinaLinux:/usr/lib# tplayerdemo play /etc/img/abc.mp4
      WARNING: awplayer <log_set_level:30>: Set log level to 3
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-0 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-1 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-2 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-3 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-4 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-5 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-6 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-7 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-8 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-9 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-10 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-11 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-12 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-13 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry adecoder-14 ok.
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry adecoder-15 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 15 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open adecoder lib
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.aac comment is "aac_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_aacdec.so
      DEBUG  : awplayer <AwStreamInit:97>: aw stream init...
      DEBUG  : awplayer <AwStreamInit:131>: stream list size:6
      INFO   : awplayer <AwParserInit:399>: aw parser init...
      DEBUG  : awplayer <AwParserInit:470>: aw parser size:17
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.alac comment is "alac_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_alacdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.amr comment is "amr_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_amrdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.ape comment is "ape_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_apedec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.flac comment is "flac_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_flacdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.mp3 comment is "mp3_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_mp3dec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.ogg comment is "ogg_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_oggdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.wav comment is "wav_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_wavdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.atrc comment is "atrc_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_atrcdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.cook comment is "cook_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_cookdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.ra comment is "ra_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_radec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.sipr comment is "sipr_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_siprdec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.dsd comment is "dsd_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_dsddec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.g729 comment is "g729_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_g729dec.so
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin adecoder.opus comment is "opus_adecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libaw_opusdec.so
      DEBUG  : awplayer <CdxPluginLoadList:202>: Load Plugin list vdecoder
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-0 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-1 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-2 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-3 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-4 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-5 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-6 ok.
      DEBUG  : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-7 ok.
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry vdecoder-8 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 8 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open vdecoder lib
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.avs comment is "avs_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawavs.so
      ERROR  : awplayer <DlOpenPlugin:103>: dlopen 'libawavs.so' fail: Error loading shared library libawavs.so: No such file or directory
      DEBUG  : awplayer <CdxPluginLoadList:231>: load vdecoder id vdecoder.avs fail!
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.h264 comment is "h264_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawh264.so
      DEBUG  : awplayer <DlOpenPlugin:116>: plugin init : CedarPluginVDInit
      warning: cedarc <VDecoderRegister:127>: register codec: '115:h264' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mjpeg comment is "mjpeg_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmjpeg.so
      warning: cedarc <VDecoderRegister:127>: register codec: '101:mjpeg' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg2 comment is "mpeg2_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg2.so
      warning: cedarc <VDecoderRegister:127>: register codec: '102:mpeg2' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '103:mpeg2' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4base comment is "mpeg4base_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4base.so
      WARNING: awplayer <DlOpenPlugin:112>: Invalid plugin,function CedarPluginVDInit not found.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4dx comment is "mpeg4dx_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4dx.so
      warning: cedarc <VDecoderRegister:127>: register codec: '105:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '106:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '107:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10e:mpeg4dx' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10f:mpeg4dx' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4h263 comment is "mpeg4h263_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4h263.so
      warning: cedarc <VDecoderRegister:127>: register codec: '104:mpeg4H263' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10b:mpeg4H263' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10d:mpeg4H263' success.
      DEBUG  : awplayer <DlOpenPlugin:96>: plugin vdecoder.mpeg4normal comment is "mpeg4normal_vdecoder"
      DEBUG  : awplayer <DlOpenPlugin:97>: plugin open lib: libawmpeg4normal.so
      warning: cedarc <VDecoderRegister:127>: register codec: '10a:mpeg4Normal' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '10c:mpeg4Normal' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '108:mpeg4Normal' success.
      warning: cedarc <VDecoderRegister:127>: register codec: '109:mpeg4Normal' success.
      DEBUG  : awplayer <CdxPluginLoadList:202>: Load Plugin list plugin
      DEBUG  : awplayer <ReadPluginEntry:194>: read plugin entry plugin-0 fail!
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 0 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open plugin lib
      * This program implements a simple player, you can type commands to control the player.
      * To show what commands supported, type 'help'.
      tag   : tina3.5
      branch: tina-dev
      DEBUG : tplayer <TPlayerCreate:193>: TPlayerCreate
      DEBUG  : awplayer <XPlayerCreate:219>: XPlayerCreate.
      DEBUG  : awplayer <LogVersionInfo:34>:
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> CedarX <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : CedarX-2.8.0
      branch: master
      commit: 967535b8ff6a073cb4f38e85a4ae5fa6008014d8
      date  : Mon, 15 May 2017 01:30:22 +0000 (09:30 +0800)
      author:
      DEBUG : tsoundcontrol <TSoundDeviceCreate:147>: TinaSoundDeviceInit()
      DEBUG : tsoundcontrol <openSoundDevice:17>: openSoundDevice() in default style
      DEBUG  : awplayer <LayerCreate:955>: LayerCreate.
      DEBUG  : awplayer <LayerCreate:975>: ==== callback: 0xb6e6ce5c, pUser: 0xb6f0de40
      DEBUG  : awplayer <LayerCreate:986>: screen:w 800, screen:h 1280
      DEBUG : tsubtitlectrl <SubtitleCreate:84>: ==== pCallback: 0xb6e6cccc, pUser: 0xb6f0de40
      DEBUG  : awplayer <XPlayerSetVideoSurfaceTexture:594>: setVideoSurfaceTexture, surface = 0x14f0180
      DEBUG  : awplayer <XPlayerThread:1906>: process message XPLAYER_COMMAND_SET_SURFACE.
      DEBUG  : awplayer <XPlayerThread:1967>: ==== process message XPLAYER_COMMAND_SET_SUBCTRL.
      DEBUG  : awplayer <PlayerSetSubCtrl:679>: === PlayerSetSubCtrl
      DEBUG  : awplayer <XPlayerSetDeinterlace:695>: set deinterlace
      DEBUG  : awplayer <XPlayerThread:1982>: ==== process message XPLAYER_COMMAND_SET_SUBCTRL.
      16001+0 records in
      16000+0 records out
