    H618 sdio频率一直是400k
    H/F/TV Series
    h618 sdio问题
    • G
      gwx123 LV 3 最后由 xiaowenge 编辑
      H618安卓12的sdio一直是400k,wifi起不来,有知道的大佬帮忙看看吗?
      日志:
      --------- beginning of main
      01-01 08:00:05.964   174   174 W lowmemorykiller: LMKD : whitelist android.signature.cts.api.hiddenapi_blacklist_api_27;android.signature.cts.api.hiddenapi_blacklist_api_28;android.signature.cts.api.hiddenapi_blacklist_current;android.media.cts;android.process.media;com.antutu.ABenchMark;com.antutu.benchmark.full;com.antutu.benchmark.full:unity;com.antutu.ABenchMark:push;com.futuremark.dmandroid.application;com.allwinner.batterytest;cn.xender;com.socialnmobile.dictapps.notepad.color.note;org.videolan.vlc;
      01-01 08:00:05.964   174   174 I lowmemorykiller: Using psi monitors for memory pressure detection
      01-01 08:00:05.966   174   174 I lowmemorykiller: Process polling is supported
      --------- beginning of kernel
      01-01 08:00:02.196     0     0 I         : Booting Linux on physical CPU 0x0000000000 [0x410fd034]
      01-01 08:00:02.196     0     0 I         : Linux version 5.4.125+ (robin@robin) (Android (7485623, based on r416183b1) clang version 12.0.7 (https://android.googlesource.com/toolchain/llvm-project c935d99d7cf2016289302412d708641d52d2f7ee), LLD 12.0.7 (/buildbot/src/android/llvm-r416183/out/llvm-project/lld c935d99d7cf2016289302412d708641d52d2f7ee)) #3 SMP PREEMPT Tue Dec 10 15:33:55 CST 2024
      01-01 08:00:02.196     0     0 I Machine model: sun50iw9
      01-01 08:00:02.196     0     0 I earlycon: uart8250 at MMIO32 0x0000000005000000 (options '')
      01-01 08:00:02.196     0     0 I printk  : bootconsole [uart8250] enabled
      01-01 08:00:02.196     0     0 I cma     : Reserved 8 MiB at 0x00000000bf800000
      01-01 08[    8.365780][  T248] cutils-trace: Error opening trace file: No such file or directory (2)
      :00:02.196     0     0 D         : On node 0 totalpages: 524288
      01-01 08:00:02.196     0     0 D DMA32 zone: 8192 pages used for memmap
      01-01 08:00:02.196     0     0 D DMA32 zone: 0 pages reserved
      01-01 08:00:02.196     0     0 D DMA32 zone: 524288 pages, LIFO batch:63
      01-01 08:00:02.196     0     0 I psci    : probing for conduit method from DT.
      01-01 08:00:02.196     0     0 I psci    : PSCIv1.0 detected in firmware.
      01-01 08:00:02.196     0     0 I psci    : Using standard PSCI v0.2 function IDs
      01-01 08:00:02.196     0     0 I psci    : Trusted OS migration not required
      01-01 08:00:02.196     0     0 I psci    : SMC Calling Convention v1.0
      01-01 08:00:02.196     0     0 I percpu  : Embedded 22 pages/cpu s49944 r8192 d31976 u90112
      01-01 08:00:02.196     0     0 D pcpu-alloc: s49944 r8192 d31976 u90112 alloc=22*4096
      01-01 08:00:02.196     0     0 D pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      01-01 08:00:02.196     0     0 I         : Detected VIPT I-cache on CPU0
      01-01 08:00:02.196     0     0 I CPU features: detected: ARM erratum 845719
      01-01 08:00:02.196     0     0 I         : Built 1 zonelists, mobility grouping on.  Total pages: 516096
      01-01 08:00:02.196     0     0 I         : Kernel command line: earlycon=uart8250,mmio32,0x05000000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=4 root=/dev/mmcblk0p4 init=/init cma=8M snum=0c001050010248d1f91 mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.force_normal_boot=1 androidboot.slot_suffix=_a androidboot.vbmeta.avb_version=2.0 androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=7872 androidboot.vbmeta.digest=5b1037089489ad2fa0c62cd98e9ae2801bc6e393fd0b59a89d303bac5f3f4f8e androidboot.vbmeta.device_state=locked androidboot.veritymode=enforcing androidboot.mode=normal androidboot.serialno=0c001050010248d1f91 androidboot.hardware=sun50iw9p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=1 androidboot.trustchain=false androidboot.drmkey=false gpt=1 uboot_message=2018.07-gb99798b(04/04/2023-13:23:26) mbr_offset=1032192 disp_reserve=3686400,0xbbf21000 bootreason=unknow androidboot.dramfreq=720 androidboot.dramsize=2048 loop.max_part=4 android
      01-01 08:00:02.196     0     0 I         : Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
      01-01 08:00:02.196     0     0 I         : Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
      01-01 08:00:02.196     0     0 I mem auto-init: stack:off, heap alloc:off, heap free:off
      01-01 08:00:02.196     0     0 I Memory  : 1990540K/2097152K available (14076K kernel code, 1366K rwdata, 5684K rodata, 1024K init, 778K bss, 98420K reserved, 8192K cma-reserved)
      01-01 08:00:02.196     0     0 I SLUB    : HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      01-01 08:00:02.196     0     0 I rcu     : Preemptible hierarchical RCU implementation.
      01-01 08:00:02.196     0     0 I         : Tasks RCU enabled.
      01-01 08:00:02.196     0     0 I rcu     : RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      01-01 08:00:02.196     0     0 I NR_IRQS : 64, nr_irqs: 64, preallocated irqs: 0
      01-01 08:00:02.196     0     0 I kfence  : initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
      01-01 08:00:02.196     0     0 I random  : get_random_bytes called from start_kernel+0x224/0x434 with crng_init=0
      01-01 08:00:02.196     0     0 I arch_timer: cp15 timer(s) running at 24.00MHz (virt).
      01-01 08:00:02.196     0     0 I clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      01-01 08:00:02.196     0     0 I sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      01-01 08:00:02.197     0     0 I clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      01-01 08:00:02.197     0     0 I         : Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
      01-01 08:00:02.197     0     0 I pid_max : default: 32768 minimum: 301
      01-01 08:00:02.197     0     0 I LSM     : Security Framework initializing
      01-01 08:00:02.197     0     0 I SELinux : Initializing.
      01-01 08:00:02.197     0     0 I         : Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      01-01 08:00:02.197     0     0 I         : Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      01-01 08:00:02.198     1     1 I         : ASID allocator initialised with 32768 entries
      01-01 08:00:02.198     1     1 I rcu     : Hierarchical SRCU implementation.
      01-01 08:00:02.201     1     1 E BOOTEVENT: 4.206998: ON
      01-01 08:00:02.206     1     1 I smp     : Bringing up secondary CPUs ...
      01-01 08:00:02.206     0     0 I         : Detected VIPT I-cache on CPU1
      01-01 08:00:02.206     0     0 I CPU1    : Booted secondary processor 0x0000000001 [0x410fd034]
      01-01 08:00:02.207     0     0 I         : Detected VIPT I-cache on CPU2
      01-01 08:00:02.207     0     0 I CPU2    : Booted secondary processor 0x0000000002 [0x410fd034]
      01-01 08:00:02.207     0     0 I         : Detected VIPT I-cache on CPU3
      01-01 08:00:02.207     0     0 I CPU3    : Booted secondary processor 0x0000000003 [0x410fd034]
      01-01 08:00:02.207     1     1 I smp     : Brought up 1 node, 4 CPUs
      01-01 08:00:02.207     1     1 I SMP     : Total of 4 processors activated.
      01-01 08:00:02.207     1     1 I CPU features: detected: 32-bit EL0 Support
      01-01 08:00:02.207     1     1 I CPU features: detected: CRC32 instructions
      01-01 08:00:02.207     1     1 I CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
      01-01 08:00:02.207     1     1 I         : CPU: All CPU(s) started at EL1
      01-01 08:00:02.207    12    12 I alternatives: patching kernel code
      01-01 08:00:02.208     1     1 I CPU3    : update max cpu_capacity 1024
      01-01 08:00:02.209     1     1 I devtmpfs: initialized
      01-01 08:00:02.210     0     0 I [    C1] CPU1: update max cpu_capacity 1024
      01-01 08:00:02.217     1     1 I         : Registered cp15_barrier emulation handler
      01-01 08:00:02.217     1     1 I         : Registered setend emulation handler
      01-01 08:00:02.217     1     1 I clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      01-01 08:00:02.217     1     1 I         : futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      01-01 08:00:02.217     1     1 I pinctrl core: initialized pinctrl subsystem
      01-01 08:00:02.218     1     1 I NET     : Registered protocol family 16
      01-01 08:00:02.220     1     1 I DMA     : preallocated 256 KiB pool for atomic allocations
      01-01 08:00:02.220     1     1 I audit   : initializing netlink subsys (disabled)
      01-01 08:00:00.020   173   173 W auditd  : type=2000 audit(0.0:1): state=initialized audit_enabled=0 res=1
      01-01 08:00:02.220     1     1 I cpuidle : using governor menu
      01-01 08:00:02.220     1     1 I hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
      01-01 08:00:02.243     1     1 I ccu     : sunxi ccu init OK
      01-01 08:00:02.243     1     1 I r_ccu   : sunxi ccu init OK
      01-01 08:00:02.243     1     1 D         : Sunxi ccu sun50iw9-r init OK
      01-01 08:00:02.243     1     1 I sun50iw9-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
      01-01 08:00:02.252     1     1 I cryptd  : max_cpu_qlen set to 1000
      01-01 08:00:02.263     1     1 I iommu   : Default domain type: Translated
      01-01 08:00:02.263     1     1 I sunxi iommu: irq = 39
      01-01 08:00:02.264     1     1 I         : SCSI subsystem initialized
      01-01 08:00:02.264     1     1 I usbcore : registered new interface driver usbfs
      01-01 08:00:02.264     1     1 I usbcore : registered new interface driver hub
      01-01 08:00:02.264     1     1 I usbcore : registered new device driver usb
      01-01 08:00:02.264     1     1 I videodev: Linux video capture interface: v2.00
      01-01 08:00:02.265     1     1 I         : Advanced Linux Sound Architecture Driver Initialized.
      01-01 08:00:02.265     1     1 I Bluetooth: Core ver 2.22
      01-01 08:00:02.265     1     1 I NET     : Registered protocol family 31
      01-01 08:00:02.265     1     1 I Bluetooth: HCI device and connection manager initialized
      01-01 08:00:02.265     1     1 I Bluetooth: HCI socket layer initialized
      01-01 08:00:02.265     1     1 I Bluetooth: L2CAP socket layer initialized
      01-01 08:00:02.265     1     1 I Bluetooth: SCO socket layer initialized
      01-01 08:00:02.265     1     1 I         : pwm module init!
      01-01 08:00:02.266     1     1 W sun50iw9-r-pinctrl 7022000.pinctrl: 7022000.pinctrl supply vcc-pl not found, using dummy regulator
      01-01 08:00:02.266     1     1 W sunxi-i2c5: sunxi-i2c5 supply twi not found, using dummy regulator
      01-01 08:00:02.267     1     1 I axp20x-i2c 5-0036: AXP20x variant AXP1530 found
      01-01 08:00:02.269     1     1 I axp1530-dcdc1: supplied by regulator-dummy
      01-01 08:00:02.269     1     1 I axp1530-dcdc2: supplied by regulator-dummy
      01-01 08:00:02.270     1     1 I axp1530-dcdc3: supplied by regulator-dummy
      01-01 08:00:02.271     1     1 I axp1530-aldo1: supplied by regulator-dummy
      01-01 08:00:02.271     1     1 I axp1530-dldo1: supplied by regulator-dummy
      01-01 08:00:02.272     1     1 I axp20x-i2c 5-0036: AXP20X driver loaded
      01-01 08:00:02.272     1     1 I sunxi-i2c5: probe success
      01-01 08:00:02.272     1     1 I clocksource: Switched to clocksource arch_sys_counter
      01-01 08:00:02.273     1     1 I VFS     : Disk quotas dquot_6.6.0
      01-01 08:00:02.273     1     1 I VFS     : Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      01-01 08:00:02.274     1     1 I thermal_sys: Registered thermal governor 'step_wise'
      01-01 08:00:02.274     1     1 I thermal_sys: Registered thermal governor 'power_allocator'
      01-01 08:00:02.274     1     1 I NET     : Registered protocol family 2
      01-01 08:00:02.275     1     1 I         : IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
      01-01 08:00:02.275     1     1 I         : tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
      01-01 08:00:02.275     1     1 I         : TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
      01-01 08:00:02.275     1     1 I         : TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
      01-01 08:00:02.276     1     1 I TCP     : Hash tables configured (established 16384 bind 16384)
      01-01 08:00:02.276     1     1 I         : UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
      01-01 08:00:02.276     1     1 I         : UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
      01-01 08:00:02.276     1     1 I NET     : Registered protocol family 1
      01-01 08:00:02.276     1     1 I RPC     : Registered named UNIX socket transport module.
      01-01 08:00:02.276     1     1 I RPC     : Registered udp transport module.
      01-01 08:00:02.276     1     1 I RPC     : Registered tcp transport module.
      01-01 08:00:02.276     1     1 I RPC     : Registered tcp NFSv4.1 backchannel transport module.
      01-01 08:00:02.277     1     1 I NET     : Registered protocol family 44
      01-01 08:00:02.277     1     1 I         : Trying to unpack rootfs image as initramfs...
      01-01 08:00:02.394     1     1 I         : Freeing initrd memory: 12456K
      01-01 08:00:02.398     1     1 I         : Initialise system trusted keyrings
      01-01 08:00:02.398     1     1 I workingset: timestamp_bits=62 max_order=19 bucket_order=0
      01-01 08:00:02.402     1     1 I         : Key type cifs.idmap registered
      01-01 08:00:02.402     1     1 I fuse    : init (API version 7.31)
      01-01 08:00:02.434     1     1 I NET     : Registered protocol family 38
      01-01 08:00:02.434     1     1 I         : Key type asymmetric registered
      01-01 08:00:02.434     1     1 I         : Asymmetric key parser 'x509' registered
      01-01 08:00:02.434     1     1 I         : Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      01-01 08:00:02.434     1     1 I         : io scheduler mq-deadline registered
      01-01 08:00:02.434     1     1 I         : io scheduler kyber registered
      01-01 08:00:02.434     1     1 I atomic64_test: passed
      01-01 08:00:02.436     1     1 E         : failed to get standby led pin assign
      01-01 08:00:02.441     1     1 E         : failed to get network led pin assign
      01-01 08:00:02.447     1     1 E         : failed to get gpio_sdcard_reused assign
      01-01 08:00:02.453     1     1 E         : get config err!
      01-01 08:00:02.457     1     1 I         : [DISP]disp_module_init
      01-01 08:00:02.457     1     1 I disp 1000000.disp: Adding to iommu group 0
      01-01 08:00:02.458     1     1 D display_fb_request,fb_id: 0
      01-01 08:00:02.466     1     1 I         : [DISP]disp_module_init finish
      01-01 08:00:02.466     1     1 I rtc_ccu : sunxi ccu init OK
      01-01 08:00:02.467     1     1 W         : sunxi_sid_init()737 - insmod ok
      01-01 08:00:02.467     1     1 I Serial  : 8250/16550 driver, 4 ports, IRQ sharing disabled
      01-01 08:00:02.469     1     1 I         : misc dump reg init
      01-01 08:00:02.469     1     1 I g2d 1480000.g2d: Adding to iommu group 0
      01-01 08:00:02.470     1     1 I G2D     : Module initialized.major:246
      01-01 08:00:02.470     1     1 I deinterlace 1420000.deinterlace: Adding to iommu group 0
      01-01 08:00:02.470     1     1 I deinterlace 1420000.deinterlace: version[1.0.0], ip=0x0
      01-01 08:00:02.470     1     1 I         : Gralloc Module initialized.
      01-01 08:00:02.470    13    13 W cacheinfo: Unable to detect cache hierarchy for CPU 0
      01-01 08:00:02.475     1     1 I brd     : module loaded
      01-01 08:00:02.478     1     1 I loop    : module loaded
      01-01 08:00:02.479     1     1 I zram    : Added device: zram0
      01-01 08:00:02.479     1     1 E         : [NAND][NE] Not found valid nand node on dts
      01-01 08:00:02.486     1     1 D [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      01-01 08:00:02.486     1     1 D [ADDR_MGT] addr_mgt_probe: success.
      01-01 08:00:02.487     1     1 I libphy  : Fixed MDIO Bus: probed
      01-01 08:00:02.487     1     1 I tun     : Universal TUN/TAP device driver, 1.6
      01-01 08:00:02.487     1     1 I         : PPP generic driver version 2.4.2
      01-01 08:00:02.487     1     1 I         : PPP BSD Compression module registered
      01-01 08:00:02.487     1     1 I         : PPP Deflate Compression module registered
      01-01 08:00:02.487     1     1 I         : PPP MPPE Compression module registered
      01-01 08:00:02.487     1     1 I NET     : Registered protocol family 24
      01-01 08:00:02.487     1     1 I         : PPTP driver version 0.8.5
      01-01 08:00:02.488     1     1 I ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      01-01 08:00:02.488     1     1 I ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver uas
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver usb-storage
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-alauda
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-cypress
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-datafab
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums_eneub6250
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-freecom
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-isd200
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-jumpshot
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-karma
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-onetouch
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-realtek
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-sddr09
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-sddr55
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver ums-usbat
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver xpad
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver usb_acecad
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver aiptek
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver gtco
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver hanwang
      01-01 08:00:02.488     1     1 I usbcore : registered new interface driver kbtab
      01-01 08:00:02.489     1     1 E axp2101_pek: axp2101-pek can not register without irq
      01-01 08:00:02.496     1     1 W axp2101-pek: probe of axp2101-pek.0 failed with error -22
      01-01 08:00:02.496     1     1 E sunxi-rtc 7000000.rtc: reset_control_get() failed
      01-01 08:00:02.503     1     1 W sunxi-rtc 7000000.rtc: Fail to get clock 'rtc-spi'
      01-01 08:00:02.503     1     1 I sunxi-rtc 7000000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      01-01 08:00:02.503     1     1 I sunxi-rtc 7000000.rtc: registered as rtc0
      01-01 08:00:02.503     1     1 I sunxi-rtc 7000000.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
      01-01 08:00:02.503     1     1 I sunxi-rtc 7000000.rtc: sunxi rtc probed
      01-01 08:00:02.504     1     1 I         : i2c /dev entries driver
      01-01 08:00:02.504     1     1 I         : IR NEC protocol handler initialized
      01-01 08:00:02.504     1     1 I         : IR RC5(x/sz) protocol handler initialized
      01-01 08:00:02.504     1     1 I uvcvideo: Unable to create debugfs directory
      01-01 08:00:02.504     1     1 I usbcore : registered new interface driver uvcvideo
      01-01 08:00:02.504     1     1 I         : USB Video Class driver (1.1.1)
      01-01 08:00:02.504     1     1 D         : sunxi cedar version 1.1
      01-01 08:00:02.504     1     1 I sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      01-01 08:00:02.504     1     1 D VE      : install start!!!
      01-01 08:00:02.504     1     1 I VE      : cedar-ve the get irq is 20
      01-01 08:00:02.504     1     1 D VE      : install end!!!
      01-01 08:00:02.505     1     1 I sunxi-cedar soc@3000000: ve1@1c0e000: Adding to iommu group 0
      01-01 08:00:02.505     1     1 I VE      : device ve1 just use to add iommu master
      01-01 08:00:02.505     1     1 I sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      01-01 08:00:02.505     1     1 I device-mapper: uevent: version 1.0.3
      01-01 08:00:02.506     1     1 I device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
      01-01 08:00:02.507     1     1 I hidraw  : raw HID events driver (C) Jiri Kosina
      01-01 08:00:02.509     1     1 I usbcore : registered new interface driver usbhid
      01-01 08:00:02.509     1     1 I usbhid  : USB HID core driver
      01-01 08:00:02.509     1     1 I ashmem  : initialized
      01-01 08:00:02.510     1     1 I optee   : probing for conduit method from DT.
      01-01 08:00:02.510     1     1 I optee   : revision 2.5
      01-01 08:00:02.510     1     1 I optee   : initialized driver
      01-01 08:00:02.510     1     1 D         : drm_base=0x40000000
      01-01 08:00:02.510     1     1 D         : drm_size=0x0
      01-01 08:00:02.510     1     1 D         : tee_base=0x2000000
      01-01 08:00:02.510     1     1 I usbcore : registered new interface driver snd-usb-audio
      01-01 08:00:02.511     1     1 I netem   : version 1.3
      01-01 08:00:02.511     1     1 I         : u32 classifier
      01-01 08:00:02.511     1     1 I         : input device check on
      01-01 08:00:02.511     1     1 I         : Actions configured
      01-01 08:00:02.511     1     1 I xt_time : kernel timezone is -0000
      01-01 08:00:02.511     1     1 I ipip    : IPv4 and MPLS over IPv4 tunneling driver
      01-01 08:00:02.512     1     1 I gre     : GRE over IPv4 demultiplexor driver
      01-01 08:00:02.512     1     1 I ip_gre  : GRE over IPv4 tunneling driver
      01-01 08:00:02.512     1     1 I         : IPv4 over IPsec tunneling driver
      01-01 08:00:02.513     1     1 I         : Initializing XFRM netlink socket
      01-01 08:00:02.513     1     1 I         : IPsec XFRM device driver
      01-01 08:00:02.513     1     1 I NET     : Registered protocol family 10
      01-01 08:00:02.514     1     1 I         : Segment Routing with IPv6
      01-01 08:00:02.514     1     1 I mip6    : Mobile IPv6
      01-01 08:00:02.515     1     1 I sit     : IPv6, IPv4 and MPLS over IPv4 tunneling driver
      01-01 08:00:02.515     1     1 I ip6_gre : GRE over IPv6 tunneling driver
      01-01 08:00:02.516     1     1 I NET     : Registered protocol family 17
      01-01 08:00:02.516     1     1 I NET     : Registered protocol family 15
      01-01 08:00:02.516     1     1 I Bluetooth: RFCOMM TTY layer initialized
      01-01 08:00:02.516     1     1 I Bluetooth: RFCOMM socket layer initialized
      01-01 08:00:02.516     1     1 I Bluetooth: RFCOMM ver 1.11
      01-01 08:00:02.516     1     1 I Bluetooth: HIDP (Human Interface Emulation) ver 1.2
      01-01 08:00:02.516     1     1 I Bluetooth: HIDP socket layer initialized
      01-01 08:00:02.516     1     1 I l2tp_core: L2TP core driver, V2.0
      01-01 08:00:02.516     1     1 I l2tp_ppp: PPPoL2TP kernel driver, V2.0
      01-01 08:00:02.516     1     1 I tipc    : Activated (version 2.0.0)
      01-01 08:00:02.516     1     1 I NET     : Registered protocol family 30
      01-01 08:00:02.516     1     1 I tipc    : Started in single node mode
      01-01 08:00:02.516     1     1 I         : registered taskstats version 1
      01-01 08:00:02.516     1     1 I         : Loading compiled-in X.509 certificates
      01-01 08:00:02.516     1     1 I         : Key type ._fscrypt registered
      01-01 08:00:02.516     1     1 I         : Key type .fscrypt registered
      01-01 08:00:02.516     1     1 I         : Key type fscrypt-provisioning registered
      01-01 08:0Gatekeeper_TA_CreateEntryPoint0:02.517     1     1 I         : HDMI 2.0 driver init start!
      01-01 08:00:02.517     1     1 I         : boot_hdmi=false
      01-01 08:00:02.518     1     1 I         : Can not find the node of esm
      01-01 08:00:02.518     1     1 E         : ERROR: pinctrl_get for HDMI2.0 DDC fail
      01-01 08:00:02.524     1     1 I Get hdmi_power0: aldo1
      01-01 08:00:02.524     1     1 W         : (NULL device *): deviceless supply aldo1 not found, using dummy regulator
      01-01 08:00:02.524     1     1 I Get hdmi_power1: dcdc1
      01-01 08:00:02.524     1     1 W         : (NULL device *): deviceless supply dcdc1 not found, using dummy regulator
      01-01 08:00:02.526     1     1 I         : hdmi_cec_init
      01-01 08:00:02.526     1     1 I         : HDMI2.0 module init end
      01-01 08:00:02.526     1     1 E         : tv_probe()1574 - of_property_read_string tv_power failed!
      01-01 08:00:02.534     1     1 D         : tv probe finished!
      01-01 08:00:03.160    17    17 I [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x4 cs:0x101 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
      01-01 08:00:03.840     0     0 I [    C0] random: fast init done
      01-01 08:00:04.185    17    17 W [DISP] de_rtmx_mgr_apply,line: 456:
      01-01 08:00:04.185    17    17 W         : ctx->output.hdr_type=0
      01-01 08:00:04.185    17    17 W [DISP] de_rtmx_mgr_apply,line: 474:
      01-01 08:00:04.209    17    17 W [DISP] disp_device_attached_and_enable,line: 235:
      01-01 08:00:04.209    17    17 W         : attached ok, mgr0<-->dev0
      01-01 08:00:04.209    17    17 W [DISP] disp_device_attached_and_enable,line: 248:
      01-01 08:00:04.209    17    17 W type    : 4,mode:10,fmt:rgb,bits:8bits,eotf:4,cs:257 dvi_hdmi:2, range:2 scan:0 ratio:8
      01-01 08:00:04.215    33    33 I sun50iw9-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
      01-01 08:00:04.216    33    33 W sun50iw9-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pc not found, using dummy regulator
      01-01 08:00:04.216    33    33 I sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-12-17 11:02)
      01-01 08:00:04.216    33    33 I sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
      01-01 08:00:04.216    33    33 E sunxi-mmc 4022000.sdmmc: sdmmc1111 device,check dts
      01-01 08:00:04.224    33    33 I sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
      01-01 08:00:04.224    33    33 I sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
      01-01 08:00:04.224    33    33 I sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
      01-01 08:00:04.224    33    33 I sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
      01-01 08:00:04.224    33    33 I sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
      01-01 08:00:04.224    33    33 W sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      01-01 08:00:04.225    33    33 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.238    33    33 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.250    33    33 I sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
      01-01 08:00:04.251    33    33 I sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-12-17 11:02)
      01-01 08:00:04.251    33    33 I sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      01-01 08:00:04.251    33    33 E sunxi-mmc 4020000.sdmmc: sdmmc1111 device,check dts
      01-01 08:00:04.258   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.260    33    33 I sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      01-01 08:00:04.260    33    33 I sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      01-01 08:00:04.261    33    33 I sunxi-mmc 4020000.sdmmc: Got CD GPIO
      01-01 08:00:04.261    33    33 I sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.261    33    33 I sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      01-01 08:00:04.261   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.262   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.274    33    33 I sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.285    33    33 I sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      01-01 08:00:04.285    33    33 I sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-12-17 11:02)
      01-01 08:00:04.285    33    33 I sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      01-01 08:00:04.285    33    33 E sunxi-mmc 4021000.sdmmc: sdmmc1111 device,check dts
      01-01 08:00:04.292   130   130 I sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.293    33    33 I sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      01-01 08:00:04.293    33    33 I sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      01-01 08:00:04.293    33    33 I sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      01-01 08:00:04.293    33    33 I sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      01-01 08:00:04.293    33    33 I sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      01-01 08:00:04.293    33    33 W sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      01-01 08:00:04.294    33    33 I sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.298   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.301   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.304    33    33 I sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.315    33    33 I sunxi-mmc 4021000.sdmmc: detmode:manually by software
      01-01 08:00:04.315    33    33 W sun50iw9-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-ph not found, using dummy regulator
      01-01 08:00:04.315    33    33 E uart0   : get regulator failed
      01-01 08:00:04.321    33    33 W uart0   : uart0 supply uart not found, using dummy regulator
      01-01 08:00:04.321    33    33 E uart0   : uart0 error to get fifo size property
      01-01 08:00:04.328    33    33 I uart0   : ttyAS0 at MMIO 0x5000000 (irq = 43, base_baud = 1500000) is a SUNXI
      01-01 08:00:04.328    33    33 W         : sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
      01-01 08:00:04.328    33    33 I printk  : console [ttyAS0] enabled
      01-01 08:00:04.328    33    33 I printk  : bootconsole [uart8250] disabled
      01-01 08:00:04.329    33    33 E uart1   : get regulator failed
      01-01 08:00:04.329     0     0 E         : [    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      01-01 08:00:04.334    33    33 W uart1   : uart1 supply uart not found, using dummy regulator
      01-01 08:00:04.342   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.342    33    33 I uart1   : ttyAS1 at MMIO 0x5000400 (irq = 44, base_baud = 1500000) is a SUNXI
      01-01 08:00:04.343     0     0 E         : [    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      01-01 08:00:04.343    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA0
      01-01 08:00:04.360   130   130 I sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.360    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA1
      01-01 08:00:04.370    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA2
      01-01 08:00:04.380    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA3
      01-01 08:00:04.390   130   130 I sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
      01-01 08:00:04.390    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA4
      01-01 08:00:04.400   127   127 E sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      01-01 08:00:04.410   127   127 E sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      01-01 08:00:04.421   130   130 W sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      01-01 08:00:04.421    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA5
      01-01 08:00:04.431   127   127 E sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      01-01 08:00:04.441    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA6
      01-01 08:00:04.451   127   127 E sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      01-01 08:00:04.462    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA7
      01-01 08:00:04.472    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA8
      01-01 08:00:04.482    33    33 E sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA9
      01-01 08:00:04.491   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 8 timing LEGACY(SDR12) dt B
      01-01 08:00:04.492    33    33 W sun50iw9-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pa not found, using dummy regulator
      01-01 08:00:04.492    33    33 I         : sunxi gmac driver's version: 1.0.0
      01-01 08:00:04.492    33    33 I gmac-power0: NULL
      01-01 08:00:04.492    33    33 I gmac-power1: NULL
      01-01 08:00:04.492    33    33 I gmac-power2: NULL
      01-01 08:00:04.493    33    33 E sunxi_ir_startup: get ir protocol failed
      01-01 08:00:04.494    33    33 I         : Registered IR keymap rc_map_sunxi
      01-01 08:00:04.500   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS200 dt B
      01-01 08:00:04.500    33    33 I rc0     : sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      01-01 08:00:04.500    33    33 I input   : sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      01-01 08:00:04.500   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 100000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS200 dt B
      01-01 08:00:04.501   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 100000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS(SDR20) dt B
      01-01 08:00:04.501   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 52000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS(SDR20) dt B
      01-01 08:00:04.502   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS400 dt B
      01-01 08:00:04.502   127   127 I sunxi-mmc 4022000.sdmmc: sdc set ios:clk 100000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS400 dt B
      01-01 08:00:04.502    33    33 E         : failed to get standby led pin assign
      01-01 08:00:04.508    33    33 E         : failed to get network led pin assign
      01-01 08:00:04.514    33    33 E         : failed to get gpio_sdcard_reused assign
      01-01 08:00:04.520    33    33 I         : gpio_pin_1(230) gpio_is_valid
      01-01 08:00:04.520   127   127 I mmc0    : new HS400 MMC card at address 0001
      01-01 08:00:04.521   127   127 I mmcblk0 : mmc0:0001 AQB11T 14.6 GiB
      01-01 08:00:04.521   127   127 I mmcblk0boot0: mmc0:0001 AQB11T partition 1 4.00 MiB
      01-01 08:00:04.522   127   127 I mmcblk0boot1: mmc0:0001 AQB11T partition 2 4.00 MiB
      01-01 08:00:04.522   127   127 I mmcblk0rpmb: mmc0:0001 AQB11T partition 3 4.00 MiB, chardev (244:0)
      01-01 08:00:04.523    33    33 I gpio    : 230, name: PH6, ret = 0
      01-01 08:00:04.523    33    33 I         : gpio-sunxi probe success
      01-01 08:00:04.525    33    33 W energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 1 >= em_cap_state0
      01-01 08:00:04.525    33    33 D energy_model: Created perf domain 0-3
      01-01 08:00:04.525   127   127 I mmcblk0 : p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25
      01-01 08:00:04.541     1     1 I sunxi-snd-mach soc@3000000: codec_mach: 5096000.codec <-> soc@3000000:codec_plat mapping ok
      01-01 08:00:04.541     1     1 I sunxi-snd-mach soc@3000000: ahub_dam_mach: snd-soc-dummy-dai <-> 5097000.ahub_dam_plat mapping ok
      01-01 08:00:04.542     1     1 I sunxi-snd-mach soc@3000000: ahub1_mach: snd-soc-dummy-dai <-> soc@3000000:ahub1_plat mapping ok
      01-01 08:00:04.543     1     1 I sunxi-snd-mach soc@3000000: ahub2_mach: snd-soc-dummy-dai <-> soc@3000000:ahub2_plat mapping ok
      01-01 08:00:04.544     1     1 I cfg80211: Loading compiled-in X.509 certificates for regulatory database
      01-01 08:00:04.545     1     1 I cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      01-01 08:00:04.545    34    34 W platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      01-01 08:00:04.545    34    34 W platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
      01-01 08:00:04.545     1     1 W clk     : Not disabling unused clocks
      01-01 08:00:04.545     1     1 E         : get_key_map_info()187 - Failed to find "oe" in dts.
      01-01 08:00:04.553     0     0 E         : [    C0] sunxi-i2c sunxi-i2c5: SLA+W has been transmitted; ACK not received
      01-01 08:00:04.562     1     1 E sunxi-i2c5: engine-mode: xfer failed(dev addr:0x10)
      01-01 08:00:04.570     1     1 I         : of_property_read_string ac200.tv_regulator_name fail
      01-01 08:00:04.570     1     1 E         : [ac200] get ave_regulator_name failed!
      01-01 08:00:04.576     1     1 E         : [ac200] pwm enable
      01-01 08:00:04.581     1     1 I         : ALSA device list:
      01-01 08:00:04.581     1     1 I         : #0: audiocodec
      01-01 08:00:04.581     1     1 I         : #1: ahubdam
      01-01 08:00:04.581     1     1 I         : #2: ahubhdmi
      01-01 08:00:04.581     1     1 I         : #3: ahubi2s2
      01-01 08:00:04.581     1     1 W alloc_fd: slot 0 not NULL!
      01-01 08:00:04.581     1     1 I         : Freeing unused kernel memory: 1024K
      01-01 08:00:04.596     1     1 E         : Kernel init done
      01-01 08:00:04.600     1     1 I         : Run /init as init process
      01-01 08:00:04.672     1     1 I init    : init first stage started!
      01-01 08:00:04.673     1     1 I init    : Unable to open /lib/modules, skipping module loading.
      01-01 08:00:04.673     1     1 I init    : Copied ramdisk prop to /second_stage_resources/system/etc/ramdisk/build.prop
      01-01 08:00:04.673     1     1 I init    : Switching root to '/first_stage_ramdisk'
      01-01 08:00:04.674     1     1 I init    : [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
      01-01 08:00:04.676     1     1 I init    : Using Android DT directory /proc/device-tree/firmware/android/
      01-01 08:00:04.693     1     1 I init    : [libfs_mgr]Invalid ext4 superblock on '/dev/block/by-name/metadata'
      01-01 08:00:04.694     1     1 E EXT4-fs (mmcblk0p19): VFS: Can't find ext4 filesystem
      01-01 08:00:04.702     1     1 I init    : [libfs_mgr]__mount(source=/dev/block/by-name/metadata,target=/metadata,type=ext4)=-1: Invalid argument
      01-01 08:00:04.703     1     1 I random  : init: uninitialized urandom read (16 bytes read)
      01-01 08:00:04.704     1     1 I init    : [libfs_mgr]Created logical partition system_a on device /dev/block/dm-0
      01-01 08:00:04.704     1     1 I init    : [libfs_mgr]Skipping zero-length logical partition: system_b
      01-01 08:00:04.704     1     1 I random  : init: uninitialized urandom read (16 bytes read)
      01-01 08:00:04.705     1     1 I random  : init: uninitialized urandom read (16 bytes read)
      01-01 08:00:04.711     1     1 I EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
      01-01 08:00:04.718     1     1 I EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
      01-01 08:00:04.721     1     1 I EXT4-fs (dm-3): mounted filesystem without journal. Opts: barrier=1
      01-01 08:00:04.724     1     1 I EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
      01-01 08:00:04.730     1     1 I newfs_msdos: executing /system/bin/newfs_msdos failed: No such file or directory
      01-01 08:00:04.731     1     1 I newfs_msdos: newfs_msdos terminated by exit(255)
      01-01 08:00:04.732     1     1 E FAT-fs (mmcblk0p23): bogus number of reserved sectors
      01-01 08:00:04.739     1     1 I FAT-fs (mmcblk0p23): Can't find a valid FAT filesystem
      01-01 08:00:04.770     1     1 W printk  : init: 21 output lines suppressed due to ratelimiting
      01-01 08:00:04.936     1     1 W init    : DM_DEV_STATUS failed for system_ext_a: No such device or address
      01-01 08:00:04.936     1     1 E init    : Could not update logical partition
      01-01 08:00:04.942     1     1 I init    : Opening SELinux policy
      01-01 08:00:04.952     1     1 I init    : Loading SELinux policy
      01-01 08:00:04.973     1     1 I SELinux : Permission nlmsg_getneigh in class netlink_route_socket not defined in policy.
      01-01 08:00:04.973     1     1 I SELinux : the above unknown classes and permissions will be denied
      01-01 08:00:04.973     1     1 I SELinux : policy capability network_peer_controls=1
      01-01 08:00:04.973     1     1 I SELinux : policy capability open_perms=1
      01-01 08:00:04.973     1     1 I SELinux : policy capability extended_socket_class=1
      01-01 08:00:04.973     1     1 I SELinux : policy capability always_check_network=0
      01-01 08:00:04.973     1     1 I SELinux : policy capability cgroup_seclabel=0
      01-01 08:00:04.973     1     1 I SELinux : policy capability nnp_nosuid_transition=1
      01-01 08:00:04.996   173   173 W auditd  : type=1403 audit(0.0:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
      01-01 08:00:05.008     1     1 I selinux : SELinux: Loaded file_contexts
      01-01 08:00:05.085     1     1 I init    : init second stage started!
      01-01 08:00:05.086     1     1 E FAT-fs (mmcblk0p23): bogus number of reserved sectors
      01-01 08:00:05.094     1     1 I FAT-fs (mmcblk0p23): Can't find a valid FAT filesystem
      01-01 08:00:05.094     1     1 E init    : mount media_data fail*****Invalid argument
      01-01 08:00:05.160     1     1 I init    : Using Android DT directory /proc/device-tree/firmware/android/
      01-01 08:00:05.167     1     1 W init    : Overriding previous property 'persist.sys.usb.config':'none' with new value 'adb'
      01-01 08:00:05.168     1     1 W init    : Overriding previous property 'persist.sys.usb.config':'adb' with new value 'none'
      01-01 08:00:05.168     1     1 W init    : Couldn't load property file '/vendor/default.prop': open() failed: No such file or directory: No such file or directory
      01-01 08:00:05.174     1     1 W init    : Couldn't load property file '/odm_dlkm/etc/build.prop': open() failed: No such file or directory: No such file or directory
      01-01 08:00:05.176     1     1 W init    : Couldn't load property file '/oem/build.prop': open() failed: No such file or directory: No such file or directory
      01-01 08:00:05.177     1     1 E init    : Could not set 'ro.boot.dynamic_partitions' to 'true' while loading .prop filesRead-only property was already set
      01-01 08:00:05.191     1     1 E init    : Could not set 'ro.boot.dynamic_partitions_retrofit' to 'true' while loading .prop filesRead-only property was already set
      01-01 08:00:05.328     1     1 E cgroup1 : Unknown subsys name 'blkio'
      01-01 08:00:05.337     1     1 E cgroup1 : Unknown subsys name 'memory'
      01-01 08:00:06.010   175   175 W SELinux : Multiple same specifications for softwinner\.multiir.
      01-01 08:00:05.548   161   161 I ueventd : ueventd started!
      01-01 08:00:06.011   177   177 I SELinux : SELinux: Loaded service_contexts from:
      01-01 08:00:06.011   177   177 I SELinux :     /vendor/etc/selinux/vndservice_contexts
      01-01 08:00:05.553   161   161 I selinux : SELinux: Loaded file_contexts
      01-01 08:00:05.553   161   161 I ueventd : Parsing file /system/etc/ueventd.rc...
      01-01 08:00:05.553   161   161 I ueventd : Added '/vendor/etc/ueventd.rc' to import list
      01-01 08:00:05.553   161   161 I ueventd : Added '/odm/etc/ueventd.rc' to import list
      01-01 08:00:05.554   161   161 I ueventd : Parsing file /vendor/etc/ueventd.rc...
      01-01 08:00:05.554   161   161 I ueventd : Unable to read config file '/vendor/etc/ueventd.rc': open() failed: No such file or directory
      01-01 08:00:05.554   161   161 I ueventd : Parsing file /odm/etc/ueventd.rc...
      01-01 08:00:05.554   161   161 I ueventd : Unable to read config file '/odm/etc/ueventd.rc': open() failed: No such file or directory
      01-01 08:00:05.797   158   158 I sunxi-rfkill soc@3000000: rfkill: module version: v1.0.9
      01-01 08:00:05.797   158   158 W sunxi-rfkill soc@3000000: rfkill: pinctrl_lookup_state(default) failed! return ffffffffffffffed
      01-01 08:00:05.797   158   158 E sunxi-rfkill soc@3000000: rfkill: get gpio chip_en failed
      01-01 08:00:05.805   158   158 E sunxi-rfkill soc@3000000: rfkill: get gpio power_en failed
      01-01 08:00:05.813   158   158 I sunxi-rfkill soc@3000000: rfkill: wlan_busnum (1)
      01-01 08:00:05.813   158   158 W sunxi-rfkill soc@3000000: rfkill: Missing wlan_power.
      01-01 08:00:05.813   158   158 I sunxi-rfkill soc@3000000: rfkill: wlan_regon gpio=210 assert=0
      01-01 08:00:05.813   158   158 I sunxi-rfkill soc@3000000: rfkill: wlan_hostwake gpio=207 assert=0
      01-01 08:00:05.813   158   158 I sunxi-rfkill soc@3000000: rfkill: wakeup source is enabled
      01-01 08:00:05.813   158   158 W sunxi-rfkill soc@3000000: rfkill: Missing bt_power.
      01-01 08:00:05.813   158   158 I sunxi-rfkill soc@3000000: rfkill: bt_rst gpio=211 assert=0
      01-01 08:00:05.892   124   124 I         : hdmi_hpd_sys_config_release
      01-01 08:00:05.933     1     1 I         : Registered swp emulation handler
      01-01 08:00:05.977   173   173 I logd.auditd: start
      01-01 08:00:06.013   175   175 I SELinux : SELinux: Loaded service_contexts from:
      01-01 08:00:06.013   175   175 I SELinux :     /system/etc/selinux/plat_service_contexts
      01-01 08:00:06.013   175   175 I SELinux :     /system_ext/etc/selinux/system_ext_service_contexts
      01-01 08:00:06.013   175   175 I SELinux :     /vendor/etc/selinux/vendor_service_contexts
      01-01 08:00:06.017   176   176 I hwservicemanager: getFrameworkHalManifest: Reading VINTF information.
      01-01 08:00:06.028   176   176 I hwservicemanager: getDeviceHalManifest: Reading VINTF information.
      01-01 08:00:06.032   185   185 I format_device: Start format /dev/block/by-name/Reserve0
      01-01 08:00:06.033   189   189 I format_device: fork to format /dev/block/by-name/Reserve0
      01-01 08:00:06.046     1     1 I make_f2fs:
      01-01 08:00:06.046     1     1 I make_f2fs: F2FS-tools: mkfs.f2fs Ver: 1.14.0 (2020-08-24)
      01-01 08:00:06.046     1     1 I make_f2fs: Info: Disable heap-based policy
      01-01 08:00:06.046     1     1 I make_f2fs: Info: Debug level = 1
      01-01 08:00:06.046     1     1 I make_f2fs: Info: Trim is enabled
      01-01 08:00:06.046     1     1 I make_f2fs: Info: Set conf for android
      01-01 08:00:06.046     1     1 I make_f2fs: Info: Enable utf8 with casefolding
      01-01 08:00:06.046     1     1 I make_f2fs: Info: Enable Project quota
      01-01 08:00:06.048     1     1 I make_f2fs: Info: No support kernel version!
      01-01 08:00:06.049   176   176 I hwservicemanager: getDeviceHalManifest: Successfully processed VINTF information
      01-01 08:00:06.049   176   176 I hwservicemanager: getFrameworkHalManifest: Successfully processed VINTF information
      01-01 08:00:06.051   176   176 I hwservicemanager: hwservicemanager is ready now.
      01-01 08:00:06.056   185   185 I format_device: format /dev/block/by-name/Reserve0 ok
      dts配置如下:
      &sdc1 {
              pinctrl-0 = <&sdc1_pins_a>;
              bus-width = <4>;
              no-mmc;
              no-sd;
              cap-sd-highspeed;
              /*sd-uhs-sdr12;
              sd-uhs-sdr25;*/
              sd-uhs-sdr50;
              sd-uhs-ddr50;
              sd-uhs-sdr104;
              /*sunxi-power-save-mode;*/
              sunxi-dis-signal-vol-sw;
              mmc-ddr-1_8v;
              cap-sdio-irq;
              keep-power-in-suspend;
              ignore-pm-notify;
              ctl-spec-caps = <0x8>;
              max-frequency = <50000000>;
              /*vmmc-supply = <&reg_dldo1>;
              vqmmc-supply = <&reg_aldo1>;*/
      G 1 条回复 最后回复 回复 引用 分享 0
      • G
        gwx123 LV 3 @gwx123 最后由 编辑
        用的wifi 模组是8822cs,sdio注册probe都没有跑,这有大佬知道吗
