    飞凌T113-i核心板+自制底板 mcp2515驱动失败
    • T
      TS_123456789 LV 2 最后由 编辑
      查了一下午了,实在是没有头绪了
      飞凌T113-i的核心板+自制底板
      有没有懂的看一下
      内核启动打印
      [    0.524093] spi spi1: spi1 supply spi not found, using dummy regulator
      [    0.531182] sunxi_spi_resource_get()2160 - [spi1] SPI MASTER MODE
      [    0.537660] sunxi_spi_resource_get()2198 - Failed to get sample mode
      [    0.544326] sunxi_spi_resource_get()2203 - Failed to get sample delay
      [    0.551092] sunxi_spi_resource_get()2207 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.559920] sunxi_spi_clk_init()2249 - [spi1] mclk 100000000
      [    0.566634] sunxi_spi_probe()2663 - [spi1]: driver probe succeed, base e0821000, irq 43
      [    0.577014] Initialise system trusted keyrings
      [    0.581918] workingset: timestamp_bits=30 max_order=17 bucket_order=0
      [    0.599369] fuse: init (API version 7.31)
      [    0.633464] NET: Registered protocol family 38
      [    0.638150] Key type asymmetric registered
      [    0.642442] Asymmetric key parser 'x509' registered
      [    0.647666] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
      [    0.655419] io scheduler mq-deadline registered
      [    0.660180] io scheduler kyber registered
      [    0.664509] atomic64_test: passed
      [    0.669863] [DISP]disp_module_init
      [    0.674022] disp 5000000.disp: Adding to iommu group 0
      [    0.680050] [DISP] disp_init,line:2386:
      [    0.680056] smooth display screen:0 type:2 mode:11
      [    0.689474] [DISP] disp_init_hdmi,line:1047:
      [    0.689479] dont support hdmi
      [    0.697384] display_fb_request,fb_id:0
      [    0.706463] [DISP] bsp_disp_sync_with_hw,line:658:
      [    0.706469] Can't find device(2) for manager 0
      [    0.708299] [DISP]disp_module_init finish
      [    0.721861] sunxi_sid_init()563 - insmod ok
      [    0.726684] pwm-regulator: supplied by regulator-dummy
      [    0.733518] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
      [    0.742145] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [    0.750688] uart uart0: get regulator failed
      [    0.755178] uart uart0: uart0 supply uart not found, using dummy regulator
      [    0.762722] uart0: ttyAS0 at MMIO 0x2500000 (irq = 33, base_baud = 1500000) is a SUNXI
      [    0.771067] sw_console_setup()1793 - console setup baud 115200 parity n bits 8, flow n
      [    0.779432] printk: console [ttyAS0] enabled
      [    0.788694] printk: bootconsole [uart8250] disabled
      [    0.800112] uart uart1: get regulator failed
      [    0.804894] uart uart1: uart1 supply uart not found, using dummy regulator
      [    0.812948] uart1: ttyAS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.822630] uart uart3: get regulator failed
      [    0.827412] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.835475] uart3: ttyAS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
      [    0.845129] uart uart4: get regulator failed
      [    0.849953] uart uart4: uart4 supply uart not found, using dummy regulator
      [    0.857994] uart4: ttyAS4 at MMIO 0x2501000 (irq = 36, base_baud = 1500000) is a SUNXI
      [    0.868022] misc dump reg init
      [    0.873158] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
      [    0.880403] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
      [    0.888201] [ADDR_MGT] addr_mgt_probe: success.
      [    0.894877] libphy: Fixed MDIO Bus: probed
      [    0.899963] CAN device driver interface
      [    0.904383] mcp251x: probe of spi1.0 failed with error -34
      设备树部分
      /dts-v1/;
      /*/memreserve/ 0x41900000 0x00100000;*/
      /* DSP used 1MB */
      /* /memreserve/ 0x42000000 0x00100000; */
      #include "sun8iw20p1.dtsi"
      	model = "sun8iw20";
      	reg_vdd_cpu: vdd-cpu {
      		pwms = <&pwm 7 5000 1>;
      		regulator-name = "vdd_cpu";
      		regulator-settling-time-us = <4000>;
      		regulator-always-on;
      		regulator-boot-on;
      	can0: can@0x0 {
      		#address-cells = <1>;
      		#size-cells = <0>;
      		pinctrl-0 = <&can0_pins_a>;
      		pinctrl-names = "default";
      		compatible = "allwinner,sun8i-can";
      		device_type = "can0";
      		id = <0>;
      	can1: can@0x1 {
      		#size-cells = <0>;
      		pinctrl-0 = <&can1_pins_a>;
      		device_type = "can1";
      		id = <1>;
      	leds {
      		compatible = "gpio-leds";
      		led@0 {
      			label = "heartbeat";
      			gpios = <&pio PG 16 GPIO_ACTIVE_HIGH>;
      			linux,default-trigger = "heartbeat";
      	wifi-en {
      		regulator-name = "wifi123-en";
      		gpio = <&pio PG 10 GPIO_ACTIVE_LOW>;
      		regulator-boot-on;
      	speaker_en: speaker-en {
      		regulator-name = "s123peaker-en";
      		gpio = <&pio PB 8 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      		// regulator-always-on;
      		// regulator-boot-on;
      &cpu0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		allwinner,pull = <1>;
      		function = "sdc0";
      		drive-strength = <40>;
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      		function = "gpio_in";
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		drive-strength = <10>;
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		drive-strength = <30>;
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      			function = "sdc1";
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	lvds0_pins_a: lvds0@0 {
      		allwinner,pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,function = "lvds0";
      		allwinner,pull = <0>;
      	lvds0_pins_b: lvds0@1 {
      		allwinner,muxsel = <7>;
      	uart0_pins_a: uart0_pins@0 {
      		pins = "PG17", "PG18";
      		function = "uart0";
      		bias-pull-up;
      	uart0_pins_b: uart0_pins@1 {
      	uart1_pins_a: uart1_pins@0 {
      		pins = "PG6", "PG7";
      		function = "uart1";
      		bias-pull-up;
      	uart1_pins_b: uart1_pins {
      	uart3_pins_a: uart3_pins@0 {
      		pins = "PG8", "PG9";
      		function = "uart3";
      		bias-pull-up;
      	uart3_pins_b: uart3_pins@1 {
      	uart4_pins_a: uart4_pins@0 {
      		pins = "PG2", "PG3";
      		function = "uart4";
      		bias-pull-up;
      	uart4_pins_b: uart4_pins@1 {
      	twi2_pins_a: twi2@0 {
      		pins = "PC0", "PC1";
      		function = "twi2";
      	twi2_pins_b: twi2@1 {
      	tp_pins_a: i_tp@0 {
      		allwinner,pins = "PB6";
      		allwinner,pname = "PB6";
      		allwinner,function = "gpio_in";
      		allwinner,muxsel = <0>;
      	tp_pins_b: i_tp@1 {
      		pins = "PB6";
      	twi3_pins_a: twi3@0 {
      		pins = "PE16", "PE17";
      		/* pins = "PG10", "PG11"; */
      		/* pins = "PB6", "PB7"; */
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      	can0_pins_a: can0@0 {
      		allwinner,pins = "PB2", "PB3";
      		allwinner,function = "can0";
      		allwinner,muxsel = <8>;
      	can1_pins_a: can1@0 {
      		allwinner,pins = "PB4", "PB5";
      		allwinner,function = "can1";
      	s_cir0_pins_a: s_cir0@0 {
      		pins = "PB1";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir0@1 {
      		pins = "PB1";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      	dmic_pins_a: dmic@0 {
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		pins = "PB29", "PB23", "PB24",
      		       "PB25", "PB26", "PB27", "PB28",
      		       "PB22";
      		function = "i2s0";
      		bias-disable;
      		       "PB22";
      		bias-disable;
      	daudio1_pins_a: daudio1@0 {
      		/* MCLK, LRCK, BCLK */
      		pins = "PG11", "PG12", "PG13";
      		function = "i2s1";
      		bias-disable;
      	daudio1_pins_b: daudio1@1 {
      		/* DIN0 */
      		pins = "PG14";
      		function = "i2s1_din";
      		bias-disable;
      	daudio1_pins_c: daudio1@2 {
      		/* DOUT0 */
      		pins = "PG15";
      		function = "i2s1_dout";
      		bias-disable;
      	daudio1_pins_d: daudio1_sleep@0 {
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		pins = "PB7", "PB6", "PB5";
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2@1 {
      		/* I2S_PIN: DIN0 */
      		pins = "PB3";
      		function = "i2s2_din";
      		bias-disable;
      	daudio2_pins_c: daudio2@2 {
      		/* I2S_PIN: DOUT0 */
      		pins = "PB4";
      		function = "i2s2_dout";
      		bias-disable;
      		pins = "PB7", "PB6", "PB5", "PB4", "PB3";
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PG18";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PG18";
      		bias-disable;
      	gmac0_pins_a: gmac@0 {
      		allwinner,pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8",
      				 "PE9", "PE10", "PE11", "PE12", "PE13", "PE14", "PE15";
      		allwinner,function = "gmac0";
      	gmac0_pins_b: gmac@1 {
      		allwinner,drive = <1>;
      	spi0_pins_a: spi0@0 {
      		pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
      		function = "spi0";
      	spi0_pins_b: spi0@1 {
      		pins = "PC3";
      		function = "spi0";
      		bias-pull-up;   /* only CS should be pulled up */
      	spi0_pins_c: spi0@2 {
      	spi1_pins_a: spi1@0 {
      		pins = "PB11", "PB10", "PB9"; /*clk mosi miso hold wp*/
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		pins = "PB12";
      		function = "spi1";
      		bias-pull-up;   // only CS should be pulled up
      	spi1_pins_c: spi1@2 {
      		allwinner,pins = "PB9", "PB10","PB11", "PB12";
      	pwm3_pin_a: pwm3@0 {
      		pins = "PB0";
      		function = "pwm3";
      		bias-pull-up;
      	pwm3_pin_b: pwm3@1 {
      		pins = "PB0";
      	pwm7_pin_a: pwm7@0 {
      		pins = "PD22";
      		function = "pwm7";
      		bias-pull-up;
      	pwm7_pin_b: pwm7@1 {
      		pins = "PD22";
      	ledc_pins_a: ledc@0 {
      		pins = "PF2";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PF2";
      	rgb24_pins_a: rgb24@0 {
      		allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      			"PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      			"PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      		allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      		allwinner,function = "lcd0";
      	rgb24_pins_b: rgb24@1 {
      	dsi4lane_pins_a: dsi4lane@0 {
              allwinner,function = "dsi4lane";
              allwinner,muxsel = <4>;
      	dsi4lane_pins_b: dsi4lane@1 {
              allwinner,function = "dsi4lane_suspend";
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_b>;
      &uart4 {
      	pinctrl-0 = <&uart4_pins_a>;
      	pinctrl-1 = <&uart4_pins_b>;
      &sdc0 {
      	bus-width = <4>;
      	/*non-removable;*/
      	broken-cd;
      	/*cd-inverted*/
      	/*data3-detect;*/
      	/*cd-used-24M;*/
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	sunxi-power-save-mode;
      	/*sunxi-dis-signal-vol-sw;*/
      	max-frequency = <150000000>;
      	ctl-spec-caps = <0x8>;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	/*sunxi-power-save-mode;*/
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      	status = "disabled";
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-ddr-3_3v;
      	//mmc-ddr-1_8v;
      	//mmc-hs200-1_8v;
      	no-sdio;
      	no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	mmc-bootpart-noacc;
      	max-frequency = <200000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &twi2 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi2_pins_a>;
      	pinctrl-1 = <&twi2_pins_b>;
      	twi_drv_used = <1>;
      	dmas = <&dma 45>, <&dma 45>;
      	dma-names = "tx", "rx";
      &twi3 {
      	pinctrl-0 = <&twi3_pins_a>;
      	pinctrl-1 = <&twi3_pins_b>;
      	pcf8563:rtc@51 {
      		compatible = "nxp,pcf8563";
      		reg = <0x51>;
      	rx8010:rx8010@32 {
                  compatible = "epson,rx8010";
                  reg = <0x32>;
      	gt928: gt928@14 {
              compatible = "goodix,gt928";
              reg = <0x14>;
      		pinctrl-0 = <&tp_pins_a>;
      		pinctrl-1 = <&tp_pins_b>;
              irq-gpio = <&pio PB 6  GPIO_ACTIVE_LOW>;
              reset-gpio = <&pio PB 7  GPIO_ACTIVE_HIGH>;
              touchscreen-size-x = <1280>;
              touchscreen-size-y = <800>;
              touchscreen-swapped-x-y;
          gt911: gt911@14 {
              compatible = "goodix,gt911";
              reg = <0x14>;
              touchscreen-size-x = <1024>;
              touchscreen-size-y = <600>;
      		touchscreen-inverted-x;
      		touchscreen-inverted-y;
          ft5x06: ft5x06@38 {
              compatible = "edt,edt-ft5406", "edt,edt-ft5306";
              reg = <0x38>;
              int-gpio = <&pio PB 6  GPIO_ACTIVE_LOW>;
      &spi1 {
      	clock-frequency = <500000>;
      	pinctrl-1 = <&spi1_pins_c>;
      	spi_slave_mode = <0>;
      	spi1_cs_number = <1>;
          spi1_cs_bitmap = <1>;
      	mcp2515:mcp_2515@0{
      	    compatible = "microchip,mcp2515";
              reg = <0>;
              spi-max-frequency = <1000000>;
              interrupt-parent = <&pio>;
              interrupts = <PG  12  IRQ_TYPE_EDGE_FALLING>;//中断脚我底板接到PG12
              spi-rx-bus-width = <0x1>;
              clocks = <&clk_osc8m>;
              spi-tx-bus-width = <0x1>;
      &spi0 {
          pinctrl-1 = <&spi0_pins_c>;
          spi0_cs_number = <1>;
              spi0_cs_bitmap = <1>;
      	spinand:spi-nand@0 {
              compatible = "spi-nand";
              spi-max-frequency=<80000000>;
              reg = <0x0>;
              spi-rx-bus-width=<0x04>;
              spi-tx-bus-width=<0x04>;
              status="disabled";
      	spinor:spi_board@0 {
              device_type = "spi_board0";
              compatible = "spi-nor";
              spi-max-frequency = <80000000>;
              m25p,fast-read = <1>;
              reg = <0x0>;
              spi-rx-bus-width = <0x4>;
              spi-tx-bus-width = <0x4>;
      &ledc {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <32>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <450>;
      	t0h_ns = <400>;
      	t0l_ns = <850>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      &s_cir0 {
      	pinctrl-0 = <&s_cir0_pins_a>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      &gmac0 {
      	pinctrl-0 = <&gmac0_pins_a>;
      	pinctrl-1 = <&gmac0_pins_b>;
      	phy-mode = "rgmii";
      	use_ephy25m = <0>;
      	tx-delay = <2>;
      	rx-delay = <0>;
      	phy-tx-delay = <0>;
      	phy-rx-delay = <0>;
      	phy-rst = <&pio PG 13 GPIO_ACTIVE_HIGH>;
      &soc {
      	platform@45000004 {
      		reg = <0x0 0x45000004 0x0 0x0>;
      		eraseflag   = <1>;
      		next_work   = <3>;
      		debug_mode  = <8>;
      	target@45000008 {
      		reg = <0x0 0x45000008 0x0 0x0>;
      		boot_clock = <1008>;	/*CPU boot frequency, Unit: MHz*/
      		storage_type = <0xffffffff>; /*boot medium, 0-nand, 1-card0, 2-card2, -1(defualt)auto scan*/
      		burn_key = <0>;		/*1:support burn key; 0:not support burn key*/
      		dragonboard_test = <0>;	/*1:support card boot dragonboard; 0:not support card boot dragonboard*/
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_a>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc2_pins_a>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		//sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		//sdc_tm4_hs200_max_freq = <200>;
      		//sdc_tm4_hs400_max_freq = <100>;
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      	 	chip_en;
      	 	power_en;
      	 	wlan: wlan@0 {
      	 		clock-names = "32k-fanout1";
      	 		wlan_busnum    = <0x1>;
      	 		//wlan_regon    = <&pio PD 15 GPIO_ACTIVE_HIGH>;
      	 		//wlan_hostwake  = <&pio PG 10 GPIO_ACTIVE_HIGH>;
      	 		/*interrupt-parent = <&pio>;
      	 		//wakeup-source;
      	 	bt: bt@0 {
      	 		/*bt_power_num = <0x01>;*/
      	 		/*bt_io_vol = <3300000>;*/
      	 		/*bt_power_vol = <330000>;*/
      	 		//bt_rst_n      = <&pio PD 14 GPIO_ACTIVE_LOW>;
      	 btlpm: btlpm@0 {
      	 	uart_index  = <0x1>;
      	 	bt_wake     = <&pio PD 13 GPIO_ACTIVE_HIGH>;
      	 	bt_hostwake = <&pio PD 12 GPIO_ACTIVE_HIGH>;
      	ddr_mgt:addr_mgt {
      		type_addr_wifi = <0x0>;
      		type_addr_eth  = <0x0>;
      		status         = "okay";
          find_disp_phandle  {
              pinctrl-0 = <&lvds0_pins_a>, <&rgb24_pins_a>, <&dsi4lane_pins_a>;
              pinctrl-1 = <&lvds0_pins_b>, <&rgb24_pins_b>, <&dsi4lane_pins_b>;
      &vind0 {
      	csi_top = <378000000>;
      	csi_isp = <327000000>;
      	status = "disabled"; /* enable twi and ver1 spi-nand max freq 30M */
      	actuator0: actuator@5809450 {
      		device_type = "actuator0";
      		actuator0_slave = <0x18>;
      		actuator0_af_pwdn = <>;
      	flash0: flash@5809460 {
      		device_type = "flash0";
      		flash0_type = <2>;
      		flash0_en = <>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		flash0_flvdd_vol = <>;
      		device_id = <0>;
      	sensor0:sensor@5809470 {
      		device_type = "sensor0";
      		sensor0_mname = "n5";
      		sensor0_twi_cci_id = <1>;
      		sensor0_twi_addr = <0x64>;
      		sensor0_mclk_id = <0>;
      		sensor0_pos = "rear";
      		sensor0_isp_used = <0>;
      		sensor0_fmt = <0>;
      		sensor0_stby_mode = <0>;
      		sensor0_vflip = <0>;
      		sensor0_hflip = <0>;
      		sensor0_iovdd-supply = <>;
      		sensor0_iovdd_vol = <3300000>;
      		sensor0_avdd-supply = <>;
      		sensor0_avdd_vol = <1200000>;
      		sensor0_dvdd-supply = <>;
      		sensor0_dvdd_vol = <1200000>;
      		sensor0_power_en = <>;
      		sensor0_reset = <>;
      		sensor0_pwdn = <>;
      	sensor1:sensor@5809480 {
      		device_type = "sensor1";
      		sensor1_mname = "ov5647";
      		sensor1_twi_cci_id = <3>;
      		sensor1_twi_addr = <0x6c>;
      		sensor1_mclk_id = <1>;
      		sensor1_pos = "front";
      		sensor1_isp_used = <0>;
      		sensor1_fmt = <0>;
      		sensor1_stby_mode = <0>;
      		sensor1_vflip = <0>;
      		sensor1_hflip = <0>;
      		sensor1_iovdd-supply = <>;
      		sensor1_iovdd_vol = <>;
      		sensor1_avdd-supply = <>;
      		sensor1_avdd_vol = <>;
      		sensor1_dvdd-supply = <>;
      		sensor1_dvdd_vol = <>;
      		sensor1_power_en = <>;
      		sensor1_reset = <>;
      		sensor1_pwdn = <>;
      	vinc0:vinc@5809000 {
      		vinc0_csi_sel = <0>;
      		vinc0_mipi_sel = <0xff>;
      		vinc0_isp_sel = <0>;
      		vinc0_isp_tx_ch = <0>;
      		vinc0_tdm_rx_sel = <0xff>;
      		vinc0_rear_sensor_sel = <0>;
      		vinc0_front_sensor_sel = <0>;
      		vinc0_sensor_list = <0>;
      	vinc1:vinc@5809200 {
      		vinc1_csi_sel = <0>;
      		vinc1_mipi_sel = <0xff>;
      		vinc1_isp_sel = <0>;
      		vinc1_isp_tx_ch = <1>;
      		vinc1_tdm_rx_sel = <0xff>;
      		vinc1_rear_sensor_sel = <0>;
      		vinc1_front_sensor_sel = <0>;
      		vinc1_sensor_list = <0>;
      &csi0 {
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      &disp {
      	fb0_width                = <1024>;
      	fb0_height               = <600>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;tv configuration
      ;interface          (interface type,1<->cvbs,2<->YPBPR,4<->SVIDEO)
      ;dac_type           (0<->composite,1<->luma,2<->chroma,3<->reserved,4<->y/green,
      ;                    5<->u/pb/blue,6<->v/pr/red)
      ;dac_src            (dac no,support dac_src0~dac_src3,dac num max is 4)
      ;NOTE:              tv0,tv1 can not use the same dac_src.
      &tv0 {
      	interface       = <1>;
      	dac_type0       = <0>;
      	dac_src0        = <0>;
      	status =  "okay";
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_backlight       = <50>;
      	lcd_if              = <3>;
      	lcd_x               = <1024>;
      	lcd_y               = <600>;
      	lcd_width           = <150>;
      	lcd_height          = <94>;
      	lcd_dclk_freq       = <52>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <3>;
      	lcd_pwm_pol         = <1>;
      	lcd_pwm_max_limit   = <255>;
      	lcd_hbp             = <160>;
      	lcd_ht              = <1344>;
      	lcd_hspw            = <60>;
      	lcd_vbp             = <23>;
      	lcd_vt              = <638>;
      	lcd_vspw            = <10>;
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <0>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <1>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	lcd_bl_en = <&pio PB 1 1 0xffffffff 0xffffffff 0x1>;
      	pinctrl-0 = <&lvds0_pins_a>;
      	pinctrl-1 = <&lvds0_pins_b>;
      tvd configuration
                             mode,mean enable)
      &tvd {
      	tvd_sw          = <1>;
      	tvd_interface   = <0>;
      	tvd_format      = <0>;
      	tvd_system      = <1>;
      	tvd_row         = <1>;
      	tvd_column      = <1>;
      	tvd_channel0_en = <1>;
      	tvd_channel1_en = <0>;
      	tvd_channel2_en = <0>;
      	tvd_channel3_en = <0>;
      	/*tvd_power0      = "dc1sw"*/
      	/*tvd_power1      = "eldo3"*/
      &tvd0 {
      &hdmi {
      	hdmi_used = <0>;
      	hdmi_power_cnt = <0>;
      	hdmi_hdcp_enable = <1>;
      	hdmi_hdcp22_enable = <0>;
      	hdmi_cec_support = <1>;
      	hdmi_cec_super_standby = <0>;
      	ddc_en_io_ctrl = <0>;
      	power_io_ctrl = <0>;
      /* Audio Driver modules */
      &codec {
      	mic1gain 		= <0x1F>;
      	mic2gain 		= <0x1F>;
      	mic3gain 		= <0x1F>;
      	adcdrc_cfg		= <0x0>;
      	adchpf_cfg		= <0x1>;
      	dacdrc_cfg		= <0x0>;
      	dachpf_cfg		= <0x0>;
      	/* Volume about */
      	digital_vol 	= <0x00>;
      	lineout_vol 	= <0x1a>;
      	headphonegain	= <0x03>;
      	/* Pa enabled about */
      	pa_level 		= <0x01>;
      	pa_pwr_level 	= <0x01>;
      	pa_msleep_time 	= <0x78>;
      	/* gpio-spk	= <&pio PE 11 GPIO_ACTIVE_LOW>; */
      	/* CMA config about */
      	playback_cma	= <128>;
      	capture_cma	= <256>;
      	/* regulator about */
      &sndcodec {
      	hp_detect_case	= <0x01>;
      	jack_enable		= <0x01>;
      	speaker-supply = <&speaker_en>;
      &dummy_cpudai {
      	status			= "okay";
      &dmic {
      &dmic_codec {
      &sounddmic {
       * tdm_config		0 --> pcm
       *			1 --> i2s
       * mclk_div		0 --> not output
       *			1 --> HDMI audio type
      &daudio0 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tdm_config 	= <0x01>;
      	sign_extend 	= <0x00>;
      	msb_lsb_first 	= <0x00>;
      	pcm_lrck_period = <0x80>;
      	slot_width_select = <0x20>;
      	pinctrl_used	= <0x0>;
      &sounddaudio0 {
      		/* sound-dai = <&ac108>; */
      &daudio1 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	pinctrl-0       = <&daudio1_pins_a &daudio1_pins_b &daudio1_pins_c>;
      	pinctrl-1       = <&daudio1_pins_d>;
      	pinctrl_used	= <0x1>;
      &sounddaudio1 {
      &daudio2 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      &hdmiaudio {
      &sounddaudio2 {
      &spdif {
      &soundspdif {
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x2>;
      	usb_detect_type = <0x1>;
      	usb_detect_mode = <0x0>;
      	usb_id_gpio = <&pio PG 1 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	usb_det_vbus_gpio = <&pio PG 4 GPIO_ACTIVE_HIGH>;
      	usb_drv_vbus_gpio = <&pio PG 5 GPIO_ACTIVE_LOW>;
      	usb_wakeup_suspend = <0>;
      	usb_serial_unique = <0>;
      	rndis_wceis = <1>;
      &ehci0 {
      	//drvvbus-supply = <&reg_usb1_vbus>;
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
      	usb_regulator_io = "nocare";
      &ehci1 {
      &ohci1 {
      &pwm3 {
      	pinctrl-0 = <&pwm3_pin_a>;
      	pinctrl-1 = <&pwm3_pin_b>;
      &pwm7 {
      	pinctrl-0 = <&pwm7_pin_a>;
      	pinctrl-1 = <&pwm7_pin_b>;
      &gpadc {
      	channel_num = <2>;
      	channel_select = <0x3>;
      	channel_data_select = <0x3>;
      &rtp {
      	allwinner,ts-attached;
      &cpu_thermal_zone {
      	cpu_trips: trips {
      		cpu_crit: cpu_crit@0 {
      			temperature = <115000>;
      			type = "critical";
      			hysteresis = <0>;
      &rtc {
      	status = "disabled"; /* Disable cpu rtc */
      时钟部分
       * Allwinner Technology CO., Ltd. sun8iw20p1 platform
       * modify base on juno.dts
      /memreserve/ 0x41b00000 0x00100000;
      #include <dt-bindings/clock/sun8iw20-ccu.h>
      #include <dt-bindings/clock/sun8iw20-r-ccu.h>
      #include <dt-bindings/clock/sun8iw20-rtc.h>
      #include <dt-bindings/reset/sun8iw20-ccu.h>
      #include <dt-bindings/reset/sun8iw20-r-ccu.h>
      #include <dt-bindings/interrupt-controller/arm-gic.h>
      #include <dt-bindings/gpio/gpio.h>
      #include <dt-bindings/gpio/sun4i-gpio.h>
      #include <dt-bindings/thermal/thermal.h>
      #include <dt-bindings/power/r528-power.h>
      	model = "sun8iw20";
      	compatible = "allwinner,sun8iw20p1";
      	interrupt-parent = <&gic>;
      	#address-cells = <2>;
      	#size-cells = <2>;
      	aliases {
      		serial0 = &uart0;
      		serial1 = &uart1;
      		serial2 = &uart2;
      		serial3 = &uart3;
      		serial4 = &uart4;
      		serial5 = &uart5;
      		spi0 = &spi0;
      		spi1 = &spi1;
      		twi0 = &twi0;
      		twi1 = &twi1;
      		twi2 = &twi2;
      		twi3 = &twi3;
      		mmc0 = &sdc0;
      		mmc2 = &sdc2;
      		pwm = &pwm;
      		pwm0 = &pwm0;
      		pwm1 = &pwm1;
      		pwm2 = &pwm2;
      		pwm3 = &pwm3;
      		pwm4 = &pwm4;
      		pwm5 = &pwm5;
      		pwm6 = &pwm6;
      		pwm7 = &pwm7;
      		ir0 = &s_cir0;
      		tv0 = &tv0;
      		tvd = &tvd;
      		tvd0 = &tvd0;
      		share_space0 = &share_space0;
      	chosen {
      		bootargs = "earlyprintk=sunxi-uart,0x2500000 loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
      		//bootargs = "loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
      		linux,initrd-start = <0x0 0x0>;
      		linux,initrd-end = <0x0 0x0>;
      	firmware {
      		optee {
      			compatible = "linaro,optee-tz";
      			method = "smc";
      	cpus {
      		enable-method = "allwinner,sun8iw20p1";
      		#size-cells = <0>;
      		cpu0: cpu@0 {
      			device_type = "cpu";
      			compatible = "arm,cortex-a7","arm,armv7";
      			reg = <0x0>;
      			enable-method = "psci";
      			clocks = <&ccu CLK_CPUX>;
      			dynamic-power-coefficient = <156>;
      			cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>;
      			operating-points-v2 = <&cpu_opp_table>;
      			#cooling-cells = <2>;
      		cpu1: cpu@1 {
      			reg = <0x1>;
      		idle-states {
      			entry-method = "arm,psci";
      			CPU_SLEEP: cpu-sleep {
      				compatible = "arm,idle-state";
      				arm,psci-suspend-param = <0x0010000>;
      				entry-latency-us = <46>;
      				exit-latency-us = <59>;
      				min-residency-us = <3570>;
      				local-timer-stop;
      			CLUSTER_SLEEP: cluster-sleep {
      				arm,psci-suspend-param = <0x1010000>;
      				entry-latency-us = <47>;
      				exit-latency-us = <74>;
      				min-residency-us = <5000>;
      				local-timer-stop;
      	psci {
      		compatible = "arm,psci-1.0";
      		method = "smc";
      	dump_reg: dump_reg@20000 {
      		compatible = "allwinner,sunxi-dump-reg";
      		reg = <0x0 0x00020000 0x0 0x0004>;
      		/* 0x00020000: dump_reg test addr, 0x0004: dump_reg test size */
      	cpu_opp_table: cpu-opp-table {
      		compatible = "allwinner,sun50i-operating-points";
      		nvmem-cells = <&speedbin_efuse>, <&cpubin_efuse>;
      		nvmem-cell-names = "speed", "bin";
      		opp-shared;
      		opp@480000000 {
      			opp-hz = /bits/ 64 <480000000>;
      			clock-latency-ns = <244144>; /* 8 32k periods */
      			opp-microvolt-a0 = <900000>;
      			opp-microvolt-a1 = <900000>;
      			opp-microvolt-a2 = <900000>;
      			opp-microvolt-b0 = <950000>;
      			opp-supported-hw = <0x3>;
      		opp@720000000 {
      			opp-hz = /bits/ 64 <720000000>;
      		opp@912000000 {
      			opp-hz = /bits/ 64 <912000000>;
      			opp-microvolt-a0 = <950000>;
      		opp@1008000000 {
      			opp-hz = /bits/ 64 <1008000000>;
      			opp-microvolt-a0 = <1000000>;
      		opp@1104000000 {
      			opp-hz = /bits/ 64 <1104000000>;
      			opp-microvolt-a0 = <1050000>;
      			opp-microvolt-a1 = <950000>;
      			opp-microvolt-a2 = <950000>;
      		opp@1200000000 {
      			opp-hz = /bits/ 64 <1200000000>;
      			opp-microvolt-a0 = <1100000>;
      			opp-microvolt-a1 = <1000000>;
      			opp-microvolt-a2 = <1000000>;
      			opp-supported-hw = <0x1>;
      	dcxo24M: dcxo24M_clk {
      		#clock-cells = <0>;
      		compatible = "fixed-clock";
      		clock-frequency = <24000000>;
      		clock-output-names = "dcxo24M";
      	rc_16m: rc16m_clk {
      		#clock-cells = <0>;
      		clock-frequency = <16000000>;
      		clock-accuracy = <300000000>;
      		clock-output-names = "rc-16m";
      	ext_32k: ext32k_clk {
      		#clock-cells = <0>;
      		clock-frequency = <32768>;
      		clock-output-names = "ext-32k";
       clk_osc8m:clk_osc8m_clk{
       		#clock-cells = <0>;
      		clock-frequency = <8000000>;
      		clock-output-names = "clk_osc8m_clk";
      	dram: dram {
      		compatible = "allwinner,dram";
      		clocks = <&ccu CLK_PLL_DDR0>;
      		clock-names = "pll_ddr";
      	memory@40000000 {
      		device_type = "memory";
      		reg = <0x00000000 0x40000000 0x00000000 0x20000000>;
      	share_space0: share_space@42100000 {
      		#size-cells = <1>;
      		deice_tpye = "share_space0";
      		/* dsp write addr and len */
      		/* arm write addr and len */
      		/* dsp log addr and len */
      		/* reserve */
      		reg = <	0x42100000 0x00001000
      			0x42101000 0x00001000
      			0x42102000 0x0000E000
      			0x00000000 0x00000000>;
      	gic: interrupt-controller@3020000 {
      		compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic";
      		#interrupt-cells = <3>;
      		#address-cells = <0>;
      		device_type = "gic";
      		interrupt-controller;
      		reg = <0x0 0x03021000 0 0x1000>, /* GIC Dist */
      		      <0x0 0x03022000 0 0x2000>, /* GIC CPU */
      		      <0x0 0x03024000 0 0x2000>, /* GIC VCPU Control */
      		      <0x0 0x03026000 0 0x2000>; /* GIC VCPU */
      		interrupts = <GIC_PPI 9 0xf04>; /* GIC Maintenence IRQ */
      	timer_arch {
      		compatible = "arm,armv7-timer";
      		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
      		arm,cpu-registers-not-fw-configured;
      		arm,no-tick-in-suspend;
      	pmu {
      		compatible = "arm,cortex-a7-pmu";
      		interrupts = <GIC_SPI 172 4>,
      			     <GIC_SPI 173 4>;
      	power: power-management@ff000000 {
      		compatible = "allwinner,r528-pmu", "syscon", "simple-mfd";
      		reg = <0x0 0x07001000 0x0 0x400>;
      		pd: power-controller {
      			compatible = "allwinner,r528-power-controller";
      			clocks = <&r_ccu CLK_R_PPU>;
      			clock-names = "ppu";
      			resets = <&r_ccu RST_R_PPU>;
      			reset-names = "ppu_rst";
      			#power-domain-cells = <1>;
      			#size-cells = <0>;
      			/* These power domains are grouped by VD_SYS */
      			pd_ve@R528_PD_VE {
      				reg = <R528_PD_VE>;
      	mmu_aw: iommu@2010000 {
      		compatible = "allwinner,sunxi-iommu";
      		reg = <0x0 0x02010000 0x0 0x1000>;
      		interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
      		interrupt-names = "iommu-irq";
      		clocks = <&ccu CLK_BUS_IOMMU>;
      		clock-names = "iommu";
      		#iommu-cells = <2>;
      	reg_pio1_8: pio-18 {
      		regulator-name = "pio-18";
      		regulator-min-microvolt = <1800000>;
      		regulator-max-microvolt = <1800000>;
      	reg_pio3_3: pio-33 {
      		regulator-name = "pio-33";
      	thermal-zones {
      		cpu_thermal_zone: cpu_thermal_zone {
      			polling-delay-passive = <500>;
      			polling-delay = <1000>;
      			thermal-sensors = <&ths 0>;
      			sustainable-power = <589>;
      			cpu_trips: trips {
      				cpu_threshold: trip-point@0 {
      					temperature = <70000>;
      					type = "passive";
      					hysteresis = <0>;
      				cpu_target: trip-point@1 {
      					temperature = <90000>;
      					type = "passive";
      					hysteresis = <0>;
      					temperature = <110000>;
      					type = "critical";
      					hysteresis = <0>;
      			cooling-maps {
      				map0 {
      					trip = <&cpu_target>;
      					cooling-device = <&cpu0
      					THERMAL_NO_LIMIT
      					THERMAL_NO_LIMIT>;
      					contribution = <1024>;
      	soc: soc@3000000 {
      		compatible = "simple-bus";
      		#size-cells = <2>;
      		ranges;
      		device_type = "soc";
      		sram_ctrl: sram_ctrl@3000000 {
      			compatible = "allwinner,sram_ctrl";
      			reg = <0x0 0x3000000 0 0x16C>;
      			soc_ver {
      				offset = <0x24>;
      				mask = <0x7>;
      				shift = <0>;
      				ver_a = <0x18590000>;
      				ver_b = <0x18590002>;
      			soc_id {
      				offset = <0x200>;
      				mask = <0x1>;
      				shift = <22>;
      			soc_bin {
      				offset = <0x0>;
      				mask = <0x3ff>;
      				shift = <0x0>;
      		rtc_ccu: rtc_ccu@7090000 {
      			compatible = "allwinner,sun8iw20-rtc-ccu";
      			device_type = "rtc-ccu";
      			reg = <0x0 0x07090000 0x0 0x320>;  /* The same as rtc */
      			#clock-cells = <1>;
      		ccu: ccu@2001000 {
      			compatible = "allwinner,sun8iw20-ccu";
      			reg = <0x0 0x02001000 0x0 0x1000>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>;
      			clock-names = "hosc", "losc", "iosc";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		r_ccu: r_ccu@7010000 {
      			compatible = "allwinner,sun8iw20-r-ccu";
      			reg = <0x0 0x07010000 0x0 0x240>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>,
      				 <&ccu CLK_PLL_PERIPH0>;
      			clock-names = "hosc", "losc", "iosc", "pll-periph0";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		rtc: rtc@7090000 {
      			compatible = "allwinner,sun8iw20-rtc";
      			device_type = "rtc";
      			wakeup-source;
      			interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_AHB_BUS_RTC>, <&rtc_ccu CLK_RTC_1K>, <&rtc_ccu CLK_RTC_SPI>;
      			clock-names = "r-ahb-rtc", "rtc-1k", "rtc-spi";
      			resets = <&r_ccu RST_R_AHB_BUS_RTC>;
      			gpr_cur_pos = <6>;
      		dma:dma-controller@3002000 {
      			compatible = "allwinner,sun8iw20-dma";
      			reg = <0x0 0x03002000 0x0 0x1000>;
      			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>;
      			clock-names = "bus", "mbus";
      			dma-channels = <8>;
      			dma-requests = <48>;
      			resets = <&ccu RST_BUS_DMA>;
      			#dma-cells = <1>;
      		soc_timer0: timer@2050000 {
      			compatible = "allwinner,sun4i-a10-timer";
      			device_type = "soc_timer";
      			reg = <0x0 0x02050000 0x0 0xA0>;
      			interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&dcxo24M>;
      		wdt: watchdog@20500A0 {
      			compatible = "allwinner,sun6i-a31-wdt";
      			reg = <0x0 0x020500A0 0x0 0x20>;  /* In Timers Spec */
      			interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;  /* In GIC Spec */
      		mbus0: mbus-controller@3102000 {
      			compatible = "allwinner,sun8i-mbus";
      			reg = <0x0 0x03102000 0x0 0x1000>;  /* In SDRAM Controller Spec: DRAMC Common Register */
      			#mbus-cells = <1>;
      		pio: pinctrl@2000000 {
      			compatible = "allwinner,sun8iw20-pinctrl";
      			reg = <0x0 0x02000000 0x0 0x500>;
      			interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>,  /* AW1859_GIC_Spec: GPIOB: 101-32=69 */
      				     <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
      			device_type = "pio";
      			clocks = <&ccu CLK_APB0>, <&dcxo24M>, <&rtc_ccu CLK_OSC32K>;
      			clock-names = "apb", "hosc", "losc";
      			gpio-controller;
      			#gpio-cells = <3>;
      			#size-cells = <0>;
      			vcc-pf-supply = <&reg_pio1_8>;
      			vcc-pe-supply = <&reg_pio1_8>;
      			vcc-pfo-supply = <&reg_pio3_3>;
      			csi_mclk0_pins_a: csi_mclk0@0 {
      				pins = "PE3";
      				function = "csi0";
      			csi_mclk0_pins_b: csi_mclk0@1 {
      				pins = "PE3";
      			csi0_pins_a: csi0@0 {
      				pins = "PE2", "PE4", "PE5",
      						 "PE6", "PE7", "PE8", "PE9", "PE10", "PE11";
      				function = "ncsi0";
      			csi0_pins_b: csi0@1 {
      				function = "lvds0";
      				bias-disable;
      				bias-disable;
      				pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      					"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      					"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      				function = "lcd0";
      				bias-disable;
      				bias-disable;
      			rgb18_pins_a: rgb18@0 {
      				function = "lcd0";
      				bias-disable;
      			rgb18_pins_b: rgb18@1 {
      				bias-disable;
      			dsi2lane_pins_a: dsi2lane@0 {
      				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5";
      				function = "dsi";
      				bias-disable;
      			dsi2lane_pins_b: dsi2lane@1 {
      				bias-disable;
      				function = "dsi";
      				bias-disable;
      				bias-disable;
      		uart0: uart@2500000 {
      			device_type = "uart0";
      			reg = <0x0 0x02500000 0x0 0x400>;
      			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,uart-fifosize = <64>;
      			clocks = <&ccu CLK_BUS_UART0>;
      			clock-names = "uart0";
      			uart0_port = <0>;
      			uart0_type = <2>;
      			// dmas = <&dma 14>, <&dma 14>;
      			// dma-names = "tx", "rx";
      			// use_dma = <0>;
      		uart1: uart@2500400 {
      			device_type = "uart1";
      			reg = <0x0 0x02500400 0x0 0x400>;
      			sunxi,uart-fifosize = <256>;
      			clocks = <&ccu CLK_BUS_UART1>;
      			clock-names = "uart1";
      			uart1_port = <1>;
      			uart1_type = <4>;
      			dmas = <&dma 15>, <&dma 15>;
      			dma-names = "rx", "tx";
      			use_dma = <0>;
      		uart2: uart@2500800 {
      			device_type = "uart2";
      			reg = <0x0 0x02500800 0x0 0x400>;
      			interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART2>;
      			clock-names = "uart2";
      			resets = <&ccu RST_BUS_UART2>;
      			uart2_port = <2>;
      			uart2_type = <4>;
      			dmas = <&dma 16>, <&dma 16>;
      			use_dma = <0>;
      		uart3: uart@2500c00 {
      			device_type = "uart3";
      			reg = <0x0 0x02500c00 0x0 0x400>;
      			interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART3>;
      			clock-names = "uart3";
      			resets = <&ccu RST_BUS_UART3>;
      			uart3_port = <3>;
      			uart3_type = <4>;
      			dmas = <&dma 17>, <&dma 17>;
      			use_dma = <0>;
      		uart4: uart@2501000 {
      			device_type = "uart4";
      			reg = <0x0 0x02501000 0x0 0x400>;
      			interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART4>;
      			clock-names = "uart4";
      			resets = <&ccu RST_BUS_UART4>;
      			uart4_port = <4>;
      			uart4_type = <2>;
      			dmas = <&dma 18>, <&dma 18>;
      			use_dma = <0>;
      		uart5: uart@2501400 {
      			device_type = "uart5";
      			reg = <0x0 0x02501400 0x0 0x400>;
      			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART5>;
      			clock-names = "uart5";
      			resets = <&ccu RST_BUS_UART5>;
      			uart5_port = <5>;
      			uart5_type = <2>;
      			dmas = <&dma 19>, <&dma 19>;
      			use_dma = <0>;
      		cryptoengine: ce@03040000 {
      			compatible = "allwinner,sunxi-ce";
      			device_name = "ce";
      			reg = <0x0 0x03040000 0x0 0xa0>, /* non-secure space */
      			      <0x0 0x03040800 0x0 0xa0>; /* secure space */
      			interrupts = <GIC_SPI 52 IRQ_TYPE_EDGE_RISING>, /*non-secure*/
      				   <GIC_SPI 53 IRQ_TYPE_EDGE_RISING>; /* secure*/
      			clock-frequency = <400000000>; /* 400MHz */
      			clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>, <&ccu CLK_MBUS_CE>,
      					<&ccu CLK_PLL_PERIPH0_2X>;
      			clock-names = "bus_ce", "ce_clk", "mbus_ce", "pll_periph0_2x";
      			resets = <&ccu RST_BUS_CE>;
      		gmac0: eth@4500000 {
      			compatible = "allwinner,sunxi-gmac";
      			reg = <0x0 0x04500000 0x0 0x10000>,
      			      <0x0 0x03000030 0x0 0x4>;
      			interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "gmacirq";
      			clocks = <&ccu CLK_BUS_EMAC0>, <&ccu CLK_EMAC0_25M>;
      			clock-names = "gmac", "ephy";
      			resets = <&ccu RST_BUS_EMAC0>;
      			device_type = "gmac0";
      			gmac-power0;
      			gmac-power1;
      			gmac-power2;
      		sdc2: sdmmc@4022000 {
      			device_type = "sdc2";
      			interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_PLL_PERIPH0_2X>,
      				 <&ccu CLK_MMC2>,
      				 <&ccu CLK_BUS_MMC2>;
      			resets = <&ccu RST_BUS_MMC2>;
      			reset-names = "rst";
      			pinctrl-1 = <&sdc2_pins_b>;
      			bus-width = <4>;
      			req-page-count = <2>;
      			cap-mmc-highspeed;
      			cap-cmd23;
      			mmc-cache-ctrl;
      			non-removable;
      			/*max-frequency = <200000000>;*/
      			max-frequency = <50000000>;
      			cap-erase;
      			mmc-high-capacity-erase-size;
      			no-sdio;
      			no-sd;
      			/*-- speed mode --*/
      			/*sm0: DS26_SDR12*/
      			/*sm1: HSSDR52_SDR25*/
      			/*sm2: HSDDR52_DDR50*/
      			/*sm3: HS200_SDR104*/
      			/*sm4: HS400*/
      			/*-- frequency point --*/
      			/*f0: CLK_400K*/
      			/*f1: CLK_25M*/
      			/*f2: CLK_50M*/
      			/*f3: CLK_100M*/
      			/*f4: CLK_150M*/
      			/*f5: CLK_200M*/
      			sdc_tm4_sm0_freq0 = <0>;
      			sdc_tm4_sm0_freq1 = <0>;
      			sdc_tm4_sm1_freq1 = <0>;
      			sdc_tm4_sm2_freq1 = <0>;
      			sdc_tm4_sm4_freq0_cmd = <0>;
      			sdc_tm4_sm4_freq1_cmd = <0>;
      			/*vmmc-supply = <&reg_3p3v>;*/
      			/*vqmc-supply = <&reg_3p3v>;*/
      			/*vdmc-supply = <&reg_3p3v>;*/
      			/*vmmc = "vcc-card";*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      		sdc0: sdmmc@4020000 {
      			device_type = "sdc0";
      			reg = <0x0 0x04020000 0x0 0x1000>;
      			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC0>,
      				 <&ccu CLK_BUS_MMC0>;
      			resets = <&ccu RST_BUS_MMC0>;
      			pinctrl-names = "default","mmc_1v8","sleep","uart_jtag";
      			pinctrl-1 = <&sdc0_pins_b>;
      			pinctrl-2 = <&sdc0_pins_c>;
      			pinctrl-3 = <&sdc0_pins_d &sdc0_pins_e>;
      			bus-width = <4>;
      			/*non-removable;*/
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PF 6 GPIO_ACTIVE_LOW>;*/
      			/* vmmc-supply = <&reg_3p3v>;*/
      			/* vqmc-supply = <&reg_3p3v>;*/
      			/* vdmc-supply = <&reg_3p3v>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			cap-wait-while-busy;
      			no-sdio;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*cap-sdio-irq;*/
      			/*keep-power-in-suspend;*/
      			/*ignore-pm-notify;*/
      			/*sunxi-dly-400k = <1 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr4  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0>;*/
      			/*sunxi-dly-104M  = <1 0 0 0>;*/
      			/*sunxi-dly-208M  = <1 0 0 0>;*/
      			/*sunxi-dly-104M-ddr  = <1 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0>;*/
      		sdc1: sdmmc@4021000 {
      			device_type = "sdc1";
      			reg = <0x0 0x04021000 0x0 0x1000>;
      			interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC1>,
      				 <&ccu CLK_BUS_MMC1>;
      			resets = <&ccu RST_BUS_MMC1>;
      			pinctrl-0 = <&sdc1_pins_a>;
      			pinctrl-1 = <&sdc1_pins_b>;
      			bus-width = <4>;
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PG 6 6 1 2 0>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*sd-uhs-sdr104;*/
      			/*cap-sdio-irq;*/
      			/*sunxi-dly-400k = <1 0 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0 0>;*/
      			sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0 0>;*/
      			sunxi-dly-104M  = <1 0 0 0 1>;
      			/*sunxi-dly-208M  = <1 1 0 0 0>;*/
      			sunxi-dly-208M  = <1 0 0 0 1>;
      			/*sunxi-dly-104M-ddr  = <1 0 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0 0>;*/
      		rtp:rtp@2009c00 {
      			compatible = "allwinner,sun8i-ts";
      			reg = <0x0 0x02009c00 0x0 0x400>;
      			clocks = <&ccu CLK_TPADC>, <&ccu CLK_BUS_TPADC>;
      			clock-names = "mod", "bus";
      			clock-frequency = <1000000>;
      			resets = <&ccu RST_BUS_TPADC>;
      			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
      		spi0: spi@4025000 {
      			#size-cells = <0>;
      			compatible = "allwinner,sun8i-spi";
      			device_type = "spi0";
      			reg = <0x0 0x04025000 0x0 0x1000>;
      			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI0>, <&ccu CLK_BUS_SPI0>;
      			clock-names = "pll", "mod", "bus";
      			resets = <&ccu RST_BUS_SPI0>;
      			dmas = <&dma 22>, <&dma 22>;
      		spi1: spi@4026000 {
      			#size-cells = <0>;
      			device_type = "spi1";
      			reg = <0x0 0x04026000 0x0 0x1000>;
      			interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI1>, <&ccu CLK_BUS_SPI1>;
      			resets = <&ccu RST_BUS_SPI1>;
      			dmas = <&dma 23>, <&dma 23>;
      		ve: ve@1c0e000 {
      			    compatible = "allwinner,sunxi-cedar-ve";
      			    reg = <0x0 0x01c0e000 0x0 0x1000>,
      				<0x0 0x03000000 0x0 0x10>,
      				<0x0 0x03001000 0x0 0x1000>;
      			    interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>;
      			    clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, <&ccu CLK_MBUS_VE>;
      			    clock-names = "bus_ve", "ve", "mbus_ve";
      			    resets = <&ccu RST_BUS_VE>;
      			    iommus = <&mmu_aw 0 1>;
      		twi0: twi@2502000{
      			#size-cells = <0>;
      			compatible = "allwinner,sun8i-twi";
      			device_type = "twi0";
      			reg = <0x0 0x02502000 0x0 0x400>;
      			interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C0>;
      			resets = <&ccu RST_BUS_I2C0>;
      			clock-names = "bus";
      		twi1: twi@2502400{
      			#size-cells = <0>;
      			device_type = "twi1";
      			reg = <0x0 0x02502400 0x0 0x400>;
      			interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C1>;
      			resets = <&ccu RST_BUS_I2C1>;
      			clock-frequency = <200000>;
      		twi2: twi@2502800{
      			#size-cells = <0>;
      			device_type = "twi2";
      			reg = <0x0 0x02502800 0x0 0x400>;
      			interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C2>;
      			resets = <&ccu RST_BUS_I2C2>;
      			clock-frequency = <100000>;
      		twi3: twi@2502c00{
      			#size-cells = <0>;
      			device_type = "twi3";
      			reg = <0x0 0x02502c00 0x0 0x400>;
      			interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C3>;
      			resets = <&ccu RST_BUS_I2C3>;
      		ledc: ledc@2008000 {
      			#size-cells = <0>;
      			interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "ledcirq";
      			dmas = <&dma 42>, <&dma 42>;
      			resets = <&ccu RST_BUS_LEDC>;
      			reset-names = "ledc_reset";
      			status = "disable";
      		pwm: pwm@2000c00 {
      			#pwm-cells = <0x3>;
      			compatible = "allwinner,sunxi-pwm";
      			reg = <0x0 0x02000c00 0x0 0x400>;
      			clocks = <&ccu CLK_BUS_PWM>;
      			resets = <&ccu RST_BUS_PWM>;
      			pwm-number = <8>;
      			pwm-base = <0x0>;
      			sunxi-pwms = <&pwm0>, <&pwm1>, <&pwm2>, <&pwm3>, <&pwm4>,
      				<&pwm5>, <&pwm6>, <&pwm7>;
      		pwm0: pwm0@2000c10 {
      			compatible = "allwinner,sunxi-pwm0";
      			reg = <0x0 0x02000c10 0x0 0x4>;
      			reg_base = <0x02000c00>;
      		pwm1: pwm1@2000c11 {
      			compatible = "allwinner,sunxi-pwm1";
      			reg = <0x0 0x02000c11 0x0 0x4>;
      		pwm2: pwm2@2000c12 {
      			compatible = "allwinner,sunxi-pwm2";
      			reg = <0x0 0x02000c12 0x0 0x4>;
      		pwm3: pwm3@2000c13 {
      			compatible = "allwinner,sunxi-pwm3";
      			reg = <0x0 0x02000c13 0x0 0x4>;
      		pwm4: pwm4@2000c14 {
      			compatible = "allwinner,sunxi-pwm4";
      			reg = <0x0 0x02000c14 0x0 0x4>;
      		pwm5: pwm5@2000c15 {
      			compatible = "allwinner,sunxi-pwm5";
      			reg = <0x0 0x02000c15 0x0 0x4>;
      		pwm6: pwm6@2000c16 {
      			compatible = "allwinner,sunxi-pwm6";
      			reg = <0x0 0x02000c16 0x0 0x4>;
      		pwm7: pwm7@2000c17 {
      			compatible = "allwinner,sunxi-pwm7";
      			reg = <0x0 0x02000c17 0x0 0x4>;
      		lcd_fb0: lcd_fb0@0 {
      			compatible = "allwinner,sunxi-lcd_fb0";
      			pinctrl-names = "active","sleep";
      		keyboard0: keyboard@2009800 {
      			compatible = "allwinner,keyboard_1350mv";
      			reg = <0x0 0x02009800 0x0 0x400>;
      			interrupts = <GIC_SPI 61 IRQ_TYPE_EDGE_RISING>;
      			clocks = <&ccu CLK_BUS_LRADC>;
      			clock-names = "mclk";
      			resets = <&ccu RST_BUS_LRADC>;
      			key_cnt = <5>;
      			key0 = <210 115>;
      			key1 = <410 114>;
      			key2 = <590 139>;
      			key3 = <710 28>;
      			key4 = <840 172>;
      			wakeup-source;
      		sid@3006000 {
      			compatible = "allwinner,sun8iw20p1-sid", "allwinner,sunxi-sid";
      			reg = <0x0 0x03006000 0 0x1000>;
      			#size-cells = <1>;
      			secure_status {
      				reg = <0x0 0>;
      				offset = <0xa0>;
      				size = <0x4>;
      			chipid {
      				reg = <0x0 0>;
      				offset = <0x200>;
      				size = <0x10>;
      			rotpk {
      				reg = <0x0 0>;
      				offset = <0x140>;
      				size = <0x4>;
      			speedbin_efuse: speedbin@00 {
      				reg = <0x00 4>;
      			cpubin_efuse: cpubin@28 {
      				reg = <0x28 4>;
      			ths_calib: calib@14 {
      				reg = <0x14 8>;
      		gpadc: gpadc@2009000 {
      			compatible = "allwinner,sunxi-gpadc";
      			reg = <0x0 0x02009000 0x0 0x400>;
      			interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_GPADC>;
      			resets = <&ccu RST_BUS_GPADC>;
      		vind0: vind@5800800 {
      			#size-cells = <2>;
      			ranges;
      			device_id = <0>;
      			csi_top = <336000000>;
      				<0x0 0x05800000 0x0 0x800>;
      			clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
      				<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
      				<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
      					"csi_bus", "csi_mbus";
      			resets = <&ccu RST_BUS_CSI>;
      			reset-names = "csi_ret";
      			pinctrl-names = "mclk0-default", "mclk0-sleep";
      			pinctrl-0 = <&csi_mclk0_pins_a>;
      			pinctrl-1 = <&csi_mclk0_pins_b>;
      			csi0: csi@5801000{
      				reg = <0x0 0x05801000 0x0 0x1000>;
      				interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
      				pinctrl-0 = <&csi0_pins_a>;
      				pinctrl-1 = <&csi0_pins_b>;
      				device_id = <0>;
      				iommus = <&mmu_aw 1 1>;
      			isp0: isp@5809410 {
      				reg = <0x0 0x05809410 0x0 0x10>;
      				device_id = <0xfe>;
      			isp1: isp@5809420 {
      				reg = <0x0 0x05809420 0x0 0x10>;
      				device_id = <0xff>;
      			scaler0: scaler@5809430 {
      				reg = <0x0 0x05809430 0x0 0x10>;
      				device_id = <0xfe>;
      			scaler1: scaler@5809440 {
      				reg = <0x0 0x05809440 0x0 0x10>;
      				device_id = <0xff>;
      				reg = <0x0 0x05809450 0x0 0x10>;
      				reg = <0x0 0x05809460 0x0 0x10>;
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				device_id = <0>;
      			sensor0: sensor@5809470 {
      				sensor0_mname = "ov5640";
      				sensor0_twi_cci_id = <2>;
      				sensor0_twi_addr = <0x78>;
      				sensor0_fmt = <0>;
      				sensor0_iovdd_vol = <>;
      				sensor0_avdd_vol = <>;
      				sensor0_dvdd_vol = <>;
      				sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
      				sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
      				sensor0_sm_vs = <>;
      				flash_handle = <&flash0>;
      				act_handle = <&actuator0>;
      				device_id = <0>;
      				status	= "okay";
      			sensor1: sensor@5809480 {
      				reg = <0x0 0x05809480 0x0 0x10>;
      				sensor1_fmt = <0>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				device_id = <1>;
      				status	= "okay";
      			vinc0: vinc@5809000 {
      				device_type = "vinc0";
      				interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
      				device_id = <0>;
      			vinc1: vinc@5809200 {
      				device_type = "vinc1";
      				reg = <0x0 0x05809200 0x0 0x200>;
      				interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
      				vinc1_isp_sel = <1>;
      				device_id = <1>;
      		s_cir0: s_cir@7040000 {
      			compatible = "allwinner,s_cir";
      			reg = <0x0 0x07040000 0x0 0x400>;
      			interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_APB0_BUS_IRRX>, <&dcxo24M>, <&r_ccu CLK_R_APB0_IRRX>;
      			clock-names = "bus", "pclk", "mclk";
      			resets = <&r_ccu RST_R_APB0_BUS_IRRX>;
      			supply = "";
      			supply_vol = "";
      		ir1: ir@2003000 {
      			compatible = "allwinner,ir_tx";
      			reg = <0x0 0x02003000 0x0 0x400>;
      			interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_IR_TX>, <&dcxo24M>, <&ccu CLK_IR_TX>;
      			resets = <&ccu RST_BUS_IR_TX>;
      		di: deinterlace@5400000 {
      			compatible = "allwinner,sunxi-deinterlace";
      			reg = <0x0 0x05400000 0x0 0x0000ffff>;
      			interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_DI>,
      				 <&ccu CLK_BUS_DI>,
      			clock-names = "clk_di",
      				      "pll_periph",
      				      "clk_bus_di";
      			resets = <&ccu RST_BUS_DI>;
      			reset-names = "rst_bus_di";
      			assigned-clocks = <&ccu CLK_DI>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>;
      			assigned-clock-rates = <300000000>;
      			iommus = <&mmu_aw 4 1>;
      		g2d: g2d@5410000 {
      			compatible = "allwinner,sunxi-g2d";
      			reg = <0x0 0x05410000 0x0 0x3ffff>;
      			interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_G2D>, <&ccu CLK_G2D>, <&ccu CLK_MBUS_G2D>;
      			clock-names = "bus", "g2d", "mbus_g2d";
      			resets = <&ccu RST_BUS_G2D>;
      			iommus = <&mmu_aw 3 1>;
      		disp: disp@5000000 {
      			compatible = "allwinner,sunxi-disp";
      			reg = <0x0 0x05000000 0x0 0x3fffff>,	/* de0 */
      			      <0x0 0x05460000 0x0 0xfff>,	/*display_if_top*/
      			      <0x0 0x05461000 0x0 0xfff>,	/* tcon-lcd0 */
      			      <0x0 0x05470000 0x0 0xfff>,	/* tcon-tv */
      			      <0x0 0x05450000 0x0 0x1fff>;	/* dsi0*/
      			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,/*tcon-lcd0*/
      				     <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,/*tcon-tv */
      				     <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;/*dsi*/
      			clocks = <&ccu CLK_DE0>,
      				 <&ccu CLK_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DPSS_TOP0>,
      				 <&ccu CLK_MIPI_DSI>,
      				 <&ccu CLK_BUS_MIPI_DSI>,
      				 <&ccu CLK_TCON_LCD0>,
      				 <&ccu CLK_TCON_TV>,
      				 <&ccu CLK_BUS_TCON_LCD0>,
      				 <&ccu CLK_BUS_TCON_TV>,
      				 <&ccu CLK_BUS_MIPI_DSI>;
      			clock-names = "clk_de0",
      					"clk_de1",
      					"clk_bus_de0",
      					"clk_bus_de1",
      					"clk_bus_dpss_top0",
      					"clk_bus_dpss_top1",
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0",
      					"clk_tcon0",
      					"clk_tcon1",/*tcon-tv actually*/
      					"clk_bus_tcon0",
      					"clk_bus_tcon1",/*tcon-tv actually*/
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0";
      			resets = <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DPSS_TOP0>,
      				 <&ccu RST_BUS_MIPI_DSI>,
      				 <&ccu RST_BUS_TCON_LCD0>,
      				 <&ccu RST_BUS_TCON_TV>,
      				 <&ccu RST_BUS_LVDS0>;
      			reset-names = "rst_bus_de0",
      					"rst_bus_de1",
      					"rst_bus_dpss_top0",
      					"rst_bus_dpss_top1",
      					"rst_bus_mipi_dsi0",
      					"rst_bus_tcon0",
      					"rst_bus_tcon1",
      					"rst_bus_lvds0";
      			assigned-clocks = <&ccu CLK_DE0>,
      			<&ccu CLK_TCON_TV>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>,
      			<&ccu CLK_PLL_VIDEO0_4X>,
      			<&ccu CLK_PLL_VIDEO1_4X>;
      			assigned-clock-rates = <300000000>,
      			<150000000>,
      			<0>,
      			<0>;
      			boot_disp = <0>;
      			boot_disp1 = <0>;
      			boot_disp2 = <0>;
      			fb_base = <0>;
      			iommus = <&mmu_aw 2 0>;
      		lcd0: lcd0@5461000 {
      			compatible = "allwinner,sunxi-lcd0";
      			reg = <0x0 0x05461000 0x0 0xfff>;
      		tv0: tv0@5600000 {
      			compatible = "allwinner,sunxi-tv";
      			reg = <0x0 0x05600000 0x0 0x3fff>,
      				<0x0 0x05604000 0x0 0x3fff>;
      			clocks = <&ccu CLK_BUS_TVE_TOP>,
      				 <&ccu CLK_TVE>,
      				 <&ccu CLK_BUS_TVE>;
      			clock-names = "clk_bus_tve_top",
      				      "clk_tve",
      				      "clk_bus_tve";
      			resets = <&ccu RST_BUS_TVE_TOP>,
      				 <&ccu RST_BUS_TVE>;
      			reset-names = "rst_bus_tve_top", "rst_bus_tve";
      			device_type = "tv0";
      		hwspinlock: hwspinlock@0x3005000 {
      			compatible = "allwinner,sunxi-hwspinlock";
      			reg = <0x0 0x3005000 0x0 0x1000>;
      			#hwlock-cells = <1>;
      			clocks = <&ccu CLK_BUS_SPINLOCK>;
      			clock-names = "clk_hwspinlock_bus";
      			resets = <&ccu RST_BUS_SPINLOCK>;
      			num-locks = <32>;
      		msgbox: msgbox@3003000 {
      			compatible = "sunxi,msgbox-amp";
      			reg = <0x0 0x03003000 0x0 0x1000>,
      			      <0x0 0x01701000 0x0 0x1000>,
      			      <0x0 0x0601f000 0x0 0x1000>;
      			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
      					<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
      					<GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_MSGBOX0>;
      			rpmsg_id = "sunxi,dsp-msgbox","sunxi,dsp-power-msgbox";
      			resets = <&ccu RST_BUS_MSGBOX0>;
      			msgbox_amp_counts = <3>;
      			msgbox_amp_local = <0>;
      			rpmsg_amp_remote-0 = <1>;
      			rpmsg_read_channel-0 = <1>;
      			rpmsg_write_channel-0 = <1>;
      			rpmsg_amp_remote-1 = <1>;
      			rpmsg_read_channel-1 = <0>;
      			rpmsg_write_channel-1 = <0>;
      			compatible = "allwinner,sunxi-msgbox";
      			#mbox-cells = <1>;
      			local_id = <0>;
      		hdmi: hdmi@5500000 {
      			compatible = "allwinner,sunxi-hdmi";
      			reg = <0x0 0x05500000 0x0 0xfffff>;
      			interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_HDMI>,
      				<&ccu CLK_HDMI_24M>,
      				<&ccu CLK_HDMI_CEC>,
      				<&ccu CLK_TCON_TV>;
      			clock-names = "clk_bus_hdmi",
      					"clk_ddc",
      					"clk_cec",
      					"clk_tcon_tv";
      			resets = <&ccu RST_BUS_HDMI_SUB>,
      				<&ccu RST_BUS_HDMI_MAIN>;
      			reset-names = "rst_bus_sub",
      				      "rst_bus_main";
      			assigned-clocks = <&ccu CLK_HDMI_CEC>;
      			assigned-clock-parents = <&ccu CLK_HDMI_CEC_32K>;
      			assigned-clock-rates = <0>;
      		usbc0:usbc0@0 {
      			compatible = "allwinner,sunxi-otg-manager";
      			usb_port_type = <2>;
      			usb_detect_type = <1>;
      			usb_id_gpio;
      			usb_det_vbus_gpio;
      			usb_luns = <3>;
      			rndis_wceis = <1>;
      		udc:udc-controller@0x04100000 {
      			compatible = "allwinner,sunxi-udc";
      			reg = <0x0 0x04100000 0x0 0x1000>, /*udc base*/
      			      <0x0 0x00000000 0x0 0x100>; /*sram base*/
      			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OTG>;
      			clock-names = "bus_otg";
      			resets = <&ccu RST_BUS_OTG>, <&ccu RST_USB_PHY0>;
      			reset-names = "otg", "phy";
      		ehci0:ehci0-controller@0x04101000 {
      			compatible = "allwinner,sunxi-ehci0";
      			reg = <0x0 0x04101000 0x0 0xFFF>, /*hci0 base*/
      			      <0x0 0x00000000 0x0 0x100>, /*sram base*/
      			      <0x0 0x04100000 0x0 0x1000>; /*otg base*/
      			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI0>;
      			clock-names = "bus_hci";
      			resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_USB_PHY0>;
      			reset-names = "hci", "phy";
      			hci_ctrl_no = <0>;
      		ohci0:ohci0-controller@0x04101400 {
      			compatible = "allwinner,sunxi-ohci0";
      			reg = <0x0 0x04101400 0x0 0xFFF>, /*hci0 base*/
      			interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>;
      			clock-names = "bus_hci", "ohci";
      			resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_USB_PHY0>;
      			hci_ctrl_no = <0>;
      		usbc1:usbc1@0 {
      			status = "disable";
      		ehci1:ehci1-controller@0x04200000 {
      			compatible = "allwinner,sunxi-ehci1";
      			reg = <0x0 0x04200000 0x0 0xFFF>, /*ehci1 base*/
      			interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI1>;
      			resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		ohci1:ohci1-controller@0x04200400 {
      			compatible = "allwinner,sunxi-ohci1";
      			reg = <0x0 0x04200400 0x0 0xFFF>, /*ohci1 base*/
      			interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI1>, <&ccu CLK_USB_OHCI1>;
      			resets = <&ccu RST_BUS_OHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		/* codec addr: 0x02030000, the others is invalid to avoid build warining */
      		codec:codec@2030000 {
      			#sound-dai-cells = <0>;
      			compatible = "allwinner,sunxi-internal-codec";
      			reg = <0x0 0x02030000 0x0 0x34c>;
      			clocks = <&ccu CLK_PLL_AUDIO0>,
      				 <&ccu CLK_PLL_AUDIO1_DIV5>,
      				 <&ccu CLK_AUDIO_DAC>,
      				 <&ccu CLK_AUDIO_ADC>,
      				 <&ccu CLK_BUS_AUDIO_CODEC>;
      			clock-names = "pll_audio0", "pll_audio1_div5",
      				      "audio_clk_dac", "audio_clk_adc",
      				      "audio_clk_bus";
      			resets = <&ccu RST_BUS_AUDIO_CODEC>;
      			rx_sync_en  = <0x00>;
      			device_type = "codec";
      		dummy_cpudai:dummy_cpudai@203034c {
      			compatible = "allwinner,sunxi-dummy-cpudai";
      			reg = <0x0 0x0203034c 0x0 0x4>;
      			tx_fifo_size    = <128>;
      			rx_fifo_size    = <256>;
      			dac_txdata      = <0x02030020>;
      			adc_txdata      = <0x02030040>;
      			device_type = "cpudai";
      			dmas = <&dma 7>, <&dma 7>;
      		sndcodec:sound@2030340 {
      			compatible = "allwinner,sunxi-codec-machine";
      			reg = <0x0 0x02030340 0x0 0x4>;
      			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,audio-codec = <&codec>;
      			sunxi,cpudai-controller = <&dummy_cpudai>;
      			device_type = "sndcodec";
      		sunxi_rpaf_dsp0:rpaf-dsp@203034c {
      			compatible = "allwinner,rpaf-dsp0";
      			device_type = "sunxi_rpaf_dsp0";
      			dsp_id = <0x0>;
      		/* dmic addr: 0x02031000, the others is invalid to avoid build warining */
      		dmic:dmic@2031000{
      			compatible = "allwinner,sunxi-dmic";
      			reg = <0x0 0x02031000 0x0 0x50>;
      			clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */
      				 <&ccu CLK_DMIC>,
      				 <&ccu CLK_BUS_DMIC>;
      			clock-names = "pll_audio", "dmic", "dmic_bus";
      			resets = <&ccu RST_BUS_DMIC>;
      			dmas		= <&dma 8>;
      			dma-names	= "rx";
      			interrupts	= <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
      			clk_parent	= <0x1>;
      			data_vol	= <0xB0>;
      			rx_chmap	= <0x76543210>;
      			device_type = "dmic";
      		dmic_codec:sound@2031050{
      			compatible = "dmic-codec";
      			reg = <0x0 0x02031050 0x0 0x4>;
      			num-channels = <8>;
      		sounddmic:sounddmic@2031060 {
      			reg = <0x0 0x02031060 0x0 0x4>;
      			compatible = "sunxi,simple-audio-card";
      			simple-audio-card,name = "snddmic";
      			simple-audio-card,capture_only;
      			simple-audio-card,cpu {
      				sound-dai = <&dmic>;
      				sound-dai = <&dmic_codec>;
      		/* daudio0 addr: 0x02032000, the others is invalid to avoid build warining */
      		daudio0:daudio@2032000 {
      			compatible = "allwinner,sunxi-daudio";
      			reg = <0x0 0x02032000 0x0 0xa0>;
      				 <&ccu CLK_I2S0>,
      				 <&ccu CLK_BUS_I2S0>;
      			clock-names = "pll_audio", "i2s0", "i2s0_bus";
      			resets = <&ccu RST_BUS_I2S0>;
      			dmas		= <&dma 3>, <&dma 3>;
      			interrupts	= <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
      			pinctrl_used		= <0x01>;
      			tx_data_mode		= <0x00>;
      			rx_data_mode		= <0x00>;
      			frametype		= <0x00>;
      			tdm_num			= <0x00>;
      			mclk_div		= <0x00>;
      			clk_parent		= <0x00>;
      			capture_cma		= <128>;
      			tx_num			= <4>;
      			tx_chmap1		= <0x76543210>;
      			tx_chmap0		= <0xFEDCBA98>;
      			rx_num			= <4>;
      			rx_chmap3		= <0x03020100>;
      			rx_chmap2		= <0x07060504>;
      			rx_chmap1		= <0x0B0A0908>;
      			rx_chmap0		= <0x0F0E0D0C>;
      			asrc_function_en	= <0x00>;
      			device_type = "daudio0";
      		sounddaudio0: sounddaudio0@20320a0 {
      			reg = <0x0 0x020320a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio0";
      				sound-dai = <&daudio0>;
      		/* daudio1 addr: 0x02033000, the others is invalid to avoid build warining */
      		daudio1:daudio@2033000 {
      			reg = <0x0 0x02033000 0x0 0xa0>;
      				 <&ccu CLK_I2S1>,
      				 <&ccu CLK_BUS_I2S1>;
      			clock-names = "pll_audio", "i2s1", "i2s1_bus";
      			resets = <&ccu RST_BUS_I2S1>;
      			dmas		= <&dma 4>, <&dma 4>;
      			interrupts	= <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
      			frametype		= <0x00>;
      			tdm_num			= <0x01>;
      			mclk_div		= <0x00>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio1";
      		sounddaudio1: sounddaudio1@20330a0 {
      			reg = <0x0 0x020330a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio1";
      				sound-dai = <&daudio1>;
      		/* daudio2 addr: 0x02034000, the others is invalid to avoid build warining */
      		daudio2:daudio@2034000 {
      			reg = <0x0 0x02034000 0x0 0xa0>;
      				 <&ccu CLK_I2S2>,
      				 <&ccu CLK_BUS_I2S2>,
      				 <&ccu CLK_PLL_AUDIO0_4X>,
      				 <&ccu CLK_I2S2_ASRC>;
      			resets = <&ccu RST_BUS_I2S2>;
      			dmas		= <&dma 5>, <&dma 5>;
      			interrupts	= <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
      			daudio_type		= <0x00>;
      			frametype		= <0x00>;
      			tdm_num			= <0x02>;
      			mclk_div		= <0x01>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio2";
      		sounddaudio2: sounddaudio2@20340a0 {
      			reg = <0x0 0x020340a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio2";
      				sound-dai = <&daudio2>;
      		hdmiaudio: hdmiaudio@20340a4 {
      			reg = <0x0 0x020340a4 0x0 0x4>;
      			compatible = "allwinner,sunxi-hdmiaudio";
      		/* spdif addr: 0x02036000, the others is invalid to avoid build warining */
      		spdif:spdif@2036000 {
      			compatible = "allwinner,sunxi-spdif";
      			reg = <0x0 0x02036000 0x0 0x58>;
      			clocks = <&ccu CLK_PLL_AUDIO0_4X>,	/* 90.3168M */
      				 <&ccu CLK_SPDIF_TX>,
      				 <&ccu CLK_BUS_SPDIF>,
      				 <&ccu CLK_PLL_AUDIO1>,         /* 98.304M */
      				 <&ccu CLK_SPDIF_RX>;
      			clock-names = "pll_audio0", "spdif", "spdif_bus",
      				      "pll_audio1", "pll_audio1_div5",
      				      "pll_periph", "spdif_rx";
      			resets = <&ccu RST_BUS_SPDIF>;
      			dmas		= <&dma 2>, <&dma 2>;
      			interrupts	= <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
      			clk_parent	= <0x1>;
      			rx_sync_en      = <0>;
      			device_type = "spdif";
      		soundspdif:soundspdif@203605c {
      			reg = <0x0 0x0203605c 0x0 0x4>;
      			simple-audio-card,name = "sndspdif";
      				 sound-dai = <&spdif>;
      				 /*snd-soc-dummy*/
      		ths: ths@02009400 {
      			compatible = "allwinner,sun8iw20p1-ths";
      			reg = <0x0 0x02009400 0x0 0x400>;
      			clocks = <&ccu CLK_BUS_THS>;
      			resets = <&ccu RST_BUS_THS>;
      			nvmem-cells = <&ths_calib>;
      			nvmem-cell-names = "calibration";
      			#thermal-sensor-cells = <1>;
      		tvd: tvd@05c00000 {
      			compatible = "allwinner,sunxi-tvd";
      			reg = <0x0 0x05c00000 0x0 0x00010000>;/*tvd_top*/
      			interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_TVD_TOP>,
      			<&ccu CLK_MBUS_TVIN>;
      			clock-names = "clk_bus_tvd_top",
      			"clk_mbus_tvd";
      			resets = <&ccu RST_BUS_TVD_TOP>;
      			reset-names = "rst_bus_tvd_top";
      			tvd-number = <1>;
      			tvds = <&tvd0>;
      		tvd0: tvd0@05c01000 {
      			compatible = "allwinner,sunxi-tvd0";
      			reg = <0x0 0x05c01000 0x0 0x00010000>;
      			clocks = <&ccu CLK_TVD>,
      			<&ccu CLK_BUS_TVD>;
      			clock-names = "clk_tvd0","clk_bus_tvd0";
      			resets = <&ccu RST_BUS_TVD>;
      			reset-names = "rst_bus_tvd0";
      			assigned-clocks = <&ccu CLK_TVD>;
      			assigned-clock-parents = <&ccu CLK_PLL_VIDEO1>;
      			tvd_used = <1>;
      			tvd_if = <0>;
      有没有懂的知道这个mcp2515初始化失败,-34是什么??
      J 1 条回复 最后回复 回复 引用 分享 0
        Jingyan LV 6 @TS_123456789 最后由 Jingyan 编辑
        @ts_123456789 在 飞凌T113-i核心板+自制底板 mcp2515驱动失败 中说:
        这个报错是mcp驱动返回的错误码,请检查时钟。要求范围在1M~25M之间
