    A133 android10.0 rtl8189ftv打不开wifi
    A Series
    4328
      lu1688 LV 3 最后由 编辑
      开机也不会自动加载,insmod 能加载上,然后在设置打开开关就打不开。
      wifi.txt
        lu1688 LV 3 @lu1688 最后由 编辑
        手动加载ko成功,然后在设置打开wifi开关,驱动会被卸载
        [ 1316.238104] RTW: module init start
        [ 1316.242275] RTW: rtl8189fs v5.15.12-7-g4c86cb3ae.20231020
        [ 1316.248600] RTW: build time: Dec 14 2024 10:06:13
        [ 1316.254120] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
        [ 1316.266467] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
        [ 1316.385043] RTW: platform_wifi_power_on: power up, rescan card.
        [ 1316.385124] sunxi-mmc sdc1: smc 2 p1 err, cmd 7, RTO !!
        [ 1316.391769] sunxi-mmc sdc1: smc 2 p1 err, cmd 7, RTO !!
        [ 1316.397618] sunxi-mmc sdc1: smc 2 p1 err, cmd 7, RTO !!
        [ 1316.403465] sunxi-mmc sdc1: smc 2 p1 err, cmd 7, RTO !!
        [ 1316.410214] mmc2: card 0001 removed
        [ 1316.410720] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [ 1316.411897] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1316.412028] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
        [ 1316.426258] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1316.459512] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
        [ 1316.465799] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
        [ 1316.465864] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1316.473051] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1316.494394] RTW: rtw_inetaddr_notifier_register
        [ 1316.500086] RTW: module init ret=0
        [ 1316.512279] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [ 1316.522982] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [ 1316.533893] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
        [ 1316.545403] mmc2: new high speed SDIO card at address 0001
        [ 1316.552631] RTW: == SDIO Card Info ==
        [ 1316.556814] RTW: card: ffffffc079fab800
        [ 1316.561446] RTW: clock: 50000000 Hz
        [ 1316.565648] RTW: timing spec: sd high-speed
        [ 1316.570712] RTW: sd3_bus_mode: FALSE
        [ 1316.575087] RTW: func num: 1
        [ 1316.578603] RTW: func1: ffffffc04bbb0000 (*)
        [ 1316.583692] RTW: max_byte_size: 512
        [ 1316.587858] RTW: ================
        [ 1316.591678] RTW: CHIP TYPE: RTL8188F
        [ 1316.595903] RTW: loadparam, Select P2P interface: iface_id:1
        [ 1316.603086] RTW: Chip Version Info: CHIP_8188F_S2_1T1R_RomVer(0)
        [ 1316.610407] RTW: SetHwReg: hci_sus_state=1
        [ 1316.618182] RTW: SetHwReg: bMacPwrCtrlOn=1
        [ 1316.622785] RTW: SetHwReg: hci_sus_state=2
        [ 1316.627715] RTW: sdio_power_on_check: val_mix:0x0000063f, res:0x0000063f
        [ 1316.635257] RTW: sdio_power_on_check: 0x100 the result of cmd52 and cmd53 is the same.
        [ 1316.644282] RTW: sdio_power_on_check: 0x1B8 test Pass.
        [ 1316.650118] RTW: EEPROM type is E-FUSE
        [ 1316.654999] RTW: hal_EfuseSwitchToBank: Efuse switch bank to 0
        [ 1316.666678] RTW: hal_ReadEFuse_WiFi: data end at address=0x12
        [ 1316.673235] RTW: HW EFUSE
        [ 1316.676278] RTW: 0x000: 29 81 03 CC 00 00 50 00 00 00 04 CC 0A 0C 00 00
        [ 1316.684552] RTW: 0x010: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.692653] RTW: 0x020: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.700771] RTW: 0x030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.708993] RTW: 0x040: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.717142] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.725264] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.733478] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.741658] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.749706] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.757736] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.765735] RTW: 0x0B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.773795] RTW: 0x0C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.781892] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.789960] RTW: 0x0E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.798048] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.806121] RTW: 0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.814204] RTW: 0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.822808] RTW: 0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.831419] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.839911] RTW: 0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.847921] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.855928] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.863972] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.871984] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.880013] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.888514] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.897107] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.905682] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.913701] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.921728] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.929747] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.937862] RTW: retriveFromFile openFile path:/system/etc/wifi/wifi_efuse_8189fs.map fp=ffffffc058173500
        [ 1316.948595] RTW: retriveFromFile readFile, ret:1421
        [ 1316.954190] RTW: efuse file:/system/etc/wifi/wifi_efuse_8189fs.map, 0x1d0 byte content read
        [ 1316.963701] RTW: EFUSE FILE
        [ 1316.966993] RTW: 0x000: 29 81 03 7C 01 08 28 00 42 07 0D 45 10 00 00 00
        [ 1316.975583] RTW: 0x010: 30 30 30 30 2F 2F 31 31 31 2F 2F 02 FF FF FF FF
        [ 1316.984348] RTW: 0x020: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1316.992600] RTW: 0x030: FF FF FF FF FF FF FF FF FF FF 30 30 30 30 2F 2F
        [ 1317.000685] RTW: 0x040: 31 31 31 2F 2F 02 FF FF FF FF FF FF FF FF FF FF
        [ 1317.008720] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.016737] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.024766] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.032778] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.040780] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.049390] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.057982] RTW: 0x0B0: FF FF FF FF FF FF FF FF 20 20 25 00 00 00 FF FF
        [ 1317.066496] RTW: 0x0C0: FF 39 20 51 00 00 00 FF 00 FF 10 FF FF FF FF FF
        [ 1317.074636] RTW: 0x0D0: 3E 10 01 02 23 00 00 FF 20 04 4C 02 23 B7 21 02
        [ 1317.082645] RTW: 0x0E0: 0C 00 22 04 00 08 00 32 FF 21 02 0C 00 22 2A 01
        [ 1317.090679] RTW: 0x0F0: 01 00 00 00 00 00 00 00 00 00 00 00 02 00 FF FF
        [ 1317.098688] RTW: 0x100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        [ 1317.106733] RTW: 0x110: 00 EB 00 6E 01 00 00 00 00 FF 00 E0 4C B7 23 01
        [ 1317.114746] RTW: 0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.123298] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.131919] RTW: 0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.140362] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.148385] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.156582] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.164600] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.172625] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.180634] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.188666] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.197226] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.205771] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.214279] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.222287] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        [ 1317.230675] RTW: hal_EfuseSwitchToBank: Efuse switch bank to 0
        [ 1317.240566] RTW: hal_ReadEFuse_WiFi: data end at address=0x12
        [ 1317.247075] RTW: rtw_read_macaddr_from_file /data/wifimac.txt is not readable
        [ 1317.255430] RTW: kfree Pwr Trim flag:1
        [ 1317.259634] RTW: bb_gain:0
        [ 1317.262724] RTW: rtl8188f_FirmwareDownload((null)) tmp_ps=3
        [ 1317.269106] RTW: rtl8188f_FirmwareDownload fw: FW_NIC, size: 20874
        [ 1317.276159] RTW: rtl8188f_FirmwareDownload: fw_ver=f fw_subver=0002 sig=0x88f1, Month=05, Date=10, Hour=11, Minute=05
        [ 1317.288224] RTW: rtl8188f_FirmwareDownload(): Shift for fw header!
        [ 1317.295327] RTW: rtl8188f_FirmwareDownload by IO write!
        [ 1317.440421] RTW: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x07050105
        [ 1317.450028] RTW: _8051Reset8188: Finish
        [ 1317.463563] RTW: _FWFreeToGo: Polling FW ready OK! (131, 13ms), REG_MCUFWDL:0x070501c6
        [ 1317.472459] RTW: rtl8188f_FirmwareDownload: DLFW OK !
        [ 1317.478169] RTW: rtl8188f_FirmwareDownload success. write_fw:1, 183ms
        [ 1317.485473] RTW: <=== rtl8188f_FirmwareDownload()
        [ 1317.491188] RTW: hal_read_mac_hidden_rpt OK! (1, 0ms), fwdl:1, id:0x19
        [ 1317.499057] RTW: SetHwReg: bMacPwrCtrlOn=0
        [ 1317.503671] RTW: SetHwReg: hci_sus_state=3
        [ 1317.508932] RTW: SetHwReg: hci_sus_state=0
        [ 1317.513543] RTW: rtw_hal_read_chip_info in 903 ms
        [ 1317.518868] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
        [ 1317.524176] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
        [ 1317.534447] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
        [ 1317.541144] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
        [ 1317.549961] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
        [ 1317.557120] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1
        [ 1317.564477] RTW: rtw_hal_rfpath_init trx_path_bmp:0x11(RF_1T1R), NumTotalRFPath:1, max_tx_cnt:1
        [ 1317.574279] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
        [ 1317.580180] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
        [ 1317.586150] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
        [ 1317.592035] RTW: rtw_hal_trxnss_init tx_nss:1, rx_nss:1
        [ 1317.597934] RTW: txpath=0x1, rxpath=0x1
        [ 1317.602273] RTW: txpath_1ss:0x1, num:1
        [ 1317.606520] RTW: devobj_decide_init_chplan alpha2:{255,255}
        [ 1317.612788] RTW: devobj_decide_init_chplan chplan:0x20
        [ 1317.618573] RTW: devobj_decide_init_chplan chplan_6g:0x00
        [ 1317.624657] RTW: devobj_decide_init_chplan disable_sw_chplan:0
        [ 1317.631217] RTW: rtw_rfctl_decide_init_chplan chplan:0x20
        [ 1317.637396] RTW: init_mlme_default_rate_set: support CCK
        [ 1317.643392] RTW: init_mlme_default_rate_set: support OFDM
        [ 1317.650058] RTW: rtw_alloc_macid((null)) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
        [ 1317.658345] RTW: rtw_init_pwrctrl_priv: IPS_mode=1, LPS_mode=2, LPS_level=1
        [ 1317.666502] RTW: Init_ODM_ComInfo bb_opmode set to 0
        [ 1317.672072] RTW: IQK FW offload:disable
        [ 1317.676370] RTW: Init_ODM_ComInfo_8188f(): Fv=0 Cv=12
        [ 1317.682095] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
        [ 1317.692133] RTW: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
        [ 1317.701687] RTW: default power by rate loaded
        [ 1317.706584] RTW: rtw_chset_apply_from_rtk_priv chplan:0x20 chplan_6g:0x00
        [ 1317.714189] RTW: rtw_rfctl_chset_apply_regulatory ch num:13
        [ 1317.720754] RTW: ERROR invalid mac addr:00:00:00:00:00:00, assign random MAC
        [ 1317.728624] RTW: rtw_macaddr_cfg mac addr:00:e0:4c:64:1e:8e
        [ 1317.734989] RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
        [ 1317.744286] RTW: loadparam, Select P2P interface: iface_id:1
        [ 1317.750955] RTW: init_mlme_default_rate_set: support CCK
        [ 1317.756988] RTW: init_mlme_default_rate_set: support OFDM
        [ 1317.764547] RTW: rtw_alloc_macid((null)) if2, mac_addr:ff:ff:ff:ff:ff:ff macid:1
        [ 1317.772969] RTW: rtw_drv_add_vir_if if2 mac_addr : 02:e0:4c:64:1e:8e
        [ 1317.780254] RTW: rtw_cfg80211_init_wiphy_band:rf_type=0
        [ 1317.786331] RTW: [HT] HAL Support STBC = 0x01
        [ 1317.791369] RTW: rtw_wiphy_alloc(phy2)
        [ 1317.795722] RTW: rtw_wdev_alloc(padapter=ffffff80096fa000)
        [ 1317.802074] RTW: rtw_wdev_alloc(padapter=ffffff8009efc000)
        [ 1317.808310] RTW: rtw_wiphy_register(phy2)
        [ 1317.812912] RTW: Register RTW cfg80211 vendor cmd(0x67) interface
        [ 1317.821955] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:e0:4c:64:1e:8e
        [ 1317.830096] RTW: rtw_ndev_notifier_call(wlan0) state:16
        [ 1317.841535] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1317.849231] RTW: rtw_ndev_notifier_call(wlan0) state:5
        [ 1317.855174] RTW: rtw_ndev_init(wlan1) if2 mac_addr=02:e0:4c:64:1e:8e
        [ 1317.863095] RTW: rtw_ndev_notifier_call(wlan1) state:16
        [ 1317.872213] RTW: cfg80211_rtw_get_txpower(wlan1) total max: -10000 mbm
        [ 1317.879784] RTW: rtw_ndev_notifier_call(wlan1) state:5
        [ 1326.138311] healthd: battery none chg=au
        [ 1329.325934] logd: logdr: UID=2000 GID=2000 PID=4821 b tail=0 logMask=19 pid=0 start=0ns timeout=0ns
        [ 1336.164880] healthd: battery none chg=au
        [ 1344.895128] healthd: battery none chg=au
        [ 1345.283140] logd: logdr: UID=2000 GID=2000 PID=4853 b tail=0 logMask=19 pid=0 start=0ns timeout=0ns
        [ 1346.190467] healthd: battery none chg=au
        [ 1346.535754] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1674 (/system/bin/hwservicemanager)
        [ 1346.553535] init: starting service 'vendor.wifi_hal_legacy'...
        [ 1346.563990] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1674 (/system/bin/hwservicemanager)
        [ 1346.637086] init: Received control message 'interface_start' for 'android.hardware.wifi.supplicant@1.0::ISupplicant/default' from pid: 1674 (/system/bin/hwservicemanager)
        [ 1346.656749] init: starting service 'wpa_supplicant'...
        [ 1346.672327] init: Created socket '/dev/socket/wpa_wlan0', mode 660, user 1010, group 1010
        [ 1346.846853] RTW: rtw_ndev_notifier_call(wlan0) state:13
        [ 1346.852843] RTW: _netdev_open(wlan0) , bup=0
        [ 1346.858775] RTW: FW does not exist before power on!!
        [ 1346.864777] RTW: SetHwReg: hci_sus_state=1
        [ 1346.872262] RTW: SetHwReg: bMacPwrCtrlOn=1
        [ 1346.876947] RTW: SetHwReg: hci_sus_state=2
        [ 1346.882198] RTW: sdio_power_on_check: val_mix:0x0000063f, res:0x0000063f
        [ 1346.889806] RTW: sdio_power_on_check: 0x100 the result of cmd52 and cmd53 is the same.
        [ 1346.898934] RTW: sdio_power_on_check: 0x1B8 test Pass.
        [ 1346.904801] RTW: Power on ok!
        [ 1346.908367] RTW: rtl8188f_FirmwareDownload(wlan0) tmp_ps=3
        [ 1346.914525] RTW: rtl8188f_FirmwareDownload fw: FW_NIC, size: 20874
        [ 1346.921459] RTW: rtl8188f_FirmwareDownload: fw_ver=f fw_subver=0002 sig=0x88f1, Month=05, Date=10, Hour=11, Minute=05
        [ 1346.933320] RTW: rtl8188f_FirmwareDownload(): Shift for fw header!
        [ 1346.940290] RTW: rtl8188f_FirmwareDownload by IO write!
        [ 1347.129170] RTW: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00050105
        [ 1347.138917] RTW: _8051Reset8188: Finish
        [ 1347.152456] RTW: _FWFreeToGo: Polling FW ready OK! (93, 13ms), REG_MCUFWDL:0x000501c6
        [ 1347.161256] RTW: rtl8188f_FirmwareDownload: DLFW OK !
        [ 1347.167046] RTW: rtl8188f_FirmwareDownload success. write_fw:1, 226ms
        [ 1347.174365] RTW: <=== rtl8188f_FirmwareDownload()
        [ 1347.179790] RTW: HalDetectPwrDownMode(): PDN=0
        [ 1347.184877] RTW: Set RF Chip ID to RF_6052 and RF type to 0.
        [ 1347.194465] RTW: WARN init_reg_0x63c:0x10100a0a != 0x0e0e0a0a
        [ 1347.534905] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =00:e0:4c:64:1e:8e
        [ 1347.544129] RTW: rtw_hal_set_macaddr_port wlan1- hw port(1) mac_addr =02:e0:4c:64:1e:8e
        [ 1347.553565] RTW: [HW_VAR_ENABLE_RX_BAR] 0x6A2=0x500
        [ 1347.562943] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =00:e0:4c:64:1e:8e
        [ 1347.572282] RTW: #### hw_var_set_opmode() -4562 hw_port(0) mode = 2 ####
        [ 1347.580207] RTW: rtw_rf_get_kfree_tx_gain_offset path:0, ch:6, bb_gain_sel:0, kfree_offset:0
        [ 1347.590353] RTW: kfree gain_offset 0x55:0x82060 RTW: after :0x2060
        [ 1347.598289] RTW: MAC Address = 00:e0:4c:64:1e:8e
        [ 1347.603473] RTW: rtw_start_drv_threads(wlan0) enter
        [ 1347.609478] RTW: rtw_start_drv_threads(wlan0) start RTW_XMIT_THREAD
        [ 1347.618828] RTW: rtw_start_drv_threads(wlan0) start RTW_CMD_THREAD
        [ 1347.626135] RTW: rtl8188f_start_thread(wlan0) start RTWHALXT
        [ 1347.632671] RTW: start rtl8188fs_xmit_thread(wlan0)
        [ 1347.633306] RTW: _netdev_vir_if_open(wlan1) , bup=0
        [ 1347.633311] RTW: rtw_start_drv_threads(wlan1) enter
        [ 1347.633316] RTW: rtl8188f_start_thread(wlan1) start RTWHALXT
        [ 1347.633471] RTW: _netdev_vir_if_open(wlan1) (bup=1) exit
        [ 1347.633476] RTW: -871x_drv - drv_open, bup=1
        [ 1347.633478] RTW: start rtl8188fs_xmit_thread(wlan1)
        [ 1347.633581] RTW: cfg80211_rtw_set_power_mgmt(wlan0) enabled:1, timeout:-1
        [ 1347.633609] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
        [ 1347.633616] RTW: rtw_ndev_notifier_call(wlan0) state:1
        [ 1347.653312] RTW: cfg80211_rtw_get_txpower(wlan1) total max: -10000 mbm
        [ 1347.653322] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.694907] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.695087] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.696117] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.696333] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.703944] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.704179] RTW: rtw_ndev_notifier_call(wlan0) state:4
        [ 1347.734496] RTW: cfg80211_rtw_flush_pmksa(wlan0)
        [ 1347.764216] RTW: rtw_ndev_notifier_call(wlan0) state:9
        [ 1347.770135] RTW: netdev_close(wlan0) , bup=1
        [ 1347.774946] RTW: (2)871x_drv - drv_close, bup=1, hw_init_completed=_TRUE
        [ 1347.782694] RTW: rtw_hal_set_bssid wlan0- hw port -0 BSSID: 00:00:00:00:00:00
        [ 1347.790813] RTW: rtw_set_rts_bw connect_to_8812=0,enable=1
        [ 1347.797016] RTW: rtw_phydm_update_ap_vendor_ie ODM_CMNINFO_HUAWEI_HWID:0 ATHEROS_HWID:0
        [ 1347.805997] RTW: rtw_phydm_update_ap_vendor_ie ODM_CMNINFO_BROADCOM_HWID:0 ODM_CMNINFO_RALINK_HWID:0
        [ 1347.816461] RTW: rtw_cfg80211_indicate_disconnect(wlan0) ,reason = 0
        [ 1347.823702] RTW: rtw_cfg80211_indicate_disconnect(wlan0) call cfg80211_disconnected, reason:0
        [ 1347.833425] RTW: rtw_reset_securitypriv(wlan0) - End to Disconnect
        [ 1347.840394] RTW: rtw_free_assoc_resources-wlan0 tgt_network MacAddress=00:00:00:00:00:00 ssid=
        [ 1347.850092] RTW: ERROR Free disconnecting network of scanned_queue failed due to pwlan == NULL
        [ 1347.850092]
        [ 1347.861490] RTW: -871x_drv - drv_close, bup=1
        [ 1347.866546] RTW: rtw_ndev_notifier_call(wlan0) state:2
        [ 1347.872508] RTW: cfg80211_rtw_del_key(wlan0) key_index=0, addr= (null)
        [ 1347.880752] RTW: cfg80211_rtw_del_key(wlan0) key_index=1, addr= (null)
        [ 1347.888961] RTW: cfg80211_rtw_del_key(wlan0) key_index=2, addr= (null)
        [ 1347.897511] RTW: cfg80211_rtw_del_key(wlan0) key_index=3, addr= (null)
        [ 1347.905754] RTW: cfg80211_rtw_del_key(wlan0) key_index=4, addr= (null)
        [ 1347.914103] RTW: cfg80211_rtw_del_key(wlan0) key_index=5, addr= (null)
        [ 1347.925942] RTW: cfg80211_rtw_get_txpower(wlan1) total max: -10000 mbm
        [ 1347.933320] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.944495] RTW: module exit start
        [ 1347.948601] RTW: rtw_wdev_unregister(wdev=ffffffc04e76d000)
        [ 1347.955804] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
        [ 1347.979733] RTW: rtw_ndev_notifier_call(wlan0) state:6
        [ 1347.985562] RTW: rtw_ndev_uninit(wlan0) if1
        [ 1347.998870] init: Service 'wpa_supplicant' (pid 4864) exited with status 0
        [ 1348.006652] init: Sending signal 9 to service 'wpa_supplicant' (pid 4864) process group...
        [ 1348.016349] libprocessgroup: Successfully killed process cgroup uid 0 pid 4864 in 0ms
        [ 1348.026575] RTW: rtw_ndev_notifier_call(wlan0) state:17
        [ 1348.052878] RTW: rtw_wdev_unregister(wdev=ffffffc04e76ce00)
        [ 1348.059369] RTW: cfg80211_rtw_get_txpower(wlan1) total max: -10000 mbm
        [ 1348.096592] RTW: rtw_ndev_notifier_call(wlan1) state:6
        [ 1348.102538] RTW: rtw_ndev_uninit(wlan1) if2
        [ 1348.139567] RTW: rtw_ndev_notifier_call(wlan1) state:17
        [ 1348.166248] RTW: rtw_wiphy_unregister(phy2)
        [ 1348.171027] RTW: Vendor: Unregister RTW cfg80211 vendor interface
        [ 1348.193209] RTW: rtw_pm_set_ips IPS mode: IPS_NONE
        [ 1348.198738] RTW: rtw_cmd_thread(wlan0) Exit
        [ 1348.203776] RTW: rtw_drv_stop_vir_if(wlan1) enter
        [ 1348.209294] RTW: rtw_stop_drv_threads(wlan1) enter
        [ 1348.214761] RTW: rtl8188fs_xmit_thread(wlan1) Exit
        [ 1348.220337] RTW: ==> rtw_dev_unload(wlan0)
        [ 1348.225042] RTW: rtw_stop_drv_threads(wlan0) enter
        [ 1348.230582] RTW: rtw_xmit_thread(wlan0) Exit
        [ 1348.235476] RTW: rtl8188fs_xmit_thread(wlan0) Exit
        [ 1348.241031] RTW: CheckIPSStatus(): Read 0x100=0xff 0x86=0x00
        [ 1348.247503] RTW: rtw_dev_unload: driver not in IPS
        [ 1348.261738] RTW: SetHwReg: bMacPwrCtrlOn=0
        [ 1348.266381] RTW: SetHwReg: hci_sus_state=3
        [ 1348.271904] RTW: SetHwReg: hci_sus_state=0
        [ 1348.276557] RTW: <== rtw_dev_unload(wlan0)
        [ 1348.281190] RTW: +r871xu_dev_remove, hw_init_completed=0
        [ 1348.287718] RTW: rtw_wdev_free(wdev=ffffffc04e76d000)
        [ 1348.293475] RTW: rtw_drv_free_vir_if(wlan1)
        [ 1348.298580] RTW: rtw_wdev_free(wdev=ffffffc04e76ce00)
        [ 1348.304470] RTW: rtw_wiphy_free(phy2)
        [ 1348.308807] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
        [ 1348.314826] platform_wifi_power_off===== 1
        [ 1348.420687] RTW: platform_wifi_power_off: remove card, power off.
        [ 1348.427600] RTW: rtw_inetaddr_notifier_unregister
        [ 1348.449525] RTW: module exit success
        [ 1356.216530] healthd: battery none chg=au
        [ 1366.238860] healthd: battery none chg=au
        [ 1376.269096] healthd: battery none chg=au
        [ 1386.300625] healthd: battery none chg=au
        [ 1396.323567] healthd: battery none chg=au
        --------- beginning of system
        12-18 16:14:24.271 2040 2370 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
        12-18 16:14:24.271 2040 2370 D PackageManager: Clear ephemeral installer activity
        --------- beginning of main
        12-18 16:14:24.247 1829 3236 I chatty : uid=1041(audioserver) writer expire 4 lines
        12-18 16:14:24.269 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:24.276 2327 3296 D SettingsActivity: Enabled state changed for some tiles, reloading all categories {com.android.settings/com.android.settings.Settings$PowerUsageSummaryActivity},
        12-18 16:14:24.284 2327 4841 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
        12-18 16:14:24.290 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:24.482 1829 3236 I chatty : uid=1041(audioserver) writer identical 9 lines
        12-18 16:14:24.503 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:24.515 1840 1840 I AW_PowerHAL_Platform: ==NORMAL MODE==
        12-18 16:14:24.515 1840 1840 D AW_PowerHAL: c-s = 18
        12-18 16:14:24.524 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:25.165 1829 3236 I chatty : uid=1041(audioserver) writer identical 30 lines
        12-18 16:14:25.186 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:25.205 2040 2069 E system_server: No package ID 7f found for ID 0x7f08024a.
        12-18 16:14:25.206 2040 2069 E system_server: No package ID 7f found for ID 0x7f1211a1.
        12-18 16:14:25.206 2040 2069 E system_server: No package ID 7f found for ID 0x7f080249.
        12-18 16:14:25.206 2040 2069 E system_server: No package ID 7f found for ID 0x7f1204e0.
        12-18 16:14:25.206 2040 2069 E system_server: No package ID 7f found for ID 0x7f080248.
        12-18 16:14:25.206 2040 2069 E system_server: No package ID 7f found for ID 0x7f120afa.
        12-18 16:14:25.208 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:25.213 2268 2268 E PhoneInterfaceManager: [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
        12-18 16:14:25.213 2268 2268 D CarrierSvcBindHelper: No carrier app for: 0
        12-18 16:14:25.226 2327 4841 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
        12-18 16:14:25.229 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:25.235 2040 2040 D DeviceIdleController: find package null
        12-18 16:14:25.248 2040 2140 I InputReader: Reconfiguring input devices. changes=0x00000010
        12-18 16:14:25.250 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:25.269 2040 2040 I Telecom : DefaultDialerCache: Refreshing default dialer for user 0: now null: DDC.oR@AAw
        12-18 16:14:25.286 2040 2069 W VoiceInteractionManagerService: no available voice interaction services found for user 0
        12-18 16:14:26.050 2040 2598 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
        12-18 16:14:27.128 1829 3236 I chatty : uid=1041(audioserver) writer identical 88 lines
        12-18 16:14:27.150 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:27.159 1829 1829 D audio_hw_primary: out_standby
        12-18 16:14:31.546 2327 2327 W SettingsMetricsFeature: action(Pair<Integer, Object>... taggedData) is deprecated, Use action(int, int, int, String, int) instead.
        12-18 16:14:31.549 2040 3190 I WifiService: setWifiEnabled package=com.android.settings uid=1000 enable=true
        12-18 16:14:31.550 2040 2149 D WifiController: StaEnabledState.enter()
        12-18 16:14:31.551 2040 2150 D WifiActiveModeWarden: received a message in WifiDisabledState: { when=-1ms what=0 target=com.android.internal.util.StateMachine$SmHandler }
        12-18 16:14:31.551 2040 2150 D WifiActiveModeWarden: Switching from WifiDisabledState to ClientMode
        12-18 16:14:31.551 2040 2150 D WifiActiveModeWarden: Entering ClientModeActiveState
        12-18 16:14:31.557 1829 3236 D audio_hw_primary: start_output_stream
        12-18 16:14:31.557 1829 3236 V audio_platform: disable backend pcm(direction:PCM_OUT)
        12-18 16:14:31.557 1829 3236 D audio_route: Apply path: out-reset
        12-18 16:14:31.558 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:31.558 1829 3236 D audio_route: Apply path: media-speaker
        12-18 16:14:31.558 1829 3236 D audio_hw_primary: select device(out):pdev:OUT_DULSPK, path:media-speaker
        12-18 16:14:31.559 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:31.559 1829 3236 D audio_hw_primary: +++++++++++++++ start_output_stream: pcm sample_rate: 48000,pcm fmt: 0x00000000,pcm channels: 2
        12-18 16:14:31.560 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:31.560 2040 2150 D WifiClientModeManager: entering IdleState
        12-18 16:14:31.560 2040 2150 D WifiActiveModeWarden: State changed from client mode. state = 2
        12-18 16:14:31.568 2040 2040 D WifiP2pService: Wifi enabled=false, P2P Interface availability=true
        12-18 16:14:31.577 2040 2150 I ServiceManagement: getService: Trying again for android.hardware.wifi@1.0::IWifi/default...
        12-18 16:14:31.638 1835 1990 D sunxihwc: checkPerformance: PerfMonitor total[w]: 75 acquire: 1 submit: 0 release: 74
        12-18 16:14:31.655 4861 4861 I android.hardware.wifi@1.0-service-lazy: Wifi Hal is booting up...
        12-18 16:14:31.656 4861 4861 I android.hardware.wifi@1.0-service-lazy: Registering HAL: android.hardware.wifi@1.3::IWifi with name: default
        12-18 16:14:31.658 2040 2491 D HalDevMgr: IWifi registration notification: fqName=android.hardware.wifi@1.0::IWifi, name=default, preexisting=false
        12-18 16:14:31.658 4861 4861 I ServiceManagement: Registered android.hardware.wifi@1.3::IWifi/default (start delay of 65ms)
        12-18 16:14:31.658 4861 4861 I ServiceManagement: Removing namespace from process name android.hardware.wifi@1.0-service-lazy to wifi@1.0-service-lazy.
        12-18 16:14:31.660 2040 2150 I android_os_HwBinder: HwBinder: Starting thread pool for getting: android.hardware.wifi@1.0::IWifi/default
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Start to load wireless module hardware info table...
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [01], ID: 0x00018179, Name: rtl8189es.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [02], ID: 0x0001B723, Name: rtl8723bs_vq0.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [03], ID: 0x0001B703, Name: rtl8723cs.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [04], ID: 0x0001D723, Name: rtl8723ds.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [05], ID: 0x00008179, Name: rtl8188etv.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [06], ID: 0x00000179, Name: rtl8188eu.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [07], ID: 0x0000818B, Name: rtl8192eu.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [08], ID: 0x0000B720, Name: rtl8723bu.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [09], ID: 0x0001F179, Name: rtl8189fs.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [10], ID: 0x0001B822, Name: rtl88x2bs.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [11], ID: 0x0001A9A6, Name: ap6212.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [12], ID: 0x00014330, Name: ap6330.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [13], ID: 0x00014356, Name: ap6356s.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [14], ID: 0x0001A9BF, Name: ap6255.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [15], ID: 0x00012281, Name: xr819.
        12-18 16:14:31.668 4861 4861 D WifiHWInfo: Entry [16], ID: 0x00012282, Name: xr829.
        12-18 16:14:31.669 4861 4861 D WifiHWInfo: Entry [17], ID: 0x0001050A, Name: qca6174a.
        12-18 16:14:31.669 4861 4861 D WifiHWInfo: Entry [18], ID: 0x00013030, Name: ssv6x5x.
        12-18 16:14:31.669 4861 4861 D WifiHWInfo: Entry [19], ID: 0x00010000, Name: uwe5622.
        12-18 16:14:31.669 4861 4861 D WifiHWInfo: Entry [20], ID: 0x00010145, Name: aic8800.
        12-18 16:14:31.669 4861 4861 D WifiHWInfo: Entry [21], ID: 0x000018F0, Name: dummy.
        12-18 16:14:31.669 4861 4861 I android.hardware.wifi@1.0-service-lazy: Driver 8189fs not load? I'm not sure.
        12-18 16:14:31.669 4861 4861 D wifi_hal-auto-detect: libwifi hal name: libwifi-hal-rtk.so
        12-18 16:14:31.671 4861 4861 I android.hardware.wifi@1.0-service-lazy: Wifi HAL started
        12-18 16:14:31.672 2040 2150 I WifiVendorHal: Vendor Hal started successfully
        12-18 16:14:31.673 2040 2150 I SupplicantStaIfaceHal: Starting supplicant using HIDL
        12-18 16:14:31.673 2040 2151 I WifiP2pNative: Registering for interface available listener
        12-18 16:14:31.675 2040 2150 D SupplicantStaIfaceHal: Successfully triggered start of supplicant using HIDL
        12-18 16:14:31.678 2040 2151 I WifiP2pNative: Registering for interface available listener
        12-18 16:14:31.678 2040 2151 D WifiP2pNative: P2P InterfaceAvailableListener true
        12-18 16:14:31.678 2040 2151 D WifiP2pService: Wifi enabled=false, P2P Interface availability=true, Number of clients=1
        12-18 16:14:31.763 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:31.774 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:31.780 4864 4864 D wpa_supplicant: wpa_supplicant v2.8-devel-10
        12-18 16:14:31.780 4864 4864 D wpa_supplicant: Global control interface '@android:wpa_wlan0'
        12-18 16:14:31.780 4864 4864 D wpa_supplicant: Using Android control socket 'wpa_wlan0'
        12-18 16:14:31.780 4864 4864 D wpa_supplicant: Initing hidl control
        12-18 16:14:31.780 4864 4864 I wpa_supplicant: Processing hidl events on FD 4
        12-18 16:14:31.783 4864 4864 I ServiceManagement: Registered android.hardware.wifi.supplicant@1.2::ISupplicant/default (start delay of 80ms)
        12-18 16:14:31.783 4864 4864 I wpa_supplicant: Successfully initialized wpa_supplicant
        12-18 16:14:31.783 1847 2007 D AudioFlinger: mixer(0xf6a925c0) throttle end: throttle time(9)
        12-18 16:14:31.784 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:31.785 2040 2491 I android_os_HwBinder: HwBinder: Starting thread pool for getting: android.hardware.wifi.supplicant@1.0::ISupplicant/default
        12-18 16:14:31.785 2040 2491 I SupplicantStaIfaceHal: Completed initialization of ISupplicant.
        12-18 16:14:31.805 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.648 1829 3236 I chatty : uid=1041(audioserver) writer identical 39 lines
        12-18 16:14:32.670 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.673 4861 4861 I WifiHAL : Initializing wifi, version : v1.0.2
        12-18 16:14:32.674 4861 4861 I WifiHAL : Creating socket
        12-18 16:14:32.674 2040 2061 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: false
        12-18 16:14:32.677 4861 4861 I WifiHAL : Initialized Wifi HAL Successfully; vendor cmd = 103
        12-18 16:14:32.677 4861 4861 I android.hardware.wifi@1.0-service-lazy: Adding interface handle for wlan0
        12-18 16:14:32.677 4861 4861 I android.hardware.wifi@1.0-service-lazy: Adding interface handle for wlan1
        12-18 16:14:32.677 4861 4861 W android.hardware.wifi@1.0-service-lazy: No active wlan interfaces in use! Using default
        12-18 16:14:32.678 4861 4861 E android.hardware.wifi@1.0-service-lazy: Failed to register radio mode change callback
        12-18 16:14:32.678 4861 4861 W android.hardware.wifi@1.0-service-lazy: No active wlan interfaces in use! Using default
        12-18 16:14:32.678 4861 4861 E WifiHAL : Failed to register debug response; result = -95
        12-18 16:14:32.678 4861 4861 E android.hardware.wifi@1.0-service-lazy: Failed to get driver version: SUCCESS
        12-18 16:14:32.678 4861 4861 I android.hardware.wifi@1.0-service-lazy: Configured chip in mode 0
        12-18 16:14:32.680 2040 2150 D HalDevMgr: updateRttController: no one is interested in RTT controllers
        12-18 16:14:32.681 4861 4861 E android.hardware.wifi@1.0-service-lazy: Failed to set DFS flag; DFS channels may be unavailable.
        12-18 16:14:32.692 2040 2150 D WificondControl: Setting up interface for client mode
        12-18 16:14:32.693 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.696 1895 1895 I wificond: create scanner for interface with index: 14
        12-18 16:14:32.696 1895 1895 I wificond: subscribe scan result for interface with index: 14
        12-18 16:14:32.698 1674 1674 I hwservicemanager: getTransport: Cannot find entry android.hardware.wifi.offload@1.0::IOffload/default in either framework or device manifest.
        12-18 16:14:32.699 1895 1895 E wificond: No Offload Service available
        12-18 16:14:32.699 1895 1895 I wificond: Offload HAL not supported
        12-18 16:14:32.702 2040 2150 E SupplicantStaIfaceHal: Can't call setupIface, ISupplicantStaIface is null
        12-18 16:14:32.707 2040 2150 I android_os_HwBinder: HwBinder: Starting thread pool for getting: android.hardware.wifi.supplicant@1.0::ISupplicant/default
        12-18 16:14:32.709 4864 4864 D wpa_supplicant: Override interface parameter: ctrl_interface ('(null)' -> '/data/vendor/wifi/wpa/sockets')
        12-18 16:14:32.709 4864 4864 D wpa_supplicant: Initializing interface 'wlan0' conf '/data/vendor/wifi/wpa/wpa_supplicant.conf' driver 'nl80211' ctrl_interface '/data/vendor/wifi/wpa/sockets' bridge 'N/A'
        12-18 16:14:32.709 4864 4864 D wpa_supplicant: Configuration file '/data/vendor/wifi/wpa/wpa_supplicant.conf' -> '/data/vendor/wifi/wpa/wpa_supplicant.conf'
        12-18 16:14:32.709 4864 4864 D wpa_supplicant: Reading configuration file '/data/vendor/wifi/wpa/wpa_supplicant.conf'
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: update_config=1
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: eapol_version=1
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: ap_scan=1
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: fast_reauth=1
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: pmf=1
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: p2p_add_cli_chan=1
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: Line: 7 - start of a new network block
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: ssid - hexdump(len=7): 5a 48 4b 4a 5f 41 50
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: PSK (ASCII passphrase) - hexdump(len=8): [REMOVED]
        12-18 16:14:32.710 4864 4864 D wpa_supplicant: key_mgmt: 0x2
        12-18 16:14:32.712 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.728 4864 4864 D wpa_supplicant: PSK (from passphrase) - hexdump(len=32): [REMOVED]
        12-18 16:14:32.728 4864 4864 D wpa_supplicant: Priority group 0
        12-18 16:14:32.728 4864 4864 D wpa_supplicant: id=0 ssid='ZHKJ_AP'
        12-18 16:14:32.728 4864 4864 D wpa_supplicant: Reading configuration file '/vendor/etc/wifi/wpa_supplicant_overlay.conf'
        12-18 16:14:32.729 4864 4864 D wpa_supplicant: disable_scan_offload=1
        12-18 16:14:32.729 4864 4864 D wpa_supplicant: wowlan_triggers='any'
        12-18 16:14:32.729 4864 4864 D wpa_supplicant: p2p_disabled=0
        12-18 16:14:32.729 4864 4864 D wpa_supplicant: filter_rssi=-75
        12-18 16:14:32.729 4864 4864 D wpa_supplicant: no_ctrl_interface -> ctrl_interface=NULL
        12-18 16:14:32.729 4864 4864 D wpa_supplicant: Priority group 0
        12-18 16:14:32.729 4864 4864 D wpa_supplicant: id=0 ssid='ZHKJ_AP'
        12-18 16:14:32.733 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.735 4864 4864 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:1
        12-18 16:14:32.735 4864 4864 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:5
        12-18 16:14:32.735 4864 4864 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:2
        12-18 16:14:32.735 4864 4864 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:4
        12-18 16:14:32.735 4864 4864 D wpa_supplicant: nl80211: Supported cipher 00-0f-ac:6
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4106
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4107
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: Use separate P2P group interface (driver advertised support)
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: interface wlan0 in phy phy2
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: Set mode ifindex 14 iftype 2 (STATION)
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: Subscribe to mgmt frames with non-AP handle 0xe7484ce8
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xe7484ce8 match=
        12-18 16:14:32.736 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0104
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=040a
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=040b
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=040c
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=040d
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=090a
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=090b
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=090c
        12-18 16:14:32.737 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=090d
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0409506f9a09
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=7f506f9a09
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0409506f9a1a
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0801
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=06
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0a07
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0a11
        12-18 16:14:32.738 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0a0b
        12-18 16:14:32.739 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0a1a
        12-18 16:14:32.739 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=1101
        12-18 16:14:32.739 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=1102
        12-18 16:14:32.739 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0505
        12-18 16:14:32.739 4864 4864 D wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xe7484ce8 match=0500
        12-18 16:14:32.743 4864 4864 I wpa_supplicant: rfkill: Cannot open RFKILL control device
        12-18 16:14:32.743 4864 4864 D wpa_supplicant: nl80211: RFKILL status not available
        12-18 16:14:32.744 4864 4864 D wpa_supplicant: netlink: Operstate: ifindex=14 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
        12-18 16:14:32.745 2040 2061 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: false
        12-18 16:14:32.747 4864 4864 D wpa_supplicant: Add interface wlan0 to a new radio phy2
        12-18 16:14:32.748 4864 4864 D wpa_supplicant: nl80211: Regulatory information - country=99
        12-18 16:14:32.748 4864 4864 D wpa_supplicant: nl80211: 2402-2472 @ 40 MHz 20 mBm
        12-18 16:14:32.748 4864 4864 D wpa_supplicant: nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
        12-18 16:14:32.749 4864 4864 D wpa_supplicant: nl80211: Added 802.11b mode based on 802.11g information
        12-18 16:14:32.749 4864 4864 D wpa_supplicant: nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED]
        12-18 16:14:32.749 4864 4864 D wpa_supplicant: nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED]
        12-18 16:14:32.754 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.773 4864 4864 D wpa_supplicant: wlan0: Own MAC address: 00:e0:4c:64:1e:8e
        12-18 16:14:32.773 4864 4864 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=14 (wlan0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
        12-18 16:14:32.773 4864 4864 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=14 (wlan0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
        12-18 16:14:32.773 4864 4864 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=14 (wlan0) alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
        12-18 16:14:32.774 4864 4864 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=14 (wlan0) alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
        12-18 16:14:32.774 4864 4864 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=14 (wlan0) alg=0 addr=0x0 key_idx=4 set_tx=0 seq_len=0 key_len=0
        12-18 16:14:32.774 4864 4864 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=14 (wlan0) alg=0 addr=0x0 key_idx=5 set_tx=0 seq_len=0 key_len=0
        12-18 16:14:32.774 4864 4864 D wpa_supplicant: wlan0: RSN: flushing PMKID list in the driver
        12-18 16:14:32.774 4864 4864 D wpa_supplicant: nl80211: Flush PMKIDs
        12-18 16:14:32.776 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.796 4864 4864 D wpa_supplicant: TDLS: TDLS operation not supported by driver
        12-18 16:14:32.796 4864 4864 D wpa_supplicant: TDLS: Driver uses internal link setup
        12-18 16:14:32.796 4864 4864 D wpa_supplicant: TDLS: Driver does not support TDLS channel switching
        12-18 16:14:32.796 4864 4864 D wpa_supplicant: wlan0: WPS: UUID based on MAC address: 088a91dc-fdb1-53ea-b0c9-81411ab2240a
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: EAP: EAP entering state DISABLED
        12-18 16:14:32.797 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: P2P: Add operating class 81
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: P2P: Add operating class 81 (client only)
        12-18 16:14:32.797 4864 4864 D wpa_supplicant: P2P: Channels - hexdump(len=11): 01 02 03 04 05 06 07 08 09 0a 0b
        12-18 16:14:32.798 4864 4864 D wpa_supplicant: P2P: Channels (client only) - hexdump(len=2): 0c 0d
        12-18 16:14:32.798 4864 4864 D wpa_supplicant: P2P: Own listen channel: 81:1
        12-18 16:14:32.798 4864 4864 D wpa_supplicant: P2P: Random operating channel: 81:6
        12-18 16:14:32.798 4864 4864 D wpa_supplicant: P2P: initialized
        12-18 16:14:32.798 4864 4864 D wpa_supplicant: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11
        12-18 16:14:32.798 4864 4864 D wpa_supplicant: P2P: cli_channels: 81:12,13
        12-18 16:14:32.798 4864 4864 D wpa_supplicant: nl80211: Setting wowlan
        12-18 16:14:32.799 4864 4864 D wpa_supplicant: Registering interface to hidl control: wlan0
        12-18 16:14:32.799 4864 4864 D wpa_supplicant: Registering network to hidl control: 0
        12-18 16:14:32.799 4864 4864 D wpa_supplicant: wlan0: Added interface wlan0
        12-18 16:14:32.799 4864 4864 D wpa_supplicant: wlan0: State: DISCONNECTED -> DISCONNECTED
        12-18 16:14:32.799 4864 4864 D wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
        12-18 16:14:32.799 4864 4864 D wpa_supplicant: netlink: Operstate: ifindex=14 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
        12-18 16:14:32.799 4864 4864 D wpa_supplicant: RTM_NEWLINK: ifi_index=14 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP])
        12-18 16:14:32.799 2040 2150 E SupplicantStaIfaceHal: Failed to create ISupplicantIface 1
        12-18 16:14:32.799 2040 2150 E SupplicantStaIfaceHal: setupIface got null iface
        12-18 16:14:32.799 2040 2150 E WifiNative: Failed to setup iface in supplicant on Iface:{Name=wlan0,Id=3,Type=STA_CONNECTIVITY}
        12-18 16:14:32.801 4861 4861 W android.hardware.wifi@1.0-service-lazy: No active wlan interfaces in use! Using default
        12-18 16:14:32.803 2040 2150 E WifiNative: Failed to unregister network observer on Iface:{Name=wlan0,Id=3,Type=STA_CONNECTIVITY}
        12-18 16:14:32.803 2040 2150 E SupplicantStaIfaceHal: Can't call teardownIface, ISupplicantStaIface is null
        12-18 16:14:32.803 2040 2150 E WifiNative: Failed to teardown iface in supplicant on Iface:{Name=wlan0,Id=3,Type=STA_CONNECTIVITY}
        12-18 16:14:32.804 1895 1895 I wificond: Unsubscribe scan result for interface with index: 14
        12-18 16:14:32.818 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.863 1829 3236 I chatty : uid=1041(audioserver) writer identical 2 lines
        12-18 16:14:32.884 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.906 4864 4864 D wpa_supplicant: RTM_NEWLINK: ifi_index=14 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1002 ()
        12-18 16:14:32.907 4864 4864 D wpa_supplicant: nl80211: Interface down (wlan0/wlan0)
        12-18 16:14:32.907 4864 4864 D wpa_supplicant: wlan0: Event INTERFACE_DISABLED (26) received
        12-18 16:14:32.907 4864 4864 D wpa_supplicant: wlan0: Interface was disabled
        12-18 16:14:32.907 4864 4864 D wpa_supplicant: nl80211: Data frame filter flags=0x0
        12-18 16:14:32.907 4864 4864 D wpa_supplicant: wlan0: State: DISCONNECTED -> DISCONNECTED
        12-18 16:14:32.907 4864 4864 D wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
        12-18 16:14:32.907 4864 4864 D wpa_supplicant: netlink: Operstate: ifindex=14 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
        12-18 16:14:32.908 2040 2061 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: false
        12-18 16:14:32.912 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.914 2040 2150 I SupplicantStaIfaceHal: Terminating supplicant using HIDL
        12-18 16:14:32.925 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.946 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.962 4864 4864 D wpa_supplicant: EAPOL: External notification - portEnabled=0
        12-18 16:14:32.962 4864 4864 D wpa_supplicant: EAPOL: External notification - portValid=0
        12-18 16:14:32.962 4864 4864 D wpa_supplicant: wlan0: State: DISCONNECTED -> INTERFACE_DISABLED
        12-18 16:14:32.962 4864 4864 D wpa_supplicant: Notifying state change event to hidl control: 1
        12-18 16:14:32.962 4864 4864 D wpa_supplicant: wlan0: Determining shared radio frequencies (max len 1)
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: wlan0: Shared frequencies (len=0): completed iteration
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: P2P: Add operating class 81
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: P2P: Add operating class 81 (client only)
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: P2P: Channels - hexdump(len=11): 01 02 03 04 05 06 07 08 09 0a 0b
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: P2P: Channels (client only) - hexdump(len=2): 0c 0d
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: P2P: Update channel list
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: P2P: cli_channels: 81:12,13
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: nl80211: Event message available
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: nl80211: Drv Event 48 (NL80211_CMD_DISCONNECT) received for wlan0
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: nl80211: Disconnect event
        12-18 16:14:32.963 2040 2150 I android_os_HwBinder: HwBinder: Starting thread pool for getting: android.hardware.wifi.supplicant@1.0::ISupplicant/default
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: wlan0: Ignore event DEAUTH (11) while interface is disabled
        12-18 16:14:32.963 4864 4864 D wpa_supplicant: l2_packet_receive - recvfrom: Network is down
        12-18 16:14:32.965 2040 2150 D WificondControl: tearing down interfaces in wificond
        12-18 16:14:32.965 4864 4864 I wpa_supplicant: Terminating...
        12-18 16:14:32.965 4864 4864 D wpa_supplicant: wlan0: Removing interface wlan0
        12-18 16:14:32.965 4864 4864 D wpa_supplicant: wlan0: Request to deauthenticate - bssid=00:00:00:00:00:00 pending_bssid=00:00:00:00:00:00 reason=3 state=INTERFACE_DISABLED
        12-18 16:14:32.965 4864 4864 D wpa_supplicant: TDLS: Tear down peers
        12-18 16:14:32.965 4864 4864 D wpa_supplicant: nl80211: Data frame filter flags=0x0
        12-18 16:14:32.968 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:32.973 4864 4864 D wpa_supplicant: Deregistering network from hidl control: 0
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: wlan0: WPA: Clear old PMK and PTK
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: wlan0: Cancelling scan request
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: wlan0: Cancelling authentication timeout
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: Off-channel: Clear pending Action frame TX (pending_action_tx=0x0
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: nl80211: Data frame filter flags=0x0
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: HS20: Delete all stored icons
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: Off-channel: Action frame sequence done notification: pending_action_tx=0x0 drv_offchan_tx=0 action_tx_wait_time=0 off_channel_freq=0 roc_waiting_drv_freq=0
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: wlan0: P2P: Disable P2P since removing the management interface is being removed
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: P2P: All ASP advertisements flushed
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: P2P: Disabling Extended Listen Timing
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: P2P: Stopping find
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: P2P: Clear timeout (state=IDLE)
        12-18 16:14:32.981 4864 4864 D wpa_supplicant: P2P: State IDLE -> IDLE
        12-18 16:14:32.981 4864 4864 D WifiHWInfo: Start to load wireless module hardware info table...
        12-18 16:14:32.981 4864 4864 D WifiHWInfo: Entry [01], ID: 0x00018179, Name: rtl8189es.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [02], ID: 0x0001B723, Name: rtl8723bs_vq0.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [03], ID: 0x0001B703, Name: rtl8723cs.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [04], ID: 0x0001D723, Name: rtl8723ds.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [05], ID: 0x00008179, Name: rtl8188etv.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [06], ID: 0x00000179, Name: rtl8188eu.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [07], ID: 0x0000818B, Name: rtl8192eu.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [08], ID: 0x0000B720, Name: rtl8723bu.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [09], ID: 0x0001F179, Name: rtl8189fs.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [10], ID: 0x0001B822, Name: rtl88x2bs.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [11], ID: 0x0001A9A6, Name: ap6212.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [12], ID: 0x00014330, Name: ap6330.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [13], ID: 0x00014356, Name: ap6356s.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [14], ID: 0x0001A9BF, Name: ap6255.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [15], ID: 0x00012281, Name: xr819.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [16], ID: 0x00012282, Name: xr829.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [17], ID: 0x0001050A, Name: qca6174a.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [18], ID: 0x00013030, Name: ssv6x5x.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [19], ID: 0x00010000, Name: uwe5622.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [20], ID: 0x00010145, Name: aic8800.
        12-18 16:14:32.982 4864 4864 D WifiHWInfo: Entry [21], ID: 0x000018F0, Name: dummy.
        12-18 16:14:32.982 4864 4864 W wpa_supplicant: check_initialed for nl80211, use realtek wpa_supplicant_8_lib.
        12-18 16:14:32.982 4864 4864 D wpa_supplicant: rtl_wpa_driver_set_ap_wps_p2p_ie: Entry
        12-18 16:14:32.982 4864 4864 D wpa_supplicant: P2P: All ASP advertisements flushed
        12-18 16:14:32.982 4864 4864 D wpa_supplicant: Remove interface wlan0 from radio phy2
        12-18 16:14:32.982 4864 4864 D wpa_supplicant: Remove radio phy2
        12-18 16:14:32.982 4864 4864 I wpa_supplicant: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
        12-18 16:14:32.983 4861 4870 E WifiHAL : wifi_event_loop: Read after POLL returned 4, error no = 0 (Success)
        12-18 16:14:32.983 4861 4870 D WifiHAL : Got a signal to exit!!!
        12-18 16:14:32.983 4861 4870 I WifiHAL : Exit wifi_event_loop
        12-18 16:14:32.983 4861 4861 E WifiHAL : wifi_cleanup: Read after POLL returned 4, error no = 0 (Success)
        12-18 16:14:32.983 4861 4861 E WifiHAL : Event processing terminated
        12-18 16:14:32.983 4861 4861 I android.hardware.wifi@1.0-service-lazy: Legacy HAL stop complete callback received
        12-18 16:14:32.983 4861 4861 I WifiHAL : Internal cleanup completed
        12-18 16:14:32.984 4861 4861 I android.hardware.wifi@1.0-service-lazy: Driver 8189fs not load? I'm not sure.
        12-18 16:14:32.995 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.009 4864 4864 D wpa_supplicant: nl80211: Remove monitor interface: refcount=0
        12-18 16:14:33.009 4864 4864 D wpa_supplicant: netlink: Operstate: ifindex=14 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
        12-18 16:14:33.010 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.032 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.034 4864 4864 D wpa_supplicant: nl80211: Set mode ifindex 14 iftype 2 (STATION)
        12-18 16:14:33.034 4864 4864 D wpa_supplicant: nl80211: Failed to set interface 14 to mode 2: -19 (No such device)
        12-18 16:14:33.034 2040 2185 D EthernetNetworkFactory: updateCapabilityFilter: []
        12-18 16:14:33.034 4864 4864 D wpa_supplicant: nl80211: Unsubscribe mgmt frames handle 0x6fc0c461 (deinit)
        12-18 16:14:33.034 4864 4864 D wpa_supplicant: Deregistering interface from hidl control: wlan0
        12-18 16:14:33.034 4864 4864 I wpa_supplicant: wlan0: CTRL-EVENT-TERMINATING
        12-18 16:14:33.034 4864 4864 D wpa_supplicant: Deiniting hidl control
        12-18 16:14:33.036 2040 2144 W BestClock: java.time.DateTimeException: Missing NTP fix
        12-18 16:14:33.053 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.066 1825 1950 I netd : trafficSwapActiveStatsMap() <29.12ms>
        12-18 16:14:33.069 1825 1950 I netd : tetherGetStats() <1.74ms>
        12-18 16:14:33.073 2040 2144 W BestClock: java.time.DateTimeException: Missing NTP fix
        12-18 16:14:33.074 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.075 2040 2145 W BestClock: java.time.DateTimeException: Missing NTP fix
        12-18 16:14:33.096 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.117 1829 3236 I chatty : uid=1041(audioserver) writer identical 1 line
        12-18 16:14:33.138 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.152 2040 2185 D EthernetNetworkFactory: updateCapabilityFilter: []
        12-18 16:14:33.160 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.672 1829 3236 I chatty : uid=1041(audioserver) writer identical 24 lines
        12-18 16:14:33.694 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.706 1674 1674 I hwservicemanager: Notifying android.hardware.wifi@1.3::IWifi/default they have clients: 1
        12-18 16:14:33.715 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:33.510 4861 4861 I android.hardware.wifi@1.0-service-lazy: Driver 8189fs not load? I'm not sure.
        12-18 16:14:34.012 4861 4861 I android.hardware.wifi@1.0-service-lazy: Wifi HAL stopped
        12-18 16:14:34.012 4861 4861 I android.hardware.wifi@1.0-service-lazy: Process has 1 (of 1 available) client(s) in use after notification android.hardware.wifi@1.3::IWifi has clients: 1
        12-18 16:14:33.992 1829 3236 I chatty : uid=1041(audioserver) writer identical 13 lines
        12-18 16:14:34.014 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:34.014 2040 2150 I WifiVendorHal: Vendor Hal stopped
        12-18 16:14:34.014 2040 2150 I WifiNative: Successfully torn down Iface:{Name=wlan0,Id=3,Type=STA_CONNECTIVITY}
        12-18 16:14:34.014 2040 2150 E HalDevMgr: getAllChipInfo: called but mWifi is null!?
        12-18 16:14:34.015 2040 2150 E HalDevMgr: dispatchAvailableForRequestListeners: no chip info found
        12-18 16:14:34.015 2040 2150 W HalDevMgr: stopWifi called but mWifi is null!?
        12-18 16:14:34.015 2040 2150 I WifiNative: Successfully initiated teardown for iface=wlan0
        12-18 16:14:34.015 2040 2151 W HalDevMgr: isWifiStarted called but mWifi is null!?
        12-18 16:14:34.015 2040 2150 E WifiClientModeManager: Failed to create ClientInterface. Sit in Idle
        12-18 16:14:34.015 2040 2150 D WifiActiveModeWarden: State changed from client mode. state = 4
        12-18 16:14:34.015 2040 2150 D WifiClientModeManager: expected stop, not triggering callbacks: newState = 1
        12-18 16:14:34.017 2040 2150 E WifiNative: Could not get Iface object for interface null
        12-18 16:14:34.017 2040 2040 D WifiP2pService: Wifi enabled=false, P2P Interface availability=true
        12-18 16:14:34.017 2040 2150 W HalDevMgr: isWifiStarted called but mWifi is null!?
        12-18 16:14:34.018 2040 2150 W HalDevMgr: isWifiStarted called but mWifi is null!?
        12-18 16:14:34.018 2040 2150 W SupplicantStaIfaceHal: ISupplicant died: cookie=3
        12-18 16:14:34.019 2040 2150 W HalDevMgr: isWifiStarted called but mWifi is null!?
        12-18 16:14:34.019 2040 2150 D WifiActiveModeWarden: ClientMode failed, return to WifiDisabledState.
        12-18 16:14:34.020 2040 2150 D WifiController: ClientMode unexpected failure: state unknown
        12-18 16:14:34.020 2040 2150 D WifiClientModeManager: currentstate: IdleState
        12-18 16:14:34.021 2040 2155 I WifiScanningService: wifi driver unloaded
        12-18 16:14:34.022 2040 2150 D WifiScanRequestProxy: Sending scan available broadcast: false
        12-18 16:14:34.023 2040 2150 I WifiScanRequestProxy: Scanning is disabled
        12-18 16:14:34.024 2040 2150 D WifiActiveModeWarden: Entering WifiDisabledState
        12-18 16:14:34.025 2040 2150 D WifiActiveModeWarden: received a message in WifiDisabledState: { when=-5ms what=3 target=com.android.internal.util.StateMachine$SmHandler }
        12-18 16:14:34.025 2040 2150 D WifiActiveModeWarden: Switching from WifiDisabledState to WifiDisabled
        12-18 16:14:34.025 2040 2150 D WifiActiveModeWarden: Entering WifiDisabledState
        12-18 16:14:34.025 2040 2150 E WifiNative: Could not get Iface object for interface null
        12-18 16:14:34.035 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:34.888 1829 3236 I chatty : uid=1041(audioserver) writer identical 40 lines
        12-18 16:14:34.909 1829 3236 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
        12-18 16:14:34.920 1829 1829 D audio_hw_primary: out_standby
          zdq_123 LV 3 最后由 编辑
            darwin LV 4 最后由 编辑
            我也遇到这种问题,请问解决了没有?
