    A527 neon加速测试
    A Series
      a502849625 LV 2 最后由 编辑
      在A527下测试了一下neon加速的效果。
      计算res=(a+3.4)*3.1。
      # include <iostream>
      # include <chrono>
      # include <random>
      # include <arm_neon.h>
        float *data_tmp = new float[1080 * 720 * 3];
        std::default_random_engine e;
        std::uniform_real_distribution<float> u(0, 255);
        for(int i = 0; i < 1080 * 720 * 3; ++i) {
          *(data_tmp + i) = u(e);
        float *data = data_tmp;
        float *data_res1 = new float[1080 * 720 * 3];
        float *data_tmp1 = data_res1;
        std::chrono::microseconds start_time = std::chrono::duration_cast<std::chrono::microseconds>(
          std::chrono::system_clock::now().time_since_epoch()
          *data_res1 = ((*data) + 3.4 ) * 3.1;
          ++data_res1;
          ++data;
        std::chrono::microseconds end_time = std::chrono::duration_cast<std::chrono::microseconds>(
        std::cout << "cost total time : " << (end_time - start_time).count() << " microseconds  -- common method" << std::endl;
        data = data_tmp;
        float *data_res2 = new float[1080 * 720 * 3];
        float *data_tmp2 = data_res2;
        float32x4_t A = vdupq_n_f32(3.4);
        float32x4_t B = vdupq_n_f32(3.1);
        for(int i = 0; i < 1080 * 720 * 3 / 4; ++i) {
          float32x4_t C = vld1q_f32(data);
          float32x4_t D = vmulq_f32(vaddq_f32(C, A), B);
          vst1q_f32(data_res2, D);
          data = data + 4;
          data_res2 = data_res2 + 4;
        std::cout << "cost total time : " << (end_time - start_time).count() << " microseconds  -- neon method" << std::endl;
        data = data_tmp;
        float *data_res3 = new float[1080 * 720 * 3];
        float *data_tmp3 = data_res3;
        A = vdupq_n_f32(10.54);
          float32x4_t D = vmlaq_f32(A, B, C);
          vst1q_f32(data_res3, D);
          data = data + 4;
          data_res3 = data_res2 + 4;
        for(int i = 0; i < 1; ++i) {
          std::cout << "data[" << i << "]:" <<data_tmp[i] << std::endl;
          std::cout << "data_res1[" << i << "]:" <<data_tmp1[i] << std::endl;
          std::cout << "data_res2[" << i << "]:" <<data_tmp2[i] << std::endl;
          std::cout << "data_res3[" << i << "]:" <<data_tmp3[i] << std::endl;
      测试结果
      cost total time : 47286 microseconds  -- common method
      cost total time : 26103 microseconds  -- neon method
      data[0]:0.00199561
      data_res1[0]:10.5462
      data_res2[0]:10.5462
      data_res3[0]:10.5462
      cost total time : 19555 microseconds  -- neon method
      手动计算转成乘加后,比普通C++速度提升了59%。
      • Moved from T Series by  xiaowenge xiaowenge
