    【FAQ】全志R329出现以太网使能报No phy found或Initialize hardware error怎么解决?
    r329 faq 技术支持 网络
      1.【问题现象】
      执行ifconfig eth0 up命令,出现"No phy found"或"Initialize hardware error"异常log,有如下类似打印:
      root@TinaLinux:/# ifconfig eth0 up
      [  130.363159] libphy: gmac0: probed
      [  130.366897] sunxi-gmac gmac0 eth0: No PHY found!
      ifconfig: SIOCSIFFLAGS: Invalid argument
      [   30.109456] libphy: gmac0: probed
      [   30.113921] sunxi-gmac gmac0 eth0: eth0: Type(7) PHY ID 0000ffff at 0 IRQ poll (gmac0-0:00)
      [   30.133308] sunxi-gmac gmac0 eth0: Initialize hardware error
      2.【问题分析】
      • 出现"No phy found",常见原因是供给phy使用的25M时钟异常,导致phy工作不正常,gmac驱动通过mdio接口也读不到phy的设备信息;
      • 出现"Initialize hardware error",一般是由于phy没有输出rx clk至mac控制器,导致mac控制器内部soft reset失败,常见原因是phy供电异常或25M时钟异常;
      3.【排查步骤】
      • 检查phy供电是否正常;
      • 检查phy使用的25M时钟(Soc ephy25M或外部晶振)是否正常;
      • 检查phy-mode是否按板级实际情况配置(mii/rmii/rgmii);
      • 检查phy-rst引脚配置是否正确;
      • 检查phy芯片的rx clk和tx clk引脚信号是否正常,若出现异常,需检查phy外围电路是否符合规范;
      附件:FlameGraph.tar.xz
      • U
        ubuntu LV 7 最后由 编辑
        [   80.396133] libphy: 4500000.eth: probed
        [   80.437613] sunxi-gmac 4500000.eth eth0: eth0: Type(7) PHY ID 001cc816 at 0 IRQ poll (4500000.eth-0:00)
        [   80.508656] sunxi-gmac 4500000.eth eth0: Initialize hardware error
        root@TinaLinux:/#
        U 1 条回复 最后回复 回复 引用 分享 0
        • U
          ubuntu LV 7 @ubuntu 最后由 编辑
          @ubuntu
          root@TinaLinux:/#
          root@TinaLinux:/#
          [   13.062114] libphy: 4500000.eth: probed
          [   13.092260] sunxi-gmac 4500000.eth eth0: eth0: Type(7) PHY ID 001cc816 at 0 IRQ poll (4500000.eth-0:00)
          root@TinaLinux:/#
          root@TinaLinux:/#
          root@TinaLinux:/# udhcpc -i eth0
          udhcpc: started, v1.27.2
          udhcpc: sending discover
          [   16.296790] sunxi-gmac 4500000.eth eth0: Link is Up - 100Mbps/Full - flow control off
          [   16.305630] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          udhcpc: sending select for 192.168.141.169
          udhcpc: lease of 192.168.141.169 obtained, lease time 3599
          udhcpc: ifconfig eth0 192.168.141.169 netmask 255.255.255.0 broadcast 192.168.141.255
          udhcpc: setting default routers: 192.168.141.72
          root@TinaLinux:/#
          拖焊一下D1s搞定了.
