    V851S 初次烧写,无法烧写固件,串口信息如下
      yugit327 LV 2 最后由 xiaowenge 编辑
      00000001	0.00000000	[168] serial, parallel
      00000002	6.63973618	[168] IN 1
      00000003	6.67744255	[168] PnpFelIn  current m_pEfexTool is NULL
      00000004	6.67748308	[168] E:\yolocam\burningtool\AllwinnertechPhoeniSuitRelease20230905.zip\PhoenixSuit_Windows_2.0.0\tools.dll
      00000005	6.67901611	[168] .\image\ASuitImage.cpp release m_pEfexTool 805
      00000006	6.67922735	[168] Img_OpenItem now!
      00000007	6.67924643	[168] Img_OpenItem[PXTOOLSB][XXXXXXXXXXXXXXXX]
      00000008	6.67926359	[168] Closing image now!
      00000009	6.67928600	[168] CloseImage OK
      00000010	6.67940617	[168] The spec_tool.fex file is spec_tool_no.fex.
      00000011	6.67944098	[168] The spec_tool  file is not exist.
      00000012	6.67955112	[168] Img_OpenItem now!
      00000013	6.67956781	[168] Img_OpenItem[PXTOOLSB][XXXXXXXXXXXXXXXX]
      00000014	6.68030977	[168] Closing image now!
      00000015	6.68033361	[168] CloseImage OK
      00000016	6.70990181	[168] ImageTools64 .\image\ASuitImage.cpp 573 0
      00000017	6.71019983	[168] **************************************
      00000018	6.71034813	[168] *********global_info_entry***********
      00000019	6.71050167	[168] **************************************
      00000020	6.71456337	[168] [fel]++++++++RecordDev:\\?\USB#VID_1F3A&PID_EFE8#5&3230a2d8&0&7#{0e57c50f-0ccc-4ad2-a895-93c5ed119860}
      00000021	6.71517658	[168] ********* before Fel2Fes *********
      00000022	6.71541023	[168] ********* pFel2FesParam->extend = 0xefe8da00 *********
      00000023	6.71569538	[168] ***************************************
      00000024	6.71576309	[168] ********ToolEntry_fel************
      00000025	6.71584940	[168] ***************************************
      00000026	6.71586943	[168] PANIC : enter fel choose mode
      00000027	6.71600628	[168] fel other=0x135f90
      00000028	6.71601343	[168] OS SourceCodePage = 936
      00000029	6.71647024	[168] WRN: fail in LoadPluginCenter, f(IniLanPlg)L45
      00000030	6.71650648	[168] WRN: f(exist_multiple_lang_tips)L94, Fail to init plg of iniLan, "Please update LiveSuit"
      00000031	6.72243261	[168] user choose to erase all
      00000032	6.72246790	[168] Img_OpenItem now!
      00000033	6.72251749	[168] Img_OpenItem[FES     ][FES_1-0000000000]
      00000034	6.72262001	[168] down file length = 4de0.
      00000035	6.72276020	[168] magic eGON.BT0踵M, it is fes1
      00000036	6.72285843	[168] down and run fes1 at addr 0x28000
      00000037	6.72344637	[168] Clear dram log OK.
      00000038	6.75976801	[168] DOWN FES1_dram OK
      00000039	7.26924562	[168] dram paras[0]: 0x210
      00000040	7.26934862	[168] dram paras[1]: 0x2
      00000041	7.26944733	[168] dram paras[2]: 0x7b7bf9
      00000042	7.26954317	[168] dram paras[3]: 0x0
      00000043	7.26962662	[168] dram paras[4]: 0xd2
      00000044	7.26970959	[168] dram paras[5]: 0x400000
      00000045	7.26981211	[168] dram paras[6]: 0xe73
      00000046	7.26986074	[168] dram paras[7]: 0x2
      00000047	7.26989508	[168] dram paras[8]: 0x0
      00000048	7.26992655	[168] dram paras[9]: 0x0
      00000049	7.26995659	[168] dram paras[10]: 0x471992
      00000050	7.26998806	[168] dram paras[11]: 0x131a10c
      00000051	7.27002478	[168] dram paras[12]: 0x57041
      00000052	7.27006960	[168] dram paras[13]: 0xb4787896
      00000053	7.27012253	[168] dram paras[14]: 0x0
      00000054	7.27020884	[168] dram paras[15]: 0x48484848
      00000055	7.27029848	[168] dram paras[16]: 0x48
      00000056	7.27033424	[168] dram paras[17]: 0x1621121e
      00000057	7.27036333	[168] dram paras[18]: 0x0
      00000058	7.27039194	[168] dram paras[19]: 0x0
      00000059	7.27042103	[168] dram paras[20]: 0x0
      00000060	7.27044964	[168] dram paras[21]: 0x22
      00000061	7.27047825	[168] dram paras[22]: 0x77
      00000062	7.27050638	[168] dram paras[23]: 0x34006103
      00000063	7.27053499	[168] dram paras[24]: 0x0
      00000064	7.27056408	[168] dram paras[25]: 0x0
      00000065	7.27059221	[168] dram paras[26]: 0x0
      00000066	7.27062082	[168] dram paras[27]: 0x0
      00000067	7.27064896	[168] dram paras[28]: 0x0
      00000068	7.27067757	[168] dram paras[29]: 0x0
      00000069	7.27070618	[168] dram paras[30]: 0x0
      00000070	7.27073526	[168] dram paras[31]: 0x0
      00000071	7.27076340	[168] RUN fes1 OK.
      00000072	7.27079201	[168] INFO: try to down and run fes2
      00000073	7.27080965	[168] Img_OpenItem now!
      00000074	7.27082539	[168] Img_OpenItem[12345678][UBOOT_0000000000]
      00000075	7.27085543	[168] fes2 size 0xe0000
      00000076	7.27111816	[168] uboot down and run addr 0x43000000
      00000077	7.27114868	[168] dtb_syscfg_base 0x43200000
      00000078	8.98388004	[168] INFO: try to down dtb at 0x43200000
      00000079	8.98408794	[168] Img_OpenItem now!
      00000080	8.98423481	[168] Img_OpenItem[COMMON  ][DTB_CONFIG000000]
      00000081	8.98457718	[168] down_dtb_syscfg size 0x19600
      00000082	9.17200565	[168] INFO: try to down soc cfg at 0x43300000
      00000083	9.17205238	[168] Img_OpenItem now!
      00000084	9.17218685	[168] Img_OpenItem[COMMON  ][SYS_CONFIG_BIN00]
      00000085	9.17251587	[168] down_dtb_syscfg size 0x1400
      00000086	9.18285751	[168] INFO: try to down board cfg at 0x43380000
      00000087	9.18294621	[168] Img_OpenItem now!
      00000088	9.18303680	[168] Img_OpenItem[COMMON  ][BOARD_CONFIG_BIN]
      00000089	9.18313026	[168] Img_OpenItem: cannot find item COMMON   BOARD_CONFIG_BIN
      00000090	9.18324471	[168] PANIC : down_dtb_syscfg() : can not open fes2 item
      00000091	9.18337154	[168] board config item empty,do not need to down!
      00000092	9.18350601	[168] INFO:  down dtb syscfg OK
      00000093	9.18362713	[168] INFO: down fes2 ok
      00000094	9.18420124	[168] INFO: run fes2 ok
      00000095	9.18421268	[168] Closing image now!
      00000096	9.18428516	[168] CloseImage OK
      00000097	9.18435478	[168] *********** after Fel2Fes *********
      之前没有用过全志的板子,是看B站上孙老师的YOLO小相机想复刻一下,用了他提供的IMG,但一直是烧写失败,想请教一下各位可能是什么原因引起的?感谢大佬们
