    T113-S3 MIPI 帧率低
    6
    5336
    • K
      kennsu LV 2 最后由 xiaowenge 编辑
      使用T113-S3驱动 800x480 MIPI 2lane 的屏,帧率只有22.2fps,请问这是哪里的原因?我想做到60fps。
      cat /sys/class/disp/disp/attr/sys
      screen 0:
      de_rate 300000000 hz, ref_fps:68
      mgr0: 480x800 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
      dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[4]
              lcd output      backlight( 50)  **fps:22.2**         480x 800
              err:4   skip:14 irq:6777        vsync:0 vsync_skip:0
         BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 480, 800; 480, 800; 480, 800] crop[   0,   0, 480, 800] frame[   0,   0, 480, 800] addr[       0,       0,       0] flags[0x       0] trd[0,0]
      depth[ 0]
      T W 2 条回复 最后回复 回复 引用 分享 0
      • T
        tivon LV 6 @kennsu 最后由 编辑
        @kennsu 我也有一个mipi屏幕,也是2lane,还没有研究到那里,以后遇到了看看能不能解决
          whycanservice2 LV 8 @kennsu 最后由 编辑
          @kennsu 设备树 lcd0 配置不正确
          K 1 条回复 最后回复 回复 引用 分享 0
          • K
            kennsu LV 2 @whycanservice2 最后由 xiaowenge 编辑
            @whycanservice2
            &lcd0 {
            	lcd_used            = <1>;
            	lcd_driver_name     = "st7701s";
            	lcd_backlight       = <100>;
                lcd_if              = <4>;
                lcd_x               = <480>;
                lcd_y               = <800>;
                lcd_width           = <52>;
                lcd_height          = <52>;
                lcd_dclk_freq       = <25>;
                lcd_pwm_used        = <1>;
                lcd_pwm_ch          = <0>;
                lcd_pwm_freq        = <1000>;
                lcd_pwm_pol         = <0>;
                lcd_pwm_max_limit   = <255>;
                lcd_hbp             = <10>;
                lcd_ht              = <515>;
                lcd_hspw            = <5>;
                lcd_vbp             = <20>;
                lcd_vt              = <830>;
                lcd_vspw            = <5>;
                lcd_dsi_if          = <0>;
                lcd_dsi_lane        = <2>;
                lcd_lvds_if         = <0>;
                lcd_lvds_colordepth = <0>;
                lcd_lvds_mode       = <0>;
                lcd_frm             = <0>;
                lcd_hv_clk_phase    = <0>;
                lcd_hv_sync_polarity= <0>;
                lcd_gamma_en        = <0>;
                lcd_bright_curve_en = <0>;
                lcd_cmap_en         = <0>;
                lcd_fsync_en        = <0>;
                lcd_fsync_act_time  = <1000>;
                lcd_fsync_dis_time  = <1000>;
                lcd_fsync_pol       = <0>;
                deu_mode            = <0>;
                lcdgamma4iep        = <22>;
                smart_color         = <90>;
                // lcd_gpio_0 =  <&pio PG 13 GPIO_ACTIVE_HIGH>;
            &disp {
            	disp_rotation_used       = <1>;
            	degree0			 = <0>;
            	fb0_buffer_num           = <2>;
            	fb0_width                = <480>;
            	fb0_height               = <800>;
            	//dc1sw-supply = <&reg_dc1sw>;
            	//eldo3-supply = <&reg_eldo3>;
            	//dcdc1-supply = <&reg_dcdc1>;
            是哪里不对呢?麻烦您指点一下
            W 1 条回复 最后回复 回复 引用 分享 0
              mysky LV 4 最后由 编辑
              时序参数不对,修改时序参数
                @kennsu clk=25 应该是不合适的 pll倍频分频一般偶数频率容易匹配,8的倍数比较好。你这种情况是典型的 无法匹配最接近的频率导致的,在启动时会给出打印 说 选择频率是25000000 但实际频率是xxxxxx。。
