    T113-s3日志打印了,但是不进入终端,输入不了命令
      skylar LV 4 最后由 编辑
      用的是sd卡启动,系统可能是进入了,但是用不了终端😭
      完整log:
      [21]HELLO! BOOT0 is starting!
      [24]BOOT0 commit :
      [00.220]smc_tee_inform_fdt failed with: ffff000a
      [00.226][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.232][mmc]: get sdc_type fail and use default host:tm1.
      [00.238][mmc]: can't find node "mmc0",will add new node
      [00.242][mmc]: fdt err returned <no error>
      [00.246][mmc]: Using default timing para
      [00.250][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.268][mmc]: card_caps:0x3000000a
      [00.271][mmc]: host_caps:0x3000003f
      [00.331]Item0 (Map) magic is bad
      [00.333]the secure storage item0 copy0 magic is bad
      [00.350]Item0 (Map) magic is bad
      [00.352]the secure storage item0 copy1 magic is bad
      [00.357]Item0 (Map) magic is bad
      [00.360]secure storage read widevine fail with:-1
      [00.364]secure storage read ec_key fail with:-1
      [00.369]secure storage read ec_cert1 fail with:-1
      [00.373]secure storage read ec_cert2 fail with:-1
      [00.377]secure storage read ec_cert3 fail with:-1
      [00.382]secure storage read rsa_key fail with:-1
      [00.386]secure storage read rsa_cert1 fail with:-1
      [00.391]secure storage read rsa_cert2 fail with:-1
      [00.395]secure storage read rsa_cert3 fail with:-1
      [00.400]out of usb burn from boot: not need burn key
      [00.587]no vendor_boot partition is found
      [00.596]Starting kernel ...
      [00.598][mmc]: MMC Device 2 not found
      [00.602][mmc]: mmc 2 not find, so not exit
      [    0.000000] Linux version 5.4.61 (taiji@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #438 SMP PREEMPT Mon Jan 6 13:45:31 UTC 2025
      [    0.000000] cma: Reserved 8 MiB at 0x47800000
      [    0.000000] percpu: Embedded 15 pages/cpu s30284 r8192 d22964 u61440
      [    0.000000] pcpu-alloc: s30284 r8192 d22964 u61440 alloc=15*4096
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 rootdelay=0 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.07(01/06/2025-21:44:23) androidboot.dramsize=128
      [    0.000000] Memory: 109544K/131072K available (6144K kernel code, 293K rwdata, 1392K rodata, 1024K init, 204K bss, 13336K reserved, 8192K cma-reserved)
      [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.008016] Switching to timer-based delay loop, resolution 41ns
      [    0.014186] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023898] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.034264] pid_max: default: 32768 minimum: 301
      [    0.038991] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.046332] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.054666] CPU: Testing write buffer coherency: ok
      [    0.059878] /cpus/cpu@0 missing clock-frequency property
      [    0.065211] /cpus/cpu@1 missing clock-frequency property
      [    0.070542] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.076714] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.083373] rcu: Hierarchical SRCU implementation.
      [    0.088585] smp: Bringing up secondary CPUs ...
      [    0.094222] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.094340] smp: Brought up 1 node, 2 CPUs
      [    0.104171] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.110367] CPU: All CPU(s) started in SVC mode.
      [    0.115458] devtmpfs: initialized
      [    0.129754] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.137873] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.147752] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.154997] pinctrl core: initialized pinctrl subsystem
      [    0.161169] NET: Registered protocol family 16
      [    0.167041] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.204468] rtc_ccu: sunxi ccu init OK
      [    0.210423] ccu: sunxi ccu init OK
      [    0.214319] r_ccu: sunxi ccu init OK
      [    0.235692] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.243331] iommu: Default domain type: Translated
      [    0.248401] sunxi iommu: irq = 24
      [    0.252622] SCSI subsystem initialized
      [    0.256558] usbcore: registered new interface driver usbfs
      [    0.262143] usbcore: registered new interface driver hub
      [    0.267554] usbcore: registered new device driver usb
      [    0.273447] pwm module init!
      [    0.277563] g2d 5410000.g2d: Adding to iommu group 0
      [    0.282925] G2D: rcq version initialized.major:251
      [    0.288473] clocksource: Switched to clocksource arch_sys_counter
      [    0.302805] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.312158] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    0.323350] NET: Registered protocol family 2
      [    0.328264] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.336669] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.344347] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.351416] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.357860] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.364442] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.371610] NET: Registered protocol family 1
      [    0.376443] RPC: Registered named UNIX socket transport module.
      [    0.382436] RPC: Registered udp transport module.
      [    0.387142] RPC: Registered tcp transport module.
      [    0.391867] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.399242] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.409564] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.416231] sunxi_spi_resource_get()2438 - [spi0] SPI MASTER MODE
      [    0.422392] sunxi_spi_resource_get()2476 - Failed to get sample mode
      [    0.428761] sunxi_spi_resource_get()2481 - Failed to get sample delay
      [    0.435201] sunxi_spi_resource_get()2485 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.443656] sunxi_spi_clk_init()2527 - [spi0] mclk 100000000
      [    0.449938] spi spi0: chipselect 0 already in use
      [    0.454650] spi_master spi0: spi_device register error /soc@3000000/spi@4025000/spi_board@0
      [    0.463074] spi_master spi0: Failed to create SPI device for /soc@3000000/spi@4025000/spi_board@0
      [    0.472002] sunxi_spi_probe()2978 - [spi0]: driver probe succeed, base c8821000, irq 41
      [    0.481558] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.495003] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.530546] io scheduler mq-deadline registered
      [    0.535093] io scheduler kyber registered
      [    0.540398] [DISP]disp_module_init
      [    0.544308] disp 5000000.disp: Adding to iommu group 0
      [    0.561091] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
      [    0.569657] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
      [    0.582866] [DISP] disp_sys_pwm_request,line:442:
      [    0.582872] disp_sys_pwm_request pwm 8 fail! -517
      [    0.592313] [DISP] disp_sys_pwm_config,line:509:
      [    0.592316] disp_sys_pwm_Config, handle is NULL!
      [    0.602004] display_fb_request,fb_id:0
      [    0.609704] [DISP] Fb_copy_boot_fb,line:1445:
      [    0.609707] no boot_fb0
      [    0.616943] disp_al_manager_apply ouput_type:0
      [    0.618824] [DISP]disp_module_init finish
      [    0.621786] [DISP] disp_sys_pwm_request,line:442:
      [    0.621790] disp_sys_pwm_request pwm 8 fail! -517
      [    0.626484] sunxi_sid_init()783 - insmod ok
      [    0.630170] [DISP] disp_sys_pwm_config,line:509:
      [    0.630173] disp_sys_pwm_Config, handle is NULL!
      [    0.630177] [DISP] disp_sys_pwm_set_polarity,line:528:
      [    0.630179] disp_sys_pwm_Set_Polarity, handle is NULL!
      [    0.631008] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.636092] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    0.678663] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.685788] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.693704] sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
      ⚌[    0.701711] printk: console [ttyS3] enabled
      [    0.710655] printk: bootconsole [earlycon0] disabled
      [    0.722041] misc dump reg init
      [    0.726581] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    0.733873] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.741217] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.748656] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    0.755200] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    0.762160] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    0.769908] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    0.777759] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    0.785891] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    0.793542] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    0.800319] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    0.807855] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
      [    0.816118] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.823478] sunxi-ehci: EHCI SUNXI driver
      [    0.830119] using random self ethernet address
      [    0.835107] using random host ethernet address
      [    0.840623] usb0: HOST MAC ce:d0:88:d4:8f:bf
      [    0.845514] usb0: MAC 46:e3:c9:ad:6a:1f
      [    0.848516] [DISP] disp_sys_pwm_request,line:442:
      [    0.848520] disp_sys_pwm_request pwm 8 fail! -517
      [    0.849885] using random self ethernet address
      [    0.855086] [DISP] disp_lcd_pwm_enable,line:1271:
      [    0.855089] pwm device hdl is NULL
      [    0.860371] using random host ethernet address
      [    0.860433] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
      [    0.865376] [DISP] disp_device_attached_and_enable,line:233:
      [    0.865380] attached ok, mgr0<-->dev0
      [    0.870661] g_ether gadget: g_ether ready
      [    0.874471] [DISP] disp_device_attached_and_enable,line:236:
      [    0.874479] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
      [    0.879690] ts probe start
      [    0.880051] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input0
      [    0.929907] ts probe success
      [    0.931101] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.945273] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.956022] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.967117] sunxi-rtc 7090000.rtc: registered as rtc0
      [    0.972843] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    0.983497] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:56 UTC (56)
      [    0.992506] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    0.998413] i2c /dev entries driver
      [    1.004074] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.013962] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    1.020183] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    1.026532] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    1.032989] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    1.039446] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    1.045987] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    1.052537] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    1.059090] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    1.066051] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    1.071474] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    1.078102] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.089288] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    1.109434] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.133861] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    1.139579] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.151704] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.161632] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    1.162689] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.167846] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    1.185774] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    1.192244] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    1.198710] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    1.198721] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.205258] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    1.223453] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    1.224713] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.230008] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    1.248193] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.257670] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.268875] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    1.283506] mmc0: host does not support reading read-only switch, assuming write-enable
      [    1.289033] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.304129] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    1.304214] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    1.327483] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    1.328245] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    1.339258] mmc0: new high speed SDHC card at address 1234
      [    1.346882] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    1.353152] mmcblk0: mmc0:1234 SA08G 7.21 GiB
      [    1.359949] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    1.370989] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.383114] NET: Registered protocol family 10
      [    1.385682] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.388168]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    1.400877] Segment Routing with IPv6
      [    1.409050] NET: Registered protocol family 17
      [    1.414052] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    1.421332] Registering SWP/SWPB emulation handler
      [    1.426715] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    1.434314] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    1.442049] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    1.448883] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    1.449538] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    1.472461] get ehci0-controller wakeup-source is fail.
      [    1.478422] sunxi ehci0-controller don't init wakeup source
      [    1.484716] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a73c38, 0x:c883a000, irq_no:3b
      [    1.496731] [sunxi-ehci0]: Not init ehci0
      [    1.501571] get ehci1-controller wakeup-source is fail.
      [    1.507534] sunxi ehci1-controller don't init wakeup source
      [    1.513821] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0a74158, 0x:c883e000, irq_no:3d
      [    1.526055] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    1.539443] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.546705] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    1.556640] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
      [    1.588493] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    1.596311] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [    1.605357] hub 1-0:1.0: USB hub found
      [    1.609627] hub 1-0:1.0: 1 port detected
      [    1.616856] clk: Not disabling unused clocks
      [    1.621827] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    1.631520] cfg80211: failed to load regulatory.db
      [    1.642486] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    1.654322] devtmpfs: mounted
      [    1.659583] Freeing unused kernel memory: 1024K
      [    1.698630] Run /sbin/init as init process
      [    1.809619] init: Console is alive
      [    1.813662] init: - preinit -
      [    1.828673] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [    1.905852] random: procd: uninitialized urandom read (4 bytes read)
      [    1.907119] usbcore: registered new interface driver usb-storage
      /dev/by-name/UDISK already format by ext4
      /dev/by-name/rootfs_data already format by ext4
      [    2.083901] mount_root: mounting /dev/root
      [    2.088988] mount_root: loading kmods from internal overlay
      [    2.187691] block: attempting to load /etc/config/fstab
      e2fsck 1.46.4 (18-Aug-2021)
      /dev/by-name/UDISK: recovering journal
      [    3.776777] random: fast init done
      Setting free inodes count to 468609 (was 468629)
      Setting free blocks count to 1817658 (was 1817672)
      /dev/by-name/UDISK: clean, 31/468640 files, 54045/1871703 blocks
      [    5.366918] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts:
      [    5.380512] block: extroot: failed to read UUID from /tmp/extroot/overlay/etc/.extroot-uuid: 2 (No such file or directory)
      [    5.393045] block: extroot: UUID mismatch (root: f2335c10-1f53d0b8-e0cf53e0-e3074bed, overlay: ), but continue
      [    5.415005] mount_root: switched to extroot
      [    5.427594] procd: - early -
      [    5.452289] random: procd: uninitialized urandom read (4 bytes read)
      [    5.528986] procd: - ubus -
      [    5.532640] procd (1): /proc/122/oom_adj is deprecated, please use /proc/122/oom_score_adj instead.
      [    5.555368] random: ubusd: uninitialized urandom read (4 bytes read)
      [    5.589992] random: ubusd: uninitialized urandom read (4 bytes read)
      [    5.598962] procd: - init -
      [    5.651258] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    5.743487] udevd[139]: starting version 3.2.9
      [    5.777336] udevd[139]: specified group 'tty' unknown
      [    5.790206] udevd[139]: specified group 'dialout' unknown
      [    5.806330] udevd[139]: specified group 'kmem' unknown
      [    5.820210] udevd[139]: specified group 'input' unknown
      [    5.848659] udevd[139]: specified group 'video' unknown
      [    5.866443] udevd[139]: specified group 'lp' unknown
      [    5.883989] udevd[139]: specified group 'disk' unknown
      [    5.900578] udevd[139]: specified group 'cdrom' unknown
      [    5.921886] 8723ds: version magic '5.4.61 SMP preempt mod_unload ARMv7 p2v8 ' should be '5.4.61 SMP preempt ARMv7 p2v8 '
      [    5.937572] udevd[139]: specified group 'tape' unknown
      kmodloader done
      [    5.990640] udevd[176]: starting eudev-3.2.9
      T 1 条回复 最后回复 回复 引用 分享 0
      • T
        tivon LV 6 @skylar 最后由 编辑
        @skylar 可以看看是不是我以前遇到过的问题
        https://bbs.aw-ol.com/topic/6049/t113-s3更换debug口后shell不运行-t113_qa0001/4?_=1736218960210
        S 1 条回复 最后回复 回复 引用 分享 0
          skylar LV 4 @tivon 最后由 编辑
          @tivon 很感谢你回复的帖子,可能不是tina5,在sdk目录下没找到.openwrt/target/t113相关文件夹,但是找到了tina-sdk/target/allwinner/t113-round/busybox-init-base-files/etc/inittab文件
          # Put a getty on the serial port
          /dev/console::respawn:-/bin/sh
          #ttyS0::respawn:/sbin/getty -n -L ttyS0 115200 vt100 -n -l /bin/sh # GENERIC_SERIAL
          下添加了ttyS3::respawn:/sbin/getty -n -L ttyS3 115200 vt100 -n -l /bin/sh
          ttyS3::respawn:/sbin/getty -n -L ttyS3 115200 vt100 -n -l /bin/sh # GENERIC_SERIAL
          但是编译上电后问题没有解决
