    T113-S3连接WiFi部分WiFi连接不上?
      skylar LV 4 最后由 编辑
      Tina_sdk,WiFi模块是trl8723bs,连接WiFi时发现有些WiFi连不上。不知道什么原因?
      日志:
      root@TinaLinux:/# wifi_scan_results_test
      ***Start scan!***
      bssid / frequency / signal level / flags / ssid
      3c:67:fd:8b:08:52       2437    -45     [WPA2-PSK-CCMP][WPS][ESS]       MIFI-0852
      e0:65:55:8b:25:bd       2472    -45     [WPA2-PSK-CCMP][ESS]    H3C
      16:9f:4f:e6:3b:f8       2412    -45     [ESS]
      10:9f:4f:e6:3b:f8       2412    -45     [WPS][ESS]      CMCC-kPR4
      80:ae:54:2e:dc:d0       2462    -61     [ESS]   TP-LINK_DCD0
      Wifi get_scan_results: Success!
      root@TinaLinux:/# wifi_connect_ap_test MIFI-0852 1234567890
      Connecting to the network(MIFI-0852)......
      [   58.686724] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
      [   58.945718] RTL8723BS: start auth
      [   58.955593] RTL8723BS: auth success, start assoc
      [   59.129138] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
      [   59.137037] RTL8723BS: assoc success
      [   59.164228] RTL8723BS: send eapol packet
      [   59.194021] RTL8723BS: send eapol packet
      [   59.198620] RTL8723BS: set pairwise key camid:4, addr:3c:67:fd:8b:08:52, kid:0, type:AES
      [   59.199279] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      [   59.208351] RTL8723BS: set group key camid:5, addr:3c:67:fd:8b:08:52, kid:1, type:AES
      Connected to the AP(MIFI-0852)
      Getting ip address(MIFI-0852)......
      udhcpc: started, v1.27.2
      udhcpc: sending discover
      udhcpc: sending select for 192.168.100.100
      udhcpc: lease of 192.168.100.100 obtained, lease time 86400
      Wifi connect ap : Success!
      sh: odhcp6c: not found
      root@TinaLinux:/# wifi_connect_ap_test H3C 88888889
      Connecting to the network(H3C)......
      [   89.016670] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
      [   89.069959] RTL8723BS: start auth
      [   89.075484] RTL8723BS: auth success, start assoc
      [   92.276896] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
      [   92.551615] RTL8723BS: start auth
      [   92.557085] RTL8723BS: auth success, start assoc
      [   96.166753] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
      [   96.442874] RTL8723BS: start auth
      [   96.449893] RTL8723BS: auth success, start assoc
      ASSOC REJECT!
      ASSOC REJECT!
      [   99.830045] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
      [  100.026948] RTL8723BS: start auth
      [  100.035504] RTL8723BS: auth success, start assoc
      [  112.233474] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
      [  112.315124] RTL8723BS: start auth
      [  112.321415] RTL8723BS: auth success, start assoc
      [  135.296869] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
      [  135.560271] RTL8723BS: start auth
      [  135.565686] RTL8723BS: auth success, start assoc
      ASSOC REJECT!
      ASSOC REJECT!
      Disconnected,the reason:WSE_AP_ASSOC_REJECT
      Wifi connect ap : Failure!
      root@TinaLinux:/#
      有没有可能是加密方式不支持?出现是因为驱动问题还是模块问题?
