    Win11,usb驱动启动不成功
    3526
      WessZ LV 2 最后由 编辑
      试过网上所有方法,都无解
      1.手动更新驱动,显示启动不成功,错误代码10
      2.安全模式下手动更新驱动,同上
      3.关闭内存隔离,已关闭
        WessZ LV 2 最后由 编辑
        已解决,非常尴尬的发现和驱动没有关系,完全就是数据线有问题。
        目前的问题就是每次烧录在7%的时候就提示失败
          DOT小文哥 LV 8 最后由 编辑
          7%的话可以看看log,好几次7%卡住发现是固件没对上的
            WessZ LV 2 最后由 WessZ 编辑
            这是打印日志,麻烦您帮忙看看。
            [23:37:47.033]收←◆[4273]fes begin commit:adaf1174cc
            [4276]set pll start
            [4282]periph0 has been enabled
            [4285]set pll end
            [4287][pmu]: bus read error
            [4289]board init ok
            [4291]beign to init dram
            [4294]ZQ value = 0x2f
            [4296]get_pmu_exist() = -1
            [4298]ddr_efuse_type: 0xa
            [4301]trefi:7.8ms
            [4303][AUTO DEBUG] single rank and full DQ!
            [4307]ddr_efuse_type: 0xa
            [4310]trefi:7.8ms
            [4312][AUTO DEBUG] rank 0 row = 13
            [4315][AUTO DEBUG] rank 0 bank = 8
            [4319][AUTO DEBUG] rank 0 page size = 2 KB
            [4323]DRAM BOOT DRIVE INFO: V0.33
            [4326]DRAM CLK = 936 MHz
            [4328]DRAM Type = 3 (2:DDR2,3:DDR3)
            [4332]DRAMC read ODT off.
            [4334]DRAM ODT value: 0x42.
            [4337]ddr_efuse_type: 0xa
            [4340]DRAM SIZE =128 M
            [4342]dram_tpr4:0x0
            [4344]PLL_DDR_CTRL_REG:0xf8004d00
            [4347]DRAM_CLK_REG:0xc0000000
            [4350][TIMING DEBUG] MR2= 0x20
            [4354]DRAM simple test OK.
            [4356]rtc standby flag is 0x0, super standby flag is 0x0
            [4362]init dram ok
            [23:37:49.249]收←◆
            U-Boot 2018.05-g2a1965a-dirty (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
            [06.497]CPU: Allwinner Family
            [06.499]Model: sun8iw20
            [06.502]DRAM: 128 MiB
            [06.505]Relocation Offset is: 04ebd000
            [06.531]secure enable bit: 0
            [06.533]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
            [06.539]gic: normal mode
            [06.542]flash init start
            [06.544]workmode = 16,storage type = 0
            try card 2
            set card number 2
            get card number 2
            [06.552][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
            [06.558][mmc]: Is not Boot mode!
            [06.561][mmc]: SUNXI SDMMC Controller Version:0x50310
            [06.572][mmc]: Try SD card 2
            [06.578][mmc]: mmc 2 cmd timeout 100 status 100
            [06.582][mmc]: smc 2 err, cmd 8, RTO
            [06.585][mmc]: mmc 2 close bus gating and reset
            [06.590][mmc]: mmc 2 cmd timeout 100 status 100
            [06.594][mmc]: smc 2 err, cmd 55, RTO
            [06.598][mmc]: mmc 2 close bus gating and reset
            [06.602][mmc]: Try MMC card 2
            [06.611][mmc]: mmc 2 cmd timeout 100 status 100
            [06.615][mmc]: smc 2 err, cmd 1, RTO
            [06.618][mmc]: mmc 2 close bus gating and reset
            [06.623][mmc]: Card did not respond to voltage select!
            [06.627][mmc]: SD/MMC 2 init error!
            [06.633][mmc]: mmc init product failed
            MMC init failed
            try emmc fail
            [06.639]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
            [06.645]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
            [06.653]sunxi-spinand-phy: request spi0 gpio ok
            [06.657]sunxi-spinand-phy: request general tx dma channel ok!
            [06.662]sunxi-spinand-phy: request general rx dma channel ok!
            [06.668]sunxi-spinand-phy: set spic0 clk to 20 Mhz
            [06.672]sunxi-spinand-phy: init spic0 clk ok
            [06.676]sunxi-spinand-phy: detect munufacture from id table: Winbond
            [06.682]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
            [06.688]sunxi-spinand-phy: ========== arch info ==========
            [06.693]sunxi-spinand-phy: Model: W25N01GVZEIG
            [06.699]sunxi-spinand-phy: Munufacture: Winbond
            [06.704]sunxi-spinand-phy: DieCntPerChip: 1
            [06.708]sunxi-spinand-phy: BlkCntPerDie: 1024
            [06.713]sunxi-spinand-phy: PageCntPerBlk: 64
            [06.717]sunxi-spinand-phy: SectCntPerPage: 4
            [06.722]sunxi-spinand-phy: OobSizePerPage: 64
            [06.726]sunxi-spinand-phy: BadBlockFlag: 0x0
            [06.731]sunxi-spinand-phy: OperationOpt: 0x7
            [06.735]sunxi-spinand-phy: MaxEraseTimes: 65000
            [06.740]sunxi-spinand-phy: EccFlag: 0x0
            [06.745]sunxi-spinand-phy: EccType: 2
            [06.749]sunxi-spinand-phy: EccProtectedType: 3
            [06.754]sunxi-spinand-phy: ========================================
            [06.759]sunxi-spinand-phy:
            [06.762]sunxi-spinand-phy: ========== physical info ==========
            [06.768]sunxi-spinand-phy: TotalSize: 128 M
            [06.772]sunxi-spinand-phy: SectorSize: 512 B
            [06.776]sunxi-spinand-phy: PageSize: 2 K
            [06.780]sunxi-spinand-phy: BlockSize: 128 K
            [06.784]sunxi-spinand-phy: OOBSize: 64 B
            [06.788]sunxi-spinand-phy: ========================================
            [06.794]sunxi-spinand-phy:
            [06.797]sunxi-spinand-phy: ========== logical info ==========
            [06.802]sunxi-spinand-phy: TotalSize: 128 M
            [06.806]sunxi-spinand-phy: SectorSize: 512 B
            [06.810]sunxi-spinand-phy: PageSize: 4 K
            [06.814]sunxi-spinand-phy: BlockSize: 256 K
            [06.819]sunxi-spinand-phy: OOBSize: 128 B
            [06.823]sunxi-spinand-phy: ========================================
            [06.829]sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
            [06.834]sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
            [06.840]sunxi-spinand-phy: set spic0 clk to 100 Mhz
            [06.845]sunxi-spinand-phy: block lock register: 0x00
            [06.849]sunxi-spinand-phy: feature register: 0x19
            [06.854]sunxi-spinand-phy: sunxi physic nand init end
            [06.859]line:703 init_clocks
            [06.862]init_clocks:finish
            [06.864]Loading Environment from SUNXI_FLASH... OK
            [06.868]try to burn key
            [06.871]out of usb burn from boot: not need burn key
            sunxi work mode=0x10
            run usb efex
            delay time 2500
            [23:37:52.150]收←◆weak:otg_phy_config
            usb init ok
            [23:37:52.390]收←◆set address 0x29
            set address 0x29 ok
            [23:37:52.651]收←◆set address 0xc
            set address 0xc ok
            [23:37:52.706]收←◆SUNXI_EFEX_ERASE_TAG
            erase_flag
            [23:37:52.739]收←◆ = 0x1
            origin_erase_flag = 0x1
            FEX_CMD_fes_verify_status
            FEX_CMD_fes_verify last err=0
            the 0 mbr table is ok
            the 1 mbr table is ok
            the 2 mbr table is ok
            the 3 mbr table is ok
            MBR DUMP**
            total mbr part 8
            part[0] name :boot-resource
            part[0] classname :DISK
            part[0] addrlo :0x8000
            part[0] lenlo :0x5e8
            part[0] user_type :32768
            part[0] keydata :0
            part[0] ro :0
            part[1] name :env
            part[1] classname :DISK
            part[1] addrlo :0x85e8
            part[1] lenlo :0x1f8
            part[1] user_type :32768
            part[1] keydata :0
            part[1] ro :0
            part[2] name :env-redund
            part[2] classname :DISK
            part[2] addrlo :0x87e0
            part[2] lenlo :0x1f8
            part[2] user_type :32768
            part[2] keydata :0
            part[2] ro :0
            part[3] name :boot
            part[3] classname :DISK
            part[3] addrlo :0x89d8
            part[3] lenlo :0x26ac
            part[3] user_type :32768
            part[3] keydata :0
            part[3] ro :0
            part[4] name :rootfs
            part[4] classname :DISK
            part[4] addrlo :0xb084
            part[4] lenlo :0x1c500
            part[4] user_type :32768
            part[4] keydata :0
            part[4] ro :0
            part[5] name :private
            part[5] classname :DISK
            part[5] addrlo :0x27584
            part[5] lenlo :0x1f8
            part[5] user_type :32768
            part[5] keydata :0
            part[5] ro :0
            part[6] name :rootfs_data
            part[6] classname :DISK
            part[6] addrlo :0x2777c
            part[6] lenlo :0x49700
            part[6] user_type :32768
            part[6] keydata :0
            part[6] ro :0
            part[7] name :UDISK
            part[7] classname :DISK
            part[7] addrlo :0x70e7c
            part[7] lenlo :0x0
            part[7] user_type :33024
            part[7] keydata :0
            part[7] ro :0
            total part: 9
            mbr 0, 8000, 8000
            boot-resource 1, 5e8, 8000
            env 2, 1f8, 8000
            env-redund 3, 1f8, 8000
            boot 4, 26ac, 8000
            rootfs 5, 1c500, 8000
            private 6, 1f8, 8000
            rootfs_data 7, 49700, 8000
            UDISK 8, 0, 8100
            [10.162]erase blk 0 to blk 32
            need erase flash: 1
            [10.186]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
            #: name size offset mask_flags
            0: boot0 0x00100000 0x00000000 1
            1: uboot 0x00300000 0x00100000 1
            2: secure_storage 0x00100000 0x00400000 1
            3: sys 0x07b00000 0x00500000 0
            defaults:
            mtdids : nand0=nand
            [10.236]MTD info (4)
            [10.238]pagesize: 0x1000
            [10.240]blksize: 0x40000
            [10.243]num offset bytes name
            [10.246]0 0x00000000 0x00100000 boot0
            [10.250]1 0x00100000 0x00300000 uboot
            [10.253]2 0x00400000 0x00100000 secure_storage
            [10.258]3 0x00500000 0x07b00000 sys
            [10.261]ubi attach the last part of mtd device: NO.3
            [23:37:53.095]收←◆[10.333]ubi0: attaching mtd4
            [23:37:53.207]收←◆[10.447]ubi0: scanning is finished
            [10.450]ubi0: empty MTD device detected
            [10.469]ubi0: attached mtd4 (name "sys", size 123 MiB)
            [10.474]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [10.480]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [10.486]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [10.492]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
            [10.498]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
            [10.504]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
            [10.512]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
            [23:37:54.009]收←◆private part exist
            Volume mbr not found!
            [11.252]read volume mbr failed return 19
            read local mbr on flash failed
            [11.259]erase blk 0 to blk 32
            [11.278]erase blk 40 to blk 1024
            [23:37:54.783]收←◆SUNXI_EFEX_MBR_TAG
            mbr size = 0x10000
            force mbr
            defaults:
            mtdids : nand0=nand
            [12.067]MTD info (4)
            [12.069]pagesize: 0x1000
            [12.071]blksize: 0x40000
            [12.074]num offset bytes name
            [12.077]0 0x00000000 0x00100000 boot0
            [12.081]1 0x00100000 0x00300000 uboot
            [12.085]2 0x00400000 0x00100000 secure_storage
            [12.089]3 0x00500000 0x07b00000 sys
            [12.092]MBR info (unalign):
            [12.095]partno addr sects type name
            [12.100]0 0x00000000 0x00008000 0x00000001 mbr
            [12.105]1 0x00008000 0x000005e8 0x00008000 boot-resource
            [12.110]2 0x000085e8 0x000001f8 0x00008000 env
            [12.115]3 0x000087e0 0x000001f8 0x00008000 env-redund
            [12.120]4 0x000089d8 0x000026ac 0x00008000 boot
            [12.125]5 0x0000b084 0x0001c500 0x00008000 rootfs
            [12.130]6 0x00027584 0x000001f8 0x00008000 private
            [12.135]7 0x0002777c 0x00049700 0x00008000 rootfs_data
            [12.141]8 0x00070e7c 0x00000000 0x00008100 UDISK
            [12.146]ubi attach the last part of mtd device: NO.3
            [12.150]MBR info (align):
            [12.153]partno addr sects type name
            [12.158]0 0x00002800 0x000081f0 0x00000001 mbr
            [12.162]1 0x0000a9f0 0x000005e8 0x00008000 boot-resource
            [12.168]2 0x0000afd8 0x000001f8 0x00008000 env
            [12.173]3 0x0000b1d0 0x000001f8 0x00008000 env-redund
            [12.178]4 0x0000b3c8 0x00002760 0x00008000 boot
            [12.183]5 0x0000db28 0x0001c6c8 0x00008000 rootfs
            [12.188]6 0x0002a1f0 0x000001f8 0x00008000 private
            [12.193]7 0x0002a3e8 0x00049758 0x00008000 rootfs_data
            [12.199]8 0x00073b40 0x00000000 0x00008100 UDISK
            [12.204]ubi attach the last part of mtd device: NO.3
            [12.208]ubi volume total size is larger than mtd size.
            ubi_vol_total_bytes : 0xe268000, mtd_bytes: 0x7b00000
            [12.218]initialize sunxi spinand ubi failed
            download_standard_gpt:write mbr sectors fail ret = 0
