    tina Linux编译libwebsockets失败
      skylar LV 4 最后由 编辑
      make[3]: Entering directory '/home/skylar/tina-d1-h/package/libs/libwebsockets'
      . /home/skylar/tina-d1-h/build/shell.sh; gzip -dc /home/skylar/tina-d1-h/dl/libwebsockets-2.4.0.tar.gz | tar -C /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/.. -xf -
      touch /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/.prepared_fd6e41a8b99d1351794aff4f46d8ad8e
      rm -f /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/.configured_*
      rm -f /home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/stamp/.libwebsockets.openssl_installed
      mkdir -p /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0
      (cd /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0; CFLAGS="-Os -pipe -march=armv7-a -mtune=cortex-a7 -mfpu=neon -fno-caller-saves -Wno-unused-result -mfloat-abi=hard  -Wformat -Werror=format-security -fPIC -fstack-protector -D_FORTIFY_SOURCE=2 -Wl,-z,now -Wl,-z,relro " CXXFLAGS="-Os -pipe -march=armv7-a -mtune=cortex-a7 -mfpu=neon -fno-caller-saves -Wno-unused-result -mfloat-abi=hard  -Wformat -Werror=format-security -fPIC -fstack-protector -D_FORTIFY_SOURCE=2 -Wl,-z,now -Wl,-z,relro -Wno-virtual-dtor " LDFLAGS="-L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib -L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/lib -specs=/home/skylar/tina-d1-h/build/hardened-ld-pie.specs -znow -zrelro " cmake -DCMAKE_SYSTEM_NAME=Linux -DCMAKE_SYSTEM_VERSION=1 -DCMAKE_SYSTEM_PROCESSOR=arm -DCMAKE_BUILD_TYPE=Release -DCMAKE_C_FLAGS_RELEASE="-DNDEBUG" -DCMAKE_CXX_FLAGS_RELEASE="-DNDEBUG" -DCMAKE_C_COMPILER="/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-gcc" -DCMAKE_C_COMPILER_ARG1="" -DCMAKE_CXX_COMPILER="/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-g++" -DCMAKE_CXX_COMPILER_ARG1="" -DCMAKE_ASM_COMPILER="/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-gcc" -DCMAKE_ASM_COMPILER_ARG1="" -DCMAKE_EXE_LINKER_FLAGS:STRING="-L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib -L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/lib -specs=/home/skylar/tina-d1-h/build/hardened-ld-pie.specs -znow -zrelro" -DCMAKE_MODULE_LINKER_FLAGS:STRING="-L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib -L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/lib -specs=/home/skylar/tina-d1-h/build/hardened-ld-pie.specs -znow -zrelro -Wl,-Bsymbolic-functions" -DCMAKE_SHARED_LINKER_FLAGS:STRING="-L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib -L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/lib -specs=/home/skylar/tina-d1-h/build/hardened-ld-pie.specs -znow -zrelro -Wl,-Bsymbolic-functions" -DCMAKE_AR="/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-ar" -DCMAKE_NM="/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-nm" -DCMAKE_RANLIB="/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-ranlib" -DCMAKE_FIND_ROOT_PATH="/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr;/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/toolchain;/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain" -DCMAKE_FIND_ROOT_PATH_MODE_PROGRAM=BOTH -DCMAKE_FIND_ROOT_PATH_MODE_LIBRARY=ONLY -DCMAKE_FIND_ROOT_PATH_MODE_INCLUDE=ONLY -DCMAKE_STRIP=: -DCMAKE_INSTALL_PREFIX=/usr -DDL_LIBRARY=/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target -DCMAKE_PREFIX_PATH=/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target -DCMAKE_SKIP_RPATH=TRUE -DCMAKE_EXPORT_PACKAGE_REGISTRY=FALSE -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=TRUE -DCMAKE_FIND_USE_PACKAGE_REGISTRY=FALSE -DCMAKE_FIND_PACKAGE_NO_PACKAGE_REGISTRY=TRUE -DCMAKE_FIND_USE_SYSTEM_PACKAGE_REGISTRY=FALSE -DCMAKE_FIND_PACKAGE_NO_SYSTEM_PACKAGE_REGISTRY=TRUE -DLWS_IPV6=ON -DLWS_WITHOUT_TESTAPPS=ON -DLWS_OPENSSL_CLIENT_CERTS=/etc/ssl/certs -DLWS_OPENSSL_SUPPORT=ON -DLWS_WITH_SSL=ON /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0 )
      -- The C compiler identification is GNU 6.4.1
      -- Check for working C compiler: /home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-gcc
      -- Check for working C compiler: /home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/arm-openwrt-linux-muslgnueabi-gcc -- works
      -- Detecting C compiler ABI info
      -- Detecting C compiler ABI info - done
      -- Detecting C compile features
      -- Detecting C compile features - done
      -- CMAKE_TOOLCHAIN_FILE=''
      -- Found Git: /home/skylar/tina-d1-h/out/host/bin/git
      fatal: not a git repository (or any of the parent directories): .git
      Git commit hash: skylar@Mycomputer-
      -- Performing Test LWS_HAVE_inline
      -- Performing Test LWS_HAVE_inline - Success
      -- Performing Test LWS_HAVE___inline__
      -- Performing Test LWS_HAVE___inline__ - Success
      -- Performing Test LWS_HAVE___inline - Success
      -- Looking for bzero
      -- Looking for bzero - found
      -- Looking for fork
      -- Looking for fork - found
      -- Looking for getenv
      -- Looking for getenv - found
      -- Looking for malloc
      -- Looking for malloc - found
      -- Looking for memset
      -- Looking for memset - found
      -- Looking for realloc
      -- Looking for realloc - found
      -- Looking for socket
      -- Looking for socket - found
      -- Looking for strerror
      -- Looking for strerror - found
      -- Looking for vfork
      -- Looking for vfork - found
      -- Looking for execvpe
      -- Looking for execvpe - found
      -- Looking for getifaddrs
      -- Looking for getifaddrs - found
      -- Looking for snprintf
      -- Looking for snprintf - found
      -- Looking for _snprintf
      -- Looking for _snprintf - not found
      -- Looking for _vsnprintf
      -- Looking for _vsnprintf - not found
      -- Looking for getloadavg
      -- Looking for getloadavg - found
      -- Looking for atoll
      -- Looking for atoll - found
      -- Looking for _atoi64
      -- Looking for _atoi64 - not found
      -- Looking for _stat32i64
      -- Looking for _stat32i64 - not found
      -- Looking for dlfcn.h
      -- Looking for dlfcn.h - found
      -- Looking for fcntl.h
      -- Looking for fcntl.h - found
      -- Looking for in6addr.h
      -- Looking for in6addr.h - not found
      -- Looking for inttypes.h
      -- Looking for inttypes.h - found
      -- Looking for memory.h
      -- Looking for memory.h - found
      -- Looking for netinet/in.h
      -- Looking for netinet/in.h - found
      -- Looking for stdint.h
      -- Looking for stdint.h - found
      -- Looking for stdlib.h
      -- Looking for stdlib.h - found
      -- Looking for strings.h
      -- Looking for strings.h - found
      -- Looking for string.h
      -- Looking for string.h - found
      -- Looking for sys/prctl.h
      -- Looking for sys/prctl.h - found
      -- Looking for sys/socket.h
      -- Looking for sys/socket.h - found
      -- Looking for sys/sockio.h
      -- Looking for sys/sockio.h - not found
      -- Looking for sys/stat.h
      -- Looking for sys/stat.h - found
      -- Looking for sys/types.h
      -- Looking for sys/types.h - found
      -- Looking for unistd.h
      -- Looking for unistd.h - found
      -- Looking for vfork.h
      -- Looking for vfork.h - not found
      -- Looking for sys/capability.h
      -- Looking for sys/capability.h - found
      -- Looking for cap_set_flag in cap
      -- Looking for cap_set_flag in cap - found
      -- Looking for zlib.h
      -- Looking for zlib.h - found
      -- Looking for 4 include files stdlib.h, ..., float.h
      -- Looking for 4 include files stdlib.h, ..., float.h - found
      -- Performing Test LWS_HAS_INTPTR_T
      -- Performing Test LWS_HAS_INTPTR_T - Success
      -- Performing Test LWS_HAVE_VISIBILITY
      -- Performing Test LWS_HAVE_VISIBILITY - Success
      -- Found ZLIB: /home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib/libz.so (found version "1.2.8")
      zlib include dirs: /home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/include
      zlib libraries: /home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib/libz.so
      Compiling with SSL support
      -- Found OpenSSL: /home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib/libssl.so;/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib/libcrypto.so (found version "1.1.0i")
      OpenSSL include dir: /home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/include
      OpenSSL libraries: /home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib/libssl.so;/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib/libcrypto.so
      -- Looking for openssl/ecdh.h
      -- Looking for openssl/ecdh.h - found
      -- Looking for SSL_CTX_set1_param
      -- Looking for SSL_CTX_set1_param - found
      -- Looking for SSL_set_info_callback
      -- Looking for SSL_set_info_callback - found
      -- Looking for X509_VERIFY_PARAM_set1_host
      -- Looking for X509_VERIFY_PARAM_set1_host - found
      -- Looking for RSA_set0_key
      -- Looking for RSA_set0_key - not found
      -- Looking for TLS_client_method
      -- Looking for TLS_client_method - found
      -- Looking for TLSv1_2_client_method
      -- Looking for TLSv1_2_client_method - not found
      Searching for OpenSSL executable and dlls
      OpenSSL executable: /usr/bin/openssl
       GENCERTS = 1
      Generating SSL Certificates for the test-server...
      Can't load /home/skylar/.rnd into RNG
      140284941173184:error:2406F079:random number generator:RAND_load_file:Cannot open file:../crypto/rand/randfile.c:88:Filename=/home/skylar/.rnd
      Generating a RSA private key
      writing new private key to '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/libwebsockets-test-server.key.pem'
      You are about to be asked to enter information that will be incorporated
      into your certificate request.
      What you are about to enter is what is called a Distinguished Name or a DN.
      There are quite a few fields but you can leave some blank
      For some fields there will be a default value,
      If you enter '.', the field will be left blank.
      Country Name (2 letter code) [AU]:State or Province Name (full name) [Some-State]:Locality Name (eg, city) []:Organization Name (eg, company) [Internet Widgits Pty Ltd]:Organizational Unit Name (eg, section) []:Common Name (e.g. server FQDN or YOUR name) []:Email Address []:SUCCESSFULLY generated SSL certificate
      -- Looking for RPMTools... - rpmbuild NOT FOUND
        Settings:  (For more help do cmake -LH <srcpath>)
       LWS_WITH_STATIC = ON
       LWS_WITH_SHARED = ON
       LWS_WITH_SSL = ON (SSL Support)
       LWS_SSL_CLIENT_USE_OS_CA_CERTS = 1
       LWS_WITH_WOLFSSL = OFF (wolfSSL/CyaSSL replacement for OpenSSL)
       LWS_WITH_MBEDTLS = OFF (mbedTLS replacement for OpenSSL)
       LWS_WITHOUT_BUILTIN_SHA1 = OFF
       LWS_WITHOUT_BUILTIN_GETIFADDRS = OFF
       LWS_WITHOUT_CLIENT = OFF
       LWS_WITHOUT_SERVER = OFF
       LWS_LINK_TESTAPPS_DYNAMIC = OFF
       LWS_WITHOUT_TESTAPPS = ON
       LWS_WITHOUT_TEST_SERVER = OFF
       LWS_WITHOUT_TEST_SERVER_EXTPOLL = OFF
       LWS_WITHOUT_TEST_PING = OFF
       LWS_WITHOUT_TEST_ECHO = OFF
       LWS_WITHOUT_TEST_CLIENT = OFF
       LWS_WITHOUT_TEST_FRAGGLE = OFF
       LWS_WITHOUT_EXTENSIONS = OFF
       LWS_WITH_LATENCY = OFF
       LWS_WITHOUT_DAEMONIZE = ON
       LWS_WITH_LIBEV = OFF
       LWS_WITH_LIBUV = OFF
       LWS_WITH_LIBEVENT = OFF
       LWS_IPV6 = ON
       LWS_UNIX_SOCK = OFF
       LWS_WITH_HTTP2 = OFF
       LWS_SSL_SERVER_WITH_ECDH_CERT = OFF
       LWS_MAX_SMP = 1
       LWS_WITH_CGI = OFF
       LWS_HAVE_OPENSSL_ECDH_H = 1
       LWS_HAVE_SSL_CTX_set1_param = 1
       LWS_HAVE_RSA_SET0_KEY =
       LWS_WITH_HTTP_PROXY = OFF
       LIBHUBBUB_LIBRARIES =
       PLUGINS =
       LWS_WITH_ACCESS_LOG = OFF
       LWS_WITH_SERVER_STATUS = OFF
       LWS_WITH_LEJP = OFF
       LWS_WITH_LEJP_CONF = OFF
       LWS_WITH_SMTP = OFF
       LWS_WITH_GENERIC_SESSIONS = OFF
       LWS_STATIC_PIC = OFF
       LWS_WITH_RANGES = ON
       LWS_PLAT_OPTEE = OFF
       LWS_WITH_ESP32 = OFF
       LWS_WITH_ZIP_FOPS = ON
       LWS_AVOID_SIGPIPE_IGN = OFF
       LWS_WITH_STATS = OFF
       LWS_WITH_SOCKS5 = OFF
       LWS_HAVE_SYS_CAPABILITY_H = 1
       LWS_HAVE_LIBCAP = 1
       LWS_WITH_PEER_LIMITS = OFF
       LWS_HAVE_ATOLL = 1
       LWS_HAVE__ATOI64 =
       LWS_HAVE_STAT32I64 =
       LWS_HAS_INTPTR_T = 1
      -- Configuring done
      -- Generating done
      CMake Warning:
        Manually-specified variables were not used by the project:
          CMAKE_ASM_COMPILER
          CMAKE_CXX_COMPILER
          DL_LIBRARY
      -- Build files have been written to: /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0
      touch /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/.configured_yyy
      CFLAGS="-Os -pipe -march=armv7-a -mtune=cortex-a7 -mfpu=neon -fno-caller-saves -Wno-unused-result -mfloat-abi=hard  -Wformat -Werror=format-security -fPIC -fstack-protector -D_FORTIFY_SOURCE=2 -Wl,-z,now -Wl,-z,relro  -I/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/include -I/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/include -I/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/include -I/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/include -I/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/include/fortify " CXXFLAGS="-Os -pipe -march=armv7-a -mtune=cortex-a7 -mfpu=neon -fno-caller-saves -Wno-unused-result -mfloat-abi=hard  -Wformat -Werror=format-security -fPIC -fstack-protector -D_FORTIFY_SOURCE=2 -Wl,-z,now -Wl,-z,relro -Wno-virtual-dtor  -I/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/include -I/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/include -I/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/include -I/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/include -I/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/include/fortify " LDFLAGS="-L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/usr/lib -L/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/lib -L/home/skylar/tina-d1-h/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/lib -specs=/home/skylar/tina-d1-h/build/hardened-ld-pie.specs -znow -zrelro " LIBS="" make -j1 -C /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/. AR="arm-openwrt-linux-muslgnueabi-ar" AS="arm-openwrt-linux-muslgnueabi-gcc -c -Os -pipe -march=armv7-a -mtune=cortex-a7 -mfpu=neon -fno-caller-saves -Wno-unused-result -mfloat-abi=hard  -Wformat -Werror=format-security -fPIC -fstack-protector -D_FORTIFY_SOURCE=2 -Wl,-z,now -Wl,-z,relro" LD=arm-openwrt-linux-muslgnueabi-ld NM="arm-openwrt-linux-muslgnueabi-nm" CC="arm-openwrt-linux-muslgnueabi-gcc" GCC="arm-openwrt-linux-muslgnueabi-gcc" CXX="arm-openwrt-linux-muslgnueabi-g++" RANLIB="arm-openwrt-linux-muslgnueabi-ranlib" STRIP=arm-openwrt-linux-muslgnueabi-strip OBJCOPY=arm-openwrt-linux-muslgnueabi-objcopy OBJDUMP=arm-openwrt-linux-muslgnueabi-objdump SIZE=arm-openwrt-linux-muslgnueabi-size CROSS="arm-openwrt-linux-muslgnueabi-" ARCH="arm" CMAKE_COMMAND='/home/skylar/tina-d1-h/out/host/bin/cmake' CMAKE_DISABLE_cmake_check_build_system=1 ;
      make[4]: Entering directory '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0'
      make[5]: Entering directory '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0'
      make[6]: Entering directory '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0'
      Scanning dependencies of target websockets
      make[6]: Leaving directory '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0'
      [  1%] Building C object CMakeFiles/websockets.dir/lib/misc/base64-decode.c.o
      [  3%] Building C object CMakeFiles/websockets.dir/lib/handshake.c.o
      [  5%] Building C object CMakeFiles/websockets.dir/lib/libwebsockets.c.o
      [  7%] Building C object CMakeFiles/websockets.dir/lib/service.c.o
      [  8%] Building C object CMakeFiles/websockets.dir/lib/pollfd.c.o
      [ 10%] Building C object CMakeFiles/websockets.dir/lib/output.c.o
      [ 12%] Building C object CMakeFiles/websockets.dir/lib/server/parsers.c.o
      [ 14%] Building C object CMakeFiles/websockets.dir/lib/context.c.o
      [ 16%] Building C object CMakeFiles/websockets.dir/lib/alloc.c.o
      [ 17%] Building C object CMakeFiles/websockets.dir/lib/header.c.o
      [ 19%] Building C object CMakeFiles/websockets.dir/lib/misc/lws-ring.c.o
      [ 21%] Building C object CMakeFiles/websockets.dir/lib/client/client.c.o
      [ 23%] Building C object CMakeFiles/websockets.dir/lib/client/client-handshake.c.o
      [ 25%] Building C object CMakeFiles/websockets.dir/lib/client/client-parser.c.o
      [ 26%] Building C object CMakeFiles/websockets.dir/lib/ssl.c.o
      /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/lib/ssl.c: In function 'lws_context_init_ssl_library':
      /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/lib/ssl.c:331:2: error: implicit declaration of function 'SSL_library_init' [-Werror=implicit-function-declaration]
        SSL_library_init();
      /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/lib/ssl.c:332:2: error: implicit declaration of function 'OpenSSL_add_all_algorithms' [-Werror=implicit-function-declaration]
        OpenSSL_add_all_algorithms();
      /home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/lib/ssl.c:333:2: error: implicit declaration of function 'SSL_load_error_strings' [-Werror=implicit-function-declaration]
        SSL_load_error_strings();
      cc1: all warnings being treated as errors
      CMakeFiles/websockets.dir/build.make:398: recipe for target 'CMakeFiles/websockets.dir/lib/ssl.c.o' failed
      make[6]: *** [CMakeFiles/websockets.dir/lib/ssl.c.o] Error 1
      CMakeFiles/Makefile2:99: recipe for target 'CMakeFiles/websockets.dir/all' failed
      make[5]: *** [CMakeFiles/websockets.dir/all] Error 2
      make[5]: Leaving directory '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0'
      Makefile:149: recipe for target 'all' failed
      make[4]: *** [all] Error 2
      make[4]: Leaving directory '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0'
      Makefile:88: recipe for target '/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/.built' failed
      make[3]: *** [/home/skylar/tina-d1-h/out/t113-100ask/compile_dir/target/libwebsockets-openssl/libwebsockets-2.4.0/.built] Error 2
      make[3]: Leaving directory '/home/skylar/tina-d1-h/package/libs/libwebsockets'
      package/Makefile:192: recipe for target 'package/libs/libwebsockets/compile' failed
      make[2]: *** [package/libs/libwebsockets/compile] Error 2
      make[2]: Leaving directory '/home/skylar/tina-d1-h'
      package/Makefile:189: recipe for target '/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/home/skylar/tina-d1-h/out/t113-100ask/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/skylar/tina-d1-h'
      /home/skylar/tina-d1-h/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      [2]+  Done                    $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      #### make failed to build some targets (38 seconds) ####
