    How to increase bootlogo.bmp size (to 800x480)
    H/F/TV Series
    • E
      emresensoy LV 3 最后由 编辑
      Hi there
      I can change the bootlogo.bmp with same size bmp picture,
      But if I want to increase size to 5" lcd (800x480) its not works,
      What should I do to increase its size?
      Regards,
      • E
        when I changed this bootlogo.bmp file from 200x120 to 800x480,
        ~/LC/Tina-Linux/target/allwinner/generic/boot-resource/boot-resource/bootlogo.bmp
        pack command not pack the img file and the output was as;
        test@test-virtual-machine:~/LC/Tina-Linux$ pack
        PACK_CHIP         sun20iw1p1
        PACK_PLATFORM     tina
        PACK_BOARD        f133-mq_r
        PACK_KERN
        PACK_DEBUG        uart0
        PACK_SIG          none
        PACK_SECURE       none
        PACK_MODE         normal
        PACK_FUNC         android
        PACK_PROGRAMMER   none
        PACK_TAR_IMAGE    none
        PACK_TOPDIR       /home/test/LC/Tina-Linux
        No kernel param, parse it from f133
        copying tools file
        copying configs file
        storage_type value is 1
        rm /home/test/LC/Tina-Linux/out/f133-mq_r/image/sys_partition_nor.fex
        rm /home/test/LC/Tina-Linux/out/f133-mq_r/image/image_nor.cfg
        copying boot resource
        copying boot file
        make user resource for : /home/test/LC/Tina-Linux/out/f133-mq_r/image/sys_partition.fex
        handle partition user-res
        no user resource partitions
        APP_PART_DOWNLOAD_FILE = /home/test/LC/Tina-Linux/out/f133-mq_r/image/app.fex
        Need size of filesystem
        no data resource partitions
        don't build dtbo ...
        update_chip
        sboot file Path=/home/test/LC/Tina-Linux/out/f133-mq_r/image/sboot.bin
        script file Path=/home/test/LC/Tina-Linux/out/f133-mq_r/image/sys_config.bin
        update:unable to open sboot file
        script update sboot ok
        pack boot package
        content_count=3
        packing for tina linux
        normal
        mbr count = 4
        partitation file Path=/home/test/LC/Tina-Linux/out/f133-mq_r/image/sys_partition.bin
        mbr_name file Path=/home/test/LC/Tina-Linux/out/f133-mq_r/image/sunxi_mbr.fex
        download_name file Path=/home/test/LC/Tina-Linux/out/f133-mq_r/image/dlinfo.fex
        mbr size = 16384
        mbr magic softw411
        disk name=boot-resource
        ERROR: dl file boot-resource.fex size too large
        ERROR: filename = boot-resource.fex
        ERROR: dl_file_size = 2336 sector
        ERROR: part_size = 504 sector
        update_for_part_info -1
        ERROR: update mbr file fail
        ERROR: update_mbr failed
        • E
          SOLVED
          I changed size from 504 to 11504 in the file,
          then it pack the img file,
          ~/LC/Tina-Linux/device/config/chips/f133/configs/mq_r/sys_partition.fex
          [partition]
              size         = 11504
              user_type    = 0x8000
