    D1S TF卡启动固件修改文件系统无法启动
      lztmfx LV 5 最后由 编辑
      D1S默认启动TF卡固件为squashfs文件系统,可以正常启动。然后在tina根目录用make menuconfig把squashfs取消了,选择了ext4,kernel配置也选了对ext4文件系统的支持,编译后无法引导,看样子是挂在uboot了,报错如下:
      U-Boot 2018.07-ge987def5 (Nov 07 2022 - 03:11:27 +0000) Allwinner Technology
      [00.293]DRAM: 64 MiB
      [00.295]Relocation Offset is: 01eea000
      [00.300]secure enable bit: 0
      [00.302]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      sunxi flash map init
      SPI ALL: ready
      [00.313]flash init start
      [00.315]workmode = 0,storage type = 1
      [00.318][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.324][mmc]: get sdc_type fail and use default host:tm1.
      [00.330][mmc]: can't find node "mmc0",will add new node
      [00.335][mmc]: fdt err returned <no error>
      [00.339][mmc]: Using default timing para
      [00.342][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.361][mmc]: card_caps:0x3000000a
      [00.364][mmc]: host_caps:0x3000003f
      [00.368]sunxi flash init ok
      [00.370]line:703 init_clocks
      [00.373]drv_disp_init
      [00.391]drv_disp_init finish
      [00.401]Loading Environment from SUNXI_FLASH... OK
      [00.420]boot_gui_init:start
      [00.423]set disp.dev2_output_type fail. using defval=0
      [00.450]set disp.fb0_rot_used fail. using defval=0
      [00.454]set disp.fb0_rot_degree fail. using defval=0
      [00.624]boot_gui_init:finish
      [00.633]bmp_name=bootlogo.bmp size 38454
      [00.644]out of usb burn from boot: not need burn key
      [00.649]Item0 (Map) magic is bad
      [00.652]the secure storage item0 copy0 magic is bad
      [00.657]Item0 (Map) magic is bad
      [00.659]the secure storage item0 copy1 magic is bad
      [00.664]Item0 (Map) magic is bad
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.677]update part info
      [00.683]LCD open finish
      [00.687]change working_fdt 0x42aa9da0 to 0x42a89da0
      [00.696]The storage not support sample function
      [00.722]update dts
      Unhandled exception: Load access fault
      EPC: 0000000043eebdc6 TVAL: 000000000008f840
      ERROR ### Please RESET the board
      请教一下,TF卡启动卡可以用EXT4文件系统吗?
        lztmfx LV 5 最后由 编辑
        论坛逛了一圈,成功进入系统。
        主要修改点:
        1.uboot里面menuconfig使能etx4
        2.kernel里面menuconfig使能ext4,取消squashfs
        3.SDK/device/config/chips/d1s/configs/default/env.cfg里面将rootfstype=squashfs改为rootfstype=ext4
        4.如果make成功,pack失败就修改SDK/device/config/chips/d1s/configs/nezha_sd/sys_partition.fex的相应分区大小,一般都是rootfs分区大小不够,需要多大才够可以看pack的报错有显示
