    XR806开启蓝牙standby模式后内存分配错误
    • E
      Ednaing LV 2 最后由 编辑
      出现问题后,我尝试把standby关闭,取消待机机制,连接和广播就都正常了,但是功耗极大,不符合实际需求。介于 MEM ALLOC ERR部分代码被封装了,想问问有什么解决办法?我也试过用定时器自己控制待机周期,也没成功🤕
      以下是问题阐述:
      在从机广播操作完成后取消standby锁,用以降低功耗
      if(sys_msg.ble_on == 1)
      	printf("XXXXXXX bt_le_adv_start\n");
      	if(IS_ENABLED(CONFIG_BT_EXT_ADV))
      		err = bt_le_adv_start(BT_LE_EXT_ADV_CONN_NAME_ONE_SHOT, ad, ARRAY_SIZE(ad), NULL, 0);
      		err = bt_le_adv_start(BT_LE_ADV_CONN_NAME_ONE_SHOT, ad, ARRAY_SIZE(ad), NULL, 0);
      if (err)
      	printf("Advertising failed to start (err 0x%02x)\n", err);
      	SleepUnlock(SLEEP_LOCK_BLE);
      这时,广播期间log出现MEM FREE ERR
      ble rf_init done!
      resume noirq devices took 1990 ms
      resume devices took 0 ms
      <E>    <E>    MEM FREE ERR 4: 0x00235A98, 06-02-AA-AE
      suspend devices took 0 ms
      在此状态下连接主机,从机连接报错
      [H] Connected!!
      ========== Connection Parameter ==========
      = Remote Address 21:90:34:00:20:EA
      = Internval      24
      = Latency        0
      = Timeout        500
      vnd_ccc_cfg_changed vale=1
      handle 0 ref 2 -> 1
      <E>    MEM ALLOC ERR 3:pool_idx 6, blck_cnt 151, no buf pool
      <E>    pool id: 1<E>    slave should not send only 1 pkt with retransmit
      <E>    MEM FREE ERR 0: ptr_mem invalue
      <E>    cmd buff err<E>    MEM ALLOC ERR 3:pool_idx 6, blck_cnt 151, no buf pool
      <E>    pool id: 1<E>    EXEC error
      而后,连接终止并断开
      [bt] bt_recv: evt_flags & BT_HCI_EVT_FLAG_RECV_PRIO
      [bt] hci_event_prio: hci_event_prio
      [bt] hci_disconn_complete_prio: status 0x00 handle 0 reason 0x08
      [bt] bt_conn_ref: handle 0 ref 1 -> 2
      handle 0 ref 2 -> 1
      [bt] hci_rx_thread: BT_BUF_EVT
      [bt] hci_event: hci_event
      [bt] hci_disconn_complete: status 0x00 handle 0 reason 0x08
      handle 0 ref 2 -> 1
      vnd_ccc_cfg_changed vale=0
      [H] Disconnected 61:79:78:76:EB:47 reason 0x08
      bt_le_adv_start_legacy
      [H] Disconnected 5F:72:B7:49:FD:42 reason 0x08
      [RandomAddress C0:66:66:61:88:88 ]
      [bt] bt_le_adv_start_legacy: dir_adv=0
      [bt] bt_le_adv_start_legacy: &adv->target_addr.a=
      000000000000
      bt_hci_cmd_send_sync()
      [bt] bt_hci_cmd_send_sync: buf 0x23e3e8 opcode 0x2006 len 18 status 0x00
      但在重新广播时,只运行到以下函数
      param->peer == NULL
      le_adv_update
      bt_get_name
      set_ad()
      hci_set_ad()
      而正常广播流程在hci_set_ad()后还会接着走
      以下是我的prj_config.h 、 .config配置和free空间:
      prj_config.h
      #ifndef _PRJ_CONFIG_H_
      #define _PRJ_CONFIG_H_
      #ifdef __cplusplus
      extern "C" {
      #include "user_src/task_wifi_comm.h"
       * project base config
      /* main thread priority */
      #define PRJCONF_MAIN_THREAD_PRIO        OS_THREAD_PRIO_APP
      /* main thread stack size */
      #define PRJCONF_MAIN_THREAD_STACK_SIZE  (2 * 1024)
      /* sys ctrl enable/disable */
      #define PRJCONF_SYS_CTRL_EN             1
      /* sys ctrl thread priority */
      #define PRJCONF_SYS_CTRL_PRIO           OS_THREAD_PRIO_SYS_CTRL
      /* sys ctrl stack size */
      #define PRJCONF_SYS_CTRL_STACK_SIZE     (2 * 1024)
      /* sys ctrl queue length for receiving message */
      #define PRJCONF_SYS_CTRL_QUEUE_LEN      6
      /* image flash ID */
      #define PRJCONF_IMG_FLASH               0
      /* image start address, including bootloader */
      #define PRJCONF_IMG_ADDR                0x00000000
      /* save sysinfo to flash or not */
      #define PRJCONF_SYSINFO_SAVE_TO_FLASH   1
      #if PRJCONF_SYSINFO_SAVE_TO_FLASH
      /* sysinfo flash ID */
      #define PRJCONF_SYSINFO_FLASH           0
      /* sysinfo start address */
      #define PRJCONF_SYSINFO_ADDR            ((1024 - 4) * 1024)
      /* sysinfo size */
      #define PRJCONF_SYSINFO_SIZE            (4 * 1024)
      /* enable/disable checking whether sysinfo is overlap with image */
      #define PRJCONF_SYSINFO_CHECK_OVERLAP   1
      #endif /* PRJCONF_SYSINFO_SAVE_TO_FLASH */
      /* MAC address source */
      #define PRJCONF_MAC_ADDR_SOURCE         SYSINFO_MAC_ADDR_CHIPID//SYSINFO_MAC_ADDR_FLASH
      /* watchdog enable/disable */
      #define PRJCONF_WDG_EN                  1
      /* watchdog timeout value */
      #define PRJCONF_WDG_TIMEOUT             WDG_TIMEOUT_16SEC
      /* watchdog feeding period (in ms), MUST less than PRJCONF_WDG_TIMEOUT */
      #define PRJCONF_WDG_FEED_PERIOD         (10 * 1000)
       * project hardware feature
      /* uart enable/disable */
      #if UART_DEBUG
      #define PRJCONF_UART_EN                 1
      #else
      #define PRJCONF_UART_EN                 0
      /* h/w crypto engine enable/disable */
      #define PRJCONF_CE_EN                   0
      /* spi enable/disable */
      #define PRJCONF_SPI_EN                  1
      /* Xradio internal codec sound card enable/disable */
      #define PRJCONF_INTERNAL_SOUNDCARD_EN   0
      /* AC107 sound card enable/disable */
      #define PRJCONF_AC107_SOUNDCARD_EN      0
       * project service feature
      /* console enable/disable */
      #define PRJCONF_CONSOLE_EN              0
      /* network and wlan enable/disable */
      #define PRJCONF_NET_EN                  1
      /* ble enable/disable */
      #define PRJCONF_BLE_EN                  1
      /* environment variable "TZ" for time zone setting */
      #define PRJCONF_ENV_TZ                  "TZ=GMT-8"
      #ifdef __cplusplus
      #endif /* _PRJ_CONFIG_H_ */
      .config
      # Automatically generated file; DO NOT EDIT.
      # XR806 SDK Configuration
      CONFIG_PROJECT="demo/at_demo"
      # Project settings
      CONFIG_CHIP_XR806=y
      # CONFIG_HOSC_TYPE_24M is not set
      # CONFIG_HOSC_TYPE_26M is not set
      # CONFIG_HOSC_TYPE_32M is not set
      CONFIG_HOSC_TYPE_40M=y
      CONFIG_BOARD="xr806_dig_ver"
      CONFIG_DEFAULT_FLASH_FLASHC=y
      # CONFIG_DEFAULT_FLASH_SPI is not set
      CONFIG_XIP=y
      # CONFIG_PSRAM is not set
      CONFIG_CACHE=y
      # CONFIG_CACHE_SIZE_8K is not set
      # CONFIG_CACHE_SIZE_16K is not set
      CONFIG_CACHE_SIZE_32K=y
      CONFIG_OTA=y
      # CONFIG_OTA_POLICY_PINGPONG is not set
      CONFIG_OTA_POLICY_IMAGE_COMPRESSION=y
      # CONFIG_XPLAYER is not set
      # CONFIG_BIN_COMPRESS is not set
      # CONFIG_BENCH_MARK is not set
      CONFIG_MSP_STACK_SIZE=1024
      # CONFIG_BOOTLOADER is not set
      # end of Project settings
      CONFIG_PWR_INTERNAL_LDO=y
      # CONFIG_PWR_INTERNAL_DCDC is not set
      # CONFIG_PWR_EXTERNAL is not set
      CONFIG_WLAN=y
      # Networking options
      CONFIG_MBEDTLS_VER="2.16.0"
      # CONFIG_LWIP_VER_1_4_1 is not set
      # CONFIG_LWIP_VER_2_0_3 is not set
      CONFIG_LWIP_VER_2_1_2=y
      # end of Networking options
      CONFIG_WIFI_CERTIFIED=y
      CONFIG_WLAN_STA=y
      # CONFIG_WLAN_STA_WPS is not set
      # CONFIG_WLAN_MONITOR is not set
      # CONFIG_WLAN_AP is not set
      # CONFIG_ETF is not set
      CONFIG_MBUF_IMPL_MODE=0
      # CONFIG_MUTIL_NET_STACK is not set
      CONFIG_BLE_FEATURE=y
      CONFIG_BLE=y
      CONFIG_BT=y
      CONFIG_BLEHOST=y
      CONFIG_BLEHOST_Z_ITERABLE_SECTION=y
      # CONFIG_BT_LOG_LEVEL_OFF is not set
      # CONFIG_BT_LOG_LEVEL_ERR is not set
      # CONFIG_BT_LOG_LEVEL_WRN is not set
      CONFIG_BT_LOG_LEVEL_INF=y
      # CONFIG_BT_LOG_LEVEL_DBG is not set
      CONFIG_BT_LOG_LEVEL=3
      CONFIG_BT_HCI=y
      # CONFIG_BT_CUSTOM is not set
      # CONFIG_BT_HCI_RAW is not set
      CONFIG_BT_PERIPHERAL=y
      CONFIG_BT_CENTRAL=y
      CONFIG_BT_BROADCASTER=y
      # CONFIG_BT_EXT_ADV is not set
      CONFIG_BT_OBSERVER=y
      CONFIG_BT_CONN=y
      CONFIG_BT_MAX_CONN=5
      CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
      CONFIG_BT_REMOTE_VERSION=y
      CONFIG_BT_PHY_UPDATE=y
      CONFIG_BT_DATA_LEN_UPDATE=y
      CONFIG_BT_DEINIT=y
      CONFIG_BT_VAR_MEM_DYNC_ALLOC=y
      CONFIG_BT_RPA=y
      CONFIG_BT_ASSERT=y
      CONFIG_BT_ASSERT_VERBOSE=y
      # CONFIG_BT_ASSERT_PANIC is not set
      CONFIG_BT_DEBUG=y
      # CONFIG_BT_DEBUG_NONE is not set
      # CONFIG_BT_DEBUG_LOG is not set
      # CONFIG_BT_DEBUG_LOG_WITH_HCI_PRINT is not set
      CONFIG_BTSNOOP=y
      # CONFIG_BT_DEBUG_RPA is not set
      # Networking
      CONFIG_NET_BUF=y
      CONFIG_NET_BUF_USER_DATA_SIZE=4
      # CONFIG_NET_BUF_LOG is not set
      # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
      # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
      # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
      CONFIG_NET_BUF_LOG_LEVEL_INF=y
      # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
      CONFIG_NET_BUF_LOG_LEVEL=3
      # CONFIG_NET_BUF_POOL_USAGE is not set
      # end of Networking
      # Debugging Options
      CONFIG_ASSERT=y
      CONFIG_ASSERT_LEVEL=2
      # CONFIG_FORCE_NO_ASSERT is not set
      # end of Debugging Options
      CONFIG_LOG=y
      # Logging levels filtering
      CONFIG_LOG_DEFAULT_LEVEL=0
      # end of Logging levels filtering
      # Output Formatting
      # Prepend non-hexdump log message with function name
      CONFIG_LOG_FUNC_NAME_PREFIX_ERR=y
      CONFIG_LOG_FUNC_NAME_PREFIX_WRN=y
      CONFIG_LOG_FUNC_NAME_PREFIX_INF=y
      CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
      # end of Prepend non-hexdump log message with function name
      # CONFIG_LOG_BACKEND_SHOW_COLOR is not set
      # CONFIG_LOG_SHOW_TAGS is not set
      # end of Output Formatting
      # CONFIG_SETTINGS is not set
      # Work Queue Options
      CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
      CONFIG_SYSTEM_WORKQUEUE_PRIORITY=3
      # end of Work Queue Options
      CONFIG_POLL=y
      CONFIG_SYS_CLOCK_EXISTS=y
      # Host Stack Configuration
      CONFIG_BT_HCI_HOST=y
      CONFIG_BT_HCI_CMD_COUNT=2
      CONFIG_BT_RX_BUF_COUNT=20
      CONFIG_BT_RX_BUF_LEN=255
      CONFIG_BT_DISCARDABLE_BUF_SIZE=255
      CONFIG_BT_HCI_TX_STACK_SIZE=512
      CONFIG_BT_HCI_ECC_STACK_SIZE=1024
      CONFIG_BT_HCI_TX_PRIO=3
      CONFIG_BT_HCI_RESERVE=0
      CONFIG_BT_RX_STACK_SIZE=2200
      CONFIG_BT_RX_PRIO=4
      CONFIG_BT_HOST_CRYPTO=y
      CONFIG_BT_WHITELIST=y
      CONFIG_BT_ACL_RX_COUNT=6
      CONFIG_BT_CONN_TX_MAX=8
      CONFIG_BT_USER_PHY_UPDATE=y
      # CONFIG_BT_AUTO_PHY_UPDATE is not set
      CONFIG_BT_USER_DATA_LEN_UPDATE=y
      # CONFIG_BT_AUTO_DATA_LEN_UPDATE is not set
      CONFIG_BT_REMOTE_INFO=y
      CONFIG_BT_SMP=y
      # CONFIG_BT_PRIVACY is not set
      CONFIG_BT_SIGNING=y
      CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y
      # CONFIG_BT_SMP_SC_PAIR_ONLY is not set
      # CONFIG_BT_SMP_SC_ONLY is not set
      # CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
      # CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
      CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
      # CONFIG_BT_FIXED_PASSKEY is not set
      # CONFIG_BT_USE_DEBUG_KEYS is not set
      CONFIG_BT_BONDABLE=y
      # CONFIG_BT_BONDING_REQUIRED is not set
      # CONFIG_BT_STORE_DEBUG_KEYS is not set
      CONFIG_BT_SMP_ENFORCE_MITM=y
      CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
      # L2CAP Options
      CONFIG_BT_L2CAP_RX_MTU=247
      CONFIG_BT_L2CAP_TX_BUF_COUNT=8
      CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
      CONFIG_BT_L2CAP_TX_MTU=247
      CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
      # CONFIG_BT_L2CAP_ECRED is not set
      # CONFIG_BT_DEBUG_L2CAP is not set
      # end of L2CAP Options
      # ATT and GATT Options
      # CONFIG_BT_ATT_ENFORCE_FLOW is not set
      CONFIG_BT_ATT_PREPARE_COUNT=14
      CONFIG_BT_GATT_SERVICE_CHANGED=y
      CONFIG_BT_GATT_DYNAMIC_DB=y
      # CONFIG_BT_GATT_CACHING is not set
      CONFIG_BT_GATT_CLIENT=y
      CONFIG_BT_GATT_READ_MULTIPLE=y
      CONFIG_BT_GATT_AUTO_DISCOVER_CCC=y
      CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
      # CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS is not set
      CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y
      # CONFIG_BT_DEBUG_ATT is not set
      # CONFIG_BT_DEBUG_GATT is not set
      # end of ATT and GATT Options
      CONFIG_BT_MAX_PAIRED=5
      CONFIG_BT_CREATE_CONN_TIMEOUT=3
      CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
      CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
      CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
      # CONFIG_BT_SCAN_WITH_IDENTITY is not set
      CONFIG_BT_DEVICE_NAME_DYNAMIC=y
      CONFIG_BT_DEVICE_NAME_MAX=28
      CONFIG_BT_DEVICE_NAME="Xradio"
      CONFIG_BT_DEVICE_APPEARANCE=192
      CONFIG_BT_ID_MAX=2
      # CONFIG_BT_DF is not set
      CONFIG_BT_ECC=y
      CONFIG_BT_TINYCRYPT_ECC=y
      CONFIG_BT_HOST_CCM=y
      # CONFIG_BT_DEBUG_RESOURCES_USE is not set
      # CONFIG_BT_DEBUG_HCI_CORE is not set
      # CONFIG_BT_DEBUG_CONN is not set
      # CONFIG_BT_DEBUG_ISO is not set
      # CONFIG_BT_DEBUG_KEYS is not set
      # CONFIG_BT_DEBUG_SMP is not set
      # CONFIG_BT_DEBUG_SERVICE is not set
      # CONFIG_BT_TESTING is not set
      # CONFIG_BT_HCI_VS_EVT_USER is not set
      CONFIG_BT_COMPANY_ID=0x05F1
      # CONFIG_BT_MESH is not set
      CONFIG_BT_PWR_MGR=y
      CONFIG_BT_XR_IMPL=y
      # Console options
      CONFIG_CONSOLE_CMD_LINE_SIZE=512
      # end of Console options
      # CONFIG_FILESYSTEMS is not set
      # Kernel options
      CONFIG_OS_FREERTOS=y
      CONFIG_FREERTOS_VER_10_2_1=y
      CONFIG_OS_FREERTOS_VERSION_STR="v10.2.1"
      # CONFIG_OS_USE_IDLE_HOOK is not set
      # end of Kernel options
      # Devices Driver options
      # Devices options
      # CONFIG_FLASH_ERASE_WRITE_DISABLE_IRQ is not set
      # CONFIG_FLASH_POWER_DOWN_PROTECT is not set
      CONFIG_FLASH_PM_ALLOW_ENTER_PWR_DOWN=y
      CONFIG_FLASH_ARBIT=y
      CONFIG_FLASH_ERASE_DURATION=60
      CONFIG_FLASH_WRITE_DURATION=10
      # PSRAM Devices
      # end of PSRAM Devices
      # SDMMC Devices
      # end of SDMMC Devices
      # CONFIG_IR_USED_CLK_32K is not set
      # end of Devices options
      # AXP PMU support
      # CONFIG_AXP_CORE is not set
      # end of AXP PMU support
      # CONFIG_DA217 is not set
      # end of Devices Driver options
      CONFIG_PM=y
      CONFIG_PM_WAKELOCKS=y
      CONFIG_PM_TRY_NUM_WHEN_FAIL=0
      CONFIG_PM_IDLE_SUSPEND=y
      CONFIG_STANDBY_RET_SRAM=y
      CONFIG_STANDBY_RET_SRAM_ALL=y
      # CONFIG_WAKEUP_PIN is not set
      CONFIG_BLE_LOW_PWR_MODE=y
      CONFIG_PM_DEBUG_LEVEL=4
      # Security options
      # CONFIG_SECURE_BOOT is not set
      # CONFIG_FLASH_CRYPTO is not set
      # CONFIG_TRUSTZONE is not set
      # end of Security options
      # Feature options
      CONFIG_LIBC_REDEFINE_GCC_INT32_TYPE=y
      CONFIG_LIBC_PRINTF_FLOAT=y
      CONFIG_LIBC_SCANF_FLOAT=y
      CONFIG_LIBC_WRAP_STDIO=y
      CONFIG_MALLOC_MODE=0
      CONFIG_SECTION_ATTRIBUTE_XIP=y
      CONFIG_SECTION_ATTRIBUTE_NONXIP=y
      CONFIG_SECTION_ATTRIBUTE_SRAM=y
      # end of Feature options
      # Debug options
      # CONFIG_OS_DEBUG_CPU_USAGE is not set
      CONFIG_MALLOC_TRACE=y
      # CONFIG_BACKTRACE is not set
      # CONFIG_WATCHPOINT is not set
      # CONFIG_HEAP_FREE_CHECK is not set
      # CONFIG_PSRAM_MALLOC_TRACE is not set
      CONFIG_ROM_FREERTOS=y
      CONFIG_REDUCE_DBG_MSG=y
      # CONFIG_REDUCE_RAM is not set
      # CONFIG_WLAN_SHARE_RAM is not set
      # CONFIG_EXT_FLASH_ONLY is not set
      CONFIG_ROM=y
      CONFIG_ROM_XZ=y
      # end of Debug options
      # CONFIG_CPLUSPLUS is not set
      free
      total        used        free      shared  buff/cache   available
      Mem:       28491712     3856648    20704212       62280     3930852    24141956
      Swap:        945416           0      945416
