    T113 S3 有JPG H264解码案例吗?尝试使用decodertest DEMO 解码JPG H264 出错
    • B
      b13322485475 LV 3 最后由 编辑
      代码
      #include <unistd.h>
      #include <stdlib.h>
      #include <string.h>
      #include <pthread.h>
      #include <ctype.h>
      #include <errno.h>
      #include <sys/select.h>
      #include <sys/types.h>
      #include <dirent.h>
      #include <fcntl.h>
      #include <signal.h>
      #include <tplayer.h>
      //#include <power_manager_client.h>
      #define TOTAL_VIDEO_AUDIO_NUM 100
      #define MAX_FILE_NAME_LEN 256
      #define FILE_TYPE_NUM 29
      #define FILE_TYPE_LEN 10
      #define VIDEO_TYPE_NUM 11
      #define VIDEO_TYPE_LEN 10
      #define USE_REPEAT_RESET_MODE 1
      #define LOOP_PLAY_FLAG 1
      typedef struct DemoPlayerContext
      TPlayer* mTPlayer;
      int mSeekable;
      int mError;
      int mVideoFrameNum;
      bool mPreparedFlag;
      bool mLoopFlag;
      bool mSetLoop;
      bool mComplete;
      char mUrl[512];
      MediaInfo* mMediaInfo;
      char mVideoAudioList[TOTAL_VIDEO_AUDIO_NUM][MAX_FILE_NAME_LEN];
      int mCurPlayIndex;
      int mRealFileNum;
      sem_t mPreparedSem;
      }DemoPlayerContext;
      //* define commands for user control.
      typedef struct Command
      const char* strCommand;
      int nCommandId;
      const char* strHelpMsg;
      }Command;
      #define COMMAND_HELP 0x1 //* show help message.
      #define COMMAND_QUIT 0x2 //* quit this program.
      #define COMMAND_SET_SOURCE 0x101 //* set url of media file.
      #define COMMAND_PREPARE 0x102 //* prepare the media file.
      #define COMMAND_PLAY 0x103 //* start playback.
      #define COMMAND_PAUSE 0x104 //* pause the playback.
      #define COMMAND_STOP 0x105 //* stop the playback.
      #define COMMAND_SEEKTO 0x106 //* seek to posion, in unit of second.
      #define COMMAND_RESET 0x107 //* reset the player
      #define COMMAND_SHOW_MEDIAINFO 0x108 //* show media information.
      #define COMMAND_SHOW_DURATION 0x109 //* show media duration, in unit of second.
      #define COMMAND_SHOW_POSITION 0x110 //* show current play position, in unit of second.
      #define COMMAND_SWITCH_AUDIO 0x111 //* switch autio track.
      #define COMMAND_PLAY_URL 0x112 //set url and prepare and play
      #define COMMAND_SET_VOLUME 0x113 //set the software volume
      #define COMMAND_GET_VOLUME 0x114 //get the software volume
      #define COMMAND_SET_LOOP 0x115 //set loop play flag,1 means loop play,0 means not loop play
      #define COMMAND_SET_SCALEDOWN 0x116 //set video scale down ratio,valid value is:2,4,8 . 2 means 1/2 scaledown,4 means 1/4 scaledown,8 means 1/8 scaledown
      #define COMMAND_FAST_FORWARD 0x117 //fast forward,valid value is:2,4,8,16, 2 means 2 times fast forward,4 means 4 times fast forward,8 means 8 times fast forward,16 means 16 times fast forward
      #define COMMAND_FAST_BACKWARD 0x118 //fast backward,valid value is:2,4,8,16,2 means 2 times fast backward,4 means 4 times fast backward,8 means 8 times fast backward,16 means 16 times fast backward
      #define COMMAND_SET_SRC_RECT 0x119 //set display source crop rect
      #define COMMAND_SET_OUTPUT_RECT 0x120 //set display output display rect
      #define COMMAND_GET_DISP_FRAMERATE 0x121 //* show the real display framerate
      #define CEDARX_UNUSE(param) (void)param
      static const Command commands[] =
      {"help", COMMAND_HELP, "show this help message."},
      {"quit", COMMAND_QUIT, "quit this program."},
      {"set url", COMMAND_SET_SOURCE, "set url of the media, for example, set url: ~/testfile.mkv."},
      {"prepare", COMMAND_PREPARE, "prepare the media."},
      {"play", COMMAND_PLAY, "start playback."},
      {"pause", COMMAND_PAUSE, "pause the playback."},
      {"stop", COMMAND_STOP, "stop the playback."},
      {"seek to", COMMAND_SEEKTO, "seek to specific position to play, position is in unit of second, for example, seek to: 100."},
      {"reset", COMMAND_RESET, "reset the player."},
      {"show media info", COMMAND_SHOW_MEDIAINFO, "show media information of the media file."},
      {"show duration", COMMAND_SHOW_DURATION, "show duration of the media file."},
      {"show position", COMMAND_SHOW_POSITION, "show current play position, position is in unit of second."},
      {"switch audio", COMMAND_SWITCH_AUDIO, "switch audio to a specific track, for example, switch audio: 2, track is start counting from 0."},
      {"play url", COMMAND_PLAY_URL, "set url and prepare and play url,for example:play url:/mnt/UDISK/test.mp3"},
      {"set volume", COMMAND_SET_VOLUME, "set the software volume,the range is 0-40,for example:set volume:30"},
      {"get volume", COMMAND_GET_VOLUME, "get the software volume"},
      {"set loop", COMMAND_SET_LOOP, "set the loop play flag,1 means loop play,0 means not loop play"},
      {"set scaledown", COMMAND_SET_SCALEDOWN, "set video scale down ratio,valid value is:2,4,8 . 2 means 1/2 scaledown,4 means 1/4 scaledown,8 means 1/8 scaledown"},
      {"fast forward", COMMAND_FAST_FORWARD, "fast forward,valid value is:2,4,8,16, 2 means 2 times fast forward,4 means 4 times fast forward,8 means 8 times fast forward,16 means 16 times fast forward"},
      {"fast backward", COMMAND_FAST_BACKWARD, "fast backward,valid value is:2,4,8,16,2 means 2 times fast backward,4 means 4 times fast backward,8 means 8 times fast backward,16 means 16 times fast backward"},
      {"set src_rect", COMMAND_SET_SRC_RECT, "set display source crop rect"},
      {"set dst_rect", COMMAND_SET_OUTPUT_RECT, "set display output rect"},
      {"get display framerate", COMMAND_GET_DISP_FRAMERATE, "show the real display framerate."},
      {NULL, 0, NULL}
      DemoPlayerContext demoPlayer;
      DemoPlayerContext gDemoPlayers[5];
      int isDir = 0;
      int gScreenWidth = 0;
      int gScreenHeight = 0;
      int gPlayerNum = 0;
      /* Signal handler */
      static void terminate(int sig_no)
      printf("Got signal %d, exiting ...\n", sig_no);
      if(demoPlayer.mTPlayer != NULL)
          TPlayerDestroy(demoPlayer.mTPlayer);
          demoPlayer.mTPlayer = NULL;
          printf("TPlayerDestroy() successfully\n");
      sem_destroy(&demoPlayer.mPreparedSem);
      int i=0;
      for(i = gPlayerNum-1;i >= 0;i--){
          if(gDemoPlayers[i].mTPlayer != NULL)
              TPlayerDestroy(gDemoPlayers[i].mTPlayer);
              gDemoPlayers[i].mTPlayer = NULL;
              printf("TPlayerDestroy(%d) successfully\n",i);
      printf("destroy tplayer \n");
      printf("tplaydemo exit\n");
      exit(1);
      static void install_sig_handler(void)
      signal(SIGBUS, terminate);
      signal(SIGFPE, terminate);
      signal(SIGHUP, terminate);
      signal(SIGILL, terminate);
      signal(SIGINT, terminate);
      signal(SIGIOT, terminate);
      signal(SIGPIPE, terminate);
      signal(SIGQUIT, terminate);
      signal(SIGSEGV, terminate);
      signal(SIGSYS, terminate);
      signal(SIGTERM, terminate);
      signal(SIGTRAP, terminate);
      signal(SIGUSR1, terminate);
      signal(SIGUSR2, terminate);
      static void showHelp(void)
      int i;
      printf("\n");
      printf("**********************************************************\n");
      printf("
      This is a simple media player, when it is started, you can input commands to tell\n");
      printf("
      what you want it to do.\n");
      printf("
      Usage: \n");
      printf("
      # ./tplayerdemo\n");
      printf("
      # set url:/mnt/UDISK/test.mp3\n");
      printf("
      # prepare\n");
      printf("
      # show media info\n");
      printf("
      # play\n");
      printf("
      # pause\n");
      printf("
      # stop\n");
      printf("
      # reset\n");
      printf("
      # seek to:100\n");
      printf("
      # play url:/mnt/UDISK/test.mp3\n");
      printf("
      # set volume:30\n");
      printf("
      # get volume\n");
      printf("
      # set loop:1 \n");
      printf("
      # set scaledown:2 \n");
      printf("
      # fast forward:2 \n");
      printf("
      # fast backward:2 \n");
      printf("
      # switch audio:1 \n");
      printf("
      #get display framerate \n");
      printf("
      \n");
      printf("
      Command and it's param is seperated by a colon, param is optional, as below:\n");
      printf("
      Command[: Param]\n");
      printf("
      #notice:we can play a list use the following command,for example the video or audio file puts in /mnt/UDISK/ directory \n");
      printf("
      #tplayerdemo /mnt/UDISK/ \n");
      printf("
      #notice:we can play one file use the following command,for example the video or audio file puts in /mnt/UDISK/ directory \n");
      printf("
      #tplayerdemo /mnt/UDISK/test.mp4 \n");
      printf("
      #notice:we can play two file use the following command,for example the video or audio file puts in /mnt/UDISK/ directory \n");
      printf("
      #tplayerdemo /mnt/UDISK/test1.mp4 /mnt/UDISK/test2.mp4\n");
      printf("
      \n");
      printf("
      here are the commands supported:\n");
      for(i=0; ; i++)
          if(commands[i].strCommand == NULL)
              break;
          printf("*    %s:\n", commands[i].strCommand);
          printf("*\t\t%s\n",  commands[i].strHelpMsg);
      printf("*\n");
      printf("******************************************************************************************\n");
      static int readCommand(char* strCommandLine, int nMaxLineSize)
      int nMaxFds;
      fd_set readFdSet;
      int result;
      char* p;
      unsigned int nReadBytes;
      struct timeval tv;
      tv.tv_sec = 1;
      tv.tv_usec = 0;
      fflush(stdout);
      nMaxFds    = 0;
      FD_ZERO(&readFdSet);
      FD_SET(STDIN_FILENO, &readFdSet);
      result = select(nMaxFds+1, &readFdSet, NULL, NULL, &tv);
      if(result > 0)
          printf("\ntplayerdemo# ");
          if(FD_ISSET(STDIN_FILENO, &readFdSet))
              nReadBytes = read(STDIN_FILENO, &strCommandLine[0], nMaxLineSize);
              if(nReadBytes > 0)
                  p = strCommandLine;
                  while(*p != 0)
                      if(*p == 0xa)
                          *p = 0;
                          break;
                      p++;
      return -1;
      static void formatString(char* strIn)
      char* ptrIn;
      char* ptrOut;
      int len;
      int i;
      if(strIn == NULL || (len=strlen(strIn)) == 0)
          return;
      ptrIn  = strIn;
      ptrOut = strIn;
      i      = 0;
      while(*ptrIn != '\0')
          //* skip the beginning space or multiple space between words.
          if(*ptrIn != ' ' || (i!=0 && *(ptrOut-1)!=' '))
              *ptrOut++ = *ptrIn++;
              i++;
              ptrIn++;
      //* skip the space at the tail.
      if(i==0 || *(ptrOut-1) != ' ')
          *ptrOut = '\0';
          *(ptrOut-1) = '\0';
      return;
      //* return command id,
      static int parseCommandLine(char* strCommandLine, unsigned long* pParam)
      char* strCommand;
      char* strParam;
      int i;
      int nCommandId;
      char colon = ':';
      if(strCommandLine == NULL || strlen(strCommandLine) == 0)
          return -1;
      strCommand = strCommandLine;
      strParam   = strchr(strCommandLine, colon);
      if(strParam != NULL)
          *strParam = '\0';
          strParam++;
      formatString(strCommand);
      formatString(strParam);
      nCommandId = -1;
      for(i=0; commands[i].strCommand != NULL; i++)
          if(strcmp(commands[i].strCommand, strCommand) == 0)
              nCommandId = commands[i].nCommandId;
              break;
          return -1;
      switch(nCommandId)
          case COMMAND_SET_SOURCE:
              if(strParam != NULL && strlen(strParam) > 0)
                  *pParam = (uintptr_t)strParam;        //* pointer to the url.
                  printf("no url specified.\n");
                  nCommandId = -1;
              break;
          case COMMAND_SEEKTO:
                  *pParam = (int)strtol(strParam, (char**)NULL, 10);  //* seek time in unit of second.
                  if(errno == EINVAL || errno == ERANGE)
                      printf("seek time is not valid.\n");
                      nCommandId = -1;
                  printf("no seek time is specified.\n");
                  nCommandId = -1;
              break;
          case COMMAND_SWITCH_AUDIO:
                  *pParam = (int)strtol(strParam, (char**)NULL, 10);  //* audio stream index start counting from 0.
                      printf("audio stream index is not valid.\n");
                      nCommandId = -1;
                  printf("no audio stream index is specified.\n");
                  nCommandId = -1;
              break;
          case COMMAND_PLAY_URL:
                  printf("no url to play.\n");
                  nCommandId = -1;
              break;
          case COMMAND_SET_VOLUME:
                      printf("volume value is not valid.\n");
                      nCommandId = -1;
                  printf("the volume value is not specified.\n");
                  nCommandId = -1;
              break;
          case COMMAND_SET_LOOP:
                      printf("loop value is not valid.\n");
                      nCommandId = -1;
                  printf("the loop value is not specified.\n");
                  nCommandId = -1;
              break;
          case COMMAND_SET_SCALEDOWN:
                      printf("scaledown value is not valid.\n");
                      nCommandId = -1;
                  printf("the scaledown value is not specified.\n");
                  nCommandId = -1;
              break;
          case COMMAND_FAST_FORWARD:
                      printf("play fast value is not valid.\n");
                      nCommandId = -1;
                  printf("play fast value is not specified.\n");
                  nCommandId = -1;
              break;
          case COMMAND_FAST_BACKWARD:
                      printf("play slow value is not valid.\n");
                      nCommandId = -1;
                  printf("play slow value is not specified.\n");
                  nCommandId = -1;
              break;
          default:
              break;
      return nCommandId;
      static int semTimedWait(sem_t* sem, int64_t time_ms)
      int err;
      if(time_ms == -1)
          err = sem_wait(sem);
          struct timespec ts;
          clock_gettime(CLOCK_REALTIME, &ts);
          ts.tv_nsec += time_ms % 1000 * 1000 * 1000;
          ts.tv_sec += time_ms / 1000 + ts.tv_nsec / (1000 * 1000 * 1000);
          ts.tv_nsec = ts.tv_nsec % (1000*1000*1000);
          err = sem_timedwait(sem, &ts);
      return err;
      //* a callback for tplayer.
      int CallbackForTPlayer(void* pUserData, int msg, int param0, void* param1)
      DemoPlayerContext* pDemoPlayer = (DemoPlayerContext*)pUserData;
      CEDARX_UNUSE(param1);
      switch(msg)
          case TPLAYER_NOTIFY_PREPARED:
              if (pDemoPlayer->mError == 1) {
                  printf("[tplayerdemo][%s %d]pDemoPlayer is in error status, invalid tplayer prepared call\n", __func__, __LINE__);
              } else {
                  printf("TPLAYER_NOTIFY_PREPARED,has prepared.\n");
                  sem_post(&pDemoPlayer->mPreparedSem);
                  pDemoPlayer->mPreparedFlag = 1;
              break;
          case TPLAYER_NOTIFY_PLAYBACK_COMPLETE:
              printf("TPLAYER_NOTIFY_PLAYBACK_COMPLETE\n");
              pDemoPlayer->mComplete = 1;
              if(pDemoPlayer->mSetLoop == 1){
                  pDemoPlayer->mLoopFlag = 1;
              }else{
                  pDemoPlayer->mLoopFlag = 0;
              //PowerManagerReleaseWakeLock("tplayerdemo");
              break;
          case TPLAYER_NOTIFY_SEEK_COMPLETE:
              printf("TPLAYER_NOTIFY_SEEK_COMPLETE>>>>info: seek ok.\n");
              break;
          case TPLAYER_NOTIFY_MEDIA_ERROR:
              switch (param0)
                  case TPLAYER_MEDIA_ERROR_UNKNOWN:
                      printf("erro type:TPLAYER_MEDIA_ERROR_UNKNOWN\n");
                      break;
                  case TPLAYER_MEDIA_ERROR_UNSUPPORTED:
                      printf("erro type:TPLAYER_MEDIA_ERROR_UNSUPPORTED\n");
                      break;
                  case TPLAYER_MEDIA_ERROR_IO:
                      printf("erro type:TPLAYER_MEDIA_ERROR_IO\n");
                      break;
              printf("TPLAYER_NOTIFY_MEDIA_ERROR\n");
              pDemoPlayer->mError = 1;
              if(pDemoPlayer->mPreparedFlag == 0){
                  printf("recive err when preparing\n");
              }else{
              printf("error: open media source fail.\n");
              break;
          case TPLAYER_NOTIFY_NOT_SEEKABLE:
              pDemoPlayer->mSeekable = 0;
              printf("info: media source is unseekable.\n");
              break;
          case TPLAYER_NOTIFY_BUFFER_START:
              printf("have no enough data to play\n");
              break;
          case TPLAYER_NOTIFY_BUFFER_END:
              printf("have enough data to play again\n");
              break;
          case TPLAYER_NOTIFY_VIDEO_FRAME:
              //printf("get the decoded video frame\n");
              break;
          case TPLAYER_NOTIFY_DISP_RECT_SET_ERROR:
              printf("TPLAYER_NOTIFY_DISP_RECT_SET_ERROR: multi video set disp rect area err!!!!!\n");
              break;
          case TPLAYER_NOTIFY_ODD_EVEN_COORDINATE_SET_ERROR:
              printf("TPLAYER_NOTIFY_ODD_EVEN_COORDINATE_SET_ERROR: multi video set (x,y) coordinate err!!!!!\n");
              break;
          case TPLAYER_NOTIFY_WIDTH_AREA_SET_ERROR:
              printf("TPLAYER_NOTIFY_WIDTH_AREA_SET_ERROR !!!!!\n");
              break;
          case TPLAYER_NOTIFY_DISP_DISLOCATION_ERROR:
              printf("TPLAYER_NOTIFY_DISP_DISLOCATION_ERROR: check your (x,y) coordinate and disp area\n");
              break;
          case TPLAYER_NOTIFY_AUDIO_FRAME:
              //printf("get the decoded audio frame\n");
              break;
          case TPLAYER_NOTIFY_SUBTITLE_FRAME:
              //printf("get the decoded subtitle frame\n");
              break;
          case TPLAYER_NOTYFY_DECODED_VIDEO_SIZE:
              int w, h;
              w   = ((int*)param1)[0];   //real decoded video width
              h  = ((int*)param1)[1];   //real decoded video height
              printf("*****tplayerdemo:video decoded width = %d,height = %d",w,h);
              //int divider = 1;
              //if(w>400){
              //    divider = w/400+1;
              //w = w/divider;
              //h = h/divider;
              printf("real set to display rect:w = %d,h = %d\n",w,h);
              //TPlayerSetSrcRect(pDemoPlayer->mTPlayer, 0, 0, w, h);
          default:
              printf("warning: unknown callback from Tinaplayer.\n");
              break;
      static int playVideo(DemoPlayerContext* playerContext, char* url,int x,int y,int width,int height)
      printf("before TPlayerSetDataSource,%d:%s\n",playerContext,url);
      playerContext->mSeekable = 1;
      if(TPlayerSetDataSource(playerContext->mTPlayer,url,NULL)!= 0)
          printf("TPlayerSetDataSource return fail.\n");
          return -1;
      }else{
          printf("setDataSource end\n");
      if(TPlayerPrepare(playerContext->mTPlayer)!= 0)
          printf("TPlayerPrepare return fail.\n");
          return -1;
      }else{
          printf("TPlayerPrepare end\n");
      playerContext->mComplete = 0;
      playerContext->mError = 0;
      TPlayerSetDisplayRect(playerContext->mTPlayer, x, y, width, height);
      #if LOOP_PLAY_FLAG
      #if !USE_REPEAT_RESET_MODE
      TPlayerSetLooping(playerContext->mTPlayer,1);
      #ifndef ONLY_DISABLE_AUDIO
      TPlayerSetAudioEQType(playerContext->mTPlayer, AUD_EQ_TYPE_NORMAL);
      if(TPlayerStart(playerContext->mTPlayer) != 0)
          printf("TPlayerStart() return fail.\n");
          return -1;
      }else{
          printf("started.\n");
      static int createPlayersAndPlayVideos(int argc, char** argv)
      char fileType[FILE_TYPE_NUM][FILE_TYPE_LEN] = {".avi",".mkv",".flv",".ts",".mp4",".ts",".webm",".asf",".mpg",".mpeg",".mov",".vob",".3gp",".wmv",".pmp",".f4v",
      ".mp1",".mp2",".mp3",".ogg",".flac",".ape",".wav",".m4a",".amr",".aac",".omg",".oma",".aa3"};
      char* lastStrPos;
      int ret = 0;
      for(int i = 0;i < argc-1;i++)
          if((lastStrPos = strrchr(argv[i+1],'.')) != NULL)
              gPlayerNum = argc -1;
              if(ret == -1)
                  printf("has error,break\n");
                  break;
              printf("may be is one file:cut down suffix is:%s\n",lastStrPos);
              int j = 0;
              int findMatchFileFlag = 0;
              for(j = 0;j < FILE_TYPE_NUM;j++)
                  if(!strncasecmp(lastStrPos,&(fileType[j]),strlen(&(fileType[j]))))
                      printf("find the matched type:%s\n",&(fileType[j]));
                      findMatchFileFlag = 1;
                      break;
              if(findMatchFileFlag == 0)
                  printf("%d:can not play this file:%s\n",i,argv[i]);
                  return -1;
              printf("create player:%d\n",i);
              //* create a player.
              memset(&gDemoPlayers[i], 0, sizeof(DemoPlayerContext));
              gDemoPlayers[i].mTPlayer= TPlayerCreate(CEDARX_PLAYER);
              if(gDemoPlayers[i].mTPlayer == NULL)
                  printf("can not create tplayer, quit.\n");
                  int count = 0;
                  for(count=i-1;count >= 0;count--)
                      TPlayerDestroy(gDemoPlayers[count].mTPlayer);
                      gDemoPlayers[count].mTPlayer = NULL;
                  return -1;
                  printf("create player[%d]:%p\n",i,gDemoPlayers[i].mTPlayer);
              //* set callback to player.
              TPlayerSetNotifyCallback(gDemoPlayers[i].mTPlayer,CallbackForTPlayer, (void*)&gDemoPlayers[i]);
              #ifndef ONLY_ENABLE_AUDIO
              if((gScreenWidth == 0 || gScreenHeight == 0) && gDemoPlayers[i].mTPlayer->mLayerCtrl)
                  VoutRect tmpRect;
                  TPlayerGetDisplayRect(gDemoPlayers[i].mTPlayer,&tmpRect);
                  gScreenWidth = tmpRect.width;
                  gScreenHeight = tmpRect.height;
                  printf("screen width:%d,screen height:%d\n",gScreenWidth,gScreenHeight);
              switch (argc)
                  case 2:/*one player*/
                      printf("%d:playVideo:%d\n",argc-1,i);
                      if(playVideo(&gDemoPlayers[i], argv[i+1], 0, 0, gScreenWidth, gScreenHeight) != 0)
                          printf("%d:playVideo fail%d\n",argc-1,i);
                          ret = -1;
                      break;
                  case 3:/*two player*/
                      if(i%2 == 0)
                          if(playVideo(&gDemoPlayers[i], argv[i+1], 0, 0, gScreenWidth/2, gScreenHeight) != 0)
                              ret = -1;
                          if(playVideo(&gDemoPlayers[i], argv[i+1], gScreenWidth/2, 0, gScreenWidth/2, gScreenHeight) != 0)
                              ret = -1;
                      break;
                  case 4:/*three player*/
                      if(i%3 == 0)
                              ret = -1;
                      else if(i%3 == 1)
                          if(playVideo(&gDemoPlayers[i], argv[i+1], gScreenWidth/2, 0, gScreenWidth/2, gScreenHeight/2) != 0)
                              ret = -1;
                          if(playVideo(&gDemoPlayers[i], argv[i+1], gScreenWidth/2, gScreenHeight/2, gScreenWidth/2, gScreenHeight/2) != 0)
                              ret = -1;
                      break;
                  case 5:/*four player*/
                      if(i%4 == 0)
                          if(playVideo(&gDemoPlayers[i], argv[i+1], 0, 0, gScreenWidth/2, gScreenHeight/2) != 0)
                              ret = -1;
                      else if(i%4 == 1)
                          if(playVideo(&gDemoPlayers[i], argv[i+1], 0, gScreenHeight/2, gScreenWidth/2, gScreenHeight/2) != 0)
                              ret = -1;
                      else if(i%4 == 2)
                              ret = -1;
                              ret = -1;
                      break;
                  default:
                      printf("do not support play %d videos\n",argc-1);
                      break;
          {   /*play all audio and video in one folder*/
              char* lastStrPos;
              DIR *dir = opendir(argv[1]);
              if (dir == NULL)
                  printf("opendir %s fail\n",argv[1]);
                  return -1;
              isDir = 1;
              struct dirent *entry;
              int count= 0;
              while ((entry = readdir(dir)) != NULL)
                  printf("file record length = %d,type = %d, name = %s\n",entry->d_reclen,entry->d_type,entry->d_name);
                  if(entry->d_type == 8)
                      char* strpos;
                      if((strpos = strrchr(entry->d_name,'.')) != NULL)
                          int i = 0;
                          printf("cut down suffix is:%s\n",strpos);
                          for(i = 0;i < FILE_TYPE_NUM;i++)
                              if(!strncasecmp(strpos,&(fileType[i]),strlen(&(fileType[i]))))
                                  printf("find the matched type:%s\n",&(fileType[i]));
                                  break;
                          if(i < FILE_TYPE_NUM)
                              if(count < TOTAL_VIDEO_AUDIO_NUM)
                                  strncpy(&demoPlayer.mVideoAudioList[count],entry->d_name,strlen(entry->d_name));
                                  printf("video file name = %s\n",&demoPlayer.mVideoAudioList[count]);
                                  count++;
                                  count++;
                                  printf("warning:the video file in /mnt/UDISK/ is %d,which is larger than %d,we only support %d\n",count,TOTAL_VIDEO_AUDIO_NUM,TOTAL_VIDEO_AUDIO_NUM);
              closedir(dir);
              demoPlayer.mLoopFlag = 1;
              demoPlayer.mSetLoop = 1;
              if(count >  TOTAL_VIDEO_AUDIO_NUM)
                  demoPlayer.mRealFileNum = TOTAL_VIDEO_AUDIO_NUM;
                  demoPlayer.mRealFileNum = count;
              if(demoPlayer.mRealFileNum == 0)
                  printf("there are no video or audio files in %s,exit(-1)\n",argv[1]);
                  exit(-1);
              demoPlayer.mTPlayer= TPlayerCreate(CEDARX_PLAYER);
              if(demoPlayer.mTPlayer == NULL)
                  exit(-1);
              TPlayerSetNotifyCallback(demoPlayer.mTPlayer,CallbackForTPlayer, (void*)&demoPlayer);
              if((gScreenWidth == 0 || gScreenHeight == 0) && demoPlayer.mTPlayer->mLayerCtrl)
                  VoutRect tmpRect;
                  TPlayerGetDisplayRect(demoPlayer.mTPlayer,&tmpRect);
              sem_init(&demoPlayer.mPreparedSem, 0, 0);
      return ret;
      //* the main method.
      int main(int argc, char** argv)
      install_sig_handler();
      int  nCommandId;
      unsigned long  nCommandParam;
      int  bQuit = 0;
      int nDirErrCnt = 0;
      char strCommandLine[1024];
      CEDARX_UNUSE(argc);
      CEDARX_UNUSE(argv);
      int waitErr = 0;
      int ret = 0;
      printf("\n");
      printf("* This program implements a simple player, you can type commands to control the player.\n");
      printf("* To show what commands supported, type 'help'.\n");
      if(((access("/dev/zero",F_OK)) < 0)||((access("/dev/fb0",F_OK)) < 0)){
          printf("/dev/zero OR /dev/fb0 is not exit\n");
      }else{
          system("dd if=/dev/zero of=/dev/fb0");//clean the framebuffer
      if(argc > 1 && argc < 6)   /* can play 1-4 video*/
          printf("argc = %d\n",argc);
          int argc_count=0;
          for(argc_count=0;argc_count < argc;argc_count++)
              printf("argv[%d] = %s\n",argc_count,argv[argc_count]);
          ret = createPlayersAndPlayVideos(argc, argv);
          if(ret == -1)
              goto QUIT;
          while(!bQuit)
              if(isDir)
                  if(demoPlayer.mLoopFlag)
      DirLoop_test:
      if(nDirErrCnt == demoPlayer.mRealFileNum) {
      printf("demo<%s:%d>*********there's no avaliable files in current path!\n", func, LINE);
      goto QUIT;
                      demoPlayer.mLoopFlag = 0;
                      printf("TPlayerReset begin\n");
                      if(TPlayerReset(demoPlayer.mTPlayer) != 0)
                          printf("TPlayerReset return fail.\n");
                          printf("reset the player ok.\n");
                          if(demoPlayer.mError == 1)
                              demoPlayer.mError = 0;
                      demoPlayer.mSeekable = 1;   //* if the media source is not seekable, this flag will be
        //* clear at the TINA_NOTIFY_NOT_SEEKABLE callback.
                      if(demoPlayer.mCurPlayIndex == demoPlayer.mRealFileNum)
                          demoPlayer.mCurPlayIndex = 0;
                      strcpy(demoPlayer.mUrl,argv[1]);
                      strcat(demoPlayer.mUrl,&demoPlayer.mVideoAudioList[demoPlayer.mCurPlayIndex]);
                      printf("demoPlayer.mUrl = %s\n",demoPlayer.mUrl);
                      demoPlayer.mCurPlayIndex++;
                      //* set url to the tinaplayer.
                      if(TPlayerSetDataSource(demoPlayer.mTPlayer,(const char*)demoPlayer.mUrl,NULL) != 0)
                          printf("TPlayerSetDataSource() return fail.\n");
                          printf("TPlayerSetDataSource() end\n");
                      demoPlayer.mPreparedFlag = 0;
                      if(TPlayerPrepareAsync(demoPlayer.mTPlayer) != 0)
                          printf("tplayerdemo<%s:%d>TPlayerPrepareAsync() return fail.\n", __func__, __LINE__);
                          printf("preparing...\n");
                      waitErr = semTimedWait(&demoPlayer.mPreparedSem,10*1000);
                      if(waitErr == -1)
                          nDirErrCnt++;
                          printf("tplayerdemo<%s:%d>prepare fail,has wait 10s, nDirErrCnt:%d\n", __func__, __LINE__, nDirErrCnt);
                          goto DirLoop_test;
                          //break;
                      else if(demoPlayer.mError == 1)
                          nDirErrCnt++;
                          printf("tplayerdemo<%s:%d>prepare fail, nDirErrCnt:%d\n", __func__, __LINE__, nDirErrCnt);
                          goto DirLoop_test;
                         // break;
                      printf("prepare ok\n");
                      printf("tplayerdemo<%s:%d>start play\n", __func__, __LINE__);
                  //TPlayerSetLooping(demoPlayer.mTPlayer,1);//let the player into looping mode
                      //* start the playback
                      if(TPlayerStart(demoPlayer.mTPlayer) != 0)
                          nDirErrCnt = 0;
                          //PowerManagerAcquireWakeLock("tplayerdemo");
                  #if LOOP_PLAY_FLAG
                      if(gDemoPlayers[i].mComplete == 1)
                          if(TPlayerReset(gDemoPlayers[i].mTPlayer) != 0)
                          switch (argc)
                                      goto QUIT;
                                  break;
                                  if(i%2 == 0)
                                          goto QUIT;
                                          goto QUIT;
                                  break;
                                  if(i%3 == 0)
                                          goto QUIT;
                                  else if(i%3 == 1)
                                          goto QUIT;
                                          goto QUIT;
                                  break;
                                  if(i%4 == 0)
                                          goto QUIT;
                                  else if(i%4 == 1)
                                          goto QUIT;
                                  else if(i%4 == 2)
                                          goto QUIT;
                                          goto QUIT;
                                  break;
                              default:
                                  break;
              //* read command from stdin.
              if(readCommand(strCommandLine, sizeof(strCommandLine)) == 0)
                  //* parse command.
                  nCommandParam = 0;
                  nCommandId = parseCommandLine(strCommandLine, &nCommandParam);
                  //* process command.
                  switch(nCommandId)
                      case COMMAND_HELP:
                          showHelp();
                          break;
                      case COMMAND_QUIT:
                          printf("COMMAND_QUIT\n");
                          bQuit = 1;
                          break;
      QUIT:
          if(isDir)
              int i=0;
              for(i = (argc-1)-1;i >= 0;i--)
              printf("destroy all tplayer\n");
          printf("\n");
          printf("* Quit the program, goodbye!\n");
          printf("\n");
      if(argc == 1)
      {/*use command to control one player*/
          memset(&demoPlayer, 0, sizeof(DemoPlayerContext));
          demoPlayer.mSetLoop = 0;
          demoPlayer.mMediaInfo = NULL;
              exit(-1);
              VoutRect tmpRect;
          //* read, parse and process command from user.
          bQuit = 0;
          while(!bQuit)
              //for test loop play which use reset for each play
              //printf("demoPlayer.mLoopFlag = %d",demoPlayer.mLoopFlag);
                  //* set url to the tplayer.
                      printf("TPlayerPrepareAsync() return fail.\n");
                  waitErr = semTimedWait(&demoPlayer.mPreparedSem,300*1000);
                  if(waitErr == -1)
                      printf("prepare fail,has wait 300s\n");
                      break;
                      printf("prepare fail\n");
                      break;
                  printf("start play\n");
                  //* parse command.
                  nCommandParam = 0;
                  switch(nCommandId)
                      case COMMAND_HELP:
                          showHelp();
                          break;
                      case COMMAND_QUIT:
                          bQuit = 1;
                          break;
                      case COMMAND_SET_SOURCE :   //* set url of media file.
                          char* pUrl;
                          pUrl = (char*)(uintptr_t)nCommandParam;
                          memset(demoPlayer.mUrl,0,512);
                          strcpy(demoPlayer.mUrl,pUrl);
                          if(demoPlayer.mError == 1) //pre status is error,reset the player first
                              printf("pre status is error,reset the tina player first.\n");
                              TPlayerReset(demoPlayer.mTPlayer);
                              break;
                          break;
                      case COMMAND_PREPARE:
                              printf("prepare\n");
                          if(waitErr == -1)
                              break;
                              break;
                          printf("prepared ok\n");
                          break;
                      case COMMAND_PLAY:   //* start playback.
                              break;
                          break;
                      case COMMAND_PAUSE:   //* pause the playback.
                          if(TPlayerPause(demoPlayer.mTPlayer) != 0)
                              printf("TPlayerPause() return fail.\n");
                              break;
                              printf("paused.\n");
                          break;
                      case COMMAND_STOP:   //* stop the playback.
                          if(TPlayerStop(demoPlayer.mTPlayer) != 0)
                              printf("TPlayerStop() return fail.\n");
                              break;
                          break;
                      case COMMAND_SEEKTO:   //* seek to posion, in unit of second.
                          int nSeekTimeMs;
                          int nDuration;
                          nSeekTimeMs = nCommandParam*1000;
                          int ret = TPlayerGetDuration(demoPlayer.mTPlayer,&nDuration);
                          printf("nSeekTimeMs = %d , nDuration = %d\n",nSeekTimeMs,nDuration);
                          if(ret != 0)
                              printf("getDuration fail, unable to seek!\n");
                              break;
                          if(nSeekTimeMs > nDuration)
                              printf("seek time out of range, media duration = %d seconds.\n", nDuration/1000);
                              break;
                          if(demoPlayer.mSeekable == 0)
                              printf("media source is unseekable.\n");
                              break;
                          if(TPlayerSeekTo(demoPlayer.mTPlayer,nSeekTimeMs) != 0)
                              printf("TPlayerSeekTo() return fail,nSeekTimeMs= %d\n",nSeekTimeMs);
                              break;
                              printf("is seeking.\n");
                          break;
                      case COMMAND_RESET:   //* reset the player
                              printf("TPlayerReset() return fail.\n");
                              break;
                              //PowerManagerReleaseWakeLock("tinaplayerdemo");
                          break;
                      case COMMAND_SHOW_MEDIAINFO:   //* show media information.
                          printf("show media information:\n");
                          MediaInfo* mi = NULL;
                          demoPlayer.mMediaInfo = TPlayerGetMediaInfo(demoPlayer.mTPlayer);
                          if(demoPlayer.mMediaInfo != NULL)
                              mi = demoPlayer.mMediaInfo;
                              printf("file size = %lld KB\n",mi->nFileSize/1024);
                              printf("duration = %lld ms\n",mi->nDurationMs);
                              printf("bitrate = %d Kbps\n",mi->nBitrate/1024);
                              printf("container type = %d\n",mi->eContainerType);
                              printf("video stream num = %d\n",mi->nVideoStreamNum);
                              printf("audio stream num = %d\n",mi->nAudioStreamNum);
                              printf("subtitle stream num = %d\n",mi->nSubtitleStreamNum);
                              if(mi->pVideoStreamInfo != NULL)
                                  printf("video codec tpye = %d\n",mi->pVideoStreamInfo->eCodecFormat);
                                  printf("video width = %d\n",mi->pVideoStreamInfo->nWidth);
                                  printf("video height = %d\n",mi->pVideoStreamInfo->nHeight);
                                  printf("video framerate = %d\n",mi->pVideoStreamInfo->nFrameRate);
                                  printf("video frameduration = %d\n",mi->pVideoStreamInfo->nFrameDuration);
                              if(mi->pAudioStreamInfo != NULL)
                                  printf("audio codec tpye = %d\n",mi->pAudioStreamInfo->eCodecFormat);
                                  printf("audio channel num = %d\n",mi->pAudioStreamInfo->nChannelNum);
                                  printf("audio BitsPerSample = %d\n",mi->pAudioStreamInfo->nBitsPerSample);
                                  printf("audio sample rate  = %d\n",mi->pAudioStreamInfo->nSampleRate);
                                  printf("audio bitrate = %d Kbps\n",mi->pAudioStreamInfo->nAvgBitrate/1024);
                          break;
                      case COMMAND_SHOW_DURATION:   //* show media duration, in unit of second.
                          int nDuration = 0;
                          if(TPlayerGetDuration(demoPlayer.mTPlayer,&nDuration) == 0)
                              printf("media duration = %d seconds.\n", nDuration/1000);
                              printf("fail to get media duration.\n");
                          break;
                      case COMMAND_SHOW_POSITION:   //* show current play position, in unit of second.
                          int nPosition = 0;
                          if(TPlayerGetCurrentPosition(demoPlayer.mTPlayer,&nPosition) == 0)
                              printf("current position = %d seconds.\n", nPosition/1000);
                              printf("fail to get pisition.\n");
                          break;
                      case COMMAND_GET_DISP_FRAMERATE:   //* get video real disp framerate
                          float realDispFramerate = 0.0;
                          int getFramerateRet = TPlayerGetVideoDispFramerate(demoPlayer.mTPlayer,&realDispFramerate);
                          if(getFramerateRet == -1)
                              printf("err:we should get the real display framerate after play\n");
                              printf("real display framerate : %f\n",realDispFramerate);
                          break;
                      case COMMAND_SWITCH_AUDIO:   //* switch autio track.
                          int audioStreamIndex;
                          audioStreamIndex = (int)nCommandParam;
                          printf("switch audio to the %dth track.\n", audioStreamIndex);
                          int ret = TPlayerSwitchAudio(demoPlayer.mTPlayer,audioStreamIndex);
                          if(ret != 0){
                              printf("switch audio err\n");
                          break;
                      case COMMAND_PLAY_URL:   //* set url of media file.
                          char* pUrl;
                          printf("demoPlayer.mUrl = %s",demoPlayer.mUrl);
                              break;
                          if(TPlayerSetDataSource(demoPlayer.mTPlayer,(const char*)demoPlayer.mUrl,NULL)!= 0)
                              break;
                          if(waitErr == -1)
                              break;
                              break;
      		printf("start play \n");
                              break;
                          break;
                      case COMMAND_SET_VOLUME:   //* seek to posion, in unit of second.
                          int volume = (int)nCommandParam;
                          printf("tplayerdemo setVolume:volume = %d\n",volume);
                          int ret = TPlayerSetVolume(demoPlayer.mTPlayer,volume);
                          if(ret == -1)
                              printf("tplayerdemo set volume err\n");
                              printf("tplayerdemo set volume ok\n");
                          break;
                      case COMMAND_GET_VOLUME:   //* seek to posion, in unit of second.
                          int curVolume = TPlayerGetVolume(demoPlayer.mTPlayer);
                          printf("cur volume = %d\n",curVolume);
                          break;
                      case COMMAND_SET_LOOP:   //* set loop flag
                          printf("tplayerdemo set loop flag:flag = %d\n",(int)nCommandParam);
                          if(nCommandParam == 1)
                          else if(nCommandParam == 0)
                              printf("the set loop value is wrong\n");
                          break;
                      case COMMAND_SET_SCALEDOWN:   //set video scaledown
                          int scaleDown = (int)nCommandParam;
                          printf("tplayerdemo set scaledown value = %d\n",scaleDown);
                          switch (scaleDown)
                              case 2:
                                  printf("scale down 1/2\n");
                                  int ret = TPlayerSetScaleDownRatio(demoPlayer.mTPlayer,TPLAYER_VIDEO_SCALE_DOWN_2,TPLAYER_VIDEO_SCALE_DOWN_2);
                                  if(ret != 0){
                                      printf("set scale down err\n");
                                  break;
                              case 4:
                                  printf("scale down 1/4\n");
                                  int ret = TPlayerSetScaleDownRatio(demoPlayer.mTPlayer,TPLAYER_VIDEO_SCALE_DOWN_4,TPLAYER_VIDEO_SCALE_DOWN_4);
                                  if(ret != 0){
                                  break;
                              case 8:
                                  printf("scale down 1/8\n");
                                  int ret = TPlayerSetScaleDownRatio(demoPlayer.mTPlayer,TPLAYER_VIDEO_SCALE_DOWN_8,TPLAYER_VIDEO_SCALE_DOWN_8);
                                  if(ret != 0){
                                  break;
                              default:
                                  printf("scaledown value is wrong\n");
                                  break;
                          break;
                      case COMMAND_FAST_FORWARD:   //fast forward
                          int fastForwardTimes = (int)nCommandParam;
                          printf("tplayerdemo fast forward times = %d\n",fastForwardTimes);
                          switch (fastForwardTimes)
                              case 2:
                                  printf("fast forward 2 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_FORWARD_2);
                                  if(ret != 0){
                                      printf("fast forward err\n");
                                  break;
                              case 4:
                                  printf("fast forward 4 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_FORWARD_4);
                                  if(ret != 0){
                                  break;
                              case 8:
                                  printf("fast forward 8 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_FORWARD_8);
                                  if(ret != 0){
                                  break;
                              case 16:
                                  printf("fast forward 16 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_FORWARD_16);
                                  if(ret != 0){
                                  break;
                              default:
                                  printf("the value of fast forward times is wrong,can not fast forward. value = %d\n",fastForwardTimes);
                                  printf("we set it to normal play\n");
                                  TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_1);
                                  break;
                          break;
                      case COMMAND_FAST_BACKWARD:   //fast backward
                          int fastBackwardTimes = (int)nCommandParam;
                          printf("tplayerdemo fast backward times = %d\n",fastBackwardTimes);
                          switch (fastBackwardTimes)
                              case 2:
                                  printf("fast backward 2 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_BACKWARD_2);
                                  if(ret != 0){
                                      printf("fast backward err\n");
                                  break;
                              case 4:
                                  printf("fast backward 4 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_BACKWARD_4);
                                  if(ret != 0){
                                  break;
                              case 8:
                                  printf("fast backward 8 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_BACKWARD_8);
                                  if(ret != 0){
                                  break;
                              case 16:
                                  printf("fast backward 16 times\n");
                                  int ret = TPlayerSetSpeed(demoPlayer.mTPlayer,PLAY_SPEED_FAST_BACKWARD_16);
                                  if(ret != 0){
                                  break;
                              default:
                                  printf("the value of fast backward times is wrong,can not fast backward. value = %d\n",fastBackwardTimes);
                                  break;
                          break;
                      case COMMAND_SET_SRC_RECT:
                          TPlayerSetSrcRect(demoPlayer.mTPlayer, 0, 0, 720, 480);
                          break;
                      case COMMAND_SET_OUTPUT_RECT:
                          TPlayerSetDisplayRect(demoPlayer.mTPlayer, 0, 0, 400, 400);
                          break;
          printf("\n");
          printf("\n");
      报错图片:微信图片_20250315113711.jpg 微信图片_20250315113715.jpg
