    WiFi模块加载失败
    2472
      yyh5961 LV 4 最后由 编辑
      root@T113i-RockEnergy:/# insmod ./lib/modules/5.4.61-rt37-g01fdce3-dirty/xr829.ko
      [ 651.793302] 000: ======== XRADIO WIFI OPEN ========
      [ 651.793924] 000: [XRADIO] Driver Label:XR_V02.16.88_P2P_HT40_01.31
      [ 651.793982] 000: [XRADIO] Allocated hw_priv @ d0eaa08f
      [ 651.800459] 001: sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [ 651.810508] 001: sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [ 652.010539] 001: sunxi_hosts[1] should not be null
      [ 652.010543] 001: [XRADIO] Detect SDIO card 1
      [ 654.088952] 001: sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [ 654.189256] 001: sunxi_hosts[1] should not be null
      [ 654.189258] 001: [XRADIO] Remove SDIO card 1
      [ 654.199269] 001: [SBUS_ERR] sdio probe timeout!
      [ 654.199277] 001: [XRADIO_ERR] sbus_sdio_init failed
      [ 654.199664] 001: xradio_core_init failed (-110)!
      insmod: ERROR: could not insert module ./lib/modules/5.4.61-rt37-g01fdce3-dirty/xr829.ko: Connection timed out
      老哥们 为什么这个这个sdio被移除了啊
        yyh5961 LV 4 最后由 编辑
        [ 20.101775] 001: ======== XRADIO WIFI OPEN ========
        [ 20.102410] 001: [XRADIO] Driver Label:XR_V02.16.88_P2P_HT40_01.31
        [ 20.102465] 001: [XRADIO] Allocated hw_priv @ 5637e7ba
        [ 20.108843] 000: yyxradio_wlan_power: on = 1
        [ 20.108865] 000: sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
        [ 20.118910] 000: sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
        [ 20.318976] 000: [XRADIO] Detect SDIO card 1
        [ 20.319044] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
        [ 20.319082] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
        [ 20.319128] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
        [ 20.319156] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
        [ 20.319378] 000: mmc1: card 0001 removed
        [ 20.319503] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [ 20.320905] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 20.321004] 000: sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
        [ 20.333584] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 20.346910] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
        [ 20.347757] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
        [ 20.347782] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 20.350791] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 20.352930] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 20.353763] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 20.354591] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 20.355415] 000: sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 20.355442] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [ 22.406105] 000: yywlan power down
        [ 22.406117] 000: yyxradio_wlan_power: on = 0
        [ 22.406145] 000: sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
        [ 22.506543] 000: [XRADIO] Remove SDIO card 1
        [ 22.506587] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 22.506703] 000: sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
        [ 22.516726] 000: [SBUS_ERR] sdio probe timeout!
        [ 22.516736] 000: [XRADIO_ERR] sbus_sdio_init failed
        [ 22.516740] 000: yy3: goto err1 - sbus_sdio_init fail
        [ 22.516742] 000: yy19: entering err1
        [ 22.517137] 000: yy20: return final err=-110
        [ 22.517146] 000: yyyxradio_core_init failed1 (-110)!
        [ 22.519271] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 22.532566] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 22.535584] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 22.546241] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [ 22.546337] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [ 22.546470] 000: sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
        [ 22.547370] 000: mmc1: new high speed SDIO card at address 0001
        insmod: ERROR: could not insert module /lib/modules/5.4.61-rt37-g01fdce3-dirty/xr829.ko: Connection timed out
        现在打印信息是这样了
          zoipuus LV 5 最后由 编辑
          看看WiFi模块的原理图,和dts的rfkill wlan配置?
            yyh5961 LV 4 最后由 编辑
            已经解决了
            wlan_regon是这个引脚我给他配置成了低电平有效导致的
