    T113S3 lvds dual配置不生效
      lztmfx LV 5 最后由 编辑
      lvds1_pins_a: lvds1@0 {
      				pins  =  "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19";
      				function = "lvds1";
      				drive-strength = <30>;
      				bias-disable;
      lvds1_pins_b: lvds1@1 {
      				function = "io_disabled";
      				bias-disable;
      &disp {
      	screen0_output_mode      = <10>;
      	// screen1_output_format    = <0>;
      	// screen1_output_bits      = <0>;
      	// screen1_output_eotf      = <4>;
      	// screen1_output_cs        = <257>;
      	// screen1_output_dvi_hdmi  = <2>;
      	// screen1_output_range     = <2>;
      	// screen1_output_scan      = <0>;
      	// screen1_output_aspect_ratio = <8>;
      	dev1_output_type         = <1>;
      	fb0_format               = <9>;
      	fb0_width                = <1920>;
      	fb0_height               = <1080>;
      	fb1_format               = <9>;
      	fb1_width                = <1920>;
      	fb1_height               = <1080>;
      	chn_cfg_mode             = <2>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_driver_name     = "dual_lvds_lcd";
      	lcd_if              = <3>;
      	lcd_x               = <1920>;
      	lcd_y               = <1080>;
      	lcd_width           = <340>;
      	lcd_height          = <190>;
      	lcd_dclk_freq       = <159>;
      	lcd_pwm_used        = <0>;
      	lcd_pwm_ch          = <5>;//背光PWM通道号
      	lcd_pwm_freq        = <5000>;
      	lcd_pwm_pol         = <1>;
      	lcd_backlight       = <10>;
      	lcd_pwm_max_limit   = <255>;
      	//= <&pio PD 27 1 0 3 1>;
      	// lcd_bl_en = <&pio PG 3 1 0 3 1>;//背光使能引脚
      	lcd_hbp             = <272>;
      	lcd_ht              = <2272>;//48
      	lcd_hspw            = <32>;
      	lcd_vbp             = <80>;
      	lcd_vt              = <1169>;//3
      	lcd_vspw            = <6>;
      	lcd_lvds_if         = <1>;
      	lcd_lvds_colordepth = <0>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <0>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	lcd_fsync_en = <0>;
      	lcd_fsync_act_time = <1000>;
      	lcd_fsync_dis_time = <1000>;
      	lcd_fsync_pol = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	lcd_gpio_0 = <&pio PG 3 1 0 3 0>;//背光使能
      	pinctrl-0 = <&lvds1_pins_a>;
      	pinctrl-1 = <&lvds1_pins_b>;
      adb shell dump的信息:
      root@TinaLinux:/# fbset
      mode "1920x1080-60"
              geometry 1920 1080 1920 2160 24
              timings 6289 240 80 74 9 32 6
              accel false
              rgba 8/0,8/8,8/16,0/24
      endmode
      root@TinaLinux:/# cat /sys/kernel/debug/pinctrl/2000000.pinctrl/pinmux-pins
      Pinmux settings per pin
      Format: pin (name): mux_owner|gpio_owner (strict) hog?
      pin 96 (PD0): UNCLAIMED
      pin 97 (PD1): UNCLAIMED
      pin 98 (PD2): UNCLAIMED
      pin 99 (PD3): UNCLAIMED
      pin 100 (PD4): UNCLAIMED
      pin 101 (PD5): UNCLAIMED
      pin 102 (PD6): UNCLAIMED
      pin 103 (PD7): UNCLAIMED
      pin 104 (PD8): UNCLAIMED
      pin 105 (PD9): UNCLAIMED
      pin 106 (PD10): UNCLAIMED
      pin 107 (PD11): UNCLAIMED
      pin 108 (PD12): UNCLAIMED
      pin 109 (PD13): UNCLAIMED
      pin 110 (PD14): UNCLAIMED
      pin 111 (PD15): UNCLAIMED
      pin 112 (PD16): UNCLAIMED
      pin 113 (PD17): UNCLAIMED
      pin 114 (PD18): UNCLAIMED
      pin 115 (PD19): UNCLAIMED
      pin 116 (PD20): UNCLAIMED
      pin 117 (PD21): UNCLAIMED
      pin 118 (PD22): UNCLAIMED
