    rootfs.ubifs无法正确挂载到t113i的mtd分区
      lyl20050926 LV 2 最后由 编辑
      利用原生的openwrt去编译出zImage和rootfs.ubifs,去替换t113i的sdk里面的,然后打包生成镜像,烧录到板子里,这样就可以将openwrt移植到板子里,烧录以后在利用串口获取的日志
      Starting kernel ...
      [    0.000000] Linux version 6.6.73 (forlinx@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 13.3.0 r0-7f91d3b) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Mon Feb 10 08:35:18 2025
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c5387d
      [    0.000000] earlycon: uart8250 at MMIO32 0x0000000002500000 (options '')
      [    0.000000] printk: bootconsole [uart8250] enabled
      [    0.000000] Zone ranges:
      [    0.000000]   Normal   [mem 0x0000000040000000-0x000000004fffffff]
      [    0.000000]   HighMem  empty
      [    0.000000]   node   0: [mem 0x0000000040000000-0x000000004fffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000004fffffff]
      [    0.000000] percpu: Embedded 13 pages/cpu s21204 r8192 d23852 u53248
      [    0.000000] pcpu-alloc: s21204 r8192 d23852 u53248 alloc=13*4096
      [    0.000000] Kernel command line: ubi.mtd=sys earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=ubi0_5 rootfstype=ubifs,rw init=/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:private@ubi0_7:UDISK@ubi0_8: cma=32M snum= mac_addr=22:b3:03:48:b5:bb wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05(03/28/2025-02:27:01) disp_reserve=2457600,0x4c91b000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=256
      [    0.000000] Unknown kernel command line parameters "partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:private@ubi0_7:UDISK@ubi0_8: cma=32M snum= mac_addr=22:b3:03:48:b5:bb wifi_mac= bt_mac= specialstr= boot_type=5 uboot_message=2018.05(03/28/2025-02:27:01) disp_reserve=2457600,0x4c91b000", will be passed to user space.
      [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 64960
      [    0.000000] Memory: 234176K/262144K available (8289K kernel code, 889K rwdata, 2340K rodata, 2048K init, 255K bss, 27968K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
      [    0.000000]  Tracing variant of Tasks RCU enabled.
      [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.008373] Switching to timer-based delay loop, resolution 41ns
      [    0.014821] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.025050] Console: colour dummy device 80x30
      [    0.029747] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.040615] CPU: Testing write buffer coherency: ok
      [    0.045761] pid_max: default: 32768 minimum: 301
      [    0.057333] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.065009] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.078786] /cpus/cpu@0 missing clock-frequency property
      [    0.084386] /cpus/cpu@1 missing clock-frequency property
      [    0.090002] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.097001] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
      [    0.106870] Setting up static identity map for 0x40200000 - 0x40200060
      [    0.113893] rcu: Hierarchical SRCU implementation.
      [    0.118937] rcu:     Max phase no-delay instances is 1000.
      [    0.125119] smp: Bringing up secondary CPUs ...
      [    0.131218] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.131381] smp: Brought up 1 node, 2 CPUs
      [    0.141616] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.148115] CPU: All CPU(s) started in SVC mode.
      [    0.167325] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.175675] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.186052] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.197543] pinctrl core: initialized pinctrl subsystem
      [    0.205805] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.212898] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.221303] thermal_sys: Registered thermal governor 'step_wise'
      [    0.221766] No ATAGs?
      [    0.256511] SCSI subsystem initialized
      [    0.260954] libata version 3.00 loaded.
      [    0.265299] usbcore: registered new interface driver usbfs
      [    0.271141] usbcore: registered new interface driver hub
      [    0.276763] usbcore: registered new device driver usb
      [    0.282463] pps_core: LinuxPPS API ver. 1 registered
      [    0.287654] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.297279] PTP clock support registered
      [    0.301721] Advanced Linux Sound Architecture Driver Initialized.
      [    0.310043] clocksource: Switched to clocksource arch_sys_counter
      [    0.328684] NET: Registered PF_INET protocol family
      [    0.334067] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.342563] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.351391] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.359521] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.367550] TCP bind hash table entries: 2048 (order: 3, 32768 bytes, linear)
      [    0.375091] TCP: Hash tables configured (established 2048 bind 2048)
      [    0.382272] MPTCP token hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.390150] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.397034] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.404863] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.413117] workingset: timestamp_bits=14 max_order=16 bucket_order=2
      [    0.428848] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.436874] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
      [    0.462741] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
      [    0.486051] loop: module loaded
      [    0.495635] usbcore: registered new interface driver usb-storage
      [    0.502931] mousedev: PS/2 mouse device common for all mice
      [    0.509615] i2c_dev: i2c /dev entries driver
      [    0.515727] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    0.529272] NET: Registered PF_INET6 protocol family
      [    0.536208] Segment Routing with IPv6
      [    0.540205] In-situ OAM (IOAM) with IPv6
      [    0.544437] NET: Registered PF_PACKET protocol family
      [    0.550123] can: controller area network core
      [    0.555674] NET: Registered PF_CAN protocol family
      [    0.560804] 8021q: 802.1Q VLAN Support v1.8
      [    0.565697] Registering SWP/SWPB emulation handler
      [    0.610135] clk: Not disabling unused clocks
      [    0.614626] ALSA device list:
      [    0.617739]   No soundcards found.
      [    0.621392] Warning: unable to open an initial console.
      [    0.627854] VFS: Cannot open root device "ubi0_5" or unknown-block(0,253): error -19
      [    0.636015] Please append a correct "root=" boot option; here are the available partitions:
      [    0.644859] List of all bdev filesystems:
      [    0.649061]  ext3
      [    0.649066]  ext2
      [    0.651111]  ext4
      [    0.653131]  squashfs
      [    0.655148]  vfat
      [    0.657529]  f2fs
      [    0.659528]
      [    0.663088] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,253)
      [    0.671924] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 6.6.73 #0
      [    0.678135] Hardware name: Generic DT based system
      [    0.683136]  unwind_backtrace from show_stack+0x10/0x14
      [    0.688642]  show_stack from dump_stack_lvl+0x40/0x4c
      [    0.693932]  dump_stack_lvl from panic+0x108/0x340
      [    0.698960]  panic from mount_root_generic+0x1f4/0x2a4
      [    0.704350]  mount_root_generic from prepare_namespace+0x228/0x25c
      [    0.710826]  prepare_namespace from kernel_init+0x1c/0x12c
      [    0.716587]  kernel_init from ret_from_fork+0x14/0x38
      [    0.721867] Exception stack(0xc2037fb0 to 0xc2037ff8)
      [    0.727158] 7fa0:                                     00000000 00000000 00000000 00000000
      [    0.735717] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    0.744274] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [    0.751196] CPU1: stopping
      [    0.751206] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 6.6.73 #0
      [    0.751215] Hardware name: Generic DT based system
      [    0.751221]  unwind_backtrace from show_stack+0x10/0x14
      [    0.751243]  show_stack from dump_stack_lvl+0x40/0x4c
      [    0.751264]  dump_stack_lvl from do_handle_IPI+0xec/0x120
      [    0.751280]  do_handle_IPI from ipi_handler+0x18/0x20
      [    0.751291]  ipi_handler from handle_percpu_devid_irq+0x78/0x134
      [    0.751309]  handle_percpu_devid_irq from generic_handle_domain_irq+0x28/0x38
      [    0.751331]  generic_handle_domain_irq from gic_handle_irq+0x74/0x88
      [    0.751349]  gic_handle_irq from generic_handle_arch_irq+0x34/0x44
      [    0.751365]  generic_handle_arch_irq from call_with_stack+0x18/0x20
      [    0.751380]  call_with_stack from __irq_svc+0x6c/0x7c
      [    0.751391] Exception stack(0xc2077f70 to 0xc2077fb8)
      [    0.751400] 7f60:                                     00000003 00000001 00000864 40000000
      [    0.751409] 7f80: 00000001 c1009f68 c208e300 c1009fa4 40007000 410fc075 00000000 00000000
      [    0.751417] 7fa0: c11035d0 c2077fc0 c0a10d24 c0a110f0 60000013 ffffffff
      [    0.751422]  __irq_svc from default_idle_call+0x2c/0x30
      [    0.751437]  default_idle_call from do_idle+0xa4/0x118
      [    0.751455]  do_idle from cpu_startup_entry+0x28/0x2c
      [    0.751468]  cpu_startup_entry from secondary_start_kernel+0x124/0x128
      [    0.751482]  secondary_start_kernel from 0x40201134
      [    0.883178] Rebooting in 1 seconds..
      [29]HELLO! BOOT0 is starting!
      [31]BOOT0 commit : 09b36272
      [34]set pll start
      [40]periph0 has been enabled
      [43]set pll end
      [44][pmu]: bus read error
      [47]board init ok
      [49]DRAM only have internal ZQ!!
      [52]get_pmu_exist() = -1
      [54]DRAM BOOT DRIVE INFO: V0.32
      [57]DRAM CLK = 792 MHz
      [59]DRAM Type = 3 (2:DDR2,3:DDR3)
      [63]DRAMC ZQ value: 0x7b7bfb
      [65]DRAM ODT value: 0x42.
      [68]ddr_efuse_type: 0x0
      [70]mark_id: 0x34
      [73]DRAM SIZE =256 M
      [75]PLL_DDR_CTRL_REG:0xf8004100
      [78]DRAM_CLK_REG:0xc0000000
      [80][TIMING DEBUG] MR2= 0x18
      [88]DRAM simple test OK.
      [90]rtc standby flag is 0x0, super standby flag is 0x0
      [96]dram size =256
      [98]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [103]block from 8 to 32
      [260]Check is correct.
      [262]dma 0x2b00c int is not used yet
      [266]dma 0x2b00c int is free, you do not need to free it again
      [272]Entry_name        = u-boot
      [279]Entry_name        = optee
      [283]Entry_name        = dtb
      [286]Jump to second Boot.
      [321]FORLINX: auth pass!
      M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
      U-Boot 2018.05 (Mar 28 2025 - 02:27:01 -0700) Allwinner Technology
      [00.373]CPU:   Allwinner Family
      [00.376]Model: sun8iw20
      I2C:   ready
      [00.395]DRAM:  256 MiB
      [00.399]Relocation Offset is: 0cebe000
      [00.426]secure enable bit: 0
      [00.440]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.446]gic: sec monitor mode
      [00.449]flash init start
      [00.451]workmode = 0,storage type = 0
      [BCC] 0x4025038 = 0x10000000, [DMA] 0x4025088 = 0x000000e5
      [00.498]sunxi-spinand-phy: not detect any munufacture from id table
      [00.504]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.510]sunxi-spinand-phy: get phy info from fdt fail
      defaults:
      mtdids  : nand0=nand
      [00.685]ubi0: attaching mtd4
      [01.240]ubi0: scanning is finished
      [01.251]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [01.256]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [01.262]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [01.268]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [01.274]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [01.280]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [01.286]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [01.294]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [01.303]sunxi flash init ok
      [01.305]Loading Environment from SUNXI_FLASH... OK
      disp_type:4
      [01.500]line:717 init_clocks
      [01.503]drv_disp_init
      request pwm success, pwm3:pwm3:0x2000c00.
      [01.520]drv_disp_init finish
      [01.522]boot_gui_init:start
      [01.525]set disp.dev2_output_type fail. using defval=0
      [01.531]boot_gui_init:finish
      [01.712]LCD open finish
      54 bytes read in 0 ms
      [01.841]bmp_name=bootlogo.bmp size 1036854
      1036854 bytes read in 140 ms (7.1 MiB/s)
      [02.269]Item0 (Map) magic is bad
      [02.275]secure storage read widevine fail with:-1
      [02.282]secure storage read ec_key fail with:-1
      [02.289]secure storage read ec_cert1 fail with:-1
      [02.297]secure storage read ec_cert2 fail with:-1
      [02.304]secure storage read ec_cert3 fail with:-1
      [02.312]secure storage read rsa_key fail with:-1
      [02.319]secure storage read rsa_cert1 fail with:-1
      [02.327]secure storage read rsa_cert2 fail with:-1
      [02.334]secure storage read rsa_cert3 fail with:-1
      [02.339]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [02.350]usb prepare ok
      [02.453]overtime
      [02.456]do_burn_from_boot usb : no usb exist
      List file under ULI/factory
      [02.493]update bootcmd
      [02.522]change working_fdt 0x4c87de70 to 0x4c85de70
      [02.540]update dts
      disp_type:4
      Hit any key to stop autoboot (Spacebar):  0
      [04.140]no vendor_boot partition is found
      我自己查了一些资料,是因为我的rootfs没有挂载到正确的分区上面,然后我制作了一个ubi.img,查资料显示是烧录进去就可以正确挂载mtd了,但是因为无法进入系统,只能在uboot里面操作,使用不了tftp,也用不了ubiattach指令,然后我这块是OK113i-S,没有sd卡槽,只有usb和tf卡槽,想请问一下应该怎么办
