    【求助】ERROR: update mbr file fail
      z2500abc LV 5 最后由 xiaowenge 编辑
      user@ubuntu:~/t113s3$ pack
      PACK_CHIP         sun8iw20p1
      PACK_PLATFORM     tina
      PACK_BOARD        t113-evb1
      PACK_KERN
      PACK_DEBUG        uart0
      PACK_SIG          none
      PACK_SECURE       none
      PACK_MODE         normal
      PACK_FUNC         android
      PACK_PROGRAMMER   none
      PACK_TAR_IMAGE    none
      PACK_TOPDIR       /home/user/t113s3
      No kernel param, parse it from t113
      copying tools file
      copying configs file
      storage_type value is 1
      rm /home/user/t113s3/out/t113-evb1/image/sys_partition_nor.fex
      rm /home/user/t113s3/out/t113-evb1/image/image_nor.cfg
      copying boot resource
      copying boot file
      make user resource for : /home/user/t113s3/out/t113-evb1/image/sys_partition.fex
      handle partition user-res
      no user resource partitions
      APP_PART_DOWNLOAD_FILE = /home/user/t113s3/out/t113-evb1/image/app.fex
      Need size of filesystem
      no data resource partitions
      don't build dtbo ...
      update_chip
      sboot file Path=/home/user/t113s3/out/t113-evb1/image/sboot.bin
      script file Path=/home/user/t113s3/out/t113-evb1/image/sys_config.bin
      update:unable to open sboot file
      script update sboot ok
      pack boot package
      content_count=3
      packing for tina linux
      normal
      mbr count = 4
      partitation file Path=/home/user/t113s3/out/t113-evb1/image/sys_partition.bin
      mbr_name file Path=/home/user/t113s3/out/t113-evb1/image/sunxi_mbr.fex
      download_name file Path=/home/user/t113s3/out/t113-evb1/image/dlinfo.fex
      mbr size = 16384
      mbr magic softw411
      disk name=boot-resource
      ERROR: dl file boot-resource.fex size too large
      ERROR: filename = boot-resource.fex
      ERROR: dl_file_size = 1850 sector
      ERROR: part_size = 504 sector
      update_for_part_info -1
      ERROR: update_mbr failed
      这种报错要怎么解决呀? 求助
      S 1 条回复 最后回复 回复 引用 分享 0
        shuaige LV 6 @z2500abc 最后由 编辑
        @z2500abc xxx/buildroot/sys_partition.fex目录下将 boot-resource分区size改大
        Z 1 条回复 最后回复 回复 引用 分享 1
          z2500abc LV 5 @shuaige 最后由 编辑
          @shuaige 好的 感谢
