    【求助】 创龙T113 WiFi模块工作不正常?
    创龙科技专区
    • F
      freeor LV 4 最后由 xiaowenge 编辑
      这个板子WiFi很奇怪,就是你加载模块后,就是链接不上WiFi,有时候你切换ap模式,然后链接就可以了,但是网络是不通的,ping 不同域名和ip都试过的
       ./wifi_setup.sh  -i  TP_LINK_lc -p lechi2024
      conf  : /etc/wpa_supplicant.conf
      ssid  : TP_LINK_lc
      psk   : lechi2024
      device: wlan0
      update /etc/wpa_supplicant.conf
      startup wpa_supplicant ...
      udhcpc: started, v1.33.2
      udhcpc: sending discover
      udhcpc: no lease, forking to background
      wifi setup successfully!
      root@T113-Tronlong:/home#
       ./ap_setup.sh
      root@T113-Tronlong:/home# udhcpd: ./udhcpd.conf: No such file or directory
      udhcpd: started, v1.33.2
      udhcpd: is interface eth0 up and configured?: Cannot assign requested address
      Configuration file: ./rtl_hostapd_2G.conf
      wlan0: interface state UNINITIALIZED->HT_SCAN
      20/40 MHz operation not permitted on channel pri=6 sec=10 based on overlapping BSSes
      Could not set channel for kernel driver
      Interface initialization failed
      wlan0: interface state HT_SCAN->DISABLED
      wlan0: AP-DISABLED
      wlan0: interface state DISABLED->DISABLED
      wlan0: AP-DISABLED
      wlan0: CTRL-EVENT-TERMINATING
      hostapd_free_hapd_data: Interface wlan0 wasn't started
      ssid  : TP_LINK_lc
      psk   : lechi2024
      device: wlan0
      wpa_supplicant had already startup
      udhcpc: sending select for 192.168.234.96
      udhcpc: lease of 192.168.234.96 obtained, lease time 3599
      deleting routers
      adding dns 192.168.234.204
      root@T113-Tronlong:/home# ping www.baidu.com
      ping: bad address 'www.baidu.com'
