    T113S3 USB1插入U盘问题。。。
      z2500abc LV 5 最后由 编辑
      root@TinaLinux:/mnt/exUDISK# [  146.908103] usb 1-1: new high-speed USB device number 9 using sunxi-ehci
      [  147.109349] hub 1-1:1.0: USB hub found
      [  147.113681] hub 1-1:1.0: 4 ports detected
      [  147.538102] usb 1-1.2: new high-speed USB device number 10 using sunxi-ehci
      [  147.790105] usb-storage 1-1.2:1.0: USB Mass Storage device detected
      [  147.808115] scsi host1: usb-storage 1-1.2:1.0
      [  148.008096] usb 1-1.3: new high-speed USB device number 11 using sunxi-ehci
      [  148.829256] scsi 1:0:0:0: Direct-Access     SanDisk  Ultra USB 3.0    1.00 PQ: 0 ANSI: 6
      [  148.839850] sd 1:0:0:0: [sdb] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
      [  148.850085] sd 1:0:0:0: [sdb] Write Protect is off
      [  148.855490] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
      [  148.862335] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
      [  148.918615]  sdb: sdb1 sdb2
      [  148.925959] sd 1:0:0:0: [sdb] Attached SCSI removable disk
      T113S3 USB1插入U盘能够正常挂载,可以复制里面的文件,但是使用tplayerdemo 播放里面的音乐时候就无法进行播放了,报的错误如上!!
        a06041114 LV 5 @z2500abc 最后由 编辑
        @z2500abc
        解决了嘛?我USB1经过HUB芯片装出4个USB口,插入U盘也是弹出这个信息,而且是一直弹出
        Z 1 条回复 最后回复 回复 引用 分享 0
          z2500abc LV 5 @a06041114 最后由 编辑
          @a06041114 解决了
