    T113S3使用SL2.1S-HUB芯片
      z2500abc LV 5 最后由 编辑
      固件使用OTG烧录成功后,如果不将USB线拔下 总是不停的打印以下信息,请问这个信息该怎样关闭啊。。 板子上使用了一个SL2.1S的HUB芯片
      BusyBox v1.33.2 (2023-09-13 11:29:20 UTC) built-in shell (ash)
       Tina 5.0, OpenWrt 21.02-SNAPSHOT unknown
      root@TinaLinux:/# [   22.703307] usb 1-1: new high-speed USB device number 18 using sunxi-ehci
      [   22.905308] hub 1-1:1.0: USB hub found
      [   22.909675] hub 1-1:1.0: 4 ports detected
      [   23.343289] usb 1-1.3: new high-speed USB device number 19 using sunxi-ehci
      [   23.599519] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   23.608464] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   23.617592] usb 1-1: USB disconnect, device number 18
      [   23.623345] usb 1-1.3: USB disconnect, device number 19
      [   23.927393] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   23.936311] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   23.993296] usb 1-1: new high-speed USB device number 20 using sunxi-ehci
      [   24.383285] usb 1-1: device descriptor read/64, error -71
      [   24.705069] hub 1-1:1.0: USB hub found
      [   24.709426] hub 1-1:1.0: 4 ports detected
      [   25.133289] usb 1-1.3: new high-speed USB device number 21 using sunxi-ehci
      [   25.211141] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   25.220056] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   25.228806] usb 1-1: USB disconnect, device number 20
      [   25.773285] usb 1-1.3: device not accepting address 21, error -71
      [   25.780193] usb 1-1-port3: attempt power cycle
      [   26.473290] usb 1-1: new high-speed USB device number 25 using sunxi-ehci
      [   26.675094] hub 1-1:1.0: USB hub found
      [   26.679554] hub 1-1:1.0: 4 ports detected
      [   27.088518] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   27.097438] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   27.106583] usb 1-1: USB disconnect, device number 25
      [   27.112301] usb 1-1.3: new high-speed USB device number 26 using sunxi-ehci
      [   27.143326] usb 1-1-port3: attempt power cycle
      [   27.843287] usb 1-1: new high-speed USB device number 30 using sunxi-ehci
      [   28.045056] hub 1-1:1.0: USB hub found
      [   28.049428] hub 1-1:1.0: 4 ports detected
      [   28.473377] usb 1-1.3: new high-speed USB device number 31 using sunxi-ehci
      [   29.177893] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   29.186815] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   29.195997] usb 1-1: USB disconnect, device number 30
      [   29.201690] usb 1-1.3: USB disconnect, device number 31
      [   29.563295] usb 1-1: new high-speed USB device number 32 using sunxi-ehci
      [   29.765307] hub 1-1:1.0: USB hub found
      [   29.769678] hub 1-1:1.0: 4 ports detected
      [   30.122266] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   30.131193] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   30.140359] usb 1-1: USB disconnect, device number 32
      [   30.193291] usb 1-1.3: new high-speed USB device number 33 using sunxi-ehci
      [   30.233374] usb 1-1-port3: attempt power cycle
      [   30.923296] usb 1-1: new high-speed USB device number 37 using sunxi-ehci
      [   30.930922] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   30.939870] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   31.323357] usb 1-1: device descriptor read/64, error -71
      [   31.645306] hub 1-1:1.0: USB hub found
      [   31.649675] hub 1-1:1.0: 4 ports detected
      [   31.865269] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   31.874197] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   31.883339] usb 1-1: USB disconnect, device number 37
      [   32.233321] usb 1-1: new high-speed USB device number 38 using sunxi-ehci
      [   32.435067] hub 1-1:1.0: USB hub found
      [   32.439428] hub 1-1:1.0: 4 ports detected
      [   32.671139] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   32.680068] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   32.689005] usb 1-1: USB disconnect, device number 38
      [   32.694788] usb 1-1-port3: attempt power cycle
      [   33.383323] usb 1-1: new high-speed USB device number 43 using sunxi-ehci
      [   33.585143] hub 1-1:1.0: USB hub found
      [   33.589554] hub 1-1:1.0: 4 ports detected
      [   33.626268] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   33.635200] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   33.644369] usb 1-1: USB disconnect, device number 43
      [   33.993322] usb 1-1: new high-speed USB device number 44 using sunxi-ehci
      [   34.098891] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   34.107811] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   34.583286] usb 1-1: device not accepting address 44, error -71
      [   34.953287] usb 1-1: new high-speed USB device number 45 using sunxi-ehci
      [   35.155308] hub 1-1:1.0: USB hub found
      [   35.159678] hub 1-1:1.0: 4 ports detected
      [   35.504642] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   35.513561] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   35.522636] usb 1-1: USB disconnect, device number 45
      [   35.583294] usb 1-1.3: new high-speed USB device number 46 using sunxi-ehci
      [   35.623326] usb 1-1-port3: attempt power cycle
      [   36.313292] usb 1-1: new high-speed USB device number 50 using sunxi-ehci
      [   36.515044] hub 1-1:1.0: USB hub found
      [   36.519429] hub 1-1:1.0: 4 ports detected
      [   36.943289] usb 1-1.3: new high-speed USB device number 51 using sunxi-ehci
      [   37.263644] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   37.272566] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   37.281639] usb 1-1: USB disconnect, device number 50
      [   37.287357] usb 1-1.3: USB disconnect, device number 51
      [   37.590894] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   37.599813] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   37.643298] usb 1-1: new high-speed USB device number 52 using sunxi-ehci
      [   38.033285] usb 1-1: device descriptor read/64, error -71
      [   38.355379] hub 1-1:1.0: USB hub found
      [   38.359803] hub 1-1:1.0: 4 ports detected
      [   38.535399] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   38.544333] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   38.553530] usb 1-1: USB disconnect, device number 52
      [   38.903320] usb 1-1: new high-speed USB device number 53 using sunxi-ehci
      [   39.013640] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   39.022554] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   39.493284] usb 1-1: device not accepting address 53, error -71
      [   39.863286] usb 1-1: new high-speed USB device number 54 using sunxi-ehci
      [   40.065552] hub 1-1:1.0: USB hub found
      [   40.069926] hub 1-1:1.0: 4 ports detected
      [   40.284393] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   40.293321] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   40.302448] usb 1-1: USB disconnect, device number 54
      [   40.653321] usb 1-1: new high-speed USB device number 55 using sunxi-ehci
      [   40.762639] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   40.771562] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   41.243286] usb 1-1: device not accepting address 55, error -71
      [   41.613285] usb 1-1: new high-speed USB device number 56 using sunxi-ehci
      [   41.815270] hub 1-1:1.0: USB hub found
      [   41.819679] hub 1-1:1.0: 4 ports detected
      [   42.041392] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   42.050318] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   42.059421] usb 1-1: USB disconnect, device number 56
      [   42.413287] usb 1-1: new high-speed USB device number 57 using sunxi-ehci
      [   42.504640] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   42.513552] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   43.003314] usb 1-1: device not accepting address 57, error -71
      [   43.373290] usb 1-1: new high-speed USB device number 58 using sunxi-ehci
      [   43.575253] hub 1-1:1.0: USB hub found
      [   43.579678] hub 1-1:1.0: 4 ports detected
      [   43.914141] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   43.923058] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   43.932125] usb 1-1: USB disconnect, device number 58
      [   44.003314] usb 1-1.3: new high-speed USB device number 59 using sunxi-ehci
      [   44.043325] usb 1-1-port3: attempt power cycle
      [   44.743292] usb 1-1: new high-speed USB device number 63 using sunxi-ehci
      [   44.944822] hub 1-1:1.0: USB hub found
      [   44.949175] hub 1-1:1.0: 4 ports detected
      [   45.373323] usb 1-1.3: new high-speed USB device number 64 using sunxi-ehci
      [   46.008644] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   46.017567] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   46.026743] usb 1-1: USB disconnect, device number 63
      [   46.032458] usb 1-1.3: USB disconnect, device number 64
      [   46.393289] usb 1-1: new high-speed USB device number 65 using sunxi-ehci
      [   46.595020] hub 1-1:1.0: USB hub found
      [   46.599430] hub 1-1:1.0: 4 ports detected
      [   46.883517] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   46.892435] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   46.901504] usb 1-1: USB disconnect, device number 65
      [   47.023292] usb 1-1.3: new high-speed USB device number 66 using sunxi-ehci
      [   47.063327] usb 1-1-port3: attempt power cycle
      [   47.753287] usb 1-1: new high-speed USB device number 70 using sunxi-ehci
      [   47.954903] hub 1-1:1.0: USB hub found
      [   47.959305] hub 1-1:1.0: 4 ports detected
      [   48.383329] usb 1-1.3: new high-speed USB device number 71 using sunxi-ehci
      [   48.723291] sunxi_vbus_det_work()3432 WARN: get power supply failed
      [   48.730705] android_work: sent uevent USB_STATE=DISCONNECTED
