    python 脚本根据公网IP自动获取地址和天气信息
    • tigger
      tigger LV 7 最后由 whycan 编辑
      项目地址: https://github.com/whitejoce/Get_Weather
      https://raw.githubusercontent.com/whitejoce/Get_Weather/main/GetWeather.py
      #!/usr/bin/python
      # _*_coding: utf-8 _*_
      #Coder:Whitejoce
      import sys
      import time
      import json
      import requests
      import bs4
      import re
      import urllib as urlparse
      import http.client
      #输出模式,0为shell输出,1为窗口输出(窗口仅输出天气信息)
      output=0
      def get_CityName():
          try:
              res=requests.post(url='http://ip-api.com/json/?lang=zh-CN', data={'ip': 'myip'},timeout=10)
              result = res.json()['city']
          except:
              print(" [!]正在进行网络自检并重试")
              try:
                   res=requests.post(url='http://ip-api.com/json/?lang=zh-CN', data={'ip': 'myip'},timeout=15)
              except:
                   print(" [!]无法从相关网站获得请求(请求总时长:25s),退出脚本")
                   sys.exit(1)
          ##print(res.json())
          City = re.findall('(.*?)市',result)
          CityName = "".join(City)
          #CityName = CityName[-2:]
          if len(CityName) ==0:
                   print(' [!] 未自动匹配到你所在地的地区信息:'+result)
          return CityName
      def get_city_code(city):
          try:
              parameter = urlparse.parse.urlencode({'cityname': city})
              conn = http.client.HTTPConnection('toy1.weather.com.cn', 80, timeout=5)
              conn.request('GET', '/search?' + parameter)
              r = conn.getresponse()
              data = r.read().decode()[1:-1]
              json_data = json.loads(data)
              code = json_data[0]['ref'].split('~')[0]
              return code
          except:
              print(' [!] 错误,未能找到该地区信息')
              print(" [#] 退出脚本")
              sys.exit()
      def get_weaPage(url,headers):
          res = requests.get(url, headers=headers)
          ##print(res.text)
          s=res.content
          s.decode('ISO-8859-1')
          bs = bs4.BeautifulSoup(s,"html.parser")
          html = bs.prettify()
          return html
      def CheckInput(InputString):
          if any(char.isdigit() for char in InputString):
              return True
          match = re.search('[a-zA-Z]+$',InputString)
          if match:
              return True
          return False
      def GetItem(name,list):
          name = re.findall(r'"'+list+'":"(.*?)"',name)
          name = "".join(name)
          return name
      def get_weather(City_code):
          headers1 = {
          'Referer' : "http://www.weather.com.cn",
          'Cookie': '',
          'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:66.0) Gecko/20100101 Firefox/66.0'
          #timestamp的长度为13
          #timestamp = ''.join(str(random.choice(range(10))) for i in range(13))
          t = time.time()
          timestamp = str(int(round(t * 1000)))
          port = "http://d1.weather.com.cn/weather_index/"+City_code+".html?_="+timestamp
          html = get_weaPage(port,headers1)
          #print(html)
          wea_list_all= html.split("var")
          #print(wea_list_all)
          temp_port = "http://d1.weather.com.cn/dingzhi/"+City_code+".html?_="+timestamp
          temp_html=get_weaPage(temp_port,headers1)
          #print(temp_html)
          #cityDZ
          html1= wea_list_all[1]
          wea_list1= html1.split(",")
          temp_list=temp_html.split(",")
          #print(temp_list)
          #城市英文
          city_en = wea_list1[1]
          city_en = GetItem(city_en,"cityname")
          #温度区间
          maxtemp = temp_list[3]
          maxtemp = GetItem(maxtemp,"temp")
          mintemp = temp_list[4]
          mintemp = GetItem(mintemp,"tempn")
          #实时天气
          wea_now = wea_list1[4]
          wea_now=GetItem(wea_now,"weather")
          #alarmDZ
          wea_list2 = wea_list_all[2]
          wea_alarm_all = re.findall(r'alarmDZ ={"w":[(.*?)]};',wea_list2)
          warning = 0
          EmptyList = ['']
          if wea_alarm_all == EmptyList:
               pass
          else :
               warning = 1
          #dataSK
          html3 = wea_list_all[3]
          wea_list3= html3.split(",")
          #城市
          cityname = wea_list3[1]
          cityname=GetItem(cityname,"cityname")
          #当前温度
          temp_now = wea_list3[3]
          temp_now=GetItem(temp_now,"temp")
          #湿度
          wet = wea_list3[9]
          wet=GetItem(wet,"SD")
          #时间
          update = wea_list3[13]
          update=GetItem(update,"time")
          #空气质量
          aqi = wea_list3[16]
          aqi=GetItem(aqi,"aqi")
          #PM2.5
          aqi_pm25 = wea_list3[17]
          aqi_pm25=GetItem(aqi_pm25,"aqi_pm25")
          #日期
          date = wea_list3[22]
          date=GetItem(date,"date")
          #dataZS
          wea_list4 = wea_list_all[4]
          ##print(wea_list4)
          #ataZS=re.findall(r',"(.*?)":',wea_list4)
          ##print(dataZS)
          umbrella=GetItem(wea_list4,"ys_des_s")
          #和风天气
          headers2 = {
          qwea_url = "https://www.qweather.com/weather/"+city_en+"-"+City_code+".html"
          qwea_html = get_weaPage(qwea_url,headers2)
          #print(qwea_html)
          wea_comment = re.findall(r'<div class="current-abstract">(.*?)</div>',qwea_html,flags=16)
          wea_comment = "".join(wea_comment)
          aqi_level = re.findall(r'<p class="city-air-chart__txt text-center">(.*?)</p>',qwea_html,flags=16)
          aqi_level=aqi_level[0].replace("\n","")
          aqi_level=aqi_level.replace(" ","")
          wea_comment = wea_comment.strip('\n')
          wea_comment = wea_comment.replace(" ","").replace("\n","")
          weather_text=''' {0}
       定位城市:  {1}
       实时天气:  {2}
       实时温度:  {3}℃
       温度区间:  {4} - {5}
       空气湿度:  {6}
       空气质量:  {7}({8}),PM2.5: {9}
       雨具携带:  {10}
       [更新时间: {11} {12}]
       ==================================='''.format\
      (wea_comment,cityname,wea_now,temp_now,maxtemp,\
      mintemp,wet,aqi,aqi_level,aqi_pm25,umbrella,date,update)
          #print("\n " + wea_comment)
          #print(" ===================================")
          #print(" 定位城市:  "+cityname)
          #print(" 实时天气:  "+wea_now)
          #print(" 实时温度:  "+temp_now+"℃")
          #print(" 温度区间:  "+maxtemp+"℃ - "+mintemp+"℃")
          #print(" 空气湿度:  "+wet)
          #0~50优,51~100良,101~150轻度污染,151~200中度污染,201~300重度污染,>300严重污染
          #print(" 空气质量:  "+aqi+"("+aqi_level+"),PM2.5: "+aqi_pm25)
          #print(" 雨具携带:  "+umbrella)
          #print(" [更新时间: "+date+" "+update +"]")
          #处理天气预警
          if warning==1:
              wea_alarm_all = "".join(wea_alarm_all)
              wea_alarm = re.findall(r'"w9":"(.*?)"',wea_alarm_all)
              wea_counter=len(wea_alarm)
              if wea_counter == 1:
                  weather_text=weather_text+"\n [!]气象部门发布预警,请注意:"
                  #print(" [!]气象部门发布预警,请注意:")
              else:
                  weather_text=weather_text+"\n [!]气象部门发布"+ str(wea_counter) +"则预警,请注意:"
                  #print(" [!]气象部门发布"+ str(wea_counter) +"则预警,请注意:")
              #wea_alarm = "".join(wea_alarm)
              if wea_alarm != "":
                  i=1
                  for alarm in wea_alarm:
                      alarm=alarm.replace("\\","")
                      alarm=alarm.replace(":",":\n ",1)
                      if wea_counter==1:
                          weather_text=weather_text+" \n "+alarm
                          #print(" "+alarm)
                      else:
                          weather_text=weather_text+" \n ["+ str(i) +"]"+alarm
                          #print(" ["+ str(i) +"]"+alarm)
                          i=i+1
              else:
                  print(" [!]无法获取气象预警详情")
                  option = input(" [?]显示完整数据结构?[y/n]")
                  if option=="y" or option=="Y":
                      #wea_alarm = wea_alarm.replace("{","")
                      #wea_alarm = wea_alarm.replace("}","")
                      weather_text=weather_text+" \n "+wea_alarm_all
          return weather_text
      if __name__ == '__main__':
          try:
              address = get_CityName()
              if len(address)==0:
                   address = input(" [?] 请手动输入所在地(例:广州)[输入为空即退出]:")
                   if address=="":
                       print(" [#] 退出脚本")
                       sys.exit(1)
                   else:
                       if CheckInput(address)==1:
                           print(" [!]检测非地名字符,退出脚本")
                           sys.exit(1)
                       else:
                           print(" [+] 使用手动输入定位位置:"+address)
              else:
                   print(" [+] 自动定位位置:"+address)
              code = get_city_code(address)
              try:
                  weather_text=get_weather(code)
                  if output==0:
                      print("\n"+weather_text)
                  elif output==1:
                      from tkinter import *
                      windows = Tk()
                      windows.title("GetWeather")
                      text1 = Text(windows)
                      text1.insert(INSERT,weather_text)
                      text1.pack()
                      windows.mainloop()
              except Exception as Error:
                  print(' [!] 未能找到该地区的天气信息')
                  print(" [#] 退出脚本")
                  #raise Error
                  sys.exit()
              raise Error
      准备工作:
      sudo apt install python3 python3-pip
      python3 -m pip install bs4
      运行
      $ python3 GetWeather.py
       [+] 自动定位位置:深圳
       今天多云,比昨天热一些,现在17°,空气一般。
       定位城市:  深圳
       实时天气:  多云
       实时温度:  18℃
       温度区间:  23℃ - 15℃
       空气湿度:  60%
       空气质量:  65(良),PM2.5: 65
       雨具携带:  天气较好,不用带雨伞。
       [更新时间: 11月25日(星期四) 09:20]
      • tigger
        tigger LV 7 最后由 编辑
        可以移植到哪吒吗?
