[求助][T113]T113NAND烧录失败,怎么修改固件中的对应NAND型号配置?
我想要把我再bingpi 上编出的固件直接移到百问网的T113核心板上,但是直接下载烧录的时候会卡在7%报错:
Volume mbr not found! [08.360]read volume mbr failed return 19 read local mbr on flash failed [08.366]erase blk 0 to blk 32 [08.383]erase blk 40 to blk 1024 SUNXI_EFEX_MBR_TAG mbr size = 0x10000 force mbr device nand0 <nand>, # parts = 4 #: name size offset mask_flags 0: boot0 0x00100000 0x00000000 1 1: uboot 0x00300000 0x00100000 1 2: secure_storage 0x00100000 0x00400000 1 3: sys 0x07b00000 0x00500000 0 active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000 defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys) [08.856]MTD info (4) [08.858]pagesize: 0x1000 [08.861]blksize: 0x40000 [08.863]num offset bytes name [08.866]0 0x00000000 0x00100000 boot0 [08.870]1 0x00100000 0x00300000 uboot [08.874]2 0x00400000 0x00100000 secure_storage [08.878]3 0x00500000 0x07b00000 sys [08.882]MBR info (unalign): [08.884]partno addr sects type name [08.889]0 0x00000000 0x00008000 0x00000001 mbr [08.894]1 0x00008000 0x000009c4 0x00008000 boot-resource [08.899]2 0x000089c4 0x000001f8 0x00008000 env [08.904]3 0x00008bbc 0x000001f8 0x00008000 env-redund [08.909]4 0x00008db4 0x000026ac 0x00008000 boot [08.914]5 0x0000b460 0x0001cf00 0x00008000 rootfs [08.919]6 0x00028360 0x000001f8 0x00008000 private [08.924]7 0x00028558 0x00049700 0x00008000 rootfs_data [08.930]8 0x00071c58 0x00000000 0x00008100 UDISK [08.935]ubi attach the last part of mtd device: NO.3 [08.940]MBR info (align): [08.942]partno addr sects type name [08.947]0 0x00002800 0x000081f0 0x00000001 mbr [08.952]1 0x0000a9f0 0x000009d8 0x00008000 boot-resource [08.957]2 0x0000b3c8 0x000001f8 0x00008000 env [08.962]3 0x0000b5c0 0x000001f8 0x00008000 env-redund [08.967]4 0x0000b7b8 0x00002760 0x00008000 boot [08.972]5 0x0000df18 0x0001d0a0 0x00008000 rootfs [08.977]6 0x0002afb8 0x000001f8 0x00008000 private [08.982]7 0x0002b1b0 0x00049758 0x00008000 rootfs_data [08.988]8 0x00074908 0x00000000 0x00008100 UDISK [08.993]ubi attach the last part of mtd device: NO.3 [08.997]ubi volume total size is larger than mtd size. ubi_vol_total_bytes : 0xe421000, mtd_bytes: 0x7b00000 [09.007]initialize sunxi spinand ubi failed download_standard_gpt:write mbr sectors fail ret = 0 ``` 请问有没有人知道怎么修改nand相关的配置?
