    【FAQ】全志R329如何通过uboot修改设备树属性?
    r329 r328 r818 faq 技术支持
      问题背景
      硬件:R328+ Wi-Fi模组(XRADIO)
      软件:Tina3.0及以上
      问题简述
      有时候经常需要临时调整部份设备树的属性配置,例如sdc的频率,以太网的delay参数。如果每次都源码修改后编译烧写,比较费时,所以uboot提供了临时修改的方法。
      注:uboot修改都是单次启动有效,重启无效。
      问题分析
      1.修改sdc的属性
      产看当前sdc的配置
      => fdt print /soc/sdmmc@4021000
      sdmmc@4021000 {
              device_type = "sdc1";
              reg = <0x00000000 0x04021000 0x00000000 0x00001000>;
              interrupts = <0x00000000 0x00000029 0x00000004>;
              clocks = <0x0000000c 0x00000002 0x00000005 0x00000002 0x0000003a 0x00000002 0x0000003d>;
              clock-names = "osc24m", "pll_periph", "mmc", "ahb";
              resets = <0x00000002 0x00000010>;
              reset-names = "rst";
              pinctrl-0 = <0x00000022>;
              pinctrl-1 = <0x00000023>;
              max-frequency = <0x08f0d180>;
              bus-width = <0x00000004>;
              cap-sd-highspeed;
              no-mmc;
              keep-power-in-suspend;
              sunxi-dly-52M-ddr4 = <0x00000001 0x00000000 0x00000000 0x00000000 0x00000002>;
              sunxi-dly-104M = <0x00000001 0x00000000 0x00000000 0x00000000 0x00000001>;
              sunxi-dly-208M = <0x00000001 0x00000000 0x00000000 0x00000000 0x00000001>;
              no-sd;
              cap-sdio-irq;
              ignore-pm-notify;
              ctl-spec-caps = <0x00000008>;
      修改sdc的最大支持频率
      25M
      fdt set /soc/sdmmc@04021000 max-frequency <0x017d7840>
      50M
      fdt set /soc/sdmmc@04021000 max-frequency <0x02faf080>
      100M
      fdt set /soc/sdmmc@04021000 max-frequency <0x05f5e100>
      120M
      fdt set /soc/sdmmc@04021000 max-frequency <0x07270e00>
      150M
      fdt set /soc/sdmmc@04021000 max-frequency <0x08f0d180>
      修改相位
      fdt set /soc/sdmmc@04021000 sunxi-dly-208M <0x00000001 0x00000000 0x00000000 0x00000000 0x00000000 0x00000001>
      2.修改以太网的属性
      打印当前以太网的配置
      => fdt print /soc/eth@4500000
      eth@4500000 {
              compatible = "allwinner,sunxi-gmac";
              reg = <0x00000000 0x04500000 0x00000000 0x00010000 0x00000000 0x03000030 0x00000000 0x00000004>;
              interrupts = <0x00000000 0x0000002e 0x00000004>;
              interrupt-names = "gmacirq";
              clocks = <0x00000002 0x00000050 0x00000002 0x0000004f>;
              clock-names = "gmac", "ephy";
              resets = <0x00000002 0x00000020>;
              device_type = "gmac0";
              gmac-power0;
              gmac-power1;
              gmac-power2;
              phy-mode = "rgmii";
              use_ephy25m = <0x00000001>;
              pinctrl-0 = <0x00000019>;
              pinctrl-1 = <0x0000001a>;
              tx-delay = <0x00000003>;
              rx-delay = <0x00000005>;
      修改delay 参数
      fdt set /soc/eth@4500000 rx-delay  <0x0000000a>
      注:这里只是简单介绍uboot的命令,具体设备属性的解释就不展开说明了。
      解决办法
      uboot常用命令
      fdt
      => fdt -h
      fdt - flattened device tree utility commands
      Usage:
      fdt addr [-c]  <addr> [<length>]   - Set the [control] fdt location to <addr>
      fdt apply <addr>                    - Apply overlay to the DT
      fdt boardsetup                      - Do board-specific set up
      fdt move   <fdt> <newaddr> <length> - Copy the fdt to <addr> and make it active
      fdt resize [<extrasize>]            - Resize fdt to size + padding to 4k addr + some optional <extrasize> if needed
      fdt print  <path> [<prop>]          - Recursive print starting at <path>
      fdt list   <path> [<prop>]          - Print one level starting at <path>
      fdt get value <var> <path> <prop>   - Get <property> and store in <var>
      fdt get name <var> <path> <index>   - Get name of node <index> and store in <var>
      fdt get addr <var> <path> <prop>    - Get start address of <property> and store in <var>
      fdt get size <var> <path> [<prop>]  - Get size of [<property>] or num nodes and store in <var>
      fdt set    <path> <prop> [<val>]    - Set <property> [to <val>]
      fdt mknode <path> <node>            - Create a new node after <path>
      fdt rm     <path> [<prop>]          - Delete the node or <property>
      fdt header                          - Display header info
      fdt bootcpu <id>                    - Set boot cpuid
      fdt memory <addr> <size>            - Add/Update memory node
      fdt rsvmem print                    - Show current mem reserves
      fdt rsvmem add <addr> <size>        - Add a mem reserve
      fdt rsvmem delete <index>           - Delete a mem reserves
      fdt chosen [<start> <end>]          - Add/update the /chosen branch in the tree
                                            <start>/<end> - initrd start/end addr
      printenv:打印环境变量
      setenv:设置环境变量
      saveenv:保存设置的环境变量
      md:显示内存区的内容
      mm:修改内存
      cmp:比较两块内存
