    T113i 打开RTL8821CU wifi 失败,有遇到过的么
      yjklwj LV 3 最后由 编辑
      T113i,usb 连接rtl8821cu,驱动添加完成后,ifconfig wlan0 up,内核直接报错,一下新打印信息,有遇到过的么。rtl8821cu的驱动应该是没有问题的,我们在别的平台上是可以用的。
      kernel/linux-5.4/drivers/net/wireless/realtek/rtl8821cu/hal/rtl8821c/rtl8821c_halinit.c:106 rtl8821c_power_on+0xa4/0xf4
      [ 95.855461] Modules linked in: sunxi_ce
      [ 95.859770] CPU: 0 PID: 1585 Comm: ifconfig Not tainted 5.4.61 #19
      [ 95.866696] Hardware name: Generic DT based system
      [ 95.872087] [<c010e390>] (unwind_backtrace) from [<c010a934>] (show_stack+0x10/0x14)
      [ 95.880776] [<c010a934>] (show_stack) from [<c08efcd8>] (dump_stack+0x7c/0x98)
      [ 95.888879] [<c08efcd8>] (dump_stack) from [<c0119d68>] (__warn+0xac/0xdc)
      [ 95.896593] [<c0119d68>] (__warn) from [<c0119e10>] (warn_slowpath_fmt+0x78/0xa0)
      [ 95.904987] [<c0119e10>] (warn_slowpath_fmt) from [<c0561bac>] (rtl8821c_power_on+0xa4/0xf4)
      [ 95.914451] [<c0561bac>] (rtl8821c_power_on) from [<c053764c>] (rtw_hal_power_on+0x18/0x40)
      [ 95.923818] [<c053764c>] (rtw_hal_power_on) from [<c0570728>] (_halmac_init_hal+0x2c/0x18c)
      [ 95.933183] [<c0570728>] (_halmac_init_hal) from [<c05708a4>] (rtw_halmac_init_hal_fw+0x8/0xc)
      [ 95.942844] [<c05708a4>] (rtw_halmac_init_hal_fw) from [<c0561d24>] (rtl8821c_hal_init_main+0x3c/0x160)
      [ 95.953382] [<c0561d24>] (rtl8821c_hal_init_main) from [<c0562058>] (rtl8821c_hal_init+0x14/0x6c)
      [ 95.963336] [<c0562058>] (rtl8821c_hal_init) from [<c05694f0>] (rtl8821cu_hal_init+0x1c/0xc0)
      [ 95.972900] [<c05694f0>] (rtl8821cu_hal_init) from [<c0537ffc>] (rtw_hal_init+0x30/0x1bc)
      [ 95.982071] [<c0537ffc>] (rtw_hal_init) from [<c0516dd8>] (_netdev_open+0x94/0x2b0)
      [ 95.990656] [<c0516dd8>] (_netdev_open) from [<c0517074>] (netdev_open+0x80/0xa4)
      [ 95.999047] [<c0517074>] (netdev_open) from [<c0754818>] (__dev_open+0xdc/0x14c)
      [ 96.007340] [<c0754818>] (__dev_open) from [<c0754b04>] (__dev_change_flags+0xf0/0x1a8)
      [ 96.016319] [<c0754b04>] (__dev_change_flags) from [<c0754bd4>] (dev_change_flags+0x18/0x48)
      [ 96.025781] [<c0754bd4>] (dev_change_flags) from [<c07c3c3c>] (devinet_ioctl+0x2b0/0x614)
      [ 96.034951] [<c07c3c3c>] (devinet_ioctl) from [<c07c5f3c>] (inet_ioctl+0x1b8/0x204)
      [ 96.043537] [<c07c5f3c>] (inet_ioctl) from [<c07352fc>] (sock_ioctl+0x30c/0x434)
      [ 96.051832] [<c07352fc>] (sock_ioctl) from [<c01f4fe8>] (vfs_ioctl+0x18/0x3c)
      [ 96.059835] [<c01f4fe8>] (vfs_ioctl) from [<c01f5d9c>] (do_vfs_ioctl+0x620/0x6c8)
      [ 96.068225] [<c01f5d9c>] (do_vfs_ioctl) from [<c01f5e78>] (ksys_ioctl+0x34/0x5c)
      [ 96.076518] [<c01f5e78>] (ksys_ioctl) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
      [ 96.085101] Exception stack(0xee32bfa8 to 0xee32bff0)
      [ 96.090766] bfa0: 000b83fe be88db00 00000003 00008914 be88db00 000b83fe
      [ 96.099933] bfc0: 000b83fe be88db00 be88dde8 00000036 be88dcb8 000000b0 000a1880 00000000
      [ 96.109098] bfe0: 000d71f4 be88daa4 0001ad2c b6e71958
      [ 96.114918] ---[ end trace 8a97abebe479dbb5 ]---
        awwwwa LV 8 最后由 编辑
        rtl8821c_power_on 往下调用空了,没有实现全志平台的sunxi-rfkill接口
        Y 1 条回复 最后回复 回复 引用 分享 0
          yjklwj LV 3 @awwwwa 最后由 yjklwj 编辑
