    全志T113S3 从SD卡启动LOG GUID报错请大家帮忙解决 谢谢了
      z2500abc LV 5 最后由 编辑
      U-Boot 2018.07 (Aug 29 2025 - 09:02:02 +0000) Allwinner Technology
      [00.327]CPU:   Allwinner Family
      [00.330]Model: sun8iw20
      [00.332]DRAM:  128 MiB
      [00.335]Relocation Offset is: 04ec3000
      [00.362]secure enable bit: 0
      CACHE: Misaligned operation at range [44882e68, 448a2e68]
      E/TC:0   generate_smc_mem_map:319 Not enough SMC region, 0x41b07937 byte ta ram left unsecured
      E/TC:0   fdt_getprop_u32:340 prop trace_level not found
      [00.389]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.395]gic: sec monitor mode
      [00.399]line:703 init_clocks
      [00.402]flash init start
      [00.404]workmode = 0,storage type = 1
      [00.407][mmc]: mmc driver ver uboot2018:2023-08-29 10:12:00
      [00.413][mmc]: get sdc_type fail and use default host:tm1.
      [00.419][mmc]: can't find node "mmc0",will add new node
      [00.423][mmc]: fdt err returned <no error>
      [00.427][mmc]: Using default timing para
      [00.431][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.449][mmc]: card_caps:0x3000000a
      [00.452][mmc]: host_caps:0x3000003f
      [00.456]sunxi flash init ok
      get value error
      [00.460]drv_disp_init
      GUID Partition Table Entry Array CRC is wrong: 0x4856d03b != 0xb83afff4
      part_get_info_efi: ***        Using Backup GPT ***
      [00.698]drv_disp_init finish
      [00.878]Loading Environment from SUNXI_FLASH... OK
      [00.898]boot_gui_init:start
      drv_lcd_open_callback lcd open flow is NULL! LCD enable fail!
      bad fb1_cfg[w=0,h=0,bpp=32,format=0]
      [00.978]boot_gui_init:finish
      [01.007]bmp_name=bootlogo.bmp size 38454
      [01.020]the secure storage item0 copy0 magic is bad
      [01.025]the secure storage item0 copy1 magic is bad
      [01.030]usb burn from boot
