    Tina Linux pack失败问题
    3388
      huangliqun LV 2 最后由 编辑
      1、如上图,make,和mboot。 已经正常编译通过。
      2、进行pack时,日志如下,我在目录下也找不到sboot.bin文件:
      user@DESKTOP-L3PLPDH:/t113/Tina-Linux$ pack
      PACK_CHIP sun8iw20p1
      PACK_PLATFORM tina
      PACK_BOARD t113-bingpi_m2
      PACK_KERN
      PACK_DEBUG uart3
      PACK_SIG none
      PACK_SECURE none
      PACK_MODE normal
      PACK_FUNC android
      PACK_PROGRAMMER none
      PACK_TAR_IMAGE none
      PACK_TOPDIR /t113/Tina-Linux
      No kernel param, parse it from t113
      copying tools file
      copying configs file
      storage_type value is 1
      rm /t113/Tina-Linux/out/t113-bingpi_m2/image/sys_partition_nor.fex
      rm /t113/Tina-Linux/out/t113-bingpi_m2/image/image_nor.cfg
      copying boot resource
      copying boot file
      make user resource for : /t113/Tina-Linux/out/t113-bingpi_m2/image/sys_partition.fex
      handle partition user-res
      no user resource partitions
      APP_PART_DOWNLOAD_FILE = /t113/Tina-Linux/out/t113-bingpi_m2/image/app.fex
      Need size of filesystem
      no data resource partitions
      don't build dtbo ...
      update_chip
      sboot file Path=/t113/Tina-Linux/out/t113-bingpi_m2/image/sboot.bin
      script file Path=/t113/Tina-Linux/out/t113-bingpi_m2/image/sys_config.bin
      update:unable to open sboot file
      script update sboot ok
      /t113/Tina-Linux/scripts/pack_img.sh: line 1396: /t113/Tina-Linux/out/host/bin/fsbuild: cannot execute binary file: Exec format error
      pack boot package
      content_count=3
      packing for tina linux
      normal
      mbr count = 4
      partitation file Path=/t113/Tina-Linux/out/t113-bingpi_m2/image/sys_partition.bin
      mbr_name file Path=/t113/Tina-Linux/out/t113-bingpi_m2/image/sunxi_mbr.fex
      download_name file Path=/t113/Tina-Linux/out/t113-bingpi_m2/image/dlinfo.fex
      mbr size = 16384
      mbr magic softw411
      disk name=boot-resource
      ERROR: unable to open file boot-resource.fex
      update_for_part_info -1
      ERROR: update mbr file fail
      ERROR: update_mbr failed
        zoipuus LV 5 最后由 编辑
        是不是系统缺少32位库,试试sudo apt-get install libc6:i386 libgcc1:i386 libstdc++6:i386 -y
        H 1 条回复 最后回复 回复 引用 分享 0
          huangliqun LV 2 @zoipuus 最后由 编辑
          @zoipuus 这几个库已经安装了,并且我试了在ubuntu18 或者 unbuntu22编译出来,都是卡在这个地方。很奇怪了。
          Z J 2 条回复 最后回复 回复 引用 分享 0
            zoipuus LV 5 @huangliqun 最后由 编辑
            @huangliqun lib32z1 lib32z1-dev,这两个呢,我之前也是打包失败,安装那些库后就可以了,可能还缺其他的吧
              Jingyan LV 6 @huangliqun 最后由 编辑
              @huangliqun 参考下 pack 时 ERROR: unable to open file boot-resource.fex
              sudo apt-get install lib32z1 lib32z1-dev
                搞定了,是因为使用了WSL子系统的原因,使用子系统的ubuntu要支持运行32位i386程序的方法参考了这里的:
                https://zhuanlan.zhihu.com/p/615401047?utm_id=0
                  是使用WSL的原因:
                  网下查询下:Windows的WSL上的ubuntu运行32位i386程序的方法,就解决了。
