    t113s3 emmc问题
      zhouguoxin LV 2 最后由 编辑
      [37]HELLO! BOOT0 is starting!
      [40]BOOT0 commit : 069ed30b88
      [43]set pll start
      [49]periph0 has been enabled
      [52]set pll end
      [54][pmu]: bus read error
      [56]board init ok
      [58]enable_jtag
      [60]ZQ value = 0x2e
      [61]get_pmu_exist() = -1
      [64]DRAM BOOT DRIVE INFO: V0.34
      [67]DRAM CLK = 792 MHz
      [69]DRAM Type = 3 (2:DDR2,3:DDR3)
      [72]DRAMC read ODT off.
      [75]DRAM ODT value: 0x42.
      [77]ddr_efuse_type: 0xa
      [80]DRAM SIZE = 128 MB
      [87]DRAM simple test OK.
      [89]rtc standby flag is 0x0, super standby flag is 0x0
      [94]dram size =128
      [97]card no is 2
      [99]sdcard 2 line count 4
      [101][mmc]: mmc driver ver 2021-05-21 14:47
      [110][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [116][mmc]: Try MMC card 2
      [142][mmc]: RMCA OK!
      [143][mmc]: mmc 2 bias 0
      [147][mmc]: MMC 5.1
      [148][mmc]: HSSDR52/SDR25 4 bit
      [151][mmc]: 50000000 Hz
      [154][mmc]: 7400 MB
      [155][mmc]: SD/MMC 2 init OK!!!
      [249]Loading boot-pkg Succeed(index=0).
      [253]Entry_name = u-boot
      [260]Entry_name = optee
      [264]Entry_name = dtb
      [267]tunning data addr:0x430003e8
      [270]Jump to second Boot.
      M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
      U-Boot 2018.07-gb28372f (Sep 29 2024 - 02:42:42 +0000) Allwinner Technology
      [00.322]CPU: Allwinner Family
      [00.324]Model: sun8iw20
      [00.327]DRAM: 128 MiB
      [00.330]Relocation Offset is: 04ebe000
      [00.357]secure enable bit: 0
      E/TC:0 fdt_getprop_u32:343 prop trace_level not found
      [00.371]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [00.377]gic: sec monitor mode
      SPI ALL: ready
      [00.382]line:703 init_clocks
      [00.385]flash init start
      [00.387]workmode = 0,storage type = 2
      [00.390][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
      [00.397][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.425][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.431]sunxi flash init ok
      [00.434]drv_disp_init
      [00.469]drv_disp_init finish
      [00.473]Loading Environment from SUNXI_FLASH... OK
      [00.486]boot_gui_init:start
      bad fb1_cfg[w=0,h=0,bpp=32,format=0]
      [00.501]boot_gui_init:finish
      [00.508]bmp_name=bootlogo.bmp size 1152054
      [00.545]Item0 (Map) magic is bad
      [00.548]the secure storage item0 copy0 magic is bad
      [00.552]Item0 (Map) magic is bad
      [00.555]the secure storage item0 copy1 magic is bad
      [00.560]Item0 (Map) magic is bad
      [00.590]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.602]usb prepare ok
      [00.679]LCD open finish
      [00.803]usb sof ok
      [00.805]usb probe ok
      [00.807]usb setup ok
      set address 0x6
      set address 0x6 ok
      set address 0x6
      set address 0x6 ok
      [01.212]do_burn_from_boot usb : have no handshake
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [01.239]update part info
      [01.242]update bootcmd
      [01.246]change working_fdt 0x4487de68 to 0x4485de68
      [01.250][mmc]: can't find node "sunxi-mmc2" try "mmc"
      [01.256][mmc]: no mmc-hs400-1_8v!
      [01.259][mmc]: delete mmc-hs200-1_8v from dtb
      [01.263][mmc]: get max-frequency ok 50000000 Hz
      [01.267][mmc]: get ctl-cmdq-md fail -13
      [01.270][mmc]: fdt err returned FDT_ERR_INTERNAL
      [01.275][mmc]: get sunxi-mmc2 string failed
      [01.280]The storage not support sample function
      [01.304]update dts
      boot addr 0x43000000 0x434dc800 exceed dsp0 scope
      dsp0 addr 0x43000000 0x43100000
      [01.452]no vendor_boot partition is found
      The loading address of the kernel is not in the boot image
      ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
      ERROR: reserving fdt memory region failed (addr=44908000 size=258000)
      [01.494]Starting kernel ...
      [01.497][mmc]: mmc exit start
      [01.515][mmc]: mmc 2 exit ok
      [ 0.000000] Booting Linux on physical CPU 0x0
      [ 0.000000] Linux version 5.4.61 (ubuntu@ubuntu1804) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld0 Linaro 2016_02) #1 SMP PREEMPT Mon Sep 29 12:41:23 EDT 2025
      [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
      [ 0.000000] CPU: div instructions available: patching division code
      [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [ 0.000000] OF: fdt: Machine model: sun8iw20
      [ 0.000000] printk: bootconsole [earlycon0] enabled
      [ 0.000000] Memory policy: Data cache writealloc
      [ 0.000000] Reserved memory: created DMA memory pool at 0x42200000, size 0 MiB
      [ 0.000000] OF: reserved mem: initialized node vdev0buffer@42200000, compatible id shared-dma-pool
      [ 0.000000] Reserved memory: created DMA memory pool at 0x42244000, size 0 MiB
      [ 0.000000] OF: reserved mem: initialized node dsp0_rpbuf@42244000, compatible id shared-dma-pool
      [ 0.000000] cma: Reserved 16 MiB at 0x47000000
      [ 0.000000] On node 0 totalpages: 32420
      [ 0.000000] Normal zone: 256 pages used for memmap
      [ 0.000000] Normal zone: 0 pages reserved
      [ 0.000000] Normal zone: 32420 pages, LIFO batch:7
      [ 0.000000] psci: probing for conduit method from DT.
      [ 0.000000] psci: PSCIv1.0 detected in firmware.
      [ 0.000000] psci: Using standard PSCI v0.2 function IDs
      [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
      [ 0.000000] psci: SMC Calling Convention v1.0
      [ 0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440
      [ 0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096
      [ 0.000000] pcpu-alloc: [0] 0 [0] 1
      [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32164
      [ 0.000000] Kernel command line: ubi.block=0,rootfs earlyprintk= clk_ignore_unused initcall_debug=0 console=ttyS3,115200 lot=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:p cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_typeb28372f(09/29/2024-02:42:42) mbr_offset=1032192 disp_reserve=2457600,0x44908000 androidboot.dramfreq=792 androidboot.dramsize==ubootA
      [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
      [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [ 0.000000] Memory: 90256K/129680K available (7168K kernel code, 423K rwdata, 2560K rodata, 1024K init, 173K bss, 23040K re
      [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
      [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
      [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
      [ 0.000000] Tasks RCU enabled.
      [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
      [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [ 0.000000] random: get_random_bytes called from start_kernel+0x24c/0x3cc with crng_init=0
      [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
      [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [ 0.008018] Switching to timer-based delay loop, resolution 41ns
      [ 0.014208] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [ 0.024028] Console: colour dummy device 80x30
      [ 0.028516] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [ 0.038879] pid_max: default: 32768 minimum: 301
      [ 0.043641] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [ 0.050970] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [ 0.059345] CPU: Testing write buffer coherency: ok
      [ 0.064597] /cpus/cpu@0 missing clock-frequency property
      [ 0.069917] /cpus/cpu@1 missing clock-frequency property
      [ 0.075273] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [ 0.081528] Setting up static identity map for 0x40100000 - 0x40100060
      [ 0.088233] rcu: Hierarchical SRCU implementation.
      [ 0.093357] BOOTEVENT: 93.348707: ON
      [ 0.097738] smp: Bringing up secondary CPUs ...
      [ 0.103572] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [ 0.103726] smp: Brought up 1 node, 2 CPUs
      [ 0.113529] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [ 0.119717] CPU: All CPU(s) started in SVC mode.
      [ 0.124873] devtmpfs: initialized
      [ 0.142130] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [ 0.150339] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [ 0.160214] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [ 0.167877] pinctrl core: initialized pinctrl subsystem
      [ 0.174527] NET: Registered protocol family 16
      [ 0.180909] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [ 0.230331] rtc_ccu: sunxi ccu init OK
      [ 0.236553] ccu: sunxi ccu init OK
      [ 0.240564] r_ccu: sunxi ccu init OK
      [ 0.284598] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [ 0.294756] iommu: Default domain type: Translated
      [ 0.299880] sunxi iommu: irq = 24
      [ 0.304710] SCSI subsystem initialized
      [ 0.308859] usbcore: registered new interface driver usbfs
      [ 0.314600] usbcore: registered new interface driver hub
      [ 0.320027] usbcore: registered new device driver usb
      [ 0.325346] mc: Linux media interface: v0.10
      [ 0.329683] videodev: Linux video capture interface: v2.00
      [ 0.336417] Advanced Linux Sound Architecture Driver Initialized.
      [ 0.343241] Bluetooth: Core ver 2.22
      [ 0.346955] NET: Registered protocol family 31
      [ 0.351422] Bluetooth: HCI device and connection manager initialized
      [ 0.357868] Bluetooth: HCI socket layer initialized
      [ 0.362762] Bluetooth: L2CAP socket layer initialized
      [ 0.367860] Bluetooth: SCO socket layer initialized
      [ 0.373040] pwm module init!
      [ 0.383541] g2d 5410000.g2d: Adding to iommu group 0
      [ 0.389022] G2D: rcq version initialized.major:250
      [ 0.394589] input: sunxi-keyboard as /devices/virtual/input/input0
      [ 0.402597] clocksource: Switched to clocksource arch_sys_counter
      [ 0.418125] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [ 0.439238] thermal_sys: Registered thermal governor 'step_wise'
      [ 0.439246] thermal_sys: Registered thermal governor 'user_space'
      [ 0.445312] thermal_sys: Registered thermal governor 'power_allocator'
      [ 0.451984] NET: Registered protocol family 2
      [ 0.463667] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [ 0.472027] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [ 0.479738] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [ 0.487210] TCP: Hash tables configured (established 1024 bind 1024)
      [ 0.493771] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [ 0.500335] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [ 0.507534] NET: Registered protocol family 1
      [ 0.514693] Initialise system trusted keyrings
      [ 0.519392] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [ 0.536418] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [ 0.542522] ntfs: driver 2.1.32 [Flags: R/W].
      [ 0.547330] fuse: init (API version 7.31)
      [ 0.583054] NET: Registered protocol family 38
      [ 0.587527] Key type asymmetric registered
      [ 0.591619] Asymmetric key parser 'x509' registered
      [ 0.596692] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [ 0.604128] io scheduler mq-deadline registered
      [ 0.608664] io scheduler kyber registered
      [ 0.612774] atomic64_test: passed
      [ 0.617686] [DISP]disp_module_init
      [ 0.621733] disp 5000000.disp: Adding to iommu group 0
      [ 0.627565] [DISP] disp_init,line:2372:
      [ 0.627570] smooth display screen:0 type:1 mode:4
      [ 0.653102] display_fb_request,fb_id:0
      [ 0.664910] disp_al_manager_apply ouput_type:1
      [ 0.669511] [DISP] lcd_clk_config,line:777:
      [ 0.669522] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
      [ 0.669522] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
      [ 0.673446] [DISP]disp_module_init finish
      [ 0.674103] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [ 0.691323] sunxi_sid_init()783 - insmod ok
      [ 0.706366] pwm-regulator: supplied by regulator-dummy
      [ 0.713320] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [ 0.721479] uart uart3: uart3 supply uart not found, using dummy regulator
      [ 0.728781] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [ 0.736665] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
      ▒[ 0.744682] printk: console [ttyS3] enabled
      [ 0.753634] printk: bootconsole [earlycon0] disabled
      [ 0.765418] misc dump reg init
      [ 0.769451] deinterlace 5400000.deinterlace: Adding to iommu group 0
      [ 0.778408] Freeing logo buffer memory: 2400K
      [ 0.778470] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x0
      [ 0.792386] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [ 0.799728] [ADDR_MGT] addr_mgt_probe: success.
      [ 0.806327] libphy: Fixed MDIO Bus: probed
      [ 0.810970] CAN device driver interface
      [ 0.815974] usbcore: registered new interface driver asix
      [ 0.822120] usbcore: registered new interface driver ax88179_178a
      [ 0.829084] usbcore: registered new interface driver cdc_ether
      [ 0.835719] usbcore: registered new interface driver net1080
      [ 0.842131] usbcore: registered new interface driver cdc_subset
      [ 0.848891] usbcore: registered new interface driver zaurus
      [ 0.855257] usbcore: registered new interface driver cdc_ncm
      [ 0.861627] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [ 0.868969] sunxi-ehci: EHCI SUNXI driver
      [ 0.873962] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [ 0.880951] sunxi-ohci: OHCI SUNXI driver
      [ 0.886182] usbcore: registered new interface driver uas
      [ 0.892230] usbcore: registered new interface driver usb-storage
      [ 0.899104] usbcore: registered new interface driver ums-alauda
      [ 0.905841] usbcore: registered new interface driver ums-cypress
      [ 0.912689] usbcore: registered new interface driver ums-datafab
      [ 0.919485] usbcore: registered new interface driver ums_eneub6250
      [ 0.926546] usbcore: registered new interface driver ums-freecom
      [ 0.933386] usbcore: registered new interface driver ums-isd200
      [ 0.940088] usbcore: registered new interface driver ums-jumpshot
      [ 0.947027] usbcore: registered new interface driver ums-karma
      [ 0.953657] usbcore: registered new interface driver ums-onetouch
      [ 0.960586] usbcore: registered new interface driver ums-realtek
      [ 0.967410] usbcore: registered new interface driver ums-sddr09
      [ 0.974132] usbcore: registered new interface driver ums-sddr55
      [ 0.980857] usbcore: registered new interface driver ums-usbat
      [ 0.987596] usbcore: registered new interface driver option
      [ 0.993949] usbserial: USB Serial support registered for GSM modem (1-port)
      [ 1.002881] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
      [ 1.012422] sunxi_gpadc_init,2228, success
      [ 1.017711] sunxi_gpadc_setup: get channel scan data failed
      [ 1.024296] input: sunxi-gpadc0 as /devices/virtual/input/input2
      [ 1.032457] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [ 1.043291] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [ 1.054696] sunxi-rtc 7090000.rtc: registered as rtc0
      [ 1.060437] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [ 1.071132] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:33:25 UTC (2005)
      [ 1.080354] sunxi-rtc 7090000.rtc: Fail to read dts property 'gpr_bootcount_pos'
      [ 1.088704] reasonbase NULL
      [ 1.091844] reason large than max, fix to hot reboot, save boot reason
      [ 1.099191] invalid reason or reasonbase NULL
      [ 1.104109] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [ 1.110209] i2c /dev entries driver
      [ 1.114371] IR NEC protocol handler initialized
      [ 1.119471] IR RC5(x/sz) protocol handler initialized
      [ 1.125589] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      [ 1.134609] sunxi-rc-recv 7040000.s_cir: sunxi_irrx_resource_get: get ir protocol failed
      [ 1.143833] Registered IR keymap rc_map_sunxi
      [ 1.148892] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      [ 1.157629] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      [ 1.168177] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      [ 1.178417] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
      [ 1.188222] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
      [ 1.197921] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
      [ 1.209935] usbcore: registered new interface driver uvcvideo
      [ 1.216432] USB Video Class driver (1.1.1)
      [ 1.221032] gspca_main: v2.14.0 registered
      [ 1.225646] sunxi cedar version 1.1
      [ 1.229809] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [ 1.236120] VE: sunxi_cedar_probe power-domain init!!!
      [ 1.241894] VE: install start!!!
      [ 1.241894]
      [ 1.247522] VE: cedar-ve the get irq is 41
      [ 1.247522]
      [ 1.254039] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [ 1.254039]
      [ 1.263363] VE: install end!!!
      [ 1.263363]
      [ 1.268449] VE: sunxi_cedar_probe
      [ 1.273687] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [ 1.283010] Bluetooth: HCI UART driver ver 2.3
      [ 1.288016] Bluetooth: HCI UART protocol H4 registered
      [ 1.294149] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [ 1.303410] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [ 1.312370] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [ 1.322299] sunxi-mmc 4022000.sdmmc: ctl-spec-caps 308
      [ 1.328750] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
      [ 1.335122] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
      [ 1.341576] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
      [ 1.348051] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
      [ 1.354614] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
      [ 1.361171] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
      [ 1.367732] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
      [ 1.374313] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [ 1.383922] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.407770] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.432070] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
      [ 1.439270] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.452284] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [ 1.462272] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
      [ 1.463277] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.468568] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [ 1.481454] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.486466] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [ 1.486473] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [ 1.486480] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [ 1.517697] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [ 1.524325] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [ 1.530905] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [ 1.537927] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [ 1.543622] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.554817] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [ 1.562471] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.562570] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.586636] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.599554] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.610918] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
      [ 1.617290] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [ 1.623268] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [ 1.638386] sunxi-mmc 4021000.sdmmc: ctl-spec-caps 8
      [ 1.638481] random: fast init done
      [ 1.644659] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [ 1.654744] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [ 1.661212] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [ 1.667687] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [ 1.674275] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [ 1.680836] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [ 1.687411] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [ 1.687440] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [ 1.703537] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.714775] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [ 1.722429] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.732638] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.757617] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 1.758332] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [ 1.767419] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 1.767428] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 1.767436] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 1.774325] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [ 1.784140] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [ 1.793967] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [ 1.804034] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RE !!
      [ 1.816813] usbcore: registered new interface driver usbhid
      [ 1.827582] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RE !!
      [ 1.839173] usbhid: USB HID core driver
      [ 1.845839] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.852011] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52 dt B
      [ 1.852128] exFAT: Version 1.3.0
      [ 1.861917] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 1.863632] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox start probe
      [ 1.876563] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RE !!
      [ 1.886581] sunxi-msgbox 3003000.msgbox: sunxi_msgbox_probe(): sunxi msgbox probe success
      [ 1.890169] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RE !!
      [ 1.902077] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.2.1
      [ 1.910955] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RE !!
      [ 1.917593] remoteproc remoteproc0: dsp_rproc is available
      [ 1.926728] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RE !!
      [ 1.932982] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
      [ 1.939982] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [ 1.946782] rpmsg_tty_init: Sunxi rpmsg tty driver will init
      [ 1.984232] mmc0: new DDR MMC card at address 0001
      [ 1.984407] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
      [ 1.990971] mmcblk0: mmc0:0001 AT2S38 7.23 GiB
      [ 2.000010] NET: Registered protocol family 10
      [ 2.003053] mmcblk0rpmb: mmc0:0001 AT2S38 partition 3 4.00 MiB, chardev (242:0)
      [ 2.007782] Segment Routing with IPv6
      [ 2.018633] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [ 2.026246] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [ 2.027488] NET: Registered protocol family 17
      [ 2.036420] NET: Registered protocol family 15
      [ 2.041423] can: controller area network core (rev 20170425 abi 9)
      [ 2.048526] NET: Registered protocol family 29
      [ 2.053568] can: raw protocol (rev 20170425)
      [ 2.058367] can: broadcast manager protocol (rev 20170425 t)
      [ 2.064760] can: netlink gateway (rev 20190810) max_hops=1
      [ 2.071307] Bluetooth: RFCOMM TTY layer initialized
      [ 2.076947] Bluetooth: RFCOMM socket layer initialized
      [ 2.082776] Bluetooth: RFCOMM ver 1.11
      [ 2.087831] Registering SWP/SWPB emulation handler
      [ 2.093643] Loading compiled-in X.509 certificates
      第一次启动板子后面不知道怎么处理
