    VFS: Cannot open root device "mmcblk0p5" or unknown-block(179,5): error -5
    • X
      xiandaozhang LV 3 最后由 编辑
      采用全志T113-i芯片与江波龙emmc 运行一段时间后rootfs无法挂载了是什么情况
      [04.186]do_burn_from_boot usb : have no handshake
      List file under ULI/factory
      [04.197]no item name earlycon in the map
      [04.201]no item name clk_ignore_unused initcall_debugrootdelay in the map
      [04.207]no item name rootdelay in the map
      [04.211]no item name snum in the map
      [04.214]no item name mac in the map
      [04.217]no item name wifi_mac in the map
      [04.221]no item name bt_mac in the map
      [04.224]no item name ${linx_args} othbootargs in the map
      [04.229]no item name specialstr in the map
      [04.234]update part info
      [04.236]key 0
      [04.238]no misc partition is found
      [04.240]update bootcmd
      [04.243]fdt check ok
      [04.245]change working_fdt 0x7c863e60 to 0x7c843e60
      [04.250]replace_fdt success addr:0x43200000
      [04.254][mmc]: no mmc-hs400-1_8v!
      [04.257][mmc]: delete mmc-hs200-1_8v from dtb
      [04.261][mmc]: get max-frequency ok 50000000 Hz
      [04.266]shm_base=0x41900000
      [04.268]shm_size=0x200000
      [04.271]ta_ram_base=0x41c00000
      [04.273]ta_ram_size=0x400000
      04.276update dtb dram start
      [04.293]update dtb dram end
      [04.298]update dts
      Loading NVM information... : OK v0.1
      Autoboot in 3 seconds
      [59]HELLO! BOOT0 is starting!
      [62]BOOT0 commit : 09b36272
      [65]set pll start
      [67]fix vccio detect value:0xc0
      [74]periph0 has been enabled
      [77]set pll end
      [78][pmu]: bus read error
      [81]board init ok
      [83]enable_jtag
      [84]DRAM only have internal ZQ!!
      [87]get_pmu_exist() = -1
      [90]DRAM BOOT DRIVE INFO: V0.32
      [93]DRAM CLK = 792 MHz
      [95]DRAM Type = 3 (2:DDR2,3:DDR3)
      [98]DRAMC ZQ value: 0x7b7bfb
      [101]DRAM ODT value: 0x42.
      [104]ddr_efuse_type: 0x0
      [106]mark_id: 0x34
      [109]DRAM SIZE =1024 M
      [111]PLL_DDR_CTRL_REG:0xf8004100
      [114]DRAM_CLK_REG:0xc0000000
      [117][TIMING DEBUG] MR2= 0x18
      [125]DRAM simple test OK.
      [127]rtc standby flag is 0x0, super standby flag is 0x0
      [132]dram size =1024
      [135]card no is 2
      [137]sdcard 2 line count 4
      [139][mmc]: mmc driver ver 2021-05-21 14:47
      [149][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [154][mmc]: Try MMC card 2
      [179][mmc]: RMCA OK!
      [180][mmc]: mmc 2 bias 0
      [184][mmc]: MMC 5.1
      [186][mmc]: HSSDR52/SDR25 4 bit
      [189][mmc]: 50000000 Hz
      [191][mmc]: 7456 MB
      [193][mmc]: SD/MMC 2 init OK!!!
      [289]Loading boot-pkg Succeed(index=0).
      [293]Entry_name = u-boot
      [300]Entry_name = optee
      [304]Entry_name = dtb
      [307]tunning data addr:0x430003e8
      [310]Jump to second Boot.
      M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
      U-Boot 2018.05 (Sep 20 2024 - 09:06:07 +0000) Allwinner Technology
      [00.361]CPU: Allwinner Family
      [00.364]Model: sun8iw20
      I2C: FDT ERROR:fdt_get_all_pin:get property handle pinctrl-0 error:FDT_ERR_INTERNAL
      ready
      [00.390]optee version: major:3 minor:7
      [00.393]DRAM: 1 GiB
      [00.396]Relocation Offset is: 3cea4000
      [00.425]secure enable bit: 0
      E/TC:0 fdt_getprop_u32:343 prop trace_level not found
      [00.439]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [00.445]gic: sec monitor mode
      [00.448]flash init start
      [00.450]workmode = 0,storage type = 2
      [00.454][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
      [00.460][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.484][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.491]sunxi flash init ok
      [00.493]non secure, do not need update backup boot0 to toc0
      [00.498]line:703 init_clocks
      [00.501]init_clocks:finish
      [00.504]drv_disp_init
      [00.511]get flash lcd idx 0
      [00.513]not find -476028928 lcd_compatible param for disp0
      [00.518]not find -476028928 lcd_compatible param for disp0
      [00.524]not find -476028928 lcd_compatible param for disp0
      [00.529]not find -476028928 lcd_compatible param for disp0
      [00.534]not find -476028928 lcd_compatible param for disp0
      [00.539]not find -476028928 lcd_compatible param for disp0
      [00.545]not find -476028928 lcd_compatible param for disp0
      [00.550]not find -476028928 lcd_compatible param for disp0
      [00.555]not find -476028928 lcd_compatible param for disp0
      [00.561]HDMI 2.0 driver init start!
      [00.565]drv_disp_init finish
      [00.567]boot_gui_init:start
      [00.570]set disp.dev2_output_type fail. using defval=0
      [00.575]not find -476028928 lcd_compatible param for disp0
      [00.580]not find -476028928 lcd_compatible param for disp0
      [00.585]not find -476028928 lcd_compatible param for disp0
      [00.591]not find -476028928 lcd_compatible param for disp0
      [00.596]not find -476028928 lcd_compatible param for disp0
      [00.601]not find -476028928 lcd_compatible param for disp0
      [00.607]not find -476028928 lcd_compatible param for disp0
      [00.612]not find -476028928 lcd_compatible param for disp0
      [00.617]not find -476028928 lcd_compatible param for disp0
      [00.623]not find -476028928 lcd_compatible param for disp0
      [00.628]not find -476028928 lcd_compatible param for disp0
      [00.633]not find -476028928 lcd_compatible param for disp0
      drv_lcd_open_callback lcd open flow is NULL! LCD enable fail!
      [00.644]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
      [00.651]boot_gui_init:finish
      54 bytes read in 0 ms
      [00.664]bmp_name=bootlogo.bmp size 4096054
      4096054 bytes read in 88 ms (44.4 MiB/s)
      no support big size bmp[800x1280] on fb[1024x600]
      [00.765]show bmp on fb failed !-1
      [00.772]Loading Environment from SUNXI_FLASH... OK
      [00.785]read item0 copy0
      [00.788]Item0 (Map) magic is bad
      [00.790]the secure storage item0 copy0 magic is bad
      [00.795]Item0 (Map) magic is bad
      [00.798]the secure storage item0 copy1 magic is bad
      [00.803]Item0 (Map) magic is bad
      [00.806]the secure storage map is empty
      [00.809]load key widevine with default cb
      [00.813]no item name widevine in the map
      [00.820]secure storage read widevine fail with:-1
      [00.824]load key ec_key with default cb
      [00.828]no item name ec_key in the map
      [00.834]secure storage read ec_key fail with:-1
      [00.838]load key ec_cert1 with default cb
      [00.842]no item name ec_cert1 in the map
      [00.849]secure storage read ec_cert1 fail with:-1
      [00.853]load key ec_cert2 with default cb
      [00.857]no item name ec_cert2 in the map
      [00.863]secure storage read ec_cert2 fail with:-1
      [00.868]load key ec_cert3 with default cb
      [00.871]no item name ec_cert3 in the map
      [00.878]secure storage read ec_cert3 fail with:-1
      [00.883]load key rsa_key with default cb
      [00.886]no item name rsa_key in the map
      [00.893]secure storage read rsa_key fail with:-1
      [00.897]load key rsa_cert1 with default cb
      [00.901]no item name rsa_cert1 in the map
      [00.908]secure storage read rsa_cert1 fail with:-1
      [00.912]load key rsa_cert2 with default cb
      [00.916]no item name rsa_cert2 in the map
      [00.923]secure storage read rsa_cert2 fail with:-1
      [00.927]load key rsa_cert3 with default cb
      [00.931]no item name rsa_cert3 in the map
      [00.938]secure storage read rsa_cert3 fail with:-1
      [00.943]try to burn key
      [00.945]no item name key_burned_flag in the map
      [00.949]sunxi secure storage has no flag
      [00.953]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.964]usb prepare ok
      [01.170]usb sof ok
      [01.172]usb probe ok
      [01.174]usb setup ok
      set address 0x26
      set address 0x26 ok
      try to update
      [04.179]do_burn_from_boot usb : have no handshake
      [04.190]no item name earlycon in the map
      [04.194]no item name clk_ignore_unused initcall_debugrootdelay in the map
      [04.200]no item name rootdelay in the map
      [04.204]no item name snum in the map
      [04.207]no item name mac in the map
      [04.210]no item name wifi_mac in the map
      [04.214]no item name bt_mac in the map
      [04.217]no item name ${linx_args} othbootargs in the map
      [04.222]no item name specialstr in the map
      [04.227]update part info
      [04.229]key 0
      [04.231]no misc partition is found
      [04.233]update bootcmd
      [04.236]fdt check ok
      [04.238]change working_fdt 0x7c863e60 to 0x7c843e60
      [04.243]replace_fdt success addr:0x43200000
      [04.247][mmc]: no mmc-hs400-1_8v!
      [04.250][mmc]: delete mmc-hs200-1_8v from dtb
      [04.254][mmc]: get max-frequency ok 50000000 Hz
      [04.259]shm_base=0x41900000
      [04.261]shm_size=0x200000
      [04.264]ta_ram_base=0x41c00000
      [04.266]ta_ram_size=0x400000
      04.269update dtb dram start
      [04.286]update dtb dram end
      [04.291]update dts
      => po
      [2~ Unknown command 'po[' - try 'help'
      => printenv
      boot_dsp0=sunxi_flash read 43000000 ${dsp0_partition};bootr 43000000 0 0
      boot_fastboot=fastboot
      boot_normal=sunxi_flash read 43000000 boot;bootm 43000000
      boot_recovery=sunxi_flash read 43000000 recovery;bootm 43000000
      bootcmd=run joyseq; run setargs_mmc boot_normal
      bootdelay=3
      bootstopkeysha256=ad731e21173da9d07bea80bdc036ad6e5486db0319ce1575bf33a2a89533a1bd
      cma=16M
      console=ttyAS0,115200
      dsp0_partition=dsp0
      earlycon=uart8250,mmio32,0x02500000
      fdtcontroladdr=7c863e60
      force_normal_boot=1
      init=/sbin/init
      initcall_debug=0
      joyseq=usb start; usb reset; fatload usb 0 0x42000000 joyrecovery.scr; source 0x42000000;
      keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
      linx_args=linx_serial=xxx
      loglevel=8
      mac_addr=E2:D5:91:00:00:5F
      mmc_root=/dev/mmcblk0p5 rw
      mtd_name=sys
      nand_root=ubi0_5
      othbootargs=1
      partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8
      rootfstype=ubifs,rw
      setargs_mmc=setenv bootargs earlycon=${earlycon} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} rootdelay=5 root=${mmc_root} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac_addr} wifi_mac=${wifi_mac} bt_mac=${bt_mac} ${linx_args} othbootargs=${othbootargs} specialstr=${specialstr} gpt=1
      setargs_nand=setenv bootargs ubi.mtd=${mtd_name} earlycon=${earlycon} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} earlycon=${earlycon} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_ram=setenv bootargs console=${console} root=/dev/ram rootwait rw init=/sbin/init rootfstype=ext2
      Environment size: 2248/131067 bytes
      => reset
      resetting ...
      [11.945][mmc]: mmc exit start
      [29]HELLO! BOOT0 is starting!
      [32]BOOT0 commit : 09b36272
      [35]set pll start
      [41]periph0 has been enabled
      [44]set pll end
      [45][pmu]: bus read error
      [48]board init ok
      [49]enable_jtag
      [51]DRAM only have internal ZQ!!
      [54]get_pmu_exist() = -1
      [56]DRAM BOOT DRIVE INFO: V0.32
      [59]DRAM CLK = 792 MHz
      [62]DRAM Type = 3 (2:DDR2,3:DDR3)
      [65]DRAMC ZQ value: 0x7b7bfb
      [68]DRAM ODT value: 0x42.
      [70]ddr_efuse_type: 0x0
      [73]mark_id: 0x34
      [75]DRAM SIZE =1024 M
      [77]PLL_DDR_CTRL_REG:0xf8004100
      [80]DRAM_CLK_REG:0xc0000000
      [83][TIMING DEBUG] MR2= 0x18
      [91]DRAM simple test OK.
      [93]rtc standby flag is 0x0, super standby flag is 0x0
      [98]dram size =1024
      [101]card no is 2
      [103]sdcard 2 line count 4
      [105][mmc]: mmc driver ver 2021-05-21 14:47
      [114][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [120][mmc]: Try MMC card 2
      [144][mmc]: RMCA OK!
      [146][mmc]: mmc 2 bias 0
      [150][mmc]: MMC 5.1
      [152][mmc]: HSSDR52/SDR25 4 bit
      [155][mmc]: 50000000 Hz
      [157][mmc]: 7456 MB
      [159][mmc]: SD/MMC 2 init OK!!!
      [255]Loading boot-pkg Succeed(index=0).
      [258]Entry_name = u-boot
      [266]Entry_name = optee
      [270]Entry_name = dtb
      [273]tunning data addr:0x430003e8
      [276]Jump to second Boot.
      [00.327]CPU: Allwinner Family
      [00.330]Model: sun8iw20
      ready
      [00.356]optee version: major:3 minor:7
      [00.359]DRAM: 1 GiB
      [00.362]Relocation Offset is: 3cea4000
      [00.391]secure enable bit: 0
      [00.405]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [00.411]gic: sec monitor mode
      [00.414]flash init start
      [00.416]workmode = 0,storage type = 2
      [00.419][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
      [00.426][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.450][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.456]sunxi flash init ok
      [00.459]non secure, do not need update backup boot0 to toc0
      [00.464]line:703 init_clocks
      [00.467]init_clocks:finish
      [00.469]drv_disp_init
      [00.476]get flash lcd idx 0
      [00.479]not find -476028928 lcd_compatible param for disp0
      [00.484]not find -476028928 lcd_compatible param for disp0
      [00.489]not find -476028928 lcd_compatible param for disp0
      [00.495]not find -476028928 lcd_compatible param for disp0
      [00.500]not find -476028928 lcd_compatible param for disp0
      [00.505]not find -476028928 lcd_compatible param for disp0
      [00.510]not find -476028928 lcd_compatible param for disp0
      [00.516]not find -476028928 lcd_compatible param for disp0
      [00.521]not find -476028928 lcd_compatible param for disp0
      [00.526]HDMI 2.0 driver init start!
      [00.531]drv_disp_init finish
      [00.533]boot_gui_init:start
      [00.536]set disp.dev2_output_type fail. using defval=0
      [00.541]not find -476028928 lcd_compatible param for disp0
      [00.546]not find -476028928 lcd_compatible param for disp0
      [00.551]not find -476028928 lcd_compatible param for disp0
      [00.557]not find -476028928 lcd_compatible param for disp0
      [00.562]not find -476028928 lcd_compatible param for disp0
      [00.567]not find -476028928 lcd_compatible param for disp0
      [00.572]not find -476028928 lcd_compatible param for disp0
      [00.578]not find -476028928 lcd_compatible param for disp0
      [00.583]not find -476028928 lcd_compatible param for disp0
      [00.588]not find -476028928 lcd_compatible param for disp0
      [00.594]not find -476028928 lcd_compatible param for disp0
      [00.599]not find -476028928 lcd_compatible param for disp0
      [00.610]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
      [00.617]boot_gui_init:finish
      [00.630]bmp_name=bootlogo.bmp size 4096054
      4096054 bytes read in 89 ms (43.9 MiB/s)
      [00.730]show bmp on fb failed !-1
      [00.738]Loading Environment from SUNXI_FLASH... OK
      [00.751]read item0 copy0
      [00.753]Item0 (Map) magic is bad
      [00.756]the secure storage item0 copy0 magic is bad
      [00.761]Item0 (Map) magic is bad
      [00.764]the secure storage item0 copy1 magic is bad
      [00.768]Item0 (Map) magic is bad
      [00.771]the secure storage map is empty
      [00.775]load key widevine with default cb
      [00.779]no item name widevine in the map
      [00.785]secure storage read widevine fail with:-1
      [00.790]load key ec_key with default cb
      [00.793]no item name ec_key in the map
      [00.800]secure storage read ec_key fail with:-1
      [00.804]load key ec_cert1 with default cb
      [00.808]no item name ec_cert1 in the map
      [00.814]secure storage read ec_cert1 fail with:-1
      [00.819]load key ec_cert2 with default cb
      [00.822]no item name ec_cert2 in the map
      [00.829]secure storage read ec_cert2 fail with:-1
      [00.834]load key ec_cert3 with default cb
      [00.837]no item name ec_cert3 in the map
      [00.844]secure storage read ec_cert3 fail with:-1
      [00.848]load key rsa_key with default cb
      [00.852]no item name rsa_key in the map
      [00.858]secure storage read rsa_key fail with:-1
      [00.863]load key rsa_cert1 with default cb
      [00.867]no item name rsa_cert1 in the map
      [00.873]secure storage read rsa_cert1 fail with:-1
      [00.878]load key rsa_cert2 with default cb
      [00.882]no item name rsa_cert2 in the map
      [00.889]secure storage read rsa_cert2 fail with:-1
      [00.893]load key rsa_cert3 with default cb
      [00.897]no item name rsa_cert3 in the map
      [00.904]secure storage read rsa_cert3 fail with:-1
      [00.908]try to burn key
      [00.911]no item name key_burned_flag in the map
      [00.915]sunxi secure storage has no flag
      [00.918]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.930]usb prepare ok
      [01.136]usb sof ok
      [01.137]usb probe ok
      [01.139]usb setup ok
      set address 0x27
      set address 0x27 ok
      try to update
      [04.144]do_burn_from_boot usb : have no handshake
      [04.155]no item name earlycon in the map
      [04.159]no item name clk_ignore_unused initcall_debugrootdelay in the map
      [04.165]no item name rootdelay in the map
      [04.169]no item name snum in the map
      [04.172]no item name mac in the map
      [04.175]no item name wifi_mac in the map
      [04.179]no item name bt_mac in the map
      [04.182]no item name ${linx_args} othbootargs in the map
      [04.187]no item name specialstr in the map
      [04.192]update part info
      [04.194]key 0
      [04.196]no misc partition is found
      [04.198]update bootcmd
      [04.201]fdt check ok
      [04.203]change working_fdt 0x7c863e60 to 0x7c843e60
      [04.208]replace_fdt success addr:0x43200000
      [04.212][mmc]: no mmc-hs400-1_8v!
      [04.215][mmc]: delete mmc-hs200-1_8v from dtb
      [04.219][mmc]: get max-frequency ok 50000000 Hz
      [04.224]shm_base=0x41900000
      [04.226]shm_size=0x200000
      [04.229]ta_ram_base=0x41c00000
      [04.231]ta_ram_size=0x400000
      04.234update dtb dram start
      [04.251]update dtb dram end
      [04.256]update dts
      key timeout
      starting USB...
      USB0: start sunxi USB-DRD...
      config usb clk ok
      sunxi USB-DRD init ok...
      USB EHCI 1.00
      scanning bus 0 for devices... 1 USB Device(s) found
      USB1: start sunxi USB1-Host...
      config usb clk ok
      sunxi USB1-Host init ok...
      USB EHCI 1.00
      scanning bus 1 for devices... 2 USB Device(s) found
      scanning usb for storage devices... 0 Storage Device(s) found
      resetting USB...
      stop sunxi USB-DRD ok...
      stop sunxi USB1-Host ok...
      config usb clk ok
      USB EHCI 1.00
      config usb clk ok
      USB EHCI 1.00
      ** Bad device usb 0 **
      Executing script at 42000000
      Wrong image format for "source" command
      [15.139]partinfo: name boot, start 0x1b686, size 0x20000
      [15.895]no vendor_boot partition is found
      [15.899]android.hardware = sun8iw20p1
      [15.933]Starting kernel ...
      [15.935][mmc]: mmc exit start
      [15.953][mmc]: mmc 2 exit ok
      [ 0.000000] Memory policy: Data cache writealloc
      [ 0.000000] cma: Reserved 16 MiB at 0x7f000000
      [ 0.000000] On node 0 totalpages: 262144
      [ 0.000000] Normal zone: 1728 pages used for memmap
      [ 0.000000] Normal zone: 0 pages reserved
      [ 0.000000] Normal zone: 196608 pages, LIFO batch:63
      [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15
      [ 0.000000] psci: probing for conduit method from DT.
      [ 0.000000] psci: PSCIv1.0 detected in firmware.
      [ 0.000000] psci: Using standard PSCI v0.2 function IDs
      [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
      [ 0.000000] psci: SMC Calling Convention v1.0
      [ 0.000000] percpu: Embedded 15 pages/cpu s32576 r8192 d20672 u61440
      [ 0.000000] pcpu-alloc: s32576 r8192 d20672 u61440 alloc=15*4096
      [ 0.000000] pcpu-alloc: [0] 0 [0] 1
      [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416
      [ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 rootdelay=5 root=/dev/mmcblk0p5 rw init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=16M snum= mac_addr=E2:D5:91:00:00:5F wifi_mac= bt_mac= linx_serial=xxx othbootargs=1 specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05(09/20/2024-09:06:07) disp_reserve=2457600,0x7c8cd000 androidboot.dramsize=1024
      [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [ 0.000000] Memory: 991696K/1048576K available (13312K kernel code, 617K rwdata, 4572K rodata, 1024K init, 424K bss, 40496K reserved, 16384K cma-reserved, 243360K highmem)
      [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
      [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
      [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
      [ 0.000000] Tasks RCU enabled.
      [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
      [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [ 0.000000] random: get_random_bytes called from start_kernel+0x25c/0x3e4 with crng_init=0
      [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
      [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [ 0.008399] Switching to timer-based delay loop, resolution 41ns
      [ 0.014849] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [ 0.025078] Console: colour dummy device 80x30
      [ 0.029768] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [ 0.040627] pid_max: default: 32768 minimum: 301
      [ 0.045654] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [ 0.053366] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [ 0.062425] CPU: Testing write buffer coherency: ok
      [ 0.067977] /cpus/cpu@0 missing clock-frequency property
      [ 0.073557] /cpus/cpu@1 missing clock-frequency property
      [ 0.079159] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [ 0.085765] Setting up static identity map for 0x40100000 - 0x40100060
      [ 0.092767] rcu: Hierarchical SRCU implementation.
      [ 0.098123] BOOTEVENT: 98.113416: ON
      [ 0.102782] smp: Bringing up secondary CPUs ...
      [ 0.108823] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [ 0.108983] smp: Brought up 1 node, 2 CPUs
      [ 0.119284] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [ 0.125766] CPU: All CPU(s) started in SVC mode.
      [ 0.131320] devtmpfs: initialized
      [ 0.149030] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [ 0.157567] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [ 0.167926] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [ 0.175933] xor: measuring software checksum speed
      [ 0.275967] arm4regs : 1264.000 MB/sec
      [ 0.376046] 8regs : 751.600 MB/sec
      [ 0.476121] 32regs : 769.600 MB/sec
      [ 0.480498] xor: using function: arm4regs (1264.000 MB/sec)
      [ 0.486377] pinctrl core: initialized pinctrl subsystem
      [ 0.493761] NET: Registered protocol family 16
      [ 0.500863] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [ 0.553781] rtc_ccu: sunxi ccu init OK
      [ 0.560857] ccu: sunxi ccu init OK
      [ 0.565036] r_ccu: sunxi ccu init OK
      [ 0.769428] raid6: int32x8 gen() 126 MB/s
      [ 0.939341] raid6: int32x8 xor() 79 MB/s
      [ 1.109822] raid6: int32x4 gen() 137 MB/s
      [ 1.279821] raid6: int32x4 xor() 94 MB/s
      [ 1.450032] raid6: int32x2 gen() 158 MB/s
      [ 1.620044] raid6: int32x2 xor() 129 MB/s
      [ 1.790059] raid6: int32x1 gen() 178 MB/s
      [ 1.960096] raid6: int32x1 xor() 140 MB/s
      [ 1.964569] raid6: using algorithm int32x1 gen() 178 MB/s
      [ 1.970221] raid6: .... xor() 140 MB/s, rmw enabled
      [ 1.975317] raid6: using intx1 recovery algorithm
      [ 2.006359] Deinterlace Module initialized.
      [ 2.011179] iommu: Default domain type: Translated
      [ 2.016523] sunxi iommu: irq = 24
      [ 2.021530] SCSI subsystem initialized
      [ 2.025848] usbcore: registered new interface driver usbfs
      [ 2.032393] usbcore: registered new interface driver hub
      [ 2.038095] usbcore: registered new device driver usb
      [ 2.043736] mc: Linux media interface: v0.10
      [ 2.048287] videodev: Linux video capture interface: v2.00
      [ 2.055222] Advanced Linux Sound Architecture Driver Initialized.
      [ 2.062382] Bluetooth: Core ver 2.22
      [ 2.066294] NET: Registered protocol family 31
      [ 2.070945] Bluetooth: HCI device and connection manager initialized
      [ 2.077659] Bluetooth: HCI socket layer initialized
      [ 2.082779] Bluetooth: L2CAP socket layer initialized
      [ 2.088133] Bluetooth: SCO socket layer initialized
      [ 2.093278] NET: Registered protocol family 8
      [ 2.097845] NET: Registered protocol family 20
      [ 2.103038] pwm module init!
      [ 2.107708] g2d 5410000.g2d: Adding to iommu group 0
      [ 2.113416] G2D: rcq version initialized.major:250
      [ 2.119168] input: sunxi-keyboard as /devices/virtual/input/input0
      [ 2.126793] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      [ 2.136361] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
      [ 2.145471] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
      [ 2.154521] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
      [ 2.165077] clocksource: Switched to clocksource arch_sys_counter
      [ 2.171801] VFS: Disk quotas dquot_6.6.0
      [ 2.176060] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [ 2.183547] FS-Cache: Loaded
      [ 2.186878] CacheFiles: Loaded
      [ 2.199194] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [ 2.221604] thermal_sys: Registered thermal governor 'step_wise'
      [ 2.221613] thermal_sys: Registered thermal governor 'user_space'
      [ 2.228622] NET: Registered protocol family 2
      [ 2.240492] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [ 2.249603] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [ 2.257992] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [ 2.265590] TCP: Hash tables configured (established 8192 bind 8192)
      [ 2.272389] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [ 2.279372] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [ 2.287096] NET: Registered protocol family 1
      [ 2.292323] RPC: Registered named UNIX socket transport module.
      [ 2.298579] RPC: Registered udp transport module.
      [ 2.303511] RPC: Registered tcp transport module.
      [ 2.308458] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [ 2.316360] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      [ 2.324984] spi spi1: spi1 supply spi not found, using dummy regulator
      [ 2.332109] sunxi_spi_resource_get()2151 - [spi1] SPI MASTER MODE
      [ 2.338560] sunxi_spi_resource_get()2189 - Failed to get sample mode
      [ 2.345265] sunxi_spi_resource_get()2194 - Failed to get sample delay
      [ 2.352010] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      [ 2.360844] sunxi_spi_clk_init()2240 - [spi1] mclk 100000000
      [ 2.367719] sunxi_spi_probe()2653 - [spi1]: driver probe succeed, base f0864000, irq 45
      [ 2.378688] Initialise system trusted keyrings
      [ 2.383533] workingset: timestamp_bits=14 max_order=18 bucket_order=4
      [ 2.406587] NFS: Registering the id_resolver key type
      [ 2.411934] Key type id_resolver registered
      [ 2.416445] Key type id_legacy registered
      [ 2.420658] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [ 2.427729] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [ 2.435480] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
      [ 2.443356] ntfs: driver 2.1.32 [Flags: R/W].
      [ 2.448360] fuse: init (API version 7.31)
      [ 2.453658] JFS: nTxBlock = 7875, nTxLock = 63005
      [ 2.467407] SGI XFS with ACLs, security attributes, no debug enabled
      [ 2.477190] ceph: loaded (mds proto 32)
      [ 2.510175] NET: Registered protocol family 38
      [ 2.514853] Key type asymmetric registered
      [ 2.519222] Asymmetric key parser 'x509' registered
      [ 2.524394] bounce: pool size: 64 pages
      [ 2.528510] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [ 2.536503] io scheduler mq-deadline registered
      [ 2.541249] io scheduler kyber registered
      [ 2.545613] atomic64_test: passed
      [ 2.550935] [DISP]disp_module_init
      [ 2.555214] disp 5000000.disp: Adding to iommu group 0
      [ 2.561219] [DISP] disp_init,line:2386:
      [ 2.561225] smooth display screen:0 type:1 mode:4
      [ 2.570541] [DISP] disp_init_hdmi,line:1047:
      [ 2.570546] dont support hdmi
      [ 2.578514] display_fb_request,fb_id:0
      [ 2.591073] disp_al_manager_apply ouput_type:1
      [ 2.595120] wait for new fb take effect
      [ 2.595905] [DISP] lcd_clk_config,line:735:
      [ 2.595915] disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
      [ 2.595915] clk real:pll(297000000),clk(297000000),dclk(49500000) dsi_rate(0)
      [ 2.655934] Freeing logo buffer memory: 2400K
      [ 2.660955] [DISP]disp_module_init finish
      [ 2.666621] sunxi_sid_init()563 - insmod ok
      [ 2.671469] pwm-regulator: supplied by regulator-dummy
      [ 2.678247] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
      [ 2.686970] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [ 2.695486] uart uart0: get regulator failed
      [ 2.699987] uart uart0: uart0 supply uart not found, using dummy regulator
      [ 2.707569] uart0: ttyAS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
      [ 2.715888] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
      [ 2.724240] printk: console [ttyAS0] enabled
      [ 2.733518] printk: bootconsole [uart8250] disabled
      [ 2.744993] uart uart1: get regulator failed
      [ 2.749851] uart uart1: uart1 supply uart not found, using dummy regulator
      [ 2.757977] uart1: ttyAS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
      [ 2.767734] uart uart3: get regulator failed
      [ 2.772548] uart uart3: uart3 supply uart not found, using dummy regulator
      [ 2.780646] uart3: ttyAS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
      [ 2.790380] uart uart4: get regulator failed
      [ 2.795235] uart uart4: uart4 supply uart not found, using dummy regulator
      [ 2.803299] uart4: ttyAS4 at MMIO 0x2501000 (irq = 37, base_baud = 1500000) is a SUNXI
      [ 2.813063] uart uart5: get regulator failed
      [ 2.817922] uart uart5: uart5 supply uart not found, using dummy regulator
      [ 2.825994] uart5: ttyAS5 at MMIO 0x2501400 (irq = 38, base_baud = 1500000) is a SUNXI
      [ 2.836170] misc dump reg init
      [ 2.841628] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
      [ 2.848951] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
      [ 2.856802] [ADDR_MGT] addr_mgt_probe: success.
      [ 2.863462] libphy: Fixed MDIO Bus: probed
      [ 2.868683] tun: Universal TUN/TAP device driver, 1.6
      [ 2.874703] ipddp.c:v0.01 8/28/97 Bradford W. Johnson johns393@maroon.tc.umn.edu
      [ 2.883875] ipddp0: Appletalk-IP Encap. mode by Bradford W. Johnson johns393@maroon.tc.umn.edu
      [ 2.893795] vcan: Virtual CAN interface driver
      [ 2.898797] vxcan: Virtual CAN Tunnel driver
      [ 2.903585] slcan: serial line CAN interface driver
      [ 2.909065] slcan: 10 dynamic interface channels.
      [ 2.914342] CAN device driver interface
      [ 2.918857] cc770: CAN netdevice driver
      [ 2.923995] sja1000 CAN netdevice driver
      [ 2.928934] sunxi-can can@0x0 (unnamed net_device) (uninitialized): request pinctrl handle fail!
      [ 2.939517] sunxi-can can@0x0: can driver probe ok ...
      [ 2.945647] sunxi-can can@0x1 (unnamed net_device) (uninitialized): request pinctrl handle fail!
      [ 2.956199] sunxi-can can@0x1: can driver probe ok ...
      [ 2.962817] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [ 2.971808] sunxi gmac driver's version: 1.0.0
      [ 2.977004] gmac-power0: NULL
      [ 2.980334] gmac-power1: NULL
      [ 2.983658] gmac-power2: NULL
      [ 2.987719] eth0: Use random mac address
      [ 2.992625] usbcore: registered new interface driver asix
      [ 2.998823] usbcore: registered new interface driver ax88179_178a
      [ 3.005774] usbcore: registered new interface driver cdc_ether
      [ 3.012382] usbcore: registered new interface driver net1080
      [ 3.018865] usbcore: registered new interface driver cdc_subset
      [ 3.025606] usbcore: registered new interface driver zaurus
      [ 3.031962] usbcore: registered new interface driver cdc_ncm
      [ 3.038417] usbcore: registered new interface driver huawei_cdc_ncm
      [ 3.045469] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [ 3.052792] sunxi-ehci: EHCI SUNXI driver
      [ 3.057843] get ehci0-controller wakeup-source is fail.
      [ 3.063823] sunxi ehci0-controller don't init wakeup source
      [ 3.070109] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc14e9470, 0x:f0d63000, irq_no:3e
      [ 3.082425] sunxi-ehci 4101000.ehci0-controller: 4101000.ehci0-controller supply hci not found, using dummy regulator
      [ 3.094813] sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
      [ 3.102139] sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 1
      [ 3.112218] sunxi-ehci 4101000.ehci0-controller: irq 62, io mem 0x04101000
      [ 3.145108] sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
      [ 3.154001] hub 1-0:1.0: USB hub found
      [ 3.158302] hub 1-0:1.0: 1 port detected
      [ 3.163619] get ehci1-controller wakeup-source is fail.
      [ 3.169632] sunxi ehci1-controller don't init wakeup source
      [ 3.175910] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc14e9990, 0x:f0d6f000, irq_no:40
      [ 3.188212] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [ 3.200621] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [ 3.207910] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 2
      [ 3.217835] sunxi-ehci 4200000.ehci1-controller: irq 64, io mem 0x04200000
      [ 3.255107] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [ 3.262930] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [ 3.272134] hub 2-0:1.0: USB hub found
      [ 3.277025] hub 2-0:1.0: 1 port detected
      [ 3.282246] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [ 3.289235] sunxi-ohci: OHCI SUNXI driver
      [ 3.294275] get ohci0-controller wakeup-source is fail.
      [ 3.300293] sunxi ohci0-controller don't init wakeup source
      [ 3.306568] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc14e9700
      [ 3.316549] sunxi-ohci 4101400.ohci0-controller: 4101400.ohci0-controller supply hci not found, using dummy regulator
      [ 3.328912] sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
      [ 3.336198] sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 3
      [ 3.346138] sunxi-ohci 4101400.ohci0-controller: irq 63, io mem 0x04101400
      [ 3.420080] hub 3-0:1.0: USB hub found
      [ 3.424340] hub 3-0:1.0: 1 port detected
      [ 3.429691] get ohci1-controller wakeup-source is fail.
      [ 3.435729] sunxi ohci1-controller don't init wakeup source
      [ 3.441986] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc14e9c20
      [ 3.451938] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [ 3.464337] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [ 3.471623] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 4
      [ 3.481402] debugfs: Directory 'sunxi-ohci' with parent 'ohci' already present!
      [ 3.489704] sunxi-ohci 4200400.ohci1-controller: irq 65, io mem 0x04200400
      [ 3.570073] hub 4-0:1.0: USB hub found
      [ 3.574333] hub 4-0:1.0: 1 port detected
      [ 3.579854] usbcore: registered new interface driver cdc_acm
      [ 3.586225] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [ 3.595326] usbcore: registered new interface driver cdc_wdm
      [ 3.601964] usbcore: registered new interface driver uas
      [ 3.608129] usbcore: registered new interface driver usb-storage
      [ 3.614947] usbcore: registered new interface driver ums-alauda
      [ 3.621702] usbcore: registered new interface driver ums-cypress
      [ 3.628540] usbcore: registered new interface driver ums-datafab
      [ 3.635383] usbcore: registered new interface driver ums_eneub6250
      [ 3.642392] usbcore: registered new interface driver ums-freecom
      [ 3.649176] usb 2-1: new high-speed USB device number 2 using sunxi-ehci
      [ 3.655290] usbcore: registered new interface driver ums-isd200
      [ 3.663478] usbcore: registered new interface driver ums-jumpshot
      [ 3.670553] usbcore: registered new interface driver ums-karma
      [ 3.677216] usbcore: registered new interface driver ums-onetouch
      [ 3.684156] usbcore: registered new interface driver ums-realtek
      [ 3.691020] usbcore: registered new interface driver ums-sddr09
      [ 3.697787] usbcore: registered new interface driver ums-sddr55
      [ 3.704500] usbcore: registered new interface driver ums-usbat
      [ 3.711261] usbcore: registered new interface driver usbserial_generic
      [ 3.718668] usbserial: USB Serial support registered for generic
      [ 3.725522] usbcore: registered new interface driver option
      [ 3.731820] usbserial: USB Serial support registered for GSM modem (1-port)
      [ 3.741034] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
      [ 3.750672] sunxi_gpadc_init,2137, success
      [ 3.755679] sunxi_gpadc_setup: get channel scan data failed
      [ 3.762235] input: sunxi-gpadc0 as /devices/virtual/input/input2
      [ 3.770126] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [ 3.782379] sunxi-rtc 7090000.rtc: registered as rtc0
      [ 3.788223] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [ 3.794347] i2c /dev entries driver
      [ 3.798618] IR NEC protocol handler initialized
      [ 3.803717] IR RC5(x/sz) protocol handler initialized
      [ 3.809887] sunxi_ir_startup: get ir protocol failed
      [ 3.809913] (NULL device *): deviceless supply not found, using dummy regulator
      [ 3.824003] Registered IR keymap rc_map_sunxi
      [ 3.829121] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      [ 3.837869] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      [ 3.850223] usbcore: registered new interface driver uvcvideo
      [ 3.856747] USB Video Class driver (1.1.1)
      [ 3.861349] gspca_main: v2.14.0 registered
      [ 3.865982] sunxi cedar version 1.1
      [ 3.870169] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [ 3.876536] VE: sunxi_cedar_probe power-domain init!!!
      [ 3.882340] VE: install start!!!
      [ 3.882340]
      [ 3.888068] VE: cedar-ve the get irq is 46
      [ 3.888068]
      [ 3.894652] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [ 3.894652]
      [ 3.904036] VE: install end!!!
      [ 3.904036]
      [ 3.909192] VE: sunxi_cedar_probe
      [ 3.914874] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [ 3.924473] cdc_ether 2-1:2.0 eth1: register 'cdc_ether' at usb-sunxi-ehci-1, CDC Ethernet Device, 00:e0:99:e9:e5:44
      [ 3.925413] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
      [ 3.946049] Bluetooth: HCI UART driver ver 2.3
      [ 3.951052] Bluetooth: HCI UART protocol H4 registered
      [ 3.958987] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [ 3.967981] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [ 3.977991] sunxi-mmc 4022000.sdmmc: ctl-spec-caps 308
      [ 3.984411] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
      [ 3.990791] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
      [ 3.997270] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
      [ 4.003722] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
      [ 4.010289] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
      [ 4.016855] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
      [ 4.023404] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
      [ 4.029993] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [ 4.039565] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.063396] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.087697] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
      [ 4.094858] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.108048] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [ 4.118104] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
      [ 4.124326] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [ 4.130780] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [ 4.133783] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.137318] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [ 4.150255] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.155358] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [ 4.155364] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [ 4.155371] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [ 4.155377] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [ 4.155915] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [ 4.198878] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.205460] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.210064] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [ 4.221792] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.241784] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.243877] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.265142] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
      [ 4.271225] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [ 4.276794] usbcore: registered new interface driver usbhid
      [ 4.288728] usbhid: USB HID core driver
      [ 4.293395] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
      [ 4.301093] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
      [ 4.309788] rpmsg_tty_init: Sunxi rpmsg tty driver will init
      [ 4.316269] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 4.325391] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
      [ 4.338320] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [ 4.338320]
      [ 4.340686] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 4.355677] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [ 4.365331] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 4.376780] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [ 4.386073] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 4.395565] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [ 4.404410] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [ 4.413948] [SNDCODEC][sunxi_card_init][583]:card init finished
      [ 4.424052] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [ 4.431010] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [ 4.442514] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [ 4.453530] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
      [ 4.463976] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [ 4.475880] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [ 4.488265] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52 dt B
      [ 4.495035] pktgen: Packet Generator for packet performance testing. Version: 2.75
      [ 4.506582] random: fast init done
      [ 4.514628] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [ 4.518570] mmc0: new DDR MMC card at address 0001
      [ 4.531502] NET: Registered protocol family 26
      [ 4.535869] mmcblk0: mmc0:0001 88A398 7.28 GiB
      [ 4.539284] xt_time: kernel timezone is -0000
      [ 4.542229] mmcblk0rpmb: mmc0:0001 88A398 partition 3 4.00 MiB, chardev (242:0)
      [ 4.546656] IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
      [ 4.558685] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [ 4.561632] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
      [ 4.574828] IPVS: Each connection entry needs 216 bytes at least
      [ 4.582150] IPVS: ipvs loaded.
      [ 4.585653] IPVS: [rr] scheduler registered.
      [ 4.590440] IPVS: [wrr] scheduler registered.
      [ 4.595384] IPVS: [lc] scheduler registered.
      [ 4.600173] IPVS: [wlc] scheduler registered.
      [ 4.605076] IPVS: [fo] scheduler registered.
      [ 4.609864] IPVS: [ovf] scheduler registered.
      [ 4.614764] IPVS: [lblc] scheduler registered.
      [ 4.619771] IPVS: [lblcr] scheduler registered.
      [ 4.624850] IPVS: [dh] scheduler registered.
      [ 4.629652] IPVS: [sh] scheduler registered.
      [ 4.634439] IPVS: [mh] scheduler registered.
      [ 4.639250] IPVS: [sed] scheduler registered.
      [ 4.639258] IPVS: [nq] scheduler registered.
      [ 4.648977] IPVS: ftp: loaded support on port[0] = 21
      [ 4.654644] IPVS: [sip] pe registered.
      [ 4.659069] ipip: IPv4 and MPLS over IPv4 tunneling driver
      [ 4.666028] gre: GRE over IPv4 demultiplexor driver
      [ 4.671507] ip_gre: GRE over IPv4 tunneling driver
      [ 4.678874] IPv4 over IPsec tunneling driver
      [ 4.684845] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
      [ 4.692161] Initializing XFRM netlink socket
      [ 4.697010] IPsec XFRM device driver
      [ 4.702110] NET: Registered protocol family 10
      [ 4.710892] Segment Routing with IPv6
      [ 4.715255] mip6: Mobile IPv6
      [ 4.720135] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [ 4.728571] ip6_gre: GRE over IPv6 tunneling driver
      [ 4.734957] NET: Registered protocol family 17
      [ 4.740040] NET: Registered protocol family 15
      [ 4.745192] Bridge firewalling registered
      [ 4.750086] NET: Registered protocol family 5
      [ 4.755041] NET: Registered protocol family 9
      [ 4.760124] X25: Linux Version 0.2
      [ 4.763943] can: controller area network core (rev 20170425 abi 9)
      [ 4.771027] NET: Registered protocol family 29
      [ 4.776043] can: raw protocol (rev 20170425)
      [ 4.780835] can: broadcast manager protocol (rev 20170425 t)
      [ 4.787233] can: netlink gateway (rev 20190810) max_hops=1
      [ 4.793781] Bluetooth: RFCOMM TTY layer initialized
      [ 4.799323] Bluetooth: RFCOMM socket layer initialized
      [ 4.805145] Bluetooth: RFCOMM ver 1.11
      [ 4.809652] lec:lane_module_init: lec.c: initialized
      [ 4.815266] mpoa:atm_mpoa_init: mpc.c: initialized
      [ 4.820673] l2tp_core: L2TP core driver, V2.0
      [ 4.825584] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
      [ 4.825647] l2tp_netlink: L2TP netlink interface
      [ 4.837087] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
      [ 4.843763] l2tp_debugfs: L2TP debugfs support
      [ 4.848769] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
      [ 4.856045] NET4: DECnet for Linux: V.2.5.68s (C) 1995-2003 Linux DECnet Project Team
      [ 4.865025] DECnet: Routing cache hash table of 1024 buckets, 8Kbytes
      [ 4.872346] NET: Registered protocol family 12
      [ 4.877470] NET: Registered protocol family 35
      [ 4.882713] 8021q: 802.1Q VLAN Support v1.8
      [ 4.893405] DCCP: Activated CCID 2 (TCP-like)
      [ 4.898366] DCCP: Activated CCID 3 (TCP-Friendly Rate Control)
      [ 4.905971] sctp: Hash tables configured (bind 512/512)
      [ 4.912696] NET: Registered protocol family 21
      [ 4.918079] Registered RDS/tcp transport
      [ 4.922485] lib80211: common routines for IEEE802.11 drivers
      [ 4.928865] lib80211_crypt: registered algorithm 'NULL'
      [ 4.928873] lib80211_crypt: registered algorithm 'WEP'
      [ 4.940500] lib80211_crypt: registered algorithm 'CCMP'
      [ 4.946378] lib80211_crypt: registered algorithm 'TKIP'
      [ 4.952235] tipc: Activated (version 2.0.0)
      [ 4.957052] NET: Registered protocol family 30
      [ 4.962221] tipc: Started in single node mode
      [ 4.968496] NET: Registered protocol family 36
      [ 4.973613] Key type dns_resolver registered
      [ 4.978609] Key type ceph registered
      [ 4.983311] libceph: loaded (mon/osd proto 15/24)
      [ 4.989498] batman_adv: B.A.T.M.A.N. advanced 2019.4 (compatibility version 15) loaded
      [ 4.998605] openvswitch: Open vSwitch switching datapath
      [ 5.005595] NET: Registered protocol family 40
      [ 5.010650] mpls_gso: MPLS GSO support
      [ 5.015948] Registering SWP/SWPB emulation handler
      [ 5.021731] Loading compiled-in X.509 certificates
      [ 5.030506] Btrfs loaded, crc32c=crc32c-generic, integrity-checker=on
      [ 5.037924] BTRFS: selftest: sectorsize: 4096 nodesize: 4096
      [ 5.044371] BTRFS: selftest: running btrfs free space cache tests
      [ 5.051254] BTRFS: selftest: running extent only tests
      [ 5.057067] BTRFS: selftest: running bitmap only tests
      [ 5.062902] BTRFS: selftest: running bitmap and extent tests
      [ 5.069358] BTRFS: selftest: running space stealing from bitmap to extent tests
      [ 5.078712] BTRFS: selftest: running extent buffer operation tests
      [ 5.085686] BTRFS: selftest: running btrfs_split_item tests
      [ 5.092032] BTRFS: selftest: running extent I/O tests
      [ 5.097765] BTRFS: selftest: running find delalloc tests
      [ 5.693552] BTRFS: selftest: running find_first_clear_extent_bit test
      [ 5.700866] BTRFS: selftest: running extent buffer bitmap tests
      [ 5.984720] BTRFS: selftest: running inode tests
      [ 5.989932] BTRFS: selftest: running btrfs_get_extent tests
      [ 5.996574] BTRFS: selftest: running hole first btrfs_get_extent test
      [ 6.003884] BTRFS: selftest: running outstanding_extents tests
      [ 6.010634] BTRFS: selftest: running qgroup tests
      [ 6.015946] BTRFS: selftest: running qgroup add/remove tests
      [ 6.022418] BTRFS: selftest: running qgroup multiple refs test
      [ 6.045144] BTRFS: selftest: running free space tree tests
      [ 6.211402] BTRFS: selftest: sectorsize: 4096 nodesize: 8192
      [ 6.217873] BTRFS: selftest: running btrfs free space cache tests
      [ 6.224724] BTRFS: selftest: running extent only tests
      [ 6.230523] BTRFS: selftest: running bitmap only tests
      [ 6.236358] BTRFS: selftest: running bitmap and extent tests
      [ 6.242795] BTRFS: selftest: running space stealing from bitmap to extent tests
      [ 6.252130] BTRFS: selftest: running extent buffer operation tests
      [ 6.259079] BTRFS: selftest: running btrfs_split_item tests
      [ 6.265417] BTRFS: selftest: running extent I/O tests
      [ 6.271080] BTRFS: selftest: running find delalloc tests
      [ 6.867630] BTRFS: selftest: running find_first_clear_extent_bit test
      [ 6.874893] BTRFS: selftest: running extent buffer bitmap tests
      [ 7.157744] BTRFS: selftest: running inode tests
      [ 7.162931] BTRFS: selftest: running btrfs_get_extent tests
      [ 7.169534] BTRFS: selftest: running hole first btrfs_get_extent test
      [ 7.176892] BTRFS: selftest: running outstanding_extents tests
      [ 7.183542] BTRFS: selftest: running qgroup tests
      [ 7.188843] BTRFS: selftest: running qgroup add/remove tests
      [ 7.188969] BTRFS: selftest: running qgroup multiple refs test
      [ 7.205209] BTRFS: selftest: running free space tree tests
      [ 7.372446] BTRFS: selftest: sectorsize: 4096 nodesize: 16384
      [ 7.379009] BTRFS: selftest: running btrfs free space cache tests
      [ 7.385872] BTRFS: selftest: running extent only tests
      [ 7.391651] BTRFS: selftest: running bitmap only tests
      [ 7.397513] BTRFS: selftest: running bitmap and extent tests
      [ 7.403952] BTRFS: selftest: running space stealing from bitmap to extent tests
      [ 7.413319] BTRFS: selftest: running extent buffer operation tests
      [ 7.420319] BTRFS: selftest: running btrfs_split_item tests
      [ 7.426671] BTRFS: selftest: running extent I/O tests
      [ 7.432332] BTRFS: selftest: running find delalloc tests
      [ 8.028491] BTRFS: selftest: running find_first_clear_extent_bit test
      [ 8.035784] BTRFS: selftest: running extent buffer bitmap tests
      [ 8.318480] BTRFS: selftest: running inode tests
      [ 8.323665] BTRFS: selftest: running btrfs_get_extent tests
      [ 8.330291] BTRFS: selftest: running hole first btrfs_get_extent test
      [ 8.337618] BTRFS: selftest: running outstanding_extents tests
      [ 8.344267] BTRFS: selftest: running qgroup tests
      [ 8.349564] BTRFS: selftest: running qgroup add/remove tests
      [ 8.356029] BTRFS: selftest: running qgroup multiple refs test
      [ 8.365211] BTRFS: selftest: running free space tree tests
      [ 8.531623] BTRFS: selftest: sectorsize: 4096 nodesize: 32768
      [ 8.538194] BTRFS: selftest: running btrfs free space cache tests
      [ 8.545041] BTRFS: selftest: running extent only tests
      [ 8.550844] BTRFS: selftest: running bitmap only tests
      [ 8.556683] BTRFS: selftest: running bitmap and extent tests
      [ 8.563118] BTRFS: selftest: running space stealing from bitmap to extent tests
      [ 8.572452] BTRFS: selftest: running extent buffer operation tests
      [ 8.579399] BTRFS: selftest: running btrfs_split_item tests
      [ 8.585739] BTRFS: selftest: running extent I/O tests
      [ 8.591404] BTRFS: selftest: running find delalloc tests
      [ 9.188168] BTRFS: selftest: running find_first_clear_extent_bit test
      [ 9.195455] BTRFS: selftest: running extent buffer bitmap tests
      [ 9.477948] BTRFS: selftest: running inode tests
      [ 9.483131] BTRFS: selftest: running btrfs_get_extent tests
      [ 9.489755] BTRFS: selftest: running hole first btrfs_get_extent test
      [ 9.497142] BTRFS: selftest: running outstanding_extents tests
      [ 9.503798] BTRFS: selftest: running qgroup tests
      [ 9.509097] BTRFS: selftest: running qgroup add/remove tests
      [ 9.515577] BTRFS: selftest: running qgroup multiple refs test
      [ 9.525202] BTRFS: selftest: running free space tree tests
      [ 9.692058] BTRFS: selftest: sectorsize: 4096 nodesize: 65536
      [ 9.698623] BTRFS: selftest: running btrfs free space cache tests
      [ 9.705506] BTRFS: selftest: running extent only tests
      [ 9.711290] BTRFS: selftest: running bitmap only tests
      [ 9.717139] BTRFS: selftest: running bitmap and extent tests
      [ 9.723576] BTRFS: selftest: running space stealing from bitmap to extent tests
      [ 9.732925] BTRFS: selftest: running extent buffer operation tests
      [ 9.739877] BTRFS: selftest: running btrfs_split_item tests
      [ 9.739962] BTRFS: selftest: running extent I/O tests
      [ 9.751813] BTRFS: selftest: running find delalloc tests
      [ 10.348112] BTRFS: selftest: running find_first_clear_extent_bit test
      [ 10.355640] BTRFS: selftest: running extent buffer bitmap tests
      [ 10.637671] BTRFS: selftest: running inode tests
      [ 10.642854] BTRFS: selftest: running btrfs_get_extent tests
      [ 10.649475] BTRFS: selftest: running hole first btrfs_get_extent test
      [ 10.656815] BTRFS: selftest: running outstanding_extents tests
      [ 10.663471] BTRFS: selftest: running qgroup tests
      [ 10.668766] BTRFS: selftest: running qgroup add/remove tests
      [ 10.675250] BTRFS: selftest: running qgroup multiple refs test
      [ 10.685212] BTRFS: selftest: running free space tree tests
      [ 10.852634] BTRFS: selftest: running extent_map tests
      [ 10.878084] sunxi-i2c sunxi-i2c0: sunxi-i2c0 supply twi not found, using dummy regulator
      [ 10.888468] rtc-rx8025 0-0032: 0x0d=2,0x0e=20,0x0f=40
      [ 10.895866] rtc-rx8025 0-0032: registered as rtc1
      [ 10.901654] rtc-rx8025 0-0032: setting system clock to 2025-09-28T01:31:34 UTC (1759023094)
      [ 10.911215] sunxi-i2c sunxi-i2c0: probe success
      [ 10.916857] deinterlace 5400000.deinterlace: Adding to iommu group 0
      [ 10.924555] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
      [ 10.932865] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
      [ 10.947668] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [ 10.987653] get det_vbus is fail, -84
      [ 10.995202] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
      [ 10.995524] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
      [ 11.011025] [VIN_WARN]get csi isp clk fail
      [ 11.015679] [VIN_WARN]get csi isp src clk fail
      [ 11.020662] [VIN_WARN]get csi mipi clk fail
      [ 11.025396] [VIN_WARN]get csi mipi src clk fail
      [ 11.030500] [VIN_WARN]get csi isp clk fail
      [ 11.035129] [VIN_WARN]Get isp reset control fail
      [ 11.040507] [VIN_ERR]n5 request i2c1 adapter failed!
      [ 11.049640] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [ 11.060831] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [ 11.068405] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [ 11.075124] clk: Not disabling unused clocks
      [ 11.078119] cfg80211: failed to load regulatory.db
      [ 11.082844] ALSA device list:
      [ 11.091585] #0: audiocodec
      [ 11.094820] alloc_fd: slot 0 not NULL!
      [ 11.099554] Waiting 5 sec before mounting root device...
      [ 16.307111] JBD2: Invalid checksum recovering block 1611 in log
      [ 16.316364] JBD2: recovery failed
      [ 16.320100] EXT4-fs (mmcblk0p5): error loading journal
      [ 16.332142] VFS: Cannot open root device "mmcblk0p5" or unknown-block(179,5): error -5
      [ 16.341102] Please append a correct "root=" boot option; here are the available partitions:
      [ 16.350505] b300 7634944 mmcblk0
      [ 16.350508] driver: mmcblk
      [ 16.358208] b301 17219 mmcblk0p1 a0085546-4166-744a-a353-fca9272b8e45
      [ 16.358211]
      [ 16.368310] b302 1024 mmcblk0p2 a0085546-4166-744a-a353-fca9272b8e46
      [ 16.368312]
      [ 16.378497] b303 1024 mmcblk0p3 a0085546-4166-744a-a353-fca9272b8e47
      [ 16.378500]
      [ 16.388609] b304 65536 mmcblk0p4 a0085546-4166-744a-a353-fca9272b8e48
      [ 16.388611]
      [ 16.398680] b305 7302848 mmcblk0p5 a0085546-4166-744a-a353-fca9272b8e49
      [ 16.398682]
      [ 16.408803] b306 1024 mmcblk0p6 a0085546-4166-744a-a353-fca9272b8e4a
      [ 16.408806]
      [ 16.418881] b307 16384 mmcblk0p7 a0085546-4166-744a-a353-fca9272b8e4b
      [ 16.418883]
      [ 16.428954] 103:00000 193004 mmcblk0p8 a0085546-4166-744a-a353-fca9272b8e4c
      [ 16.428956]
      [ 16.439036] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
      [ 16.448499] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #30
      [ 16.455229] Hardware name: Generic DT based system
      [ 16.460621] [<c010e388>] (unwind_backtrace) from [<c010a92c>] (show_stack+0x10/0x14)
      [ 16.469305] [<c010a92c>] (show_stack) from [<c0d1c7d8>] (dump_stack+0x7c/0x98)
      [ 16.477409] [<c0d1c7d8>] (dump_stack) from [<c011c5cc>] (panic+0x100/0x3d4)
      [ 16.485221] [<c011c5cc>] (panic) from [<c130134c>] (mount_block_root+0x260/0x304)
      [ 16.493616] [<c130134c>] (mount_block_root) from [<c130158c>] (prepare_namespace+0x118/0x178)
      [ 16.503180] [<c130158c>] (prepare_namespace) from [<c0d315b8>] (kernel_init+0x8/0x118)
      [ 16.512062] [<c0d315b8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [ 16.520547] Exception stack(0xef079fb0 to 0xef079ff8)
      [ 16.526209] 9fa0: 00000000 00000000 00000000 00000000
      [ 16.535374] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [ 16.544539] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [ 16.551960] CPU1: stopping
      [ 16.554993] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #30
      [ 16.561723] Hardware name: Generic DT based system
      [ 16.567099] [<c010e388>] (unwind_backtrace) from [<c010a92c>] (show_stack+0x10/0x14)
      [ 16.575780] [<c010a92c>] (show_stack) from [<c0d1c7d8>] (dump_stack+0x7c/0x98)
      [ 16.583877] [<c0d1c7d8>] (dump_stack) from [<c010c710>] (handle_IPI+0xc0/0x168)
      [ 16.592073] [<c010c710>] (handle_IPI) from [<c063ff38>] (gic_handle_irq+0x70/0x78)
      [ 16.600560] [<c063ff38>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [ 16.608944] Exception stack(0xef09bf80 to 0xef09bfc8)
      [ 16.614605] bf80: 0000111c ef6c99f4 00000000 c0115440 00000002 ef09a000 c1405b64 c1405ba4
      [ 16.623772] bfa0: 4000406a 410fc075 00000000 00000000 00000000 ef09bfd0 c0108020 c0108024
      [ 16.632935] bfc0: 60000113 ffffffff
      [ 16.636847] [<c01021cc>] (__irq_svc) from [<c0108024>] (arch_cpu_idle+0x2c/0x38)
      [ 16.645141] [<c0108024>] (arch_cpu_idle) from [<c0142de0>] (do_idle+0xb8/0x120)
      [ 16.653336] [<c0142de0>] (do_idle) from [<c01430dc>] (cpu_startup_entry+0x18/0x1c)
      [ 16.661824] [<c01430dc>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
      [ 16.669643] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5) ]---
